POV-Ray : Newsgroups : povray.programming : Dispersion patch Server Time
13 Oct 2025 10:38:07 EDT (-0400)
  Dispersion patch (Message 1 to 10 of 16)
Subject: Dispersion patch
Date: 4 Feb 1999 05:40:41
Message: <36B97974.DDA9851E@zess.uni-siegen.de>
I thought I read somewhere along the threads that
the dispersion patch has something like
ior_min and ior_max implemented. I just downloadad
it and can only find dispersion float and
disp_nelems int in the "documentation".
How is the ior dispersed across the
wavelengths?
Any tips? Or am I completely wrong here?
Markus
 Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
Subject: Re: Dispersion patch
Date: 4 Feb 1999 13:00:23
Message: <36B9DF6D.86903757@aol.com>
It's done by wavelength.  The dispersion controls how far the ior
differs from the shortest to the highest wavelength.  The center
wavelength is always yellow, since that's what ior in the real world is
measured against (actually a thin line of sodium, which is yellow).
-Mike
> wavelengths?
> Markus
Date: 4 Feb 1999 21:17:35
Message: <36BA0E61.FB099A39@pipeline.com>
You know a patch is big hit, when other people give the correct answer
long before the patch author gets around to reading the question  :-)
Just want to clarify some details.   The IOR in the dispersion patch is
an exponential function of color number.  By color number, i mean i'm
counting subrays that are traced, from 1 to disp_nelems.   In other
words, each subray uses an IOR a certain ratio higher than the previous
subray.  This is not based on physics, but ease of implementation and
good looks.  IMHO, a linear function did not look good enough.   Real
physical materials have a variety of dipserson curves, which would be
fun to model, but I use povray for art not physics.
Each subray is traced, and contributes some amount of a pure hue to the
sum.  The formula for converting the nth ray into a color is purely
ad-hoc, chosen to look good, again no real physical laws were refered
to, and to match some mathematical criterea, mainly that it had to sum
all-equal subrays into pure white.  For looks, I want a nice yellow, and
violet at the low-wavelength end.
At no point in the process do i calculate or use wavelengths.
With the  source code out there, it's just a matter of time before
someone tweaks it to behave more in accordance with real optics.    I'm
too lazy, and have a totally different ray tracer for good physics
rendering.
Daren Scot Wilson
dar### [at] pipelinecom
www.newcolor.com
"A ship in a harbor is safe, but that is not what ships are built for"
                                            -- William Shedd
Date: 5 Feb 1999 22:48:33
Message: <36BBBAC4.D8112233@aol.com>
I was giving the technical description of what it's supposed to be
doing. :)
You did seem to 'fudge' the colors towards making yellow in the middle,
which seems to be the accuarate way of doing it.  I don't know if anyone
will ever bother for a physically accurate representation.  I know I
sure won't.
I doubt most people will notice small inaccuracies unless they are
getting a PHD in optical physics, and those people shouldn't be turning
to POV to do their dissertation anyway!  ;-)
-Mike
> rendering.
> Daren Scot Wilson
> www.newcolor.com
>                                             -- William Shedd
Date: 8 Feb 1999 05:21:45
Message: <36BEBB01.D94F1E73@zess.uni-siegen.de>
> subray.
Ok, I understand that. So no _real_ dispersion :( (;-))
Another thing I noticed (sh*t that I didn't take the
POV source with me to demonstrate it):
Make a scene with a perfectly clear, non reflecting but
refracting sphere sitting on, say, a checker floor.
Render it once with and once without dispersion and
you'll notice that the dispersion version is slightly
brighter...
Could this be the common error made in the gamma-correction
code?
Markus
Date: 8 Feb 1999 22:00:40
Message: <36BF5E90.E057AD1F@pipeline.com>
> brighter...
> code?
No, actually, it's a sign that all the fundamental laws of logic, space and
time are falling apart. The physical universe as we know will cease to exist...
It is a bad thing that the dispersion patch has a hard-coded spectrum.  What we
need is user-defined spectra, and then I won't ever be troubled by such
questions.   And clever artists could then do some weird things.
Consider the average refractor telescope's objective lens, or lenses in any
optical instrument.  Normally these are made of two kinds of glass, for example
crown glass and flint glass, with different dispersions.  How to model this in
povray?
Lemme work on my IRTC entry, and in march I'll figure out how to allow
user-defined dispersions.   In the meantime I'll accept ideas, suggestions.
Later, for an encore, maybe I'll do birefringent materials and polarization...
Daren Scot Wilson
www.newcolor.com
                                            -- William Shedd
Date: 8 Feb 1999 22:15:18
Message: <36BFA896.5B749DC2@Kopp.com>
> povray?
I'm implementing dispersion with photon-mapping (using your code), and I will
soon switch to some form of user-defined spectra (at least for light sources...
so you can define monochromatic yellow or green+blue yellow, for example).
-Nathan
Date: 9 Feb 1999 05:19:11
Message: <36C00BEE.5393670E@zess.uni-siegen.de>
Read too much of Douglas Adams, I guess? ;-)
Definitely. I'll give you some time...
> povray?
No problem, if every object can be assigned different dispersion
spectra.
Ok, ok,
Oh yeah, and please, please do coherent light, so that I can
finally model interference and laser speckle and the like,
hang on, man!!!
Markus
Date: 9 Feb 1999 10:52:41
Message: <36C05989.96E63E1C@pacbell.net>
> hang on, man!!!
> Markus
Yeah ! And beam splitting, and diffraction grating experiments,
and..., and...
Ken Tyler
mailto://tylereng@pacbell.net
Date: 9 Feb 1999 15:00:29
Message: <36C08D54.7C64273A@bahnhof.se>
No, probably just went out of the door, or looked in a newspaper... :-)
//Spider
