POV-Ray : Newsgroups : povray.off-topic : Math questions Server Time
28 Jul 2026 05:03:42 EDT (-0400)
  Math questions (Message 21 to 30 of 90)
Subject: Re: Math questions
Date: 15 Jul 2013 05:12:15
Message: <51e3bcef@news.povray.org>
scott <sco### [at] scottcom> wrote:
> What happens if an infinite number of buses turn up at once?
Wouldn't that be the power set of natural numbers, making it a genuinely
larger set? Unless I have once again misunderstood something completely.
Date: 15 Jul 2013 05:16:26
Message: <51e3bdea@news.povray.org>
John VanSickle <evi### [at] kosherhotmailcom> wrote:
> > 4) So the next question is: Does a countably-infinite-dimensional unit
> > cube contain the same amount of points as a unit line? If yes, can you
> > give a 1-to-1 mapping between them?
> Yes, as you can see from above.  The unit line, unit square, unit cube,
> unit hypercube, etc., all have the same countability.
You demonstrated that an n-dimensional unit cube has the same amount of
points as a unit line. However, that's not what the question is asking.
> > 5) And the logical extreme: Does an uncountably-infinite-dimensional
> > unit cube contain the same amount of points as a unit line? Explain why.
> > (Also explain how the number of dimensions can be uncountably infinite.
> > That seems to defy the definition of "dimension".)
> The hypercube of infinite dimension may have a higher countability than
> any finite-dimensioned cube, but it is certainly no lower in countability.
I'm not sure that answer makes sense...
Date: 15 Jul 2013 05:47:14
Message: <51e3c521@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> Given the 2D coordinates of a point on the unit square, you can
> interleave their decimal digits, which always yields a unique point on
> the unit line. For example,
>    0.3425
>    0.2183 -> 0. 32 41 28 53
One problem I see with this is that some real numbers can have more than
one decimal representation.
For example 1 and 0.99999... represent the exact same real number, but
their decimal representation is different.
Obviously if you had eg the point (0.5, 0.1), it would make a big difference
how you represent that 0.1. In one case you would get 0.51 while in
the other you get 0.500909090909..., which is obviously not the same value
as 0.51. Thus it wouldn't be a pure bijection.
Date: 15 Jul 2013 06:08:53
Message: <51e3ca35@news.povray.org>
Thinking about it a bit more I came up with this:
People arriving on a bus, give them a bus number, B, from 1 to infinity,
and a seat number, S, from 1 to infinity
People already in the hotel, give them bus number 0, and their seat
number is their existing room number
Everyone then has a unique B and S number.
To map 2D integers to 1D you can use a formula like the cantor pairing
function (had to look up what that was called, but I remember it from
school) 0.5*(B+S)*(B+S+1)+S. This then gives you their new room number
in the hotel.
Date: 15 Jul 2013 13:16:26
Message: <51e42e6a$1@news.povray.org>
Which infinity?
Date: 15 Jul 2013 13:19:42
Message: <51e42f2e$1@news.povray.org>
>>     0.3425
Yes. However, a real has at most two decimal expansions - one ending
with a recurring 9, the other with a recurring 0. If you insert a rule
that the latter is always the one to be chosen, the representation
becomes unique.
This allows you to unambiguously transform any 2D point into a 1D point.
It is unclear to me whether it solves the reverse transformation...
Date: 15 Jul 2013 13:21:21
Message: <51e42f91$1@news.povray.org>
On 14/07/2013 10:48 PM, John VanSickle wrote:
> This is why the reals are considered to have a higher countability than
> the integers. Reals are allowed to have infinite precision (such as pi,
> for which any digital representation goes indefinitely without
> repeating), but integers are defined to have finite precision.
> (Which brings up the question, why this imposition on the integers?)
Integers are allowed to have infinite digits before the decimal place.
Reals are allowed them after the decimal place as well. ;-)
Date: 15 Jul 2013 17:54:15
Message: <51e46f87$1@news.povray.org>
On 7/13/2013 6:50 AM, Warp wrote:
> 1) Does a unit square contain the same amount of points as a unit line?
> (We are talking about real numbers here.)
Taking "same amount of points" to mean "the two sets of points have the
same cardinality", then yes.
> 2) If yes, that means there has to be a 1-to-1 mapping between those
> points. Give a function that expresses such a mapping.
An injective mapping suffices to prove #1 (since the other direction is
trivial), and interleaving the digits achieves this.  A 1-to-1 mapping
is trickier due to annoying edge cases with multiple decimal
representations of the same number.  I don't see a (constructive) way to
do a true 1-to-1 mapping off of the top of my head.
> 3) If the answer to the first question is yes, then it follows that
> the amount of points inside a unit cube is also the same as the amount
> of points on a unit line. The same for a four-dimensional hypercube,
> and so on. Can you give a generic function that gives a 1-to-1 mapping
> between a unit line and an n-dimensional unit cube?
My answer is identical to #2.
Assuming you take the "obvious" definition of an "inifinite dimensional
unit cube" to actually be a unit cube (which I think is natural to do),
then yes.  Again, only an injective mapping is obvious to me.  This can
be done with a triangular interleaving type pattern.
As you've stated it, I believe the answer to this depends on the
continuum hypothesis.
Date: 16 Jul 2013 03:35:30
Message: <51e4f7c2@news.povray.org>
Genuine question then, why isn't the set of real numbers countable,
given that you could represent each one with two integers (one for the
digits before the decimal point, one for the digits after the decimal
point)?
Date: 16 Jul 2013 04:29:55
Message: <51e50483$1@news.povray.org>
> becomes unique.
If you take out all the numbers that could be represented with recurring
0s or 9s from the 2D points, and the corresponding 1D representations of
them, the remaining numbers have a 1-to-1 relation.
So the question comes down to is there a 1-to-1 relation between the 1D
and 2D values you took out from the original sets.
The 2D coordinates taken out will be all possible pairs of numbers from
this list:
0,1,0.1,0.2,0.3,...,0.9,0.01,0.02,0.03,...
The 1D numbers taken out will be the ones generated by interleaving the
digits from all possible pairs of this list:
0.000...
0.999...
1.000...
0.099...
0.100...
0.199...
0.200...
It seems there is then an easy 1-to-1 mapping function for these
remaining numbers, namely that if your 2D coordinate is the i'th and
j'th element from the first list, then you use the i'th and j'th element
from the 2nd list to generate your 1D coordinate.
So (0.3,0.4) is the 5th and 6th element from the first list, so you use
the 5th and 6th from the second list (0.100...,0.199...), which gives
your 1D value of 0.110909090909...
