POV-Ray : Newsgroups : povray.off-topic : Revolving Server Time
12 Oct 2026 01:46:45 EDT (-0400)
  Revolving (Message 47 to 96 of 96)
<<< Previous 46 Messages Goto Initial 50 Messages
Subject: Re: Revolving
Date: 28 Apr 2014 13:30:27
Message: <535e9033@news.povray.org>
On 28/04/2014 08:59 AM, scott wrote:
>> Presumably what you do is make a translucent layer which has inclusions
>> inside it that refract the light. So the outer surfaces are smooth, yet
>> you still get colour. Hard to see how you could do that cheaply though.
> Well you could just make it in two parts, so long as the two materials
> had different refractive indices. A bit like how a CD is made. Maybe you
> could use some photo-etch process on the first layer, borrowed from IC
> manufacturing?
That sounds quite plausible. Although probably not as cheap as just
spraying some dye onto things, which is what we do now.
>> Has anybody invented a UV coating that actually works yet?
> Yes, people rely on them not to get skin cancer or go blind! Also the
> one on your car paint works. I'm sure you can find spectral response
> curves if you are interested.
Interesting. I was under the impression that UV-resistent coatings are
just overly-optimistic marketing, and in reality none of these coatings
actually work.
>> I'm sure things have changed. Just perhaps not as rapidly and
>> dramatically as the original revolution.
> You could argue that in some ways things are changing even faster now.
> Continuing with your plastics example, at the start hardly anyone used
> plastic and development was slow. Today plastic is used in almost
> everything and there are millions of different types. I'm sure if you
> plotted a graph of the number of new plastics invented against time it
> would be going upwards.
Really?
OK, really ancient plastics weren't very good. But the plastics I see
today and the plastics I saw 30 years ago seem pretty much identical in
every respect. What's changed?
>> This is very interesting. From what I can gather, the primary problem is
>> the absurd amount of computer power required.
> Indeed, it looks like they had to spend most of the effort trying to
> reduce the computing power needed whilst maintaining a decent image
> quality. Maybe in 5 or 10 years someone will come back to this
> technology and it will be able to take off.
Much like how we had CDs for decades before DVDs were invented. Clearly
a lot of people *wanted* DVDs, but the necessary computer power was
simply unavailable.
Then again, we're trying to simulate the interaction of billions of
photons in a large 3-dimensional space. Maybe there are
quantum-theoretical reasons why you can't do that any faster than the
real world can? (At least, not without using a computer many times
bigger than the real-world system it's trying to simulate!)
Date: 29 Apr 2014 04:23:57
Message: <535f619d$1@news.povray.org>
> actually work.
One of the first image results from google gave this:
http://www.alpineastro.com/filters/uv_ir_cut_specs.htm
That's a pretty sharp fall-off below 400 nm. Whether it works or not is
unquestionable, what is usually up for debate is whether it's actually
useful on a camera. On skin, eyes or paint of course it works and is
useful.
What you see today is them used in many places where they simply
couldn't be used 30 years ago because plastics with the required
performance didn't exist or were too expensive to manufacture. Car
bumpers were metal or fibre-glass that got dented or cracked, pipes in
your house were copper, anything involving even slightly corrosive
chemicals was stainless steel. Today plastics can be and are used in all
those places, ultimately making things cheaper.
Then there are all the things the consumer doesn't even notice. Like
plastics that are easier to mould (more complicated shapes are possible
to be made faster with finer details), possible to process in thinner
films, flame retardants that are environmentally friendly, stronger and
stiffer plastics that enable things to be made with less plastic for the
same performance etc.
The software we use here for simulating the moulding of a plastic part
(to make sure it will fill correctly and not leave any sink marks, weld
lines etc) has a built-in database of plastic materials to choose from.
There are over 10000 of them, and there are plenty not in the list. They
have all been developed for a specific reason, and most of them recently
(not 30 years ago).
Date: 29 Apr 2014 08:21:12
Message: <535f9938$1@news.povray.org>
> Really?
First, You have a tendency to be totally oblivious to what's around you.
  You wouldn't see the changes if they hit you in the face (in fact, one
of those changes is actually sitting right there on your nose!)
Second, you worked in the chemical industry for over 10 years.  I'm sure
you're familiar with the names 3M, Dupont and BASF, just to name those.
  Don't think for a second that these companies don't have large R&D
depts that work round the clock trying to come up with newer compounds
that are easier to work with, thereby reducing production costs, more
resitant, less dangerous, or biodegradable, just to name those
characterisitcs, thereby increasing their marketing value.  They're not
just sitting there waiting for Nylon(tm), Teflon(tm) or Kevlar(tm)
royalties to pad their bank accounts.
Many of these plastics will have special medical or industrial
applications, but here are a few examples of everyday uses that you may
have seen:
Have you noticed how nowadays most eye glasses are made of plastic?
Clear plastics with higher IOR (sorry for getting slightly on-topic for
P.O-T) than glass were unheard of 30 years ago.  The progresses made in
the domain of contact lenses is even more impressive than that of
conventional glass lenses.
The same goes for the plastic covers on most car headlights.  The
average human doesn't often stop to admire the complexity of a car's
tail lights, - unless you're stopped behind a Lamborghini at a stop
light - but there's been tremendous developments made in that area, too.
I know you don't have kids, but the plastics used in baby bottles and
toys have also changed a lot in the last 10 years, due to various "Won't
anyone think of the children?!?!!!?" reasons.
The "technical" garment industry has also greatly benefited from these
new polymers.  You're a skier, so you've most certainly seen the
74732327523 tags that are sewn or attached on a new ski jacket or
gloves, touting the amazing breathability, yet still impermeable,
feather light, yet warm as a mammoth pelt, machine washable, yet won't
fade properties these clothes now offer.
To perfectly emulate it, we'd need at least one processor per photon,
able to do all the physics calculations and share Heisenberg-principle
violating amounts of information with other processors, in real-time.  I
think Slatibartfast was on the right track!
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Apr 2014 10:21:36
Message: <535fb570$1@news.povray.org>
Since Francois mentioned 3M, that reminded me they make lots of
*plastic* optical films that are used in your mobile phone to improve
brightness, viewing angle and sunlight readability. Another area that
has been continuously improving over the last decade and will continue
to, but which most consumers wouldn't know about.
Or surely you've heard about 3D printers recently? The materials they
use (the professional ones, not the hobby ones) are state-of-the-art
polymers to give the final piece properties as close as possible to
traditional injection moulded plastics. It's not like those materials
existed 30 years ago.
Date: 29 Apr 2014 16:09:51
Message: <5360070f$1@news.povray.org>
Go back another twenty years and they would be mostly lead popes. :-(
You did not mention easier to join and repair. No soldering and the
compression joints are barely tighter than finger tight. Small Stillsons
or pipe wrenches are all you need.
You don't often here anyone or anything being described as plastic in a
derogatory way, nowadays. The image has changed.
Regards
I solemnly promise to kick the next angle, I see.
Date: 29 Apr 2014 16:19:42
Message: <5360095e$1@news.povray.org>
I think I meant pipes. Lead pipes not lead Popes. :-)
Regards
Date: 30 Apr 2014 03:14:06
Message: <5360a2be@news.povray.org>
Somehow, those /lead popes/ trigger my imagination... :-)
Date: 30 Apr 2014 03:40:15
Message: <5360a8df$1@news.povray.org>
That's a good one :-)
Two more. No annoying metal banging noises when the heating turns on or
off (light sleepers can have the heating come on before they wake up).
And because the pipes are somewhat bendy you can move things about
without having to disconnect pipes. Painting behind my radiators is
easy, I can just lift them off, rotate through 90 degrees and rest them
on a bucket or something, no plumbing needed.
Date: 30 Apr 2014 06:30:15
Message: <5360d0b7@news.povray.org>
On 2014-04-24 14:32, Francois Labreque wrote:
> Andy has also assured me that iPads, Kindles, Nooks, and the various
> android-based thingamajigs weren't tablets at all, because tablets were
> 2 inch thick laptops that weigh 20lbs and on which you write with a
> Palm-Pilot stylus.
Hear, hear!  Well, augmenting the specifications a little, but I concur
that these newfangled touch-only widgets aren't REAL tablets...my
current dream machine is the Fujitsu Stylistic Q584.  2560x1600 screen,
10.1"x7.12"x0.39" with proper Wacom pen input, weighs 1.4 lbs.
...oh, and it has loads of other bells and whistles, if you're into
those things.  But dat display...over four times the resolution of my
Fujitsu Lifebook (which, at six years old, is rather closer to your
referred attributes, ahem), in a smaller area.  And it's less than a
thousand dollars!
Mind, the Q584's specs are rather unusual and extravagant; most
pen-input tablets are still poking around the 1280x800 neighbourhood.
Also, re. OP:  It's the future.  I was promised flying cars!  But I
don't see any.  Why?  WHY?
Tim Cook
http://empyrean.sjcook.com
Date: 30 Apr 2014 09:33:38
Message: <5360fbb2$1@news.povray.org>
At this point, this becomes obligatory:
http://www.youtube.com/watch?v=PSxihhBzCjk
Date: 30 Apr 2014 14:30:23
Message: <5361413f$1@news.povray.org>
Kudos for dredging up that connection. :-)
Regards
Date: 30 Apr 2014 14:51:45
Message: <53614641@news.povray.org>
> Thomas
Edgar Allan Poe, anyone? ;-)
Regards
Date: 30 Apr 2014 15:05:07
Message: <53614963$1@news.povray.org>
I've never heard of plastic piping for radiators. O_O
The flexibility of plastic piping is great. I had to do some pipework
when I worked offshore. 1/4", 3/8" and 1/2" stainless steel. You had to
be very accurate with your measurements. It looks better, though.
Regards
Date: 1 May 2014 03:24:34
Message: <5361f6b2$1@news.povray.org>
Nor had I until I moved into a house built in this century! The pipes
are on 90 degree exit from the bottom corners of the radiator and bend
back behind in to the centre and through a hole in the wall, it's all
very neat with virtually no pipes visible (and no annoying pipes going
down through the floor).
You can get chrome plated plastic covers to go over copper pipes, to
match fancy bathroom radiators and that sort of thing :-) But I guess
you were using stainless due to its corrosion resistance rather than its
looks. The stuff we make here is mostly stainless too for the same
reason, but we are gradually changing over to PEEK, I wonder if you can
get PEEK pipes <quick google> yes of course you can, first hit is for
off-shore applications!
Date: 1 May 2014 03:26:29
Message: <5361f725$1@news.povray.org>
>> Thomas
No not really Poe, although dark enough indeed. It combines to me more
with what in Italy were called the /Years of Lead/ (anni di piombo).
Lead popes would suggest to me a period of oppressive religion. An
interesting topic for an SF novel in a distopian world.
Date: 1 May 2014 13:33:44
Message: <53628578$1@news.povray.org>
>> actually work.
> useful.
That's a pretty sharp cuttoff. OTOH, from this scale you can't tell
whether the filter still passes, say, 1% of the UV. 1% UV is presumably
still easily enough to utterly destroy whatever is underneith. (E.g., a
plastic coated in this stuff will get ruined in a few months rather than
a few days.)
I am not a professional chemist, but as I understand it, UV just
destroys absolutely everything it touches, and it's very hard to make it
not do this.
So... essentially you're saying the only real change is that plastic is
cheaper now?
And to think I was under the impression that plastic only exists in the
*first* place because it's cheaper...
> (not 30 years ago).
I knew there were at least 6 main plastic types. But 10,000? Really? I
can imagine you could have 10,000 different compounds, with different
additives in them to adjust how springy or brittle they are, etc. But
10,000 fundamentally different molecules? Really?
Actually, I just thought of something. One thing we didn't have when I
was a kid: oven bags. As in, plastic bags that you cook things inside. I
still can't quite wrap my mind around how this works; most plastics melt
if you pour boiling water on them, never mind heating them to *hundreds*
of degrees...
(Also, if this plastic as such a high melting point, how do you mould it
in the first place??)
Date: 1 May 2014 13:37:34
Message: <5362865e$1@news.povray.org>
> Don't think for a second that these companies don't have large R&D depts
I was under the impression that 3M's main business is *manufacturing*
plastics, not designing new ones. (Actually, I was under the impression
that 3M manufactures finished products that have plastic _in_ them, but
I guess they probably sell raw plastic to other people...)
Really? I thought *all* transparent materials have an IOR different than
air. As in, it's impossible to *avoid* this (e.g., if you wanted to make
a kind of "invisible glass", you can't do it.)
I thought that all of those claims were radically exaggerated marketing,
and that these materials are basically identical to what we had 40 years
ago.
Date: 1 May 2014 13:41:22
Message: <53628742@news.povray.org>
Granted I don't work in the manufacturing industry. But I would have
expected that the market for rapid prototyping is utterly *tiny*
compared to the market for actual finished goods.
Does anybody really use 3D printers much? I mean, I can imagine there
are products for which this might be really useful, but if you're just
making (for example) plastic sandwich boxes, do you really need to
prototype that?
Also: I was given to believe that 3D printed objects have approximately
the structural rigidity of jellybaby. It's strong enough to see if
various printed parts will fit together right, but if you stare at it
too hard you're gonna break it. But hey, it's only a *prototype*, right?
It's not like the finished item will be made of the same gel...
Date: 1 May 2014 16:38:40
Message: <5362b0d0$1@news.povray.org>
> prototype that?
YABAMBA
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 1 May 2014 16:41:40
Message: <5362b184@news.povray.org>
YABAMBA
YABAMBA
> ago.
YABAMBA
Sorry Andy but it has to be said
John (recovering from his stroke)
Protect the Earth
Date: 2 May 2014 03:43:26
Message: <53634c9e$1@news.povray.org>
My dentist.
My dentist makes bridges and crowns with a 3D printer, and the products
are no jellybabies, thank God. :-)
Date: 2 May 2014 04:12:26
Message: <5363536a$1@news.povray.org>
It's both - if they didn't do the latter they would be no different to
the other 10 million plastic manufacturing plants. If you've ever dealt
with 3M (as a supplier for volume manufacturing) you would know they are
not the cheapest, but they often have materials and technologies that
nobody else has. This is their business model, it is not making
bog-standard plastics cheaper than everyone else (they would never win
this).
I don't think they do much of that, maybe for some specialised areas but
I've never heard or seen anyone sourcing raw plastic from 3M.
You can create a cone structure on the surface of the material (with the
points upwards so it's pointy to touch). Now so long as the size of the
cones is smaller than the wavelength of light then you get a continuous
smooth variation of IOR from the air to the solid. This prevents any
reflections, so the glass looks invisible. I've seen prototypes of this
and it really does look invisible (you can stick a patch of it on glass
and it looks like someone cut a hole in the glass). The obvious problem
with this is the tips of the cones wear off quite easily which starts to
reduce the effect. Again, it's all about developing new materials and
processes to achieve this kind of product.
There are other anti-reflection coatings already in use, with varying
degrees of performance. One of them works by destructive interference
and is used on glasses, outdoor displays etc, you can tell by the
characteristic purple tint of the remaining reflection (it blocks green
reflection mainly).
Date: 2 May 2014 06:53:57
Message: <53637944.4090302@gmail.com>
>> prototype that?
> YABAMBA
not sure what that acronym means but if it means something like GIYF or
'why don't you just think before you post' or 'have you heard of the
concept of newspapers and magazines', I agree.
Anyway, we use our 3D printers a lot in the hospital, e.g. to plan
operations. Also, have a look at shapeways.com . Do you want plastic
(several varieties) , sandstone, metals, or ceramic?
Everytime the IT department forbids something that a researcher deems
necessary for her work there will be another hole in the firewall.
This email is free from viruses and malware because avast! Antivirus protection is
active.
http://www.avast.com
Date: 2 May 2014 08:52:50
Message: <53639522@news.povray.org>
> a few days.)
I don't think many dyes fade within a few days of sunlight exposure. A
few months maybe, but then a 1% UV filter will allow them to last a few
decades, which is actually useful for something like a car or a photo.
> cheaper now?
Not really, what I'm saying is that the development of plastics and the
processes that use them have allowed *products* to become cheaper. But
that's pretty much the entire purpose of engineering, to make a product
that meets all the requirements for as low a cost as possible. If you
can come up with a new material (or a variant on an existing one) that
allows an existing product to be made cheaper you will be collecting the
Correct, there are at least 6 :-) Here's a list of the common categories:
http://www.efunda.com/materials/polymers/history/history.cfm?list_order=name
There are about 40 there. If you click on each one it will give you a
list of common grades, about 20 for each of the ones I clicked on.
That's already 800 different grades without even considering various
combinations of other additives to aid manufacturing or specific
properties needed. My point is that if you plot all of these on a
timeline you'll see that most have been developed fairly recently, it's
not like there's no development in plastics.
Make your manufacturing machinery from something with a higher melting
point, say steel? How do they make the steel in the first place? :-)
Date: 2 May 2014 09:49:07
Message: <5363a253$1@news.povray.org>
On 02/05/2014 11:53, andrel wrote:
>> YABAMBA
Yet Another Bogus Assumption Made By Andy
John
Date: 2 May 2014 10:31:43
Message: <5363AC4E.7040402@gmail.com>
>>> YABAMBA
yep, that sort of covers it.
I fear that this could become an often used acronym in this group.
active.
Date: 2 May 2014 10:34:37
Message: <5363acfd$1@news.povray.org>
> prototype that?
So you'd be confident enough that the sandwich box hinge and latching
mechanism was going to work properly and not snap off, and that it would
feel right, and the MD is not going to complain the box feels too
flimsy, just by looking at CAD data on your screen and perhaps some
simulations that tell you the stiffness is X N/mm at certain points and
you need X N of force to open the latch? Confident enough to sign off
$100000 for the tooling to be made? For the sake of $500 to get a few
prototypes made up it's not worth it. FWIW I've *never* seen tooling get
made exactly right first time, there is *always* something that needs to
be fixed or changed, using prototypes just reduces the risk of any big
(=expensive) errors.
Did you miss the story a while back of the guy who made a functional
*gun* from 3D printed parts? The whole point of professional 3D printed
parts is that they match the performance of the real moulded plastic.
FWIW here we put butanone at 6 bar into 3D printed parts without issue.
Date: 2 May 2014 13:26:20
Message: <5363d53c@news.povray.org>
>> prototype that?
Given that a 3D prototype will be made of a totally different material
with totally different properties, I'm not sure how having a prototype
lets you check this.
> be fixed or changed
Really? I find that quite surprising. (Then again, I don't work in this
industry.) I had assumed that by now, making something trivial like a
cube-shaped box would be easy. Of course, if you're making something
complicated like the casing for a camera or something, that seems much
harder to get right...
That's impressive, given that even "real moulded plastic" isn't strong
enough to make a gun... They're made out of metal for a reason, after all.
Date: 2 May 2014 13:27:51
Message: <5363d597@news.povray.org>
That sounds absolutely trippy - and really expensive to manufacture. ;-)
> reflection mainly).
Yeah, interference is wavelength-specific, so you can only make stuff
non-reflective at one wavelength. I've seen Falstad. ;-)
Date: 2 May 2014 15:52:41
Message: <5363f789$1@news.povray.org>
Le 02/05/2014 19:26, Orchid Win7 v1 nous fit lire :
Only if you need to fire more than a few time. The bullet should be
metal, the percussing pin too, and maybe container of powder.
Everything else can be "consumable".
In our modern society, making things that last is so 19th century!
Date: 3 May 2014 06:09:29
Message: <5364c059$1@news.povray.org>
I was going to say something about the heat melting the plastic. But
really, the biggest problem is surely going to be that the charge will
smash the plastic to shrapnel, killing whoever fires the gun...
This makes me sad.
Date: 3 May 2014 06:31:55
Message: <5364c59b@news.povray.org>
> This makes me sad.
http://www.bbc.co.uk/news/business-27253103
Regards
Date: 3 May 2014 06:49:57
Message: <5364c9d5$1@news.povray.org>
>> This makes me sad.
So many people seem to think that when you buy something, getting the
lowest possible price is the *only* thing that matters. Which is
frustrating, because I'd actually prefer to pay more money for a quality
product. But since that's currently unfashionable, nobody makes those
anymore. (Or if they do, because so few people buy them, they're
*severely* expensive. Manufacturing costs have to be split between a
fewer number of buyers, and all that.) It's not even like buying a more
expensive model even guarantees better quality anymore; anybody can take
an inferior item and just slap a bigger price tag on it...
Date: 5 May 2014 10:03:35
Message: <53679a37$1@news.povray.org>
No, there are two.  Thermosoftening and thermosetting plastics.  Each
type has thousands of different molecules.
> But 10,000? Really?
 > I can imagine you could have 10,000 different compounds, with different
Not necessarily.  Take the simplest plastics, such polyethylene, which
is just chains (called polymers) of ethylene molecules (called
monomers).  Depending on the length of the chains, you will have
different properties, hence different commercial applications.  LDPE and
HDPE behave quite differently.
Also, if you alternate monomers in your chain, you will have different
properties as well.  Nylon-4,6 behaves differently than Nylon-6,6 or
Nylon-6,9.
Etc.
 > most plastics melt if you pour boiling water on them, never mind
 > heating them to *hundreds* of degrees...
YABAMBA.
The melting point of most plastics is above 250°C.  You *do* have access
to Google, don't you?
You realize the technology to melt metals - which have higher melting
points than plastics - has existed for millennia.
Also, look into "creep".  You don't need to melt it to be able to shape
it.  Just like a blacksmith doesn't have to melt iron into a liquid to
make horseshoes or a sword.
Finally, you *must* have come across pots and pans that have plastic
handles.  I'm sure these don't melt everytime you boil water.
Date: 5 May 2014 10:05:54
Message: <53679ac2$1@news.povray.org>
Where did air come from.  I mentioned GLASS?
> ago.
Then you thought wrong.  Even if the marketing does tend to overstate
their capabilities a bit.
Date: 5 May 2014 10:09:58
Message: <53679bb6$1@news.povray.org>
>> YABAMBA
Look earlier in the thread.  It means
Yet-Another-Bogus-Assumption-Made-By-Andy.
Date: 5 May 2014 23:44:46
Message: <53685aae$1@news.povray.org>
>>>> YABAMBA
>>> or 'why don't you just think before you post' or 'have you heard of
>>> the concept of newspapers and magazines', I agree.
I don't know that I fear that, myself.  I can see its utility in
discussion - a time saving device. ;)
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 5 May 2014 23:46:14
Message: <53685b06$1@news.povray.org>
>> Palm-Pilot stylus.
But surely that's impossible.  Or hideously expensive.  Quite possibly
both at the same time. ;)
> thousand dollars!
In all seriousness, that sounds like a pretty nice piece of kit.
Have you seen how people drive? Do you REALLY want that in 3D? ;)
Jim
Date: 6 May 2014 06:00:59
Message: <5368b2db$1@news.povray.org>
As I said, the materials used for 3D prototypes are designed to mimic
real plastics. The properties are very similar (especially for stiffness).
>> be fixed or changed
Surprisingly something simple like a cube shaped box is problematic for
a variety of reasons. The sides are large, flat and almost perpendicular
to base (or at least you want them to be). This makes it much more
likely the part gets stuck in the tool, parts stuck in tools = $$$.
Plastic shrinks as it cools, large flat surfaces = twisted and warped
parts. Usually you would put supporting ribs on the inside, but in a box
I guess you want to actually use the space inside for storing things, so
you are a bit limited what you can do.
Well it's clearly strong enough to fire at least a few rounds (there's a
video on youtube I think). And if you're the sort of person who wants to
try and get a gun through some security checkpoint then you probably
don't mind that it won't be a long lasting reliable weapon.
Date: 10 May 2014 05:52:40
Message: <536df6e8$1@news.povray.org>
> Have you seen how people drive? Do you REALLY want that in 3D?;)
I certainly don't. Too many idiots on the roads if they took to the
skies I would take to my bed. Even then you never know who might drop in
for tea. ;-)
I have been reading a lot of ancient SF recently. The thing that almost
everyone got wrong is mobile phones. It is jarring when the hero has to
stop by a drug store just to phone someone.
Regards
Date: 10 May 2014 06:59:44
Message: <536e06a0$1@news.povray.org>
Le 10/05/2014 11:52, Stephen nous fit lire :
> for tea. ;-)
Have a look at the Shadowrun RPG (as book for ambiance)... targeted
advertisement as you pass by every shop is coming to your mobile phone.
And it is going to be as hostile as it sound. Next, augmented reality to
hit your glass and audio device... still for aggressive advertisements.
Along the revision/Edition, the matrix changed a bit (connection was
more difficult in first edition, wifi is everywhere in latests).
On another hand, triple-A security blocks are emerging too. Some started
with "elderly-only" town (forbidden to less than ~60 years old alone),
but private blocks are not so far.
Arcology are not yet, unless you look at Millenium tower (tokyo,
project), or Dubai... yep, they are coming. Not sure it will not split
population too.
Date: 10 May 2014 15:51:51
Message: <536e8357$1@news.povray.org>
Now that is familiar from more more modern fiction. (Currently reading
Sinister Barrier (Sinister Barrier 1939, by Eric Frank Russell.)
I am not really into games (I'm pretty poor at playing them.) although I
have been playing the Beta of Elite Dangerous. It is just a shoot them
up in your flying saucer ATM. But it has encouraged be to start Pov-ing
after about a year off.
"as above, so below" or art imitates life.
Sounds fine to me. ;-)
> project), or Dubai... yep, they are coming. Not sure it will not split population
too.
I suppose so (Make room! Make room! by Harry Harrison.)
Regards
Date: 10 May 2014 18:35:18
Message: <536ea9a6$1@news.povray.org>
Lucky duck.  I'm having to wait for final release.  Looking forward to
it, though.
T. Cook
Date: 10 May 2014 20:15:23
Message: <536ec11b$1@news.povray.org>
> for tea. ;-)
Yeah, that really is something that is a sign of the times (as it were).
Jim
Date: 11 May 2014 06:03:23
Message: <536f4aeb$1@news.povray.org>
> it, though.
I was feeling altruistic at the time. :-)
You are not missing much ATM. It is just shooting at things and them
shooting back, so far. I'm having to learn how to fly so it is slow.
Regards
Date: 11 May 2014 06:09:02
Message: <536f4c3e$1@news.povray.org>
I find it strange that whilst the authors could imaging all sorts of
marvellous futures. Excepting Dick Tracy's walkie talkie wristwatch it
seemed to be unimaginable.
Regards
Date: 11 May 2014 10:23:04
Message: <536f87c8$1@news.povray.org>
Albert Robida (http://www.robida.info/index.html) anticipated at least
flying cars, and... Skype ;-)
Date: 11 May 2014 10:48:16
Message: <536f8db0$1@news.povray.org>
OMG! The music. :-(
But how interesting. :-)
(The man and his works.)
Of course this is probably the "exception that proves the rule". Unless
English speakers just don't have the imagination. ^_^
Regards
Date: 11 May 2014 14:22:27
Message: <536fbfe3$1@news.povray.org>
> OMG! The music. :-(
LOL
Date: 23 May 2014 16:25:12
Message: <537faea8$1@news.povray.org>
> it, though.
Here is a preview from the latest news letter.
Not being a gamer I have nothing to compare it with but I am quite
impressed with the graphics.
https://www.youtube.com/watch?v=TGf9OPot8Sc
Regards
