POV-Ray : Newsgroups : povray.off-topic : Semantics? Server Time
15 Jun 2026 15:48:26 EDT (-0400)
  Semantics? (Message 21 to 30 of 32)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Semantics?
Date: 22 Sep 2015 03:30:01
Message: <56010379$1@news.povray.org>
On 22/09/2015 07:41 AM, scott wrote:
>>> Ditto here, but all CPU-intensive apps I've got manage to get to a
>>> reported 100% CPU (POV, commerical simulation tools, multi-threaded C#
>>> apps, etc).
>> Are you looking at the Windows Task Manager rather than the System
>> Internals Process Explorer?
> Both:
Interesting. Perhaps you have a newer version of Process Explorer? Or
maybe there's some setting somewhere to configure this that I haven't
noticed...
Date: 22 Sep 2015 06:09:32
Message: <560128dc$1@news.povray.org>
> noticed...
v16.05 here, can't see any relevant setting.
If I tell POV to render with 6 threads I only get 50% usage, but with 12
threads I get 100% usage.
However the elapsed times for the benchmark are:
6 threads  : 192s
12 threads : 136s
So 50% CPU is actually more like 70% CPU, but I guess it depends on the
exact algorithm (how nicely it can hyperthread).
Date: 22 Sep 2015 08:24:35
Message: <56014883$1@news.povray.org>
>> noticed...
> 6 threads  : 192s
> 12 threads : 136s
 From my personal bench with povray, a HT-core is worth between 20 to
25% of a real core. (tests done on i7 980X, at nominal speed, with
benchmark scene)
If the OS is not total crap, the threads are allocated first on distinct
real cores.
beware, when comparing with time, the performance is 1/time.
your 6 threads has a performance index of 5.20833, about 0.868 per thread
your 12 threads has one of 7.35, about .613 per threads.
(and if you remove the 5.208 from the 7.35, the additional HT-core only
provides 2.142, that's 0.357 per HT-core, so a HT-core thread is in your
system about 41% of a real core thread, for povray-binary and your scene).
Date: 22 Sep 2015 09:06:39
Message: <5601525f$1@news.povray.org>
> benchmark scene)
This is on Win 7 with the standard POV binary, the benchmark scene and a
Xeon E5-1650 @ nominal speed.
Yes, I think the additional HT'd threads being worth 41% of a real core
thread, is the same thing as saying that if you only use the real cores
you're utilising about 70% of the total CPU performance available. I
assume that modern compilers optimise code to be hyperthread nicely?
Date: 22 Sep 2015 10:56:47
Message: <56016c2f$1@news.povray.org>
Am 22.09.2015 um 15:06 schrieb scott:
Most unlikely - there's nothing much to optimize there.
In a hyperthreaded CPU, you actually /do/ have the number of cores that
the task manager claims you have, but they're not independent; instead,
they are organized in pairs that share various resources; for instance,
there might only be one floating-point arithmetics unit for each pair of
cores.
Any thread that needs any such shared resource /will/ compete for it
with any other thread running on the pair's other core. And as you
typically can't optimize away such resource requirements, you can't
optimize away the competition. In addition, different CPU types might
share different resources among core pairs, so you don't even know what
resources to try to avoid.
There might be ways for an application developer to optimize an
application for hyperthreading; the strategy would be to separate the
application's workload into two groups of threads that use different
sets of CPU resources, and coax the OS to run one thread from each group
in each pair of HT cores; this way, competition for resources will be
reduced. However, it might not be easy to partition the workload in such
a manner.
Date: 22 Sep 2015 16:58:20
Message: <5601c0ec$1@news.povray.org>
>> noticed...
> 6 threads : 192s
> 12 threads : 136s
Oh, I see. I'm still running the single-threaded POV-Ray binary. So if
it uses 1 core, it says 12.5% CPU. I thought you were saying your copy
says 100% for each CPU core used. ;-)
Date: 23 Sep 2015 02:36:54
Message: <56024886$1@news.povray.org>
Now why doesn't that surprise me? :-)
Date: 23 Sep 2015 03:04:16
Message: <56024ef0$1@news.povray.org>
It surprised me. Ver 3.7 is shiny.
Regards
Date: 23 Sep 2015 11:28:47
Message: <5602c52f$1@news.povray.org>
Am 22.09.2015 um 22:58 schrieb Orchid Win7 v1:
Okay, now is officially the time for you to upgrade to POV-Ray 3.7. If
you refuse to, I /will/ consider that as a personal insult.
I've put a lot of effort into that version to make it awesome. You don't
need to try UberPOV (which is even more awesome), but you absolutely
/must/ install version 3.7. Now. No excuses.
(And yes, I /am/ at least semi-serious about the personal insult thing.)
Date: 23 Sep 2015 12:56:16
Message: <5602d9b0$1@news.povray.org>
I remember it being in beta for a long time, and having lots of
interesting-sounding stuff. I wasn't aware it had actually made it to
release version yet.
Then again, when was the last time I did much with POV-Ray? Sure, it's
running 24x7 working on an animation, but I wrote that years ago. I
haven't really "used" it much recently...
