POV-Ray : Newsgroups : povray.pov4.discussion.general : Request: Option to not render a scene if it has no camera Server Time
4 Feb 2026 00:35:30 EST (-0500)
  Request: Option to not render a scene if it has no camera (Message 1 to 4 of 4)
Subject: Request: Option to not render a scene if it has no camera
Date: 5 Jul 2008 16:35:01
Message: <web.486fdaa05850f9fa1a157cba0@news.povray.org>
I would like to request a configuration option to prevent POV-Ray from rendering
a scene if the scene has no camera. A lot of times I'll accidentally click the
"Run" button when viewing an include file instead of the scene it is a part of.
This results in my image output directory becoming cluttered with blank images
making it hard to browse for and view the images I actually want to work with.
Thanks.
-Mike
Subject: Re: Request: Option to not render a scene if it has no camera
Date: 5 Jul 2008 17:06:17
Message: <486fe249$1@news.povray.org>
> Thanks.
> -Mike
The Win POV beta has a feature that addresses this.
When you choose to run a file, if the file has previously been included
in another file, Win POV will ask you if you wish to run the calling
file instead.  It will then remember your choice for the rest of the
session.
Unfortunately, I can't think of a way to do this for the core
commandline version of POV.
...Chambers
Date: 6 Jul 2008 03:41:37
Message: <48707730@news.povray.org>
  This would break tons of short code contest entries. I'm not sure that's
a good idea.
  Maybe a warning dialog instead?
  Put "-f" in your main povray.ini file. Personally I find it completely
useless to have povray save images for all renders because 99% of them
would be temporary test renders anyways, and I have no use for the image
file itself. When I want the image file, it's very easy to write "+fn"
(which will override the "-f" setting in povray.ini) on the command-line
options field in winpov or the command line in unix.
Date: 25 Nov 2008 20:34:05
Message: <492ca78d@news.povray.org>
>> images making it hard to browse for and view the images I actually want
>> to work with.
For those cases, I usually put a -I switch on the command-line text box,
giving the path to the real scene. Then it renders what I want even if the
focused tab is an .inc.
