Subject: Re: Unrealistic use of ground fog in landscape views.
Date: 10 Aug 2012 15:37:22
Message: <502562f2$1@news.povray.org>
Le 10/08/2012 20:39, nemesis nous fit lire :
> how about less photographs and more color? ;)
Ever though about the light intensity on planet Mars ?
The B&W pictures might indeed use more width spectrum than a real colour
picture.
Date: 10 Aug 2012 15:42:37
Message: <5025642d$1@news.povray.org>
On Fri, 10 Aug 2012 19:28:17 +0100, Stephen wrote:
>> kidding aside, why in 2012 we still need to look at B&W photographs
>> from outer space?
> Bandwidth, old chap.
Oh, I don't think that's it. Curiosity started with 5 Mbps of bandwidth
and once they cranked it up, it's at 40 Mbps of bandwidth.
I have 3 Mbps of bandwidth (down) on my DSL line, and it handles colour
images fine. ;)
I think it's more to do with the complexity of the hardware. B&W imaging
hardware is perhaps less complex and less prone to failing. But that's
just a guess.
I suppose I could ask a friend of mine who works on satellite tech, or my
wife could ask a friend of hers at JPL who might know.
Jim
Date: 10 Aug 2012 15:51:36
Message: <50256648@news.povray.org>
> >> from outer space?
> images fine. ;)
> just a guess.
You all talk like the rover has no color cameras. Naturally that's not so.
Why some cameras are color and some B&W, that's an interesting question.
I haven't researched, but I'm guessing that they serve different purposes.
For example the rover has several "safety cameras" which purpose is to
detect and avoid collisions against obstacles when the rover moves. These
seem to be B&W, and I suppose that's enough for that purpose (and are probably
more reliable because the technology is simpler and more robust).
Perhaps some of the regular cameras are also B&W for the same reason: Maybe
they are less likely to break or malfunction in other ways. Maybe they have
a higher contrast, maybe they can capture a larger range of light amplitudes,
I don't know.
Date: 10 Aug 2012 16:00:15
Message: <5025684f$1@news.povray.org>
Also, colour camera have a resolution of 1/2 in each dimension when
compared to a B&W: the colour is achieved by masking some detectors with
coloured filter.
Do you want a 2MPixel colours pictures, or a 8MPixel B&W ?
(now, the number of pixels is probably far greater on such expedition.
Yet 10MPixel or 40MPixel ?)
Date: 10 Aug 2012 16:08:20
Message: <50256a34$1@news.povray.org>
On 10/08/2012 8:17 PM, Stephen wrote:
> Don't ask me, ask NASA. :-P
FYI http://www.bbc.co.uk/news/science-environment-19201742
Regards
Date: 10 Aug 2012 20:20:24
Message: <5025a548@news.povray.org>
Actually, precision and robustness. It's better to have one camera take
three different pictures with three filters than to build a camera that
takes three pictures at once.
"Oh no! We're out of code juice!"
"Don't panic. There's beans and filters
in the cabinet."
Date: 11 Aug 2012 11:56:50
Message: <502680c2$1@news.povray.org>
Am 10.08.2012 20:28, schrieb Stephen:
>> from outer
>> space?
More likely payload weight. That thing has plenty of cameras on board -
many of them designed for special purposes for which resolution is more
important than color. This particular one, for instance, is intended for
navigation purposes - most likely a wide-angle camera; but the
scientists have enough panorama color shots from the Mars surface
already, so they went for the lighter alternative, and only have color
on some other camera designed for close-up shots (as close as 2 cm or
so; it can focus at infinity as well though). We'll see full-res shots
from that camera in due time.
Remember, this is not a sightseeing trip - it's scientific exploration.
Date: 11 Aug 2012 12:01:33
Message: <502681dd$1@news.povray.org>
I did not even imply that but it was in my mind. It was at the start of
this phase of the mission and I suspect that there is more need for the
bandwith than sending postcards home. :-)
Regards
Date: 11 Aug 2012 12:19:18
Message: <50268606$1@news.povray.org>
Am 11.08.2012 18:01, schrieb Stephen:
Testing all the systems is probably the current top priority ATM, so
aside from some hi-res postcards from each camera, they'll also want a
nice greeting from each and every sensor, actuator and any other gizmo
onboard, yes.
"nemesis" <nam### [at] gmail com> wrote:
> "gregjohn" <pte### [at] yahoo com> wrote:
> > Typical case here:
> > http://www.nasa.gov/mission_pages/msl/multimedia/pia16013.html
> they faked it at arizona desert!
> kidding aside, why in 2012 we still need to look at B&W photographs from outer
> space?
It's a ... a ... a ... Monochromatic World.
