POV-Ray : Newsgroups : povray.off-topic : I cannot update my GitHub repo Server Time
12 Jul 2025 22:47:04 EDT (-0400)
  I cannot update my GitHub repo (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: I cannot update my GitHub repo
Date: 15 Feb 2022 17:55:00
Message: <web.620c2e2ecfbdaf8660e0cc3d949c357d@news.povray.org>
Dick Balaska <dic### [at] buckosoftcom> wrote:
> On 2/15/2022 4:43 PM, Cousin Ricky wrote:
> > ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git pull origin main
> >  From github.com:CousinRicky/POV-AndroidRobot
> >   * branch            main       -> FETCH_HEAD
> > Already up to date.
> > ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git push origin main
> > To github.com:CousinRicky/POV-AndroidRobot.git
> >   ! [rejected]        main -> main (non-fast-forward)
> > error: failed to push some refs to 'github.com:CousinRicky/POV-AndroidRobot.git'
> Try just "git pull" and "git push".
> Also what does "git status" have to say?
> dik
----------[BEGIN TERMINAL SESSION]----------
You are not currently on a branch.
Please specify which branch you want to merge with.
See git-pull(1) for details.
    git pull <remote> <branch>
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git status
HEAD detached from 638e732
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
        modified:   README.md
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        .gitignore
        README.md~
        androidrobot.pre-4.0.css
        droid-comments.txt
        session.txt
no changes added to commit (use "git add" and/or "git commit -a")
ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> ls -l README.md
-rw-r--r-- 1 ricky users 538 Feb  6 16:32 README.md
-----------[END TERMINAL SESSION]-----------
Since the git pull didn't work, I didn't bother with the push.
I do not understand what's going on with README.md.  I updated this file back in
late October, and this is what I tried to push.  But now, the git status says
that the file's commit somehow became undone, and the datestamp is today!
Weirder still is that the backup file README.md~ still exists; it should have
been deleted a long time ago by my regular cleanups.  It also has today's
datestamp.
It gets weirder.  When I look at README.md in Git-Cola, it shows the version
from before even the backup file!
Date: 16 Feb 2022 15:37:53
Message: <620d60a1$1@news.povray.org>
These two are not good.
I have run into this before and honestly what I do, and the easiest way
out is to git clone a new workspace. Then copy your old/broken files
(not the .git directory!) over to the new workspace.
dik
Date: 16 Feb 2022 15:41:01
Message: <620d615d$1@news.povray.org>
Broken files might be a bad term.  "Changed files that you want to keep
from the broken workspace".  That's better.
> dik
Date: 16 Feb 2022 21:24:02
Message: <620db1c2$1@news.povray.org>
Do you mean clone the GitHub repo?
Date: 17 Feb 2022 10:59:03
Message: <pan$e8446$50072bbb$7ed71ea2$ae813139@nospam.com>
> ricky@localhost:~/Documents/POV-Ray/oc_devl/AndroidRobot> git pull You
Yeah, I had an issue similar to this a few days ago, and ended up doing
the same thing.  Even stashing the changes I had made didn't work, along
with a hard reset to a known good commit.
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 17 Feb 2022 13:46:42
Message: <620e9812$1@news.povray.org>
yes. Something like
git clone https://github.com/CousinRicky/AndroidRobot.git
(making sure that the AndroidRobot subdirectory does not exist from
where your current directory is.)
I was going to give you the exact line but I couldn't find which
AndroidRobot was yours among the plethora of search results.
Date: 17 Feb 2022 18:17:22
Message: <620ed782$1@news.povray.org>
> yes. Something like
That worked.  As drastic as that is, at least I have a last resort
fallback when I get stuck.
For the record, it's https://github.com/CousinRicky/POV-AndroidRobot
It occurred to me that the reason for the snag /may/ be that I tagged
the repo in GitHub.  I just discovered that tags are not a GitHub
feature, but are part of Git, so tagging it in GitHub probably threw it
out of sync with my local repo.
If that's the case, then I'll need to clone *all* of my repos.  :(
Date: 17 Feb 2022 21:49:31
Message: <620f093b$1@news.povray.org>
No, that wasn't the reason.  My other repos are pushing peacefully.
Date: 17 Feb 2022 21:57:06
Message: <620f0b02$1@news.povray.org>
I think it was something like "git checkout <tag>" or "git branch <tag>"
I stuffed up a workspace recently and I can't recall what I did to
trigger it. But once you detach from head, you're screwed.
(Maybe it was "git stash ; git pull ; git stash pop" [ Warning, not
merged ])
It wasn't the repo that you stuffed, it was just that workspace.
Date: 18 Feb 2022 11:43:11
Message: <pan$76ab9$ee3a0e04$371325e$837fcf3c@nospam.com>
This is a really important point.  Even if you push bad changes to the
repo, it's actually pretty hard to "break" the repo beyond repair,
because you can almost always check out a known good commit (the only
time you can't is when you've done something like a hard reset locally
and then pushed IIRC, but even then it may be recoverable).
That's one of the really nice things about using source code management
systems.
