POV-Ray : Newsgroups : povray.pov4.discussion.general : Builtin color spaces, spectral colors? Server Time
16 May 2024 11:32:39 EDT (-0400)
  Builtin color spaces, spectral colors? (Message 11 to 18 of 18)
Subject: Re: Builtin color spaces, spectral colors?
Date: 17 Apr 2013 05:42:18
Message: <516e6e7a$1@news.povray.org>
> I do expect benefits in all areas that include colored distance-based
> attenuation, such as with fog, absorbing media (including the extinction
> effect of scattering media) and interior fading.
Won't it also vastly improve any scenes where the "light" is not
broadband, eg street lights, LEDs, lasers etc. Would fluorescent
materials be supported?
In theory colometrically correct renders could be produced which I
imagine would open up new markets for POV use (especially if combined
with an unbiased tracing option). We need something to keep increasing
those render times to keep up with new hardware :-)
Date: 17 Apr 2013 10:40:12
Message: <516eb44c$1@news.povray.org>
Am 17.04.2013 11:42, schrieb scott:
I guess so. Though I suppose such scenes are rather uncommon (especially
Sodium street lamp scenes tend to look ugly ;-))
> Would fluorescent materials be supported?
Not right from the start, but it's a possible option for the future.
:-) Don't worry, we'll find something :-)
Date: 18 Apr 2013 13:25:02
Message: <web.51702b58b3de06a65a03f8f0@news.povray.org>
Yes, it will give more physically correct render for strange lights. But the
most important aspect of spectral rendering is more "natural" color behaviour.
The problem of rgb illumination model is that the primary colors are
"orthogonal". So when you say "blue", and "red" they have absolutely nothing in
common. So a red light will give no illumination to red object, and red and blue
objects will have no radiosity effect on each other at all. This is a bit
unexpected usually - you put a primary colored object in a scene, and it seems
almost monochromatic, even if you have reflections and colored lights in a
system - it does not "take" other colors. So in essence, radiosity has too
strong contrast, colors are too sharp, and primary colors don't mix well.
I usually "fake" color overlap by having colors such as <1,0.1,0.1> for red and
so on. But it's not the same. Only spectral rendering will give you true
richness of color - you can have a pure intense color, but it can still react to
environmental illumination in a correct way. A typical example is a car in a
street.
Spectral rendering gives you subtle differences that you don't notice, but you
do notice it looks better. Just like focal blur, HDR environment mapping and
difference between flat ambient and radiosity.
Sure :) But in this case, I don't even think it will affect the render time that
much. Most of the rendering cost is the raytracing (finding intersections and
normals). Color computation is only a small part of the process, so unless you
have color dispersion in refractions and reflections, you will get a small
overhead (especially if the C++ core behind it is written efficiently).
About flourescence: it seems like a very nice idea. But somehow this opens a
wide array of options (every spectral input color could potentially produce a
different output color of different intensity). It smells more like a
custom-made shader. Having a pigment that is actually a function of input light
color, direction and coordinates, would make more sense in this case, and would
allow flexibility for users to design funny materials (like angle-dependent
colors, fluorescence, anisotropic BDRF functions, color-dependent specularity
angle and possibly a nonlinear response). This is quite a lot to ask from
developers, but it would get easier, if LLVM support actually happens at some
point in the future.
Date: 19 Apr 2013 07:46:21
Message: <51712e8d$1@news.povray.org>
This is what happens IRL though, isn't it? An sRGB red light source will
have a very narrow spectrum and almost no overlap at all with the
reflective spectrum of an sRGB blue surface, so it will appear black.
I always avoid zero terms in rgb colours too, not because I'm trying to
fake anything but I think it is genuinely more realistic for natural
surfaces and lights.
Date: 19 Apr 2013 09:05:06
Message: <web.51714056b3de06af42173100@news.povray.org>
Mostly, a colored light means a tinted glass, which has a broad spectrum (except
for LED). And even if you do have such a light, the material you are
illuminating will certainly not have a narrow reflective spetrum. If you
illuminate with a red light, you will usually be able to get some red component
from a blue material, especially since there is no blue reflected light to
overshadow it. I'm not saying the effect is strong, but it is enough to create
more natural lighting. You can approximate this by just having nonzero
components, but spectral response gives you more flexibility.
It's also easier to get a realistic illumination with different color
temperature light sources. For instance, a dim tungsten light looks quite
orange, but if you just use rgb, you don't notice, that the far-spectrum blue
light is extremely dim - most of the "blue" component comes from more central
wavelengths. This will affect appearance of blue surfaces.
Date: 19 Apr 2013 09:54:05
Message: <51714c7d$1@news.povray.org>
> for LED).
It is incorrect to model such a light as srgb <1,0,0>. It should be
modelled by something like <1,0.2,0.1> as you suggested. That isn't a
fake or a hack, that's the sort of srgb value you would get from a broad
spectrum light if you measured it with a colour meter. You'd only get
something like <1,0,0> if you measured an LED or laser.
Same as above, you shouldn't be modelling surfaces with a colour of
<0,0,1>, that corresponds to an extremely narrow reflective spectrum
that doesn't normally occur IRL.
Date: 19 Apr 2013 13:02:30
Message: <517178a5@news.povray.org>
OTOH if you have eg. a pure yellow light, it will look to the human eye
the same as a light with red and green frequencies in appropriate
proportions, but they will illuminate surfaces in radically different
ways. (White surfaces will look about the same under both lights, but
eg. red surfaces won't.)
Date: 22 Apr 2013 07:44:55
Message: <517522b7$1@news.povray.org>
The difference with yellow (or any colour other than pure red, green or
blue) in the current RGB system is that it needs at least two non-zero
components (R and G in this case). This means it will illuminate any
surface with a non-zero component in R *or* G in this case. The effect
of this is to simulate a relatively broadband spectrum - only surfaces
with R *and* G zero (ie a pure blue) would appear black.
Obviously this is a limitation (that no colour other than the sRGB
primaries can be simulated as a narrow-band spectrum) - which is what I
meant when I suggested that spectral rendering would improves scenes
with narrowband lights (or even lights with an "interesting" spectrum).
