POV-Ray : Newsgroups : povray.off-topic : Publishing Server Time
18 Mar 2026 23:28:47 EDT (-0400)
  Publishing (Message 1 to 10 of 24)
Subject: Publishing
Date: 14 Jun 2014 07:42:46
Message: <539c3536$1@news.povray.org>
Does anybody here know anything about Adobe InDesign?
Our product manual is produced with it. The manual has always been the
most neglected part of our product, so some while ago, management got
the Graphics department to redo the manual. And by "redo", I mean "make
it look like a glossy magazine".
The manual is very, very pretty. I can't even explain it in words
properly. I can't put my finger on *what* exactly is so good about it,
but it just *looks professional*. It looks really slick. I could have
wasted hundreds of hours buggering around with formatting commands and
still not come up with anything remotely this good-looking.
I guess that's what happens when you pay professional graphic artists to
make your stuff look good!
The trouble is... the actual *content* of the manual is awful. (The
Graphics department only changed the formatting, not the content.) Half
of it is three point-releases out of date. There are new features that
aren't explained anywhere. The manual is huge and intimidating, and very
poorly organised. The English is poor in many places. Some irrelevant
things are explained in unnecessary detail, while other important
information is barely explained at all. In short, it sucks.
We all know it sucks. But it would take a long time for somebody to
write something better. And there's people banging on the door wanting
new software features, so...
Anyway, I don't think anybody here actually knows how to *use* InDesign.
Oh, various people have got it to "work", but I don't think any of us
know how to use it properly. The Graphics department have built a
document that looks beautiful, but it's intractably difficult to
*change* anything. The table of contents was produced by hand (I can
tell from the inconsistent typos), the running titles on the pages were
produced by hand, all the cross-references were done manually (several
of them are incorrect), and so on. It appears that to add a new page,
you basically copy-paste an existing page and then edit the contents to
make it different. (And then go edit the page numbers on all the
succeeding pages.)
What we *really* want to do is put the manual into source control.
But... well, putting a binary blob into source control doesn't really
help much. You *can* put a Word document into source control, but it's
impossible to tell what got changed on each commit, so why bother?
What we actually want to do is write some sort of "source code" which
contains the textual content of the manual and some markup instructions,
and then press a button somewhere, and have a glossy magazine drop out
the other end. Can InDesign do that? Or do we need to find another tool?
(We could use LaTeX - but it makes your document look like a stuffy
academic publication rather than a trendy commercial product brochure.
I've been looking into DocBook, but the PDF output looks *awful*! Like,
even MS Word looks less chunky than this stuff! Perhaps we could use a
custom XML schema and I could code up some suitable XSLT for it... but I
very much doubt that my coding skills can match the talent of
professional graphics designers.)
Everything I've managed to read about InDesign (i.e., not much) says
it's brilliant for producing posters and flyers. E.g., the product page
talks about "pixel perfect" design - which is what you want if you're
designing one poster, once. But I'm not seeing anything about
automatically processing big chunks of existing text into a pretty
document. Maybe it can't do that...
Subject: Re: Publishing
Date: 14 Jun 2014 11:51:17
Message: <539C6F6F.9010004@gmail.com>
I know some people who could answer some of your questions, at least
they can work with InDesign.
For the source control part...
Both .docx and .odt are in fact zip containers that contain the images
and the content in different files. In theory you could extract the
content part, put that under revision control. Check out the content,
change, check in and rebuild the zipfile. Plus some manual fixing, but
that would be minimal. If InDesign has the same sort of filestructure
you might give that a try. Alternatively, many programs nowadays support
version control. Did you check if InDesign does?
> succeeding pages.)
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
Date: 14 Jun 2014 13:39:13
Message: <539c88c1$1@news.povray.org>
Yeah, but that probably won't work well in practice.
For example, we use a system called SpecFlow where you write integration
tests in psuedo-English, and an external DLL transforms that into C#
code. Both the source and the generated C# code are in source control.
But the trouble is, if you insert or remove a single line in the
SpecFlow file, the *entire* C# file changes. (Every line of the
generated file is annotated with the corresponding line number in the
SpecFlow file.)
I rather suspect that when you save an ODF file, the editor rebuilds the
entire file and it won't look anything like what it did before. (I
haven't tried, but I suspect that's what'll happen.) The other problem,
of course, is that it's hard to make really polished ODF files in the
first place. ;-)
As I say, nobody here seems to know how to work InDesign. It wouldn't
surprise me if our current workflow can be significantly improved just
by changing how the document it set up...
Date: 14 Jun 2014 13:56:46
Message: <539c8cde$1@news.povray.org>
Not specifically about InDesign - but FrameMaker isn't that different
from it, I hear - and both products have a pretty steep learning curve
that - once you know how the product works - actually ends up making
sense.  Kind of like the first few releases of Blender after it was made
an open source project (it had been a commercial product prior to that).
From Adobe's suite, FrameMaker is the tool of choice for producing
documentation.  There are other products out there, but Adobe is pretty
well entrenched - but that seems to be changing.  I know a few companies
that use a product called Madcap Flare who really like it, but DITA is
also becoming a lot more popular for information structuring and
documentation.  It's a format rather than a tool, but there are some good
tools for creating DITA (including, I understand, FrameMaker 12 - Frame
11 isn't so good with it, though - but it can read and write DITA files).
As it happens, what I'm doing right now is a lot of this type of
documentation work.  The client I'm working with right now has a mix of
tools used for writing and publishing the documentation, but the
direction is to simplify this because production is way too complicated
and has too many moving parts from different vendors.
Take a look at DITA tools - I'm going to start looking at oXygen (an
editor - well, an IDE) fairly soon.  One of the client's products is
documented using DITA, and the guy who handles it seems to have a very
good workflow.  oXygen can produce PDFs, XHTML, or pretty much whatever
sort of output you want.
But a tool alone isn't (hopefully obviously) going to give you great
documentation.  You also need technical writers (at least one).
A good technical writer isn't akin to "Tina the Tech Writer" in Dilbert,
but rather is someone who can learn and understand the product being
documented, and can not only write about it, but can become an expert in
using it *in order to write about it*.
Using DITA - which is an XML standard - means that putting the files in a
source control management system works the way you'd expect.  I've done
FrameMaker with various SCM tools, and while you don't get diffs, the
version control is helpful.  But doing it in DITA means you can have some
of those additional benefits.
The nice thing about using an XML standard like DITA is that you can use
xslt to transform it, so if you need to customise the transformation,
it's trivial to do - if you know xslt.
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 14 Jun 2014 15:17:02
Message: <539C9FA7.4050904@gmail.com>
> SpecFlow file.)
> first place. ;-)
it is clear that you haven't checked ;)
I made a little document saved it as .odt and opened it as .zip.
In it is the content.xml file that after a lot of presumable
initialization contains (I added some newlines):
--------contents.xml---------------
<text:h text:style-name="Heading_20_1" text:outline-level="1">This is a
file for andy</text:h><text:p text:style-name="Text_20_body"/>
<text:p text:style-name="Text_20_body">Add a mascot below</text:p>
<draw:frame draw:style-name="fr1" draw:name="graphics1"
text:anchor-type="as-char" svg:width="5.292cm" svg:height="8.255cm"
draw:z-index="0">
<draw:image
xlink:href="http://upload.wikimedia.org/wikipedia/commons/thumb/5/5b/RoyalRegimentWalesGoat_gobeirne.jpg/200px-RoyalRegimentWalesGoat_gobeirne.jpg"
xlink:type="simple" xlink:show="embed" xlink:actuate="onLoad"/>
</draw:frame>
</text:p>
<text:p text:style-name="Text_20_body">see, it is above </text:p>
-----------end contents.xml------------
Easy enough to understand, to modify and to repackage. The image was
added as a link. If you add it to the document it will be in a directory
local to the zip file.
Date: 14 Jun 2014 17:38:31
Message: <539cc0d7$1@news.povray.org>
I'd like to take a stab at this myself. I believe I'm quite a good
writer. The question, of course, is whether I can find the time to do this.
Trouble is, currently the documentation sucks, but nobody has the time
to produce something better, so we're just doing minor tweaks to it
whenever the product changes. Really the entire thing wants to be thrown
in the bin and somebody to start again. But if I turn up and go "hey,
here's the new manual" and it's *not* as shiny and pretty to look at as
the old one... nobody tell take any notice.
DocBook is an XML standard. So - in theory - it's "trivial" to make it
do what you want.
...in reality, I found it hellishly difficult to change even the tiniest
detail about it. Perhaps it would be simpler to rewrite the XSLT from
scratch rather than try to figure out how it works. And maybe, just
maybe, the XML-FO processor I'm using just can't be convinced to produce
nice output.
For that matter, we could write documentation in HTML and apply lashings
of CSS to it. You can do paper-specific CSS settings and so forth, and
everybody in the room already knows how CSS and HTML work. Again, the
trouble is, you'll never get it to look slick and polished.
Date: 16 Jun 2014 08:57:29
Message: <539ee9b9@news.povray.org>
> The other problem,
> first place. ;-)
No it's not.  It only requires a bit of planning, and military
enforcement of the rules, if you have multiple editors.
Yes.
I don't know InDesign, but I knew a few of its ancestors.
Just as CSS with HTML, or a complex software program, you need a plan
and _you need to stick to it_.
- Define styles (ex: title, subtitles, section heading, text, code,
examples,etc...) *AND USE TO THEM*  No more "I know the subtitle is
Arial 14 pts, bold, so I'll manually change the properties of that
sentence."
- Create page templates (left side should look like this, right side
should look like that, first page of a chapter should look like that,
etc...)
- Put section titles macros in the headers, and page number macros in
the footers.
- Generate the table of contents automatically.
- Put someone in charge of maintaining the manual.  He or she can (and
should) accept input from the rest of the team, but he or she has the
last word on the format.
- That someone should have a backup, in case of vacations or wild bus
rampage.
Tada!
Whether you use WordPerfect 5.1, vi and LaTex, emacs, Office365, or the
latest Adobe Creative Suite, the above rules will have your manual at
least look decent.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 16 Jun 2014 09:26:29
Message: <539ef085$1@news.povray.org>
> do what you want.
Right, because RTFMing is impossible...
> And maybe, just
> nice output.
Your problem, is that you do not like the default CSS used by your
docbook editor, not that it can't be convinced to produce nice output.
The problem is not with the tool.  The problem is with what you're
telling your tool to do (or not telling it to do).  As I said in my
other response, any word processor younger than you is able to print
crisp Arial 16pts or justify text properly.
If you want your manual to look good, you actually have to tell whatever
tool you plan on using that you want it to look good.
You need to create page templates that look good.
You need to chose font combinations that are pleasing to the eye:
sans-serif for titles, serif for text body, monospace for code or
command line text.
UNDER NO CIRCUMSTANCE SHOULD YOU USE COMIC SANS.
You need to chose colors wisely.
Etc...
Of course, some software packages will make this easier to do than
others, but regardless of your choice of software, noe of what you are
trying to do is impossible, even for someone who doesn't have the artist
gene, like you.
Your current manual looks impressive?  You like its look?  Then recreate
the same thing with something you're familiar with, if you can't wrap
your head around InDesign, or DocBook.
But the more important thing is - as you mention - the quality of the
content.  Start by writing good content in Notepad (or vi, or gedit, or
whatever) so that you can focus on the content.
Then import that text into some document formatting tool and apply the
styles you have chosen to it.
Date: 16 Jun 2014 10:42:11
Message: <539f0243@news.povray.org>
Excellent advice, Francois. Now the only problem is getting Andrew (and
others in the same position) to follow it.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 16 Jun 2014 14:39:15
Message: <539f39d3$1@news.povray.org>
>> do what you want.
Most things to do with XML are hard. For whatever reason, XML is
absurdly overcomplicated, considering what it actually does.
It took me hours of Google searching just to figure out how to make
DocBook allow me to write character entities. (The manual says it works
already... Oh, wait, that's for DocBook v4. OK, so how do you make it
work for v5? Oh yeah, we removed that feature. Great, so how do I turn
it back on?) I got there eventually, but it was a hell of a lot of work.
Similar fun with XInclude. The manual tells you that XInclude is a great
way to make modular documents - and so much better than the old entity
workaround we used to recommend you use. Except, you know what? My XML
validator and my XSLT processor both POINT-BLANK INGORE any and all
XInclude declarations. Isn't that wonderful?
>> And maybe, just
>> nice output.
I don't have a "DocBook editor", I have a text editor with a vague
understanding of XML. And then I have various command-line tools which,
after about a day of research, I was able to convince to produce PDF
output. Fortunately, all of this knowledge can be embedded into scripts. ;-)
> telling your tool to do (or not telling it to do). As I said in my other
> response, any word processor younger than you is able to print crisp
Yes, but can it render the chapter titles in a blue box with rounded
corners and a fuzzy drop-shadow? Probably not.
As I say, I can't actually put my finger on exactly what it is about the
current manual that makes it look so good. It probably isn't any one
particular thing, it's the cumulative total of many, many small things...
Whilst I agree wholeheartedly, if we write a whole bunch of content as
(say) TeX input and then decide that actually our tool of choice wants
XML (or vice versa)...
That's kind of why I'd like to pin down exactly what tool we're going to
use. Once we start the rewrite, I only want to do it once.
Still, I could sit down and look at the high-level document structure -
that's very easy to change for any tool.
