POV-Ray : Newsgroups : povray.off-topic : Make it Server Time
13 Aug 2026 15:32:33 EDT (-0400)
  Make it (Message 1 to 10 of 25)
Subject: Make it
Date: 26 May 2016 14:11:03
Message: <57473c37$1@news.povray.org>
I can't believe I've just spent an entire day writing Makefiles... At
this rate, it would almost be simpler to just write a loop to compile
every source file in every directory and then link them all! But, alas,
it turns out that you have to actually link them in the right order, or
it doesn't work.
I also enjoy how if you try to link an executable, it whines about
unresolved symbols, but if you link an SO file, it's NOT considered an
error to have missed half of the necessary object files... (!)
On the plus side, as a result of this, I got our Makefile down from 22KB
to 4KB...
Subject: Re: Make it
Date: 26 May 2016 15:28:48
Message: <57474e70$1@news.povray.org>
Le 26/05/2016 20:11, Orchid Win7 v1 a écrit :
> I can't believe I've just spent an entire day writing Makefiles... At this rate, it
would almost be simpler to just write a loop to compile every source file in every
directory and then link them all! But, alas, it turns out that you have to actually
link them in the
> right order, or it doesn't work.
> I also enjoy how if you try to link an executable, it whines about unresolved
symbols, but if you link an SO file, it's NOT considered an error to have missed half
> On the plus side, as a result of this, I got our Makefile down from 22KB to 4KB...
Shared lib (.so) are allowed to be completed later by other libs, or even the loading
binary. It's at runtime that you will get your problems.
Date: 26 May 2016 15:31:49
Message: <57474f25$1@news.povray.org>
link them in the
loading binary. It's at runtime that you will get your problems.
Another trick against the "right order" of linking: put everything but the main in a
single archive library ( .a ).
Then compile the main source into a binary with the library on the command line.
Date: 27 May 2016 06:31:08
Message: <574821ec$1@news.povray.org>
> it doesn't work.
Isn't there some tool to do that automatically?
Date: 27 May 2016 08:39:16
Message: <57483ff4$1@news.povray.org>
Am 27.05.2016 um 12:31 schrieb scott:
>> it doesn't work.
Absolutely. It is called "make", and needs a Makefile to work ;)
Date: 27 May 2016 09:23:51
Message: <57484a67@news.povray.org>
>>> it doesn't work.
Oh, what you can use make to make a makefile? Sounds like some IOCCC
entry...
Date: 27 May 2016 11:10:25
Message: <57486361$1@news.povray.org>
Am 2016-05-27 08:39, also sprach clipka:
>>> it doesn't work.
It's weird that in 2016 a 1980s program is still in charge of assembling
large swaths of code. Ant /tried/ to take over, but that's even worse.
dik
Date: 27 May 2016 11:37:03
Message: <5748699f$1@news.povray.org>
>>> it doesn't work.
Actually you can ask gcc/g++ to output the dependencies on sources files. Then you can
have them read back by "make".
Date: 27 May 2016 13:51:27
Message: <5748891f$1@news.povray.org>
loading binary.
Presumably this requires the executable to load everything in exactly
the right order though?
Indeed. This is what I feared... So at some point, when the program is
running, it will suddenly segfault for no apparent reason, and it will
be mathematically impossible to ever determine why. Great.
Date: 27 May 2016 13:52:58
Message: <5748897a$1@news.povray.org>
Heh, don't even get me started on archive files!
I had the "brilliant idea" of turning each folder into an archive, and
then linking those together. Trouble is... it only works 95% of the
time. About 5% of the time, the resulting object behaves differently
(i.e., wrong). GTest in particular seems to not like it. I have no idea why.
I stripped all traces of .a files out of the Makefile, and half my
problems went away...
