POV-Ray : Newsgroups : povray.off-topic : Sailing! Server Time
15 Jun 2026 21:18:35 EDT (-0400)
  Sailing! (Message 11 to 15 of 15)
Subject: Re: Sailing!
Date: 1 Aug 2014 03:24:57
Message: <53db40c9$1@news.povray.org>
On 31-7-2014 23:05, Francois Labreque wrote:
>> http://www.youtube.com/watch?v=Ig8ilsiloVE
>> Fascinating when a good wind blows like the last couple of days.
>> Thomas
> Two questions:
> 1 - What are the big planks on the sides of the boats? Are they
> daggerboards? and if so, why are they on the sides of the boat, rather
> than on the center of the hull?
I suppose you could call them daggerboards and they serve the same
function. These ships are flat-bottom freight ships (most of these are
more than a 100 years old) and designed to sail in very shallow water
across the former Zuiderzee and all kind of waterways. They are on the
sides I suppose because otherwise they would take up too much hold
space, and they are easy to manage up and down according to the listing
of the ship.
> 2 - Why is there a guy repeatedly sticking a pole in the water at the
> 1:44 mark (approx.)  Is he checking the water depth? Trying to paddle to
> make his boat go faster?  Spear-fishing for dinner?
Yes, he is checking the water depth.
Date: 1 Aug 2014 03:32:01
Message: <53db4271$1@news.povray.org>
On 31-7-2014 23:59, Doctor John wrote:
> On 31/07/14 22:34, Doctor John wrote:
>> Didn't see that. What I saw was a crewman using a pole to adjust the
>> foresail. Are you sure you got the timestamp right?
> OK I have just watched three times more. At ~1.30 I see what you're
> referring to. My best bet is that he's using a boat-hook to grab a sheet
> or other part of the running rigging that's fallen in the water. Either
> that or he's washing off the blood having accidentally brained a fellow
> crewman.
Interesting explanations, especially the second one ;-)
As it happens, during the current competition, at some point two ships
almost rammed each other. The captain of one of the ships jumped on the
other one and started working with his fists :-)
Emotions can soar up quite rapidly during the event.
Date: 1 Aug 2014 03:35:09
Message: <53db432d@news.povray.org>
>> IIRC those are called (in English) leeboards. The boats look much like
>> Thames sailing barges with some differences. The leeboards have much the
>> same effect as daggerboards but having two (one either side of the
>> barge), independently controlled, facilitates sharp turns. Remember
>> these are (or were) working vessels and often worked in close proximity
>> to one another.
> just thought of another reason. The barges used tidal waters. If you
> were above the low-water mark when the tide went out, the barge would
> settle on the mud and then list over to one side or the other. If you
> lowered both leeboards, they would help to keep her upright and thus
> prevent the shifting of cargo.
I have not heard of these here being used as you suggest but plausible.
However, the bottoms being perfectly flat there is no listing when
grounded, on sand banks particularly.
Date: 1 Aug 2014 03:43:07
Message: <53db450b$1@news.povray.org>
On 31-7-2014 23:34, Doctor John wrote:
> On 31/07/14 22:05, Francois Labreque wrote:
>> Two questions:
> to one another.
Ah yes! I forgot to mention the ability to make sharp turns using the
leeboards. In the video (and in others) you can see a couple of examples
of that. An important feature too when tacking on canals.
Local television (Omrop Fryslan) is broadcasting the competition here
and there are thrilling examples of fierce turning around a buoy by
several ships at the same time
As I said below: he is constantly checking the water depth indeed.
Date: 1 Aug 2014 07:21:59
Message: <53db7857$1@news.povray.org>
On 1-8-2014 5:03, clipka wrote:
> I guess those weren't the traditional wooden-hull type, were they?
As a side note it must be said that these ships here have metal hulls.
The change from wood to metal occurred at the end of the 19th century.
