On 27/10/2015 07:53 PM, Stephen wrote:
> http://www.righto.com/2015/03/12-minute-mandelbrot-fractals-on-50.html
Qui-binary...?
My mind is blown.
As an aside, Hackaday.io seems to be full of people building computers
"from scratch", using only individual logic gates. One guy claimed to be
building a computer from nothing but 7400s...
...until you realise that he means the members of the 7400 family that
implement entire counters, encoders, decoders, latches, etc.
Another guy claimed to by building a computer from discrete
transistors... until you realise that he's using an Arduino to control
it. Wuh??
It's interesting to me that the IBM 1401 appears to be a *real* computer
made only from discrete transistors. I'd always assumed that such a
thing would fill an entire warehouse. But it doesn't actually look all
that big...
On 27/10/2015 07:50 PM, Stephen wrote:
> On 10/27/2015 6:58 PM, Orchid Win7 v1 wrote:
>>> I think there's a lot you can do that's interesting without any video at
>>> all.
>> Oh, really?
>> [That maybe sounded sarcastic. It wasn't meant to.]
>> Clearly you've got different ideas to me... What kinda thing are you
>> thinking?
>> [Genuinely interested here.]
> Break codes, calculate ballistic trajectories, solve engineering
> problems. Run the finances for Lyons tea house.
Not sure too many children would be interested in any of those.
> Text processing and games.
Interesting without display capabilities. ;-)
Only just finished reading this.
Man, that is some special brand of craziness, right there. Mental stuff.
On Tue, 27 Oct 2015 18:58:19 +0000, Orchid Win7 v1 wrote:
>> Nothing else really plugged in, either. HDMI, external hard drive,
>> power. Wireless keyboard/mouse combo that I generally don't use.
> At that point, doesn't it kinda make it look like *the screen* is all
> the smarts? Not the inconspicuous little box in the corner?
Not really, but then again, I connect the HDMI to a receiver that then
sends the output to a projector. So my "screen" is a 10' diagonal image
projected on a white wall.
But it doesn't really matter.
> Oh, I *totally* agree with what you're saying. My question is how you
> keep the kids from just glancing at it and going "this is lame!" and
> going back to playing Angry Birds or something.
By making it interesting, which is done by making it relevant. A lot of
kids are curious about stuff like that.
>> Yes, but that's true on a lot of PCs that run Linux as well. That
>> doesn't mean you can't do system-level programming on it.
> Thanks to backwards compatibility, every IBM PC-compatible starts up in
> 8080 emulation mode, and has a BIOS that lets you do stuff without even
> knowing what model of video card you have. Even then, it surely has 100%
> VGA register compatibility, so you can program it that way.
> On the Pi, until you poke the GPU, the CPU isn't even *turned on*...
Mine turns on when I plug it in, before the OS is done. That's firmware-
level stuff, generally not the sort of thing I think of with "system-
level" programming.
>> at all.
> Oh, really?
> thinking?
Web hosting is the most obvious example. Music streaming, controlling
home automation - lots of IoT-related things, actually.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
> Qui-binary...?
> My mind is blown.
I know and I thought BCD was strange.
> ....until you realise that he means the members of the 7400 family that
I hope he has a big power supply and lots of fans.
In the mid 70's I built a digital clock out of TTL. It needed 25 amps at
5 volts to drive the logic. A couple of years later I built one out of
CMOS and that would run for an hour on a PP3 battery. (It was mains
powered the battery was for backup.)
> it. Wuh??
The first machine I worked on was the Honeywell H516. It used discrete
components not ICs.
> that big...
That is a media exaggeration. They were forever showing images of
computer systems in enormous clean rooms with technicians in white coats.
One company I worked for had an old PDP 8. It fitted inside a 19 inch
cabinet. I only once opened the door to look at the guts. I then prayed
it would never break. ;-)
Funnily enough. His project reminded me of you. Did you not once write
programs in PostScript or Printer Command Language?
Regards
>>>> video at
>>>> all.
>>> Oh, really?
>>> thinking?
Calculating ballistic trajectories and blowing up your target sounds
like fun.
Did not say that. You said without video.
The output was on a Teletype or a printer.
I played a graphical golf game that used a printer to show the hole and
where the ball had landed.
Thinking about it and looking up Google. I think that many of these
games were inhouse programs and not available to the public.
Regards
Disturbing. You are looking to the future and I looked to the past.
I must watch out for that.
Regards
Am 28.10.2015 um 08:56 schrieb Stephen:
Fair enough, as far as I'm concerned.
I suspect the guy in question wouldn't be using classic TTL (where on
Earth would you get those nowadays, anyway), but rather LS-TTL, cutting
power consumption to 20%.
I for one wouldn't use 7400-family chips anyway, and instead go for a
CPLD (or, more likely, a collection thereof). Makes it much easier to
make minor design changes even after the circuitry has been wired.
PostScript is fun! Especially since it comes with high-resolution
graphics output fully integrated ;)
Not worth mentioning unless it was built only using NAND gates. Now that
would be something. ;-)
This was about 40 years ago* and I was limited to what I could borrow
from the production line. :-)
From what I can remember of the circuit. It was mostly shift registers
and divide-by counters built from D type flip Flops. Ending up driving
Nixie Tubes for the display. (I worked for Boroughs at the time and
there were a few lying around.)
I did not invent my Tardis until a few years later. ;-)
How about a LM8560? Or if you want to push the boat out and spend USD 4
http://www.ecyberspaces.com/productsview.asp?id=3179
That raises the question. If Pov will not contemplate using a GPU. How
about using a printer to do some calculations? :-P
Regards
Am 28.10.2015 um 13:07 schrieb Stephen:
Nah, I'm talking about re-inventing the computer here, not throwing
together a device intended to be mistaken for a suitcase bomb.
Using the printer as a coprocessor is a rather moot idea, unless you
also include a scanner in the system design; there's no other way to get
data from the printer back into the computer.
You /could/ of course make a PostScript printer do some raytracing
entirely on its own. But I was a bit disappointed by the computing
performance of the printer I once used for generating a printout of the
Mandelbrot set, so I'll probably not pursue this project any further...
Also, I guess we won't get real-time raytracing capabilities out of a
printer anytime soon ;)
That thought had crossed my mind too. When I worked on the rigs I got
the job of replacing all the batteries in the Bed Head Units every year.
(A bad job given to me by a small minded boss. Little did he think that
it gave me carte blanche to order hundreds of AA batteries and the
opportunity to skive in the accommodation module for days on end. That
showed me who was boss. :-) )
No problem for me there. :-)
I did not think that it would be a runner. ;)
It takes forever for my printer to start printing after I've sent a page
over WiFi.
But good to know that the IoT will sometime be a rendering farm.
Regards
Hehehehehe.
Jim
> Hehehehehe.
Just you wait. It comes to us all. :-P
Wait one.
Thinking about it. I'm glad that my time is when it is. I despair when I
see the way the world is going.
If I am asked what I want to be on the next turn of the wheel. I will
say. "A rock." And I don't mean St. Peter.
Regards
>>>> controlling home automation - lots of IoT-related things, actually.
>> Hehehehehe.
> Wait one.
Waiting. ;)
But in technology, I see this all the time - IoT isn't a new thing,
really - I remember seeing networked coffee makers, VCRs, and microwave
ovens back in the 90's. It didn't catch on then, but the demo was pretty
cool.
The idea of on-demand programming was something I was first introduced to
by someone who worked at NBC back in the mid 90's as well. He described
pretty much what we see now with Netflix and other streaming/on-demand
video services.
I think we all reach that point eventually.
I wouldn't have guessed that. Or maybe I would have. ;)
Jim
>> Qui-binary...?
>> My mind is blown.
BCD is one thing. LSD...?!
Heh, yeah, well...
>> that big...
I often wonder... like, how much did [famous obsolete computer] actually
cost? What did it physically look like? What were its technical
capabilities? It's very hard to gather a general overview of this type
of data.
For that matter, how many FLOPS can you get out of an Inter Core i7? I
have absolutely no idea; it seems very hard to find data for this...
PostScript. And it wasn't *once*. ;-)
Actually, I did start trying to write a PostScript *interpreter*, to
make debugging this stuff easier! It turns out the language has a lot
more edge-cases than you'd think though...
Oh God, think of the massacre...! O_O
You know, PostScript does actually have file I/O capabilities. Sure,
I've never seen any system that actually *implements* them... but it
literally does have commands for reading and writing files, doing
terminal access, etc.
The last printer I looked at was powered by a 200 MHz Pentium II. This
was in the days when the Pentium IV was considered obsolete... (We all
know parts never stop being used, they just move down the food chain.)
> cool.
HTTP 418: I'm a teapot.
https://tools.ietf.org/html/rfc2324
Seriously. There is a defined HTTP status code for interacting with an
IoT teapot.
> video services.
Some day, maybe I'll try that.
Ah, who am I kidding? I'll just sit here surfing YouTube...
(I'm still puzzled as to why YouTube can actually exist. But that's
another story.)
On 10/28/2015 6:06 PM, Jim Henderson wrote:
>> Just you wait. It comes to us all.:-P
>> >Wait one.
> Waiting.;)
Your custom is important to us.
Please listen to this elevator musak...
> cool.
> video services.
If you read any amount of SF the infinite monkeys got there first.
Mobile (cell) phones excepted.
Strange how that got missed by everyone except Dick Tracy.
So it seems. Just glad I'm normal in one aspect. ;-)
> I wouldn't have guessed that. Or maybe I would have.;)
You have a head start. :-)
I was talking about Edinburgh Rock. The best thing to come out of
Edinburgh, the road to Glasgow, excluded. ;-)
Regards
> of data.
PDP-8 1965 $18,500 12 ~50,000 The smallest and least expensive PDP
http://homepage.cs.uiowa.edu/~jones/pdp8/faqs/
So it is.
http://www.tomshardware.co.uk/forum/262886-28-core-gflops-benchmark
One edge-case is more than I ken.
I would ask what an edge-case is but then you would say that I can't
Google. :-)
Regards
Think of the Amazon Rain Forests devastated as it outputs its
calculations to hardcopy.
Regards
> of data.
Google is really useful. I hear they have pictures and everything. ;)
Depends on the speed of the CPU and the number of cores, but a google
search for "intel core i7 flops" turned up useful results.
Jim
>> pretty cool.
> IoT teapot.
It's funny, yeah - but the history of that error code isn't really IoT,
more like RFC 1149. 418 was defined in the HTCPCP/1.0 protcool, defined
in the referenced RFC as an April Fool's day joke in 1998.
It's a fun read. (Did I mention that I work with a product that secures
websites, and HTTP geek stuff is what I currently work with daily? ;) )
>> to by someone who worked at NBC back in the mid 90's as well. He
>> described pretty much what we see now with Netflix and other
>> streaming/on-demand video services.
Definitely worth it, IMHO.
> another story.)
People want to publish videos. Youtube gives them a platform to do that.
And gives Google another platform to push advertising on.
It's about that simple, really. :)
Jim
>>> >Wait one.
>> Waiting.;)
Only if it's good. Then again, you said "musak", so it probably isn't. :P
Star Trek communicators. The design of the Motorola Flip phone allegedly
was taken from Star Trek.
More the Apple Watch, but yeah.
>>> >when I see the way the world is going.
LOL
I'll have to remember that one the next time I'm talking with friends who
live in Scotland. Especially the ones who live in Edinburgh. ;)
Jim
Elevator music is another name for musak. Which is often heard when on
hold. Or in a hotel foyer.
More a walkie talkie than a phone that everyone uses. I think.
Yip!
It is a steal from Dr Johnson.
Regards
>> :P
So "elevator musak" is redundant. ;)
>> allegedly was taken from Star Trek.
Well, from a design standpoint, though, that's what inspired Motorola, I
hear.
>> who live in Scotland. Especially the ones who live in Edinburgh. ;)
Oh, sure, try and defer the credit. ;)
Jim
>> IoT teapot.
Wasn't the world's first "webcam" a camera in some university ward so
they could watch the coffee pot?
Even for somebody who doesn't watch TV?
>> another story.)
No, I mean... why is it possible for one company to ever buy enough
harddisks to store even 0.01% of the data that YouTube holds? It seems
like there shouldn't be enough mass storage devices on Earth to hold
this much data...
>> of data.
Interesting. Now how about the Cray 2, the VAX, UNIAC and all the other
legendary systems?
To be clear, I'm sure all the data is out there. It's just rather a lot
of effort to collate it all into a short summary.
Did I tell you about the time I wrote a text to PostScript converter as
an MS-DOS batch script?
Actually, the script just concatenates the text file with some
hand-written PostScript code; the text file itself becomes a giant text
string in a PostScript program. The program itself is a semi-complete
formatting engine, which adds a filename, page number and date of
printing to each page, and scans the characters looking for line breaks.
It even line-wraps the text and adds little arrows when it does so. (I
think there *might* be a bug if it line-wraps on the last line on a page
though...)
Damn, my talents are completely unappreciated! :-(
> Google. :-)
It's simple. An edge-case is where a function is supposed to do XYZ,
*except* in this one really obscure case where if A, B and C happen
simultaneously, it does something totally different. Like when you
configure how many pages you want to print, but if you put in -1 it
prints *all* the pages. Not -1 pages.
PostScript does some slightly strange things with token parsing. You can
take a text string and ask the PostScript interpreter to parse out the
first token, giving you back the token and the remainder of the string.
But the specification gives some really inconsistent rules for whether
it should or shouldn't skip spaces...
That sounds familiar. Whether it's true or not, though, I've no idea
offhand.
Do you watch movies? I hear they have those available as well. ;)
>>> another story.)
>> that.
> this much data...
And yet there are, so maybe you're not aware either of the totality of
mass storage available in the world, or the way in which the content is
stored in order to account for the amount of data involved.
But that's just a guess. ;)
Jim
>>> :P
No it is an emphasiser like saying hot hot.
> hear.
Yes yes.
Just trying to save you embarrassment. The phrase is very well known, by
the educated. :P
Regards
> legendary systems?
What did your last slave die of?
Dinkums! Too important to do a bit of work, are we? :P
No but I am sure you will. ;)
> though...)
Not completely, I'm sure.
Your mother loves you and your boss hasn't sacked you. :)
>> Google. :-)
Are you sure about that?
Do all the cases (A,B & C) have to happen simultaneously?
My reading is when one of them is on the edge of the design parameters.
Like when you
Hit it with a shifting spanner then.
I can't stand uppity software. ;)
Regards
If you say so - it sounds more like "PIN Number" or "ATM Machine" to
me. ;)
> the educated. :P
Oooh, them's fightin' words! ;)
Jim
> me. ;)
Quite right. But the question, now is: Why did he do it?
Elevator Musak is not in common usage. I made it up especially for you.
>> the educated. :P
Only amongst people who are not friends.
Regards
>> me. ;)
So many questions. I think you did it for the points. ;)
>>> by the educated. :P
Jim
On 10/28/2015 11:25 PM, Jim Henderson wrote:
> So many questions.
Are we there yet?
> I think you did it for the points.;)
And points mean...?
Regards
On 26/10/2015 07:01 PM, Orchid Win7 v1 wrote:
> Don't get me wrong, I think it's *way* easier to learn system-level
> programming on obsolete hardware. (It's how *I* did it!) But I doubt
> many kids these days would get out of bed to see some blocky 8-bit
> graphics.
https://hackaday.com/2015/10/19/diy-computer-1968-style/
"You can argue that times change and that the paperclip computer is a
relic. Maybe. But I can’t help think if you built one of
these–especially as a kid–you’d get a lot more insight into how a
computer actually works than by only slinging some Javascript, or
setting up a Web server on a Raspberry Pi."
Did you look here:
https://www.cl.cam.ac.uk/projects/raspberrypi/tutorials/os/index.html
The benefit of the pi over IBM-compatible is that (IMHO) the assembler
is much easier to learn and use.
I think if children could see their simple first creations running on
their smartphone or tablet that would encourage them a lot. However you
need a massive chunk of experience and knowledge to even *install* the
Android SDK, let alone start writing a new app.
>> So many questions.
> Are we there yet?
On first. :)
> And points mean...?
Junctions on railroad lines, naturally. ;)
Jim
On 10/29/2015 5:15 PM, Jim Henderson wrote:
>> And points mean...?
> Junctions on railroad lines, naturally.;)
Oh! I thought it was 1⁄72 of an inch.
Thanks for that. :-P
Regards
Yeah, I haven't done a lot with x86 assembly, but with 40 years of
backwards-compatibility, it's pretty complicated. And ugly to start
with, it seems! (Well, it was originally designed for low-cost pocket
calculators, not supercomputers!)
I often wished more stuff could be like the Motorola 68000. That seemed
like a really nice architecture to work with.
Agree.
> However you
Also agree!
>>> And points mean...?
> Oh! I thought it was 1⁄72 of an inch. Thanks for that. :-P
Always glad to be of service. :)
Jim
On 10/30/2015 12:05 AM, Jim Henderson wrote:
> Always glad to be of service.:)
Regards
You could probably explain the vast majority of ARM assembler in a
single newsgroup post. The syntax is very simple, and the mnemonics are
mostly obvious or very easy to remember. You're free to use any register
for source or either of the destinations, and all registers are the same
bit-width.
>> However you
> Also agree!
Someone needs to write a wrapper to go on top of the Android SDK that is
a) easy to install and b) uses an easy language that allows you to just
start writing commands to draw stuff without tons of boiler-plate code.
> bit-width.
The M68k has 8 "data registers" and 8 "address registers", which you can
freely use for any purpose (although the address registers are somewhat
optimised for holding addresses).
x86 has... what... FOUR main registers? And the FPU register stack...
which is also the MMX registers... but then a separate set of XMM
registers added for the SSE instruction set?... but then SSE2 made them
wider, so there's XMMX... WHAT THE HELL IS GOING ON?!?!
I gather ARM is quite a popular architecture. I don't know whether
that's because there's readily available chips and IP-cores, because
it's low-power, or because it's really easy to program...
Meh. Just use Haskell. ;-)
(Seriously, people occasionally ask about cross-compiling to ARM. I
can't think of any other reason why somebody would do that. Apparently
it even *works*, vaguely...)
Backwards compatibility is what's going on.
Low power.
The root of all evil, right there.
But hey, Intel invented the Itanium to get away from all that... and
nobody bought it.
> Low power.
Why is that? It is because there's something particular about this
instruction set which makes it especially suitable for low power? Or is
it merely that a lot of people have spent R&D on making low-power
implementations of it?
>> Low power.
The former I would guess, as even the first versions used in the Acorn
desktop machines were very low power when they probably didn't have any
budget, time or real incentive to reduce it. I'm sure since then though
there has been huge pressure and R&D expenditure to reduce it further.
This list is quite interesting:
https://en.wikipedia.org/wiki/Transistor_count
At each point in time the ARM CPU seems to have about 10x fewer
transistors than its x86 equivalent. As a very rough I guess I'd say
that means it used 10x less power. In thermal terms that is probably
enough to make the difference between needing a heatsink and fan and
working with just the bare chip.
What's also interesting is that the ARM2 had 25k transistors, yet
further down the page it claims 21k transistors are needed for a 32-bit
multiplier. Figure that one out. I think the answer is that on the ARM2
the MUL instruction was the only one (apart from the load/store multiple
register instruction) that took more than one clock cycle. As such it
probably used a much smaller circuit to do it in chunks.
It also interesting to note that even on the earliest cores you could do
an arbitrary bit-shift for free with every instruction on one of the
source registers. So if you wanted to multiply by 320 (commonly needed
in graphics algorithms of the day) you could do it with a single move
and add instruction:
result = y << 8
result = result + y << 6
> nobody bought it.
Heh, yeah, it turns out that people want to be able to use the software
they've purchased.
Jim
>> nobody bought it.
> they've purchased.
But all you need to do is run the source code through the other compiler...
...oh, wait. Somebody in marketing just realised we can charge the
customer money to buy the software again. *sigh*
>>> nobody bought it.
>> they've purchased.
> compiler...
Like most software companies do.
And most software that people purchase doesn't come with source code.
Jim
•On Tue, 27 Oct 2015 00:43:59 +0200, Orchid Win7 v1 <voi### [at] dev nu
ll> wrote:
> On 26/10/2015 09:06 PM, Le_Forgeron wrote:
>> Only 2 colours per 8x8 pixels was the main drawback of the display.
> Oh yeah... I forgot about that! One time I wrote a program to draw
> randomly positioned circles in random colours. After a few minutes of
> drawing, most of the pixels were in the "on" state, but there were wei
rd
> squares of colour that changed every time a new circle was started.
> I also remember saving several test patterns to tape, and eventually
> discovering which colour provoked which tone from the speaker... Jesus
> I was bored as a child!
> I've always wanted to know... why is the framebuffer arranged so
> weirdly? Like, as you load a picture file, rather than filling from to
p
> to bottom, it seems to fill every Nth line...
I remember
•Upgrading my 16K to a 48K
•Doing string-art type designs just to see the interesting desig
ns that
aliasing resulted in.
•Designing my own fonts.
•Printing a school project on thermal paper. Bad idea.
•Making a 3d wireframe modeler that could only take 100 edges. T
he
wireframe "render" could then further be coloured and textured with my
custom paint program. Since I didn't have a joystick, I controlled the
brush with 2 different systems: Angular (L & R arrows altered the angle
of
movement) an Normal.
•Dumping my Speccy in the bin because it died and you couldn't g
et parts
anymore.
Now if I could just find the time to learn proper programming and contin
ue
the 3d project on my pc.
-Nekar Xenos-
