POV-Ray : Newsgroups : povray.off-topic : Reflections on employment Server Time
27 Nov 2026 21:43:48 EST (-0500)
  Reflections on employment (Message 4 to 53 of 53)
<<< Previous 3 Messages Goto Initial 50 Messages
Subject: Re: Reflections on employment
Date: 2 Dec 2012 10:54:49
Message: <50bb79c9$1@news.povray.org>
On 02/12/2012 03:06 PM, Warp wrote:
> Orchid Win7 v1<voi### [at] devnull>  wrote:
>> Here's a challenge - write me a C# function (or even just some
>> psuedocode) which will take a string containing space-delimited positive
>> integers, and return them in ascending order.
> If it were C++, I could write a few lines of code that does that
Haskell:
   foobar :: String -> [Int]
   foobar = sort . map read . words
C#:
   public List<Int> foobar(String s)
     string[] words = s.Split(' ');
     List<Int> list = new List<Int>();
     foreach (String word in words) {list.add(int.Parse(word));}
     list.Sort();
     return list;
Not exactly taxing, eh?
Date: 2 Dec 2012 11:11:16
Message: <50bb7da4@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
> 1) You can figure out how to split a string and parse it into integers.
In this particular case I wouldn't split it at all, but parse the ints
directly from the string (which is quite easy to do since they are
whitespace-separated.)
Incidentally, there aren't any "string splitting" functions in C++ per se
(unless you count strtok() as being one.) If you literally need to create
a bunch of substrings from a given strings, there's no easier way than to
simply write the loop explicitly. (As much as it pains me to admit it,
parsing is not the forte of the C++ standard library, and it sometimes can
be a burden.)
In this case, however, it's just easier to parse the ints directly from the
input string, with no splitting or tokenization. (Basically there would be
two ways of doing that: Either use a stringstream, or use std::strtol() in
a loop. With a stringstream you could get fancy and use an input iterator
and call a standard algorithm to read the ints, thus eliding having to write
an explicit loop. If you want efficienty, though, std::strtol() is the
better choice, but it's more low-level.)
> 2) You can sort the result.
I can't imagine a programming language that doesn't offer sorting directly.
Even standard C offers such a function, and that's saying quite a lot.
In most languages it should be a one-liner (except in C, of course.)
If using the standard sorting function is disallowed for the purpose of
the exercise, then it becomes quite an academic question in itself. It
becomes a question of whether it needs to be efficient or short. A simple
insertion sort is a four-liner (I count each main element of the algorithm
as one line of code), but it's slow with large amounts of data. Faster
algorithms are harder to implement.
> > I assume there's an at least as easy way of doing it in C#, but since
> > I don't know the language I would fail the test.
> At this point, we're not even asking for correct class or method names.
> Just something that looks like vaguely valid C# syntax and has logic
> which isn't obviously gibberish.
I don't know enough C# to make it even look like it were. Unless C#
resembles a lot C++ (which it probably does.) :)
Date: 2 Dec 2012 11:21:40
Message: <50bb8014@news.povray.org>
> Haskell:
> C#:
>      list.Sort();
>      return list;
In C++ I would probably write it like:
    std::vector<int> foobar(const std::string& s)
        std::istringstream is(s);
        std::vector<int> result;
        int value;
        while(is >> value) result.push_back(value);
        std::sort(result.begin(), result.end());
        return result;
Date: 2 Dec 2012 15:26:39
Message: <50bbb97f$1@news.povray.org>
>          int value;
>          while(is>>  value) result.push_back(value);
>          return result;
...and in much less than 25 minutes. Clearly you're better than any of
the people we've interviewed. (But we knew that.)
It's also conspicuous that, unlike any of the people we interviewed,
you're currently employed. :-P
Date: 2 Dec 2012 15:34:04
Message: <50bbbb3c$1@news.povray.org>
Two months of Bash scripting. That means we do this kind of thing all
the time. It makes me twitch slightly when I think about it too much.
Like I say, one guy did start trying to write a bubble-sort by hand. (Of
course, nobody else I work with sees anything wrong with that.) It does
amuse me that somebody could know what a bubble-sort is, but /not/ know
how to split a string, parse some integers and sort the result...
Of course, any sane person would use the built-in sorting facilities.
Off the top of my head, the only languages I can think of that lack such
a thing are PostScript, Tcl and BASIC. And who the hell would be using
any of those? (OK, PostScript is used quite a lot - but *not* as a
general-purpose programming language!)
Well, yeah, like Java it bears a strong superficial resemblance.
It's weird... I'm in a room full of programmers, and I seem to be the
only person who knows anything at all about computer science. One day my
boss says to me "I can't believe you don't know who J-Lo is". I replied
"I can't believe you don't know the difference between a binary search
tree and a binary heap tree". Every single human in the room stopped
what they were doing, turned around and stared at me as if I'd just gone
stark, raving mad. "What the *hell* are you talking about?" was my boss'
reply.
Sometimes I weep.
Then again, in all honesty, how often do you need to implement a BST by
yourself? Not very often...
Date: 2 Dec 2012 15:58:51
Message: <50bbc10b$1@news.povray.org>
On Sun, 02 Dec 2012 12:30:30 +0000, Orchid Win7 v1 wrote:
> It may be too early to say, but the WTF quotient of my new employer
> appears to be significantly lower than my previous one. I mean, there's
> still some minor brokenness there. But it's not like the last bunch of
> losers I worked for, where the company was run by deranged howler
> monkeys.
It's good that you are seeing that what many of us told you for so long
is in fact true - not all employers are as odd as the one you just
left. :)
> I have also learned that there's a thing called "Spotify", who's purpose
> appears to be to allow my boss to quickly locate terrible music with
> which to troll us all with. (Or just to replay Gangnam Style for the
> twenty-ninth time today...) Supposedly this is somehow legal. Also, I
> now know the words to The Troll Song.
Spotify is great, subscribed recently myself - very large catalog of
music, not all of it is as annoying as Gangnam Style or "other terrible
music."
And yes, it is legal - you pay a monthly fee and get access to what's in
their catalog.  Think Netflix or Lovefilm for music.
Jim
Date: 2 Dec 2012 16:40:53
Message: <50bbcae5$1@news.povray.org>
>> monkeys.
> left. :)
Or rather, I had assumed that I was working for *the only* broken
company. But now it appears that each company is broken, it's just a
question of how seriously or trivially.
> music."
I think my boss just likes trolling people, BTH. ;-)
> their catalog.
But not Pink Floyd or The Beatles, apparently... And yet, at the same
time, unknown bands like The Senti-Mentals are there. Very odd.
Ah yes - two other services that I don't yet understand...
Date: 2 Dec 2012 21:17:22
Message: <50bc0bb2@news.povray.org>
On 12/2/2012 6:30 AM, Orchid Win7 v1 wrote:
> (Some statistics: At my last place, I brought a cake, and with 23 people
> in the building, the cake lasted 3 days. A brought a similar cake to my
> current place of work, and it vanished in UNDER THREE HOURS. Less than
> 10 people work here.)
A plague of locusts descends upon everything left in our coffee bar.
Except for the bacon-flavored jelly beans.  Those lasted a while.
> Of course, The Real WTF is hiring. With unemployment at historic record
> levels, we literally cannot find *anybody* with the skill-set we need.
> Personally I find this baffling. The market must be /flooded/ with
> experienced programmers, and yet we keep interviewing people who can't
> program their way out of a paper bag.
What I noticed that that when the dot-com bubble crashed, a whole lot of
firms became very selective in their hiring.  They wanted people who had
experience with a specific environment or database.
> We have yet to interview anybody who can actually accomplish this
> Herculean task. My personal favourite is the guy who, 25 minutes into
> the task (??!), decided to add a comment explaining what the function
> does. Because, hey, if you can't work out how to write the code, at
> least look like you know how to type, amIright?
My company asked about the languages I knew, but I don't recall them
testing knowledge of specific languages during the testing for the job.
> Of course, I've seen first-hand that there are *a lot* of people who
> can't program, and never will. But I would have thought that with an
> ocean of people looking for work, it shouldn't be too hard to find the
> minority who can. I WAS WRONG! >_<
The hard part is finding people who like coding enough that they won't
get tired of a 40-hour week spent coding, and who are actually good
enough at it that their code is worth hiring them for.
John
Date: 3 Dec 2012 03:49:19
Message: <50bc678f$1@news.povray.org>
Ah, so /that/ is where that came from? "Yes, I've been programming for
20 years, writing code morning, noon and night, in half a dozen
radically dissimilar languages. But no, I haven't actually used the one
specific one you're asking about. Can I still be hired?" Most places
immediately say no.
Several of the people we tested claim to have many, many years of C#
experience. And yet none of them could write trivial programs like
sorting integers or counting words or printing prime numbers.
IMHO, there are two kinds of coders:
The ones who go to college, take a Java course because they think
there's money in it, learn the bare minimum to pass, get a job, and then
completely stop learning. They write code from 9 to 5, go home and stop
thinking about coding. /Everybody/ I went to uni with seemingly fell
into that category. They all /hated/ coding, but it was on the syllabus,
and they believed there was big money to be made with it.
On the other hand, there are people like me. I presume that doesn't
require much further description. There are people who actually /like/
coding, are passionate about it, and voluntarily do it all day just for
the /fun/ of it.
The latter are the people you want to hire.
One of the interview questions we use is "what hardware is in your PC?"
If you're a computer enthusiast, you quite probably built your own PC,
and even if you didn't, you'll almost certainly know if it's an Intel
Core 2 or an AMD Athlon or whatever, how much RAM is has, and so forth.
It's really very, very easy to tell the difference between somebody
who's memorised a list and somebody who knows what they're talking about.
Knowing what hardware you have is of course in no way directly relevant
to the job - but it's a nice way to gauge how much computer knowledge
somebody has.
Date: 3 Dec 2012 03:50:57
Message: <50bc67f1$1@news.povray.org>
Hehe welcome to the real world. We have exactly the same problems with
hiring Engineers. Can you describe what this circuit does? No, ok what
about this one? No, ok what does this *component* do ... ermmm not
exactly, have you every used an oscilloscope? No, ok we'll be in touch,
thanks bye.
I would have written almost exactly the same as you posted, but would
have probably written this line instead (no reason other than I didn't
know Int.Parse existed, and I don't normally use {} for single line
loops...).
     list.add(Convert.ToInt32(word));
> We're using an online site where we can watch people type while we're on
> the phone to them, so save wasting our time with face-to-face
> interviews. Apparently the last guy we interviewed, the guys could hear
> typing but not see anything on the screen, and then suddenly big chunks
> of text would appear... It's /almost/ as if the guy was desperately
> Googling the code while he was on the phone.
Or typing it into the IDE then copying & pasting over, that's what I
would probably do, as I pretty much rely on the auto-complete stuff to
get code right first time (or even remember the method names correctly).
 From what was discussed here before (sorry don't remember who with) it
seems recruitment agencies for software are very poor compared to ones
for engineering for some reason. Seems like there is a market for a
decent software recruitment agency that actually employs people who know
a tiny bit how to program so can weed out people like you describe.
Also as a software company you should be able to knock up a quick
website that has programming exercises (like the one above) that the
candidate has to fill in within a set time, design them so you can't
just google the answer. Send the link to people with a unique login
before you even invite them to interview...
Date: 3 Dec 2012 07:20:32
Message: <50bc9910$1@news.povray.org>
> I've learned a couple of things so far. First, in almost two months,
> I've yet to
...install Thunderbird.
Date: 3 Dec 2012 09:46:49
Message: <50bcbb59@news.povray.org>
I have had the great fortune of never having to work with someone who
isn't a competent programmer. My first job was at the university, in the
deparment of computer science, so you might imagine the competence of
the average programmer working there. (In my current job I basically work
alone on the code. We have another developer but he develops unrelated
projects. Nevertheless, he's quite competent himself too.)
Date: 3 Dec 2012 11:51:04
Message: <50bcd878$1@news.povray.org>
>>> there's still some minor brokenness there. But it's not like the last
>>> bunch of losers I worked for, where the company was run by deranged
>>> howler monkeys.
>> left. :)
All companies face challenges, certainly.  People are involved.
>> music."
>> in their catalog.
It's called "licensing fees", and some of the very popular bands (and
their labels) want extortionate fees to be included in the catalog.
But I did find some Floyd on Slacker, another similar service that I also
subscribe too.
What's to understand?  I want to watch a movie, it's in their catalog, I
stream it to my PS3 and watch it.  I pay a monthly fee and can stream as
much as I want.
Jim
Date: 3 Dec 2012 12:15:39
Message: <50bcde3b@news.povray.org>
You don't understand why people would pay a moderate sum of money in
order to be able to watch movies or listen to music? (And *legally* at
that...)
Date: 4 Dec 2012 04:05:01
Message: <50bdbcbd$1@news.povray.org>
>> I've yet to
At works? Are you nuts?? They have aggressive network surveillance
systems. It would probably be grounds for immediate termination. :-P
Date: 4 Dec 2012 09:51:22
Message: <50be0dea$1@news.povray.org>
> Haskell:
> C#:
>      list.Sort();
>      return list;
Of course there are many ways to approach this in C# and most other
languages.  Using LINQ and and working in decimal datatype without error
handling:
private List<decimal> ParseAndSortValuesFromString1(string text)
	return text.Split(' ').Select(s => Decimal.Parse(s)).OrderBy(s =>
s).ToList();
Date: 4 Dec 2012 14:08:56
Message: <50be4a48@news.povray.org>
> handling:
> s).ToList();
According to one of the guys I work with, "LINQ is great and everything,
but it makes the code extremely slow". Does anybody have any actual
/facts/ with which to confirm or refute this? I would have expected
there to be a fairly minimal speed difference...
Date: 5 Dec 2012 04:28:29
Message: <50bf13bd$1@news.povray.org>
>> handling:
>> s).ToList();
LINQ has a certain amount of overhead, as to whether that significantly
impacts the speed of your code obviously depends on the exact code and
data you're dealing with. Even in your example I suspect the speed
differential is highly dependent on the size of the list.
Date: 5 Dec 2012 09:22:22
Message: <50bf589e@news.povray.org>
Btw, why return a list?
I know that memory allocation in C# is probably faster than it is
in C++, but it still feels odd to use a list instead of something more
memory-efficient (which C# most certainly ought to support) and faster
to access. What possible advantage could there be in using a list of
ints?
Are you transferring your customs of using lists from Haskell to C#?
Date: 5 Dec 2012 10:28:36
Message: <50bf6824$1@news.povray.org>
> that...)
No, he doesn't understand how a service can offer near-HD resolution
over the Internet.  Despite the fact that tv providers have had no
problem doing 60 channels of the same thing over the same wires for the
last 30 years (10 years in the case of HD).
He also complains of not knowing what "cable tv" is, despite the fact
that he admitted his parents used to have it.
You, know, regular Andy stuff.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 5 Dec 2012 16:20:39
Message: <50bfbaa7@news.povray.org>
> ints?
The C# "List" class actually represents a growable array. So it has O(1)
index and O(1) append until the underlying array needs to be enlarged
(which is obviously O(n) time).
The "LinkedList" class represents a (double-linked) list, with the usual
performance characteristics you would expect for that container.
As best as I can tell, List is pretty much the default container to use
unless you need something more specific.
You could also use a normal array. But that isn't resizable (which
doesn't matter in this particular case).
Date: 5 Dec 2012 16:23:19
Message: <50bfbb47@news.povray.org>
> over the Internet.
Providing data over the Internet isn't hard. But providing HD video *in
realtime* would seem difficult given that people don't have
megabit-speed Internet access yet.
Digital TV isn't 30 years old. :-P
Besides, it's no secret that a simplex broadcast channel is much easier
to set up than a full-duplex communications channel.
Date: 5 Dec 2012 16:25:53
Message: <50bfbbe1$1@news.povray.org>
I've only met people who are very bad with computers. When I went to
university, I seemed to know more than most of the lectures I was paying
to teach me, which is always a little bit worrying.
Bafflingly, all the people in my class appeared to hate computers, which
begs the question "why the hell are you here??"
This job is my first experience of working with people who have a clue.
And even they think I'm a bit strange for having all this CS knowledge...
Date: 5 Dec 2012 16:27:16
Message: <50bfbc34$1@news.povray.org>
I would expect that for this example question, you would be very
hard-pressed to construct a program inefficient enough to be considered
"too slow". ;-)
You could perhaps write the program in the Iota calculus, running in an
Iota interpreter written in Bash script. That might perhaps be slow
enough...
Date: 5 Dec 2012 16:36:04
Message: <50bfbe44$1@news.povray.org>
> thanks bye.
This is what baffles me.
Consider the following conversation...
Mr Fail: Hi. I've got 20 years' experience as a brick layer. Are you hiring?
Boss: Oh really? Well, can you just quickly tell me, is that wall over
there stretcher-bond of Flemish-bond?
Mr Fail: Uh... well, I really specialised in /internal/ walls.
Boss: Great! So tell me, at what height should the internal
damp-proofing course be run?
Mr Fail: Well, I, er, mostly worked in tropical countries where damp
isn't a problem.
Boss: Cool. So how many runs of bricks between tie-in wraps?
Mr Fail: Tie-in wraps?
Boss: Goodbye.
The thing is, *nobody* thinks they can just walk in and pretend to know
how to be a brick layer. Because it's ****ing obvious that it'll take
the people interviewing you about 11 seconds to figure out that you know
nothing about anything.
So *why* the hell does this constantly happen in computing?!? >_<
Yeah, but I'm fairly sure even VS doesn't write entire blocks of code
for you. Google searching does. ;-)
I'm currently unsure as to whether we're just not paying the agents
enough money, or whether there's nobody out there to recruit.
(As a small company, we have very little money to spend. And the owners
are the type of people who see job agents as a totally unnecessary
expense and want to spend the absolute minimum possible on them.)
With such high unemployment, you would THINK there's loads of people out
there... but we're beginning to suspect that maybe all the /competent/
people get snapped up faster than we can find them...
Date: 5 Dec 2012 16:48:21
Message: <50bfc125@news.povray.org>
WTF!
Regards
Date: 5 Dec 2012 16:52:11
Message: <50bfc20b$1@news.povray.org>
>> over the Internet.
m-/
That is where you're wrong, Andy.  Even my pokey internet connection is 3
Mbps.  More than enough to handle sufficient data to do a medium quality
HD picture on a 10' screen.
>> Despite the fact that tv providers have had no problem doing 60
>> channels of the same thing over the same wires for the last 30 years
No, but cable TV is close to that.  We had cable when I was a teenager,
and easily had 120 channels at that time (that would be in the 80's).
That's not really classified information, either.
Jim
Date: 5 Dec 2012 16:53:49
Message: <50bfc26d$1@news.povray.org>
Because often times the managers hiring computing professionals do not
have a background in computing.
That's less and less common now, but when I started in IT, it was very
common, and a lot of people talked volumes of BS about it and got hired.
Jim
Date: 5 Dec 2012 18:11:57
Message: <50bfd4bd@news.povray.org>
> "too slow". ;-)
That's because you're not thinking like someone who has no idea what
they're doing.
Take for instance the following algorithm, which I *tried* to make mimic
the sort of answer a clueless person might stumble and grope their way
to after hours of trial and error.  I couldn't manage make the coding
style quite bad enough to be realistic, but you'll get the idea.  I did
at least manage to put in a bug or two which ends up working due to
blind luck.
example of use:
sortInts("5000 353 1  145 145  145 354 23 16564")
the (horrible horrible) code:
def sortInts(S):
	i = 0
	count = 0
	while count < countSpaces(S)+1:
		n = countInStr(i, S)
		if n > 0:
			for j in range(n):
				print i
				count += 1
		i += 1
def countInStr(n, S):
	S = " " + S + " "
	count = 0
	for i in range(len(S)):
		for j in range(i,len(S)):
			if S[i-1:j+1] == " " + str(n) + " ":
				count += 1
	return count
def countSpaces(S):
	count = 0
	wasLastSpace = False
		if S[i] == " ":
			if wasLastSpace == False:
				count += 1
				wasLastSpace = True
		else:
	return count
Date: 6 Dec 2012 02:54:17
Message: <50c04f29@news.povray.org>
Why is C# using the wrong terminology? (Or at the very least, really
misleading?)
What that sounds more like is a dynamic array, not a list.
Date: 6 Dec 2012 02:55:42
Message: <50c04f7e@news.povray.org>
I think you are confusing the word "people" with the word "I".
Date: 6 Dec 2012 09:37:10
Message: <50c0ad96$1@news.povray.org>
>> over the Internet.
I currently have 10Mbps downstream/1.5Mbps upstream.  And both my
provider and its direct competitor offer better packages.
That's why I said 10 years for HD.  And besides, digital channels take
the same bandwidth spectrum as analog tv channels.
That's why it's asymmetrical.  And also why most ISPs frown upon you
hosting servers out of your basement, since you would be hogging the
upstream channel.
Date: 6 Dec 2012 09:57:23
Message: <50c0b253$1@news.povray.org>
Because a lot of people don't even know what they don't know.
Afew years ago, the customer I was working for had their own cafeteria.
  At one point, they decided to outsource the services to an outside
supplier.  The cafeteria cooks, being members of the company's union,
were given the choice of either accepting a non-union job at the new
supplier (at a lower salary, of course), or put themselves on the union
avaialability list in the hope that another job would become available
in another dept.
One of the cooks asked me one day:  "You're in IT, right?  Do you think
I could apply in your dept?  I'm pretty good with my computer at home..."
Me: "Do you know the difference between the IP address classes?"
Him:  [quizzical dog look]
Me: (Ok networking is not for him) "Have you ever played with Linux?"
Me: (Ok, hmm... ) "Do you have a home network?"
Him: Huh... No.  But I customized the hell out of my MySpace page.
Me: "I'll get back to you."
He was really disappointed when I told him we were also an outside
supplier so he couldn't simply waltz in an bump one of the lower
seniority guys.
There was also the girl who wrote in her presentation letter that she
was a networking expert, (her cv mentioned her only experience as having
set up a 10 PC internet cafe), and that she knew both versions of
Windows inside and out (Win 98 *and* Win2000... we're talking serious IT
Geekage, here!)
Date: 6 Dec 2012 10:48:09
Message: <50c0be39@news.povray.org>
> Geekage, here!)
OTOH, the reverse also is problematic. In other words, if you are
completely and absolutely *honest* about your expertise, you might not
get even a job interview.
For instance, if I were seeking for a job that requires PHP skills, and
I would write honestly that I have only rudimentary experience of said
language, they would most probably not even interview me, instead opting
for someone who *claims* to have extensive knowledge and experience.
However, if I outright lied and told them that I have a lot of experience
on PHP, and I got the job, I'm pretty certain that I would learn the
tidbits quite quickly. (The language itself is really close to C++, and
basically the only thing you need to learn is the few syntactical and
semantical oddities and the different libraries.)
Date: 6 Dec 2012 12:32:16
Message: <50c0d6a0$1@news.povray.org>
IIRC, in the US at least, digital takes less spectrum.
Jim
Date: 6 Dec 2012 15:31:21
Message: <50c10099@news.povray.org>
> misleading?)
Yeah, I don't really know.
Java has a /interface/ called "list", which represents "a list of
things". It then provides several different implementations of this
interface, including "LinkedList" and "ArrayList".
C# seems to have copied this terminology, having an IList interface and
a List class which implements it. But it's certainly nothing to do with
linked lists (which don't implement IList at all, and hence don't even
*offer* element indexing as a build-in method).
Go sue the designers. :-P
Date: 6 Dec 2012 15:54:36
Message: <50c1060c$1@news.povray.org>
This is the problem. The market is so utterly flooded with "IT experts"
who claim to know everything about everything, that if you write on your
CV what you *actually* know about, nobody will even look at it. That's
utterly messed up.
Seriously, how many people apply to work as an engine designer when they
don't know anything about physics?
Date: 6 Dec 2012 15:57:31
Message: <50c106bb$1@news.povray.org>
Sure. But why is that peculiar to IT?
Nobody out there thinks they could totally draw up the blueprints for a
suspension bridge and have it actually work. Yet people think they can
write commands to make a computer perform a complex task and it'll be
fine. WTF is up with that?
Yeah, this is pretty standard. Everybody understands that designing
(say) an aeroplane is really hard. And yet people think that designing
computer software is somehow trivially easy...
This probably isn't helped by the following fact: If you pay somebody to
build a skyscraper, and they actually build a small wooden hut, you know
that you did not get what you paid for. If you pay somebody to build an
enterprise-class data management engine and they actually give you an
Excel spreadsheet and an instruction manual, you might not necessarily
realise that something is wrong - and neither might they...
Date: 6 Dec 2012 17:01:56
Message: <50c115d4$1@news.povray.org>
It's a little different when the results aren't tangible, I find.  As in
something physical that someone can look at and test.  When something is
non-physical, I find people tend to think it's easier than it is to go
from concept to implementation.
Jim
Date: 7 Dec 2012 07:26:22
Message: <50c1e06e$1@news.povray.org>
> misleading?)
According to Wikipedia:
"Lists are typically implemented either as linked lists (either singly
or doubly linked) or as arrays, usually variable length or dynamic arrays."
Date: 7 Dec 2012 07:46:39
Message: <50c1e52f$1@news.povray.org>
But seriously that is what it was like with the Engineer guy who we
interviewed. After that we decided to always do a very short telephone
interview first (even if they lived round the corner) rather than
wasting several man-hours of interviewing.
To be fair the guy I mentioned applied directly, the ones through the
agency were always pretty much there. It just strikes me as odd that you
can't find a decent agency to find the right people.
I meant I would write the block in VS and then coyp&past the whole block
to the browser window.
There's always good people out there to recruit, you just need to reach
them (monster or similar is easy nowadays, or a decent agent) and they
must want to work for your company (location, salary, if they are
interested in what you do, etc).
That's why then. Advertise on monster and ask them a few coding
questions as part of their application on monster (you can set it up to
do that and email you their answers with their cv). Sure some will try
and google it then copy&paste, but you should be creative enough to
think of something that can't be googled.
Date: 7 Dec 2012 11:02:13
Message: <50c21305$1@news.povray.org>
LOL that comment would hardly make sense even a decade ago!
Date: 7 Dec 2012 12:54:45
Message: <50c22d65$1@news.povray.org>
>> misleading?)
It's worse...
C# actually *has* an ArrayList class. But that was written before they
added generics. (I.e., an ArrayList holds only Objects.) So when they
added generics, ArrayList became just List.
Yuck.
Date: 7 Dec 2012 12:57:41
Message: <50c22e15$1@news.povray.org>
> That's why then.
Really? Is that all it is?
In my limited experience, Monster is an utter waste of time for
computing jobs. (The whole "there are no jobs in MK" came from my using
Monster to try to find work. Once I switched to a *real* jobs site, I
found plenty of stuff to apply for...)
Date: 10 Dec 2012 03:05:39
Message: <50c597d3$1@news.povray.org>
>> That's why then.
Peanuts and monkeys. IME not all recruitment agencies are created equal...
Date: 11 Dec 2012 09:10:01
Message: <web.50c73d84b927b0d4c2d977c20@news.povray.org>
INTERVIEWER: "Hi. Welcome to ACME Software Corporation. We're a cutting edge
software design company. Tell me, do you have state-of-the-art programming
skills?"
APPLICANT (Kenneth): "Oh sure, lots of skills and experience."
INTERVIEWER: "I see. Such as...?"
APPLICANT: "Six years writing super-complex code in POV-Ray, using the Scene
Description Language! Oh, and Fortran IV, of course."
INTERVIEWER: " (...???...)  I see. Well, just a few questions. Are you familiar
with classes?"
APPLICANT: " Yes, yes, I took some of those in High School and College."
INTERVIEWER: " (....?!?!?!....) Ahem. OK. So, do you even know what a for-loop
is?"
APPLICANT: "Is that like a #while loop?"
INTERVIEWER: "Hmm. So, moving right along...How about any experience with
Python, C#, Lisp, C++ or .NET?"
APPLICANT: "Um, yeah, I've heard of those. And don't forget BASIC!"
INTERVIEWER: "No, no, of course not...well...uh..."
APPLICANT: "So when do I start?!"
Date: 11 Dec 2012 09:48:54
Message: <50c747d6@news.povray.org>
I thought analog channels were 6MHz wide as well, but couldn't find any
actual numbers after a 3.5 nanosecond wiki search.
Date: 11 Dec 2012 09:59:05
Message: <50c74a39@news.povray.org>
Most jurisdiction have rules concerning not harming the public so
engineers, doctors, pharmacists, etc... will have to have some sort of
accreditation before being allowed to do their job.
So the HR person reviewing your application only has to verify that you
are a member of your neck-of-the-woods profesional engineer's
association.  She doesn't have to actually assess your bridge-making skills.
    Doing the same with IT is very difficult because you risk being too
strict and the Jobs, Gates, and Torvalds of this world would be thrown
out, or having to grand-father so many people in that the license
doesn't hold any real value.
In this case, the HR person has to make some sort of judgement call on
your IT abilities, and since they don't know the difference between the
alphabet soup of acronyms, they look for buzzwords, so you end up having
to read the cv of a person who set up an internet café for a senior
telecomm engineer position.
Actual quote I overheard:  "Oracle is just multi-user Excel."
Date: 11 Dec 2012 11:19:08
Message: <50c75cfc$1@news.povray.org>
In the UK single analogue TV channels (which were 8 MHz wide) were
replaced with digital "multiplexes" of up to 40 MBit/s that occupied the
same 8 MHz bandwidth. The frequencies used were the same for both
systems which is why they had to wait until analog was turned off before
the digital signals could be transmitted at full power (to avoid
interference with adjacent transmitters).
Each digital multiplex can hold a variable combination of video, audio
and data, but typically 10+ TV channels per multiplex. Also this allows
some channels to have a higher bitrate than others.
Date: 11 Dec 2012 12:08:42
Message: <50c7689a$1@news.povray.org>
What I found in a quick search is that it's 6-8 MHz, and while analog and
digital use the same amount of bandwidth (for "legacy reasons"), digital
can have subchannels that analog doesn't.  So perhaps I should have said
that the spectrum used is the same, but the usage is different and
digital can be more efficient in using the bandwidth.
I think I might've been thinking about SSTV in HAM applications, because
I knew there were gaps that could be used for (for example) regular FM
transmissions within the channel's spectrum.
Jim
