POV-Ray : Newsgroups : povray.off-topic : A programmer's etymology Server Time
5 Apr 2026 05:02:42 EDT (-0400)
  A programmer's etymology (Message 18 to 27 of 27)
Subject: Re: A programmer's etymology
Date: 24 Jul 2014 07:31:19
Message: <53d0ee87$1@news.povray.org>
On 24/07/2014 12:00 PM, Le_Forgeron wrote:
> On 24/07/2014 12:14, Orchid Win7 v1 wrote:
>> But hey, you try explaining that to the PHB. All he wants to hear is "we
>> spent 8 years developing this stuff, I don't want somebody to press one
>> button, and be able to steal all our hard work". Not, of course, that an
>> obfuscater necessarily does that; I hear there are 1-click deobfustation
>> tools out there...
> Changing requirement at the end... a classical of bad management (hence
> PHB :-). It's not about "the code should not be stolen", but "how much
> are we willing to invest in to deter people from stealing it."
> If really worth it, smart part of the code is inside a dongle
You know, this technology already exists.
In order to run Steinburg Cubase, you have to plug in a little USB
device. If you unplug it, the software instantly exits, losing all your
work.
Now, I'm sure there's some way of defeating this protection system if
you try hard enough. (Again, it comes down to finding the license code
and removing it.) But it seems to work pretty well. No fiddly numbers to
write down or license authorisation to manage. If you upgrade your PC,
no problem. You want to run Cubase on your laptop? Sure! You only
physically have one USB device, so you can only ever run one copy of the
software, no matter how many times you install it...
The PHB has decided that this technology is too expensive for us to
implement in our product. (To be fair, I have absolutely no idea what
this stuff actually costs...)
> Short of that, you are just following the same path as Bluray's DRM:
> making life of honest customer painful, while adding nearly nothing
> against pirates. That's why I won't buy or even use a Bluray.
First, whether the code is obfuscated or not makes absolutely no
different to the honest customer. None whatsoever. If anything, it just
makes *my* life more painful when it doesn't work right. Second, I
seriously doubt anybody will bother trying to pirate our software - so
long as we make it too much hassle, that is. If you could just put the
install DVD into 20 PCs and it works, people would PIRATE THE HELL out
of it! But that doesn't work, and I suspect most of our customers are
too stupid to work out why. And that's probably good enough.
If we were making Microsoft Word or something, this would NOT be good
enough... but our product has a much smaller target audience.
Also: Isn't BRD DRM exactly like DVD DRM? (I.e., trivial to bypass.) Do
you refuse to buy DVDs for the same reason?
Date: 24 Jul 2014 09:52:27
Message: <53d10f9b$1@news.povray.org>
Am 24.07.2014 12:06, schrieb Orchid Win7 v1:
>> I guess it's plenty of fun to wade through obfuscated code to figure out
>> exactly how the hell the 'fuscator fucked it up...
> It's simple, really. There are two events that coincidentally have the
> same name, and the obfuscater has mistaken them for being THE SAME
> event. They aren't; they're in different namespaces.
> Of course, without the source code to the obfuscater, knowing what the
> problem is doesn't help.
> Meta: I wander if the obfuscater is obfuscated?
> Also: I hear "writing your application in Haskell" is a good way to
> obfuscate stuff. The generated machine code doesn't follow the usual C
> calling conventions, which confuses the **** out of reverse engineering
> tools. That and the multiple, multiple levels of indirection. Then
> again, it's easy to *say* such things, I wonder if anybody has ever
> actually put it to the test?
Yeah; and if /I/ were to obfuscate my stuff by writing it in Haskell,
the result would certainly be broken code, too ;-)
Date: 24 Jul 2014 10:03:28
Message: <53d11230@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> The C++ code is also obfuscated, but so far we haven't run into any bugs
> with that.
Why would you want to obfuscate a compiled language?
Date: 24 Jul 2014 10:26:56
Message: <53d117b0$1@news.povray.org>
Am 24.07.2014 13:00, schrieb Le_Forgeron:
> If really worth it, smart part of the code is inside a dongle, whose
> chip is kept alive by a small battery, with decryption keys in the ram
> part of the chip only, the whole thing in resin block. And the chip is
> made by your company and never sold to third-party.
... and you have obfuscated the hell out of your chip design. And burnt
the chip design documents. And shot the chip designer. At point blank
range. With a .50 BMG round. Or two, just to be sure.
Date: 24 Jul 2014 10:48:26
Message: <53d11cba$1@news.povray.org>
If it does not work, as a honest customer, it makes a difference.
At least, it's a bad experience, even if the cause is not identified.
Not at all. DVD DRM have multiple weakness, including now leaked keys.
The impact of DVD is limited to the support and its reader.
BRD DRM are far more painful, as they propagates along HDMI.
Let say you have a fully working setting (reader---tv set).
One day you had a new device on an unrelated entry of the tv set, and
the reader stops displaying your movies.
More interesting: you just have reader+tv, you play a disc, and from
that moment, your tv will refuse to display any protected content. (disc
can contains revocation lists... your tv have been revoked due to some
decision about the brand... bad luck, you're toasted, it is your tv, but
not the one you think you bought anymore)
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 24 Jul 2014 11:00:20
Message: <53d11f84$1@news.povray.org>
Well played, sir.
(Actually, most Haskell beginners find that almost everything they write
utterly fails to compile. The saying "when it compiles, it's usually
bug-free" exists for a reason...)
Date: 24 Jul 2014 11:05:58
Message: <53d120d6$1@news.povray.org>
On 24/07/2014 03:03 PM, Warp wrote:
>> with that.
1. C# and Java are both "compiled languages". You don't (usually)
compile them to machine-code, but they're certainly compiled.
2. You obfuscate ANY language, compiled or not, to make it harder for a
human to figure out what it does.
It's a lot more obvious why you'd want to obfuscate, say, JavaScript.
(It's trivial for anybody to read the source code.) But I'm sure a quick
Internet search will turn up software that can transform machine code
back into valid C or C++ source code. (It won't be identical to the
original of course - THAT is provably impossible - it it'll be vaguely
readable.)
Date: 24 Jul 2014 11:34:39
Message: <53d1278f$1@news.povray.org>
To avoid hackers reverse engineering your code too easily? For example
if you have a game that used "int money=5000;" it will be trivial for a
hacker to scan memory and find which location holds the amount of money,
then change it. It would be better to have an obfuscated way of storing
the amount of money that makes it hard for a hacker to figure out.
The same probably applies to things like decryption keys and licensing
information in a business application. I guess having something like:
bool DemoVersion;
DemoVersion = !IsLicenseValid();
if(!DemoVersion)
  ... stuff only allowed in the full version
...is a really bad idea, as again it would be trivial to scan memory and
find the location of the DemoVersion variable and modify it. Or even
manually look at the machine code with a disassembler and look for the
"if(!DemoVersion)" instruction and bypass it.
Date: 25 Jul 2014 01:17:40
Message: <53d1e874@news.povray.org>
scott <sco### [at] scottcom> wrote:
> bool DemoVersion;
> if(!DemoVersion)
The only way to obfuscate the usage of a boolean would be to put more
complex code everywhere that uses that boolean, instead making it do
more complicated operations.
This sounds like a difficult thing to do without breaking the program
(especially since in C++ you can use booleans in all sorts of funny ways).
Also, if the obfuscator blindly converts all the booleans and other
integrals this way, it will ostensibly make the program less efficient,
if it starts obfuscating tight inner loops doing heavy calculations.
Anyways, it seems a poor way to protect your compiled binary. A determined
hacker is going to hack it no matter what.
Date: 25 Jul 2014 02:56:41
Message: <53d1ffa9$1@news.povray.org>
Indeed, that is what I was getting at.
> integrals this way,
Yes, it's probably not a good idea to just blindly obfuscate every
boolean and integer this way, only the ones you want protected from
external tampering.
I think that's only true if it's a really popular piece of software (eg
decoding blurays or Adobe/MS products etc), if it's something obscure
then you only want to make it hard enough that they give up and move on
to something else. Especially if you randomly change the obfuscation
algorithm every time you release an minor update, the hackers simply
can't be bothered to keep up.
