![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What causes cigarette lighter gas to flow from the refill into the
lighter? Is it gravity or pressure?
Just because, Andrew is AWOL
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Pressure, My guess.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Pressure, My guess.
> Thomas
It's a liquid... pushed by its own vaporized gas on the free surface
(inside the refiller can).
To refill (quite an old practice, nowadays with no-refill lighters), the
difference of pressure (from empty lighter with nearly no more gas vs
the refill at whole pressure due to the big amount of liquid providing
enough gas on the free part) found on its way the liquid and push it to
the weakest part (the empty lighter)
That is for the butane lighters.
Now, if you are using an old Zippo, the refill is with nafta and there
is no pressure, just gravity, like when you pour a drink.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Pressure, My guess.
>> Thomas
You are both saying pressure and yes I am talking about butane lighters.
Consider this, the pressure differential between the gas cylinder and
the lighter is equalised within a fraction of a second. Yet still the
liquid flows after that.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How ? the lighter has a depleted pressure chamber, and only liquid is
flowing from the refiller.
Yes, adding liquid to the lighter gives back a bit of pressure for the
lighter's side, but not enough. The fresh liquid could vaporize to
provide more gas but that transformation requires a lot of heat which is
not available at the refill time.
> Yet still the
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But it is only liquid because it is under pressure. As soon as some
liquid is in the lighter it vaporises to fill the chamber and if the
resultant pressure is less than the pressure in the gas cylinder more
liquid will go into the lighter until the system will reach stability.
The heat is taken from the air and the hand that is holding it. You can
feel the lighter getting cold and you can hear the butane rushing into
the lighter. The sound will stop when the pressure has equalised and the
lighter will continue to fill up.
>> Yet still the
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Such a long time since I stopped smoking that I only dimly remember
these things. The cold comes from the gas expanding, right? Same way as
a fridge. Your last sentence seems contradictory to me. With equal
pressure no further fill up, or am I wrong (probability: 98%)?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> a fridge.
Correct.
And the argument is: If it is not a difference in pressure then it must
be gravity that is making the liquid flow.
And because you do not have the opportunity to do the experiment
yourself. If when you are filling a lighter and you turn the system
upside down so that the lighter is above the gas cylinder. A lot of the
liquid drains into the gas cylinder. Gravity?
Some cigarette lighters have the chamber split into two by a dividing
weir. If you keep the liquid in the chamber underneath the valve. The
liquid will rise to the top of the weir and stop rising. No more gas
will go in. Then if you tip the lighter so that the liquid spills into
other chamber. The empty part (under the valve) can then be filled.
I first had this discussion 25 years ago and would quite like to know
the answer.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's sort of both.
Picture instead the ordinary case of filling a vessel with liquid at atmospheric
pressure through a narrow orifice.
At first there may be a rapid flow of liquid until the headspace gets compressed
and builds up pressure.
THEN there needs to be a chance for the gaseous headspace to bubble up and trade
volume with the liquid for there to be a mass transfer.
The problem lies in only one very narrow tube for bidirectional flow.
If there were a two-way filling mechanism, or a way to vent the gaseous
headspace, then you'd get rapid filling.
Another alternative might be to iteratively overfill with liquid by an increase
in pressure, or by chilling and contracting the headspace, and then letting the
back-pressure bubble up back into the fill vessel.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> It's sort of both.
I find this explanation neat, although I am not entirely satisfied
somehow. Imho the problem resides in the fact that the liquid is a
compressed gas which will want to expand as soon as there is a
possibility for it. I dimly remember that refilling a lighter often gave
frustrating results as it was impossible to refill up to the initial
level... with the exception of the use of a /pressurised/ filling mechanism.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
