POV-Ray : Newsgroups : povray.off-topic : Lots of statistics Server Time
9 Nov 2026 18:05:04 EST (-0500)
  Lots of statistics (Message 128 to 177 of 177)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: C#
Date: 18 Aug 2012 00:36:11
Message: <502f1bbb$1@news.povray.org>
On 8/16/2012 7:34, Warp wrote:
> Darren New<dne### [at] sanrrcom>  wrote:
>>> Even if it does, then the language could implicitly do with it what C++'s
>>> virtual inheritance does. You can still forbid all other types of diamond
>>> inheritance if you so wish.
>> You could, but then it's getting weird.
> What would be weird about it?
What about diamond inheritance from Number or Enum or something like that?
There would be a bunch of cases where you could reasonably expect diamond
inheritance to work, or where there's one class under Object which is
nothing but some extra routines you want all *your* classes to inherit.
I.e., it's a very ad hoc rule that tells the programmer that the language
designer didn't know how to solve the problem but recognized it needed
solving. :-)
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Subject: Re: C#
Date: 18 Aug 2012 06:03:01
Message: <502f6855$1@news.povray.org>
On 18/08/2012 05:34 AM, Darren New wrote:
> On 8/16/2012 3:14, Invisible wrote:
>> According to Wikipedia, Mono /also/ does JIT compilation to native code.
>> (Although I agree it would be better if there were published benchmark
>> results for .NET itself.)
> You almost have to. But the GC and the JIT for Mono both suck compared
> to the ones optimized by MS.
You have an actual citation for that?
Subject: Re: C#
Date: 18 Aug 2012 06:14:39
Message: <502f6b0f$1@news.povray.org>
On 18/08/2012 05:10 AM, Darren New wrote:
> On 8/16/2012 4:13, Invisible wrote:
>> Does /any/ high-level language do this?
> Depends what you mean by "high level", but yes. Ada, C#, FORTH, a few
> others here and there.
I very much doubt that C# lets you trivially call arbitrary machine code.
>>> Can you write programs that notice your
>>> SQL schema has changed and modifies the running program to account for
>>> that?
>> Since it's not possible to receive notifications for schema changes in
>> the first place, I don't see how this is feasible.
> You are allowed to poll. ;-)
In that case, yeah, it ought to be possible to build something that does
this. Nobody has, but somebody could.
>> Haskell is usually distributed in source form. Partly that's because the
>> community is small, and nobody has the resources to compile their code
>> for
>> every target platform. Partly it's because most Haskell code is
>> open-source
>> anyway. But partly it's because the extant Haskell implementations
>> have very
>> poor object code compatibility.
> And that's the sort of thing I'm talking about. :-)
And, as I wrote in the part you snipped, this is a property of the one
extant Haskell compiler. It's not necessarily intrinsic to the language
itself. Somebody could write a compiler that /does/ have good object
code compatibility. It's just that to date, it hasn't been a priority.
There's nothing about the /language design/ that makes this impossible.
On the other hand, if you're coding in BASIC, with line numbers and all,
then this pretty much /is/ impossible. Because BASIC is a very, very bad
language.
>>> How elegantly does it interface to dynamic languages like javascript?
>> What do you mean by "interface"?
> Can you invoke a javascript library as if it were written in Haskell?
> I.e., is it as easy to invoke something like javascript as it is to
> invoke something like C?
Don't you need a web browser to run JavaScript code?
Regardless, invoking JS is, in principle, similar to invoking any other
foreign language. Once you work out how to call it, you'd need to write
at least some trivial wrappers to get it to work, and after that it's
pretty easy.
>> More to the point, most of the questions above aren't about the language
>> itself, they're about all the supporting infrastructure that goes with a
>> language to make it useful. While these are obviously important
>> things, they
>> aren't part of the core language.
> Well, if your language can't handle dynamic loading or can't handle
> object-code distribution, then these are inherent in the language. I.e.,
> if type inference is such that you have to do whole-program compilation
> for it to work, then you can't link in new code at runtime.
No.
If the /design/ of the language makes dynamic loading impossible, then
that's a language limitation. If the current /implementation/ of the
language does not support dynamic loading, then that's just an
implementation limitation.
And that's what I'm saying. Most of the stuff you can't do with Haskell
right now isn't because of poor language design. It's just that nobody
has built the tools or libraries required to do it. Some day these
things /could/ become possible, without changing the language.
> Not superior. Superior at various tasks.
 From what I can see, C# is superior at migrating C++ code and letting
it integrate with old VB code...
Subject: Re: C#
Date: 18 Aug 2012 06:16:58
Message: <502f6b9a$1@news.povray.org>
>> Similar remarks go for most of your points. There are languages like
>> Erlang
>> where support for distributed processing is built-in. Haskell is not
>> such a
>> language.
> But that's not all it takes to make it do what Erlang does. Erlang isn't
> just "distributed processing." It's "reliable processing." Which means
> you need to be able to (for example) start a new version of the code
> running while not actually throwing away the stack of call frames that
> got you there
> How would you write a Haskell library that says "once each call to X
> returns, replace that thread's version of X with new executable code,
> without otherwise disturbing the thread that's running there"?
You wouldn't be able to do this for arbitrary code. But if you insert a
suitable layer of indirection, it wouldn't be too hard. Haskell supports
first-class functions, after all. You can do crazy things with stuff
like continuation-passing and so on.
Subject: Re: C#
Date: 18 Aug 2012 13:43:33
Message: <502fd445$1@news.povray.org>
You would be mistaken. It's no harder in C# to call COM or C code than it is
to do so from C++. Machine code? Well, you have to know the calling
convention, but sure, you can do that.
OK, so Haskell supports dynamic loading of code including declaring new
types? Funky.
> itself. Somebody could write a compiler that /does/ have good object code
> compatibility. It's just that to date, it hasn't been a priority. There's
Sure. But some systems are designed to make this easy, and some aren't. For
example, it's a lot harder to write a C# compiler that does *not* have good
Of course any language can manage pretty much any function with enough
effort. Even BASIC can have good object-code compatibility if you work hard
enough at it. (I think they call it VB.NET, ;-)  The question is how much
effort does it take, and how much does it look like part of the language
when you're done.
Why would you need a web browser?
> foreign language. Once you work out how to call it, you'd need to write at
> least some trivial wrappers to get it to work, and after that it's pretty easy.
Except that JS is dynamically-typed. So you can't write a wrapper to a JS
function. Plus, of *course* you *can* manage it. It's turing complete and
runs on the same machine. The point is whether it's easy to take a lazy
functional declarative language and conveniently invoke a stateful
dynamically-typed collection of functions and objects. I can't even imagine
how you'd write a wrapper for something like that, in terms of declaring it
and invoking it. I.e., I don't even know how you'd be able to write a
Haskell declaration of a javascript object, even assuming such library was
already written.
> right now isn't because of poor language design. It's just that nobody has
> built the tools or libraries required to do it. Some day these things
OK. It wasn't obvious to me that the design of the language was such that
you could have the things I was talking about.
>  From what I can see, C# is superior at migrating C++ code and letting it
You barely even know how it works, and you've not written any significant
programs in it, so you're judging from a position of ignorance. :-)
    in the cabinet."
Subject: Re: C#
Date: 18 Aug 2012 13:44:57
Message: <502fd499$1@news.povray.org>
And that's what I'm talking about. If you want your program to run 15 years
without ever stopping, you pretty much need to be able to replace arbitrary
bits of code, including type signatures, while you're running.
 > But if you insert a
> first-class functions, after all. You can do crazy things with stuff like
Sure, and Erlang translates into machine code instructions at some point. Or
hell, implement an Erlang interpreter in Haskell. This isn't an argument. :-)
    in the cabinet."
Subject: Re: C#
Date: 18 Aug 2012 13:51:24
Message: <502fd61c$1@news.povray.org>
First google hit on "mono gc sucks"
http://phoronix.com/forums/showthread.php?26300-Mono-2-8-Is-Out-With-C-4-0-Better-Performance/page15
Later versions of Mono are much better than the first few generations, which
sucked so bad they realized they actually needed to fix it to be even usable
let alone competitive.
    in the cabinet."
Subject: Re: C#
Date: 19 Aug 2012 06:13:49
Message: <5030bc5d$1@news.povray.org>
> years without ever stopping, you pretty much need to be able to replace
> arbitrary bits of code, including type signatures, while you're running.
And if this was a problem for your application, you would write it in
such a way as to facilitate doing this.
Yes, it would be cooler if you could do it for /arbitrary/ code, but
with extant implementations, you'd have to do the next best thing.
(And, again, if somebody wanted this, you could probably come up with a
Haskell implementation that supports it natively. It's just that nobody
has. It would take some design work, but I think you could do it without
changing the language itself.)
>> But if you insert a
> point. Or hell, implement an Erlang interpreter in Haskell. This isn't
> an argument. :-)
Implementing an Erlang interpreter in BBC BASIC would be hellishly
difficult. Doing it in Haskell wouldn't be all that hard. That's the
difference.
Subject: Re: C#
Date: 19 Aug 2012 06:26:15
Message: <5030bf47$1@news.povray.org>
> it is to do so from C++. Machine code? Well, you have to know the
> calling convention, but sure, you can do that.
It's no harder to call C than to call Haskell, once you define where the
hell the function is and what arguments it's expecting. Your point?
> types? Funky.
It's commonplace to write Haskell code which doesn't know exactly what
data types it's dealing with. Dynamically loading new types that didn't
exist at compile-time isn't really a problem, in principle. The only
real problem is that the current language implementation doesn't support
this well.
Fair enough.
> hard enough at it. (I think they call it VB.NET, ;-)
VB isn't BASIC. VB is a language with a very slight resemblance to
BASIC, which has "basic" in its name. Really, it's an utterly separate
language.
And that's the point - any language can be made to support anything if
you TOTALLY CHANGE THE LANGUAGE. The question is whether you can do X, Y
or Z /without/ drastically changing the language.
> The question is how
> much effort does it take, and how much does it look like part of the
> language when you're done.
OK.
JavaScript is a language invented for controlling web browsers. I don't
know of anything else that runs it.
And Haskell can't manage dynamically-typed code.
Oh, wait. Yes it can.
> lazy functional declarative language and conveniently invoke a stateful
> imagine how you'd write a wrapper for something like that, in terms of
> declaring it and invoking it.
"I can't imagine how this would be possible" isn't the same as "this is
not possible", as everyone is so fond of reminding me.
> significant programs in it, so you're judging from a position of
> ignorance. :-)
I said that the design is overly complicated and cluttered. That it
lacked simplicity and elegance. Why would I need an encyclopaedic
knowledge of the language to say that?
Subject: Re: C#
Date: 19 Aug 2012 12:03:40
Message: <50310e5c$1@news.povray.org>
I'm not following. You said C# doesn't let you call machine code. I said it did.
And if Haskell tends to use things like lists extensively, or options, or
something like that, then yeah, it can be hard to pass such things across
computation boundaries, let alone lazy expressions. And of course if the C
isn't actually a function in the functional sense, I'm not sure how Haskell
handles it. For example, it's really not obvious how easy it would be to
invoke a C function that takes as one of its arguments a pointer to a function.
Note I'm not bashing Haskell. I'm simply pointing out the assertion that
Haskell does everything as well as every other language doesn't sound right
to me.
> It's commonplace to write Haskell code which doesn't know exactly what data
> types it's dealing with. Dynamically loading new types that didn't exist at
> compile-time isn't really a problem, in principle. The only real problem is
> that the current language implementation doesn't support this well.
OK, cool.
> VB isn't BASIC. VB is a language with a very slight resemblance to BASIC,
> which has "basic" in its name. Really, it's an utterly separate language.
Well, it's not Dartmouth basic, no. :-)  But I was mainly kidding there.
> JavaScript is a language invented for controlling web browsers. I don't know
There are lots of other applications that have incorporated javascript. For
example, MongoDB interprets javascript to decide how to do queries and build
indexes.
http://en.wikipedia.org/wiki/Comparison_of_server-side_JavaScript_solutions
And have you not heard of node.js?
OK. Again, I didn't know that. I thought Haskell is statically typed.
> "I can't imagine how this would be possible" isn't the same as "this is not
I didn't say it's impossible. I said I can't imagine it. :-)
So how do you do it?
    in the cabinet."
Subject: Re: C#
Date: 19 Aug 2012 12:08:02
Message: <50310f62$1@news.povray.org>
> And if this was a problem for your application, you would write it in such a
Except it's exponentially harder if your language doesn't support it.
For example, there's STM for C#. But it's tremendously harder to make it
work, because C# supports arbitrary mutations of variable values. You
*could* make it work, with enough strictures, but it's not worth it.
> Haskell implementation that supports it natively. It's just that nobody has.
> It would take some design work, but I think you could do it without changing
See STM on C#.
> difference.
We're not comparing Haskell to BBC BASIC. The point I'm making is that many
of the decisions in Erlang were made to support this sort of long-running
self-healing software. Yes, you could do the same thing in Haskell, but then
it would look like Erlang. I could do the same thing in C# by writing an
Erlang interpreter in C# and linking in a bunch of C code for the stuff that
C# can't do natively (like reboot the machine it's running on). But that's
not comparing language strengths. That's just asserting they're turing complete.
    in the cabinet."
Subject: Re: C#
Date: 20 Aug 2012 04:25:35
Message: <5031f47f$1@news.povray.org>
No, it isn't.
It's exponentially harder IF YOUR LANGUAGE SUCKS. If you have a powerful
language, then adding new things is quite easy.
Well, no, that should be quite easy: You have a rule that inside a
transaction, you don't try to do anything observable to the outside
world. If you do, it won't work, and it will be your fault. Problem solved.
The trouble is, they tried to make it so that any arbitrary code can be
run in a transaction. That's impossible. Which is why it didn't work.
You might say "but almost all C# code would be disqualified!" But
remember, the purpose of a transaction is /only/ to coordinate threads.
You don't run the entire application inside STM, just the tiny bits
related to synchronisation.
> many of the decisions in Erlang were made to support this sort of
> long-running self-healing software. Yes, you could do the same thing in
> Haskell, but then it would look like Erlang.
Would it, now?
Adding features for distributed concurrency and hot code replacement
would make Haskell have crap syntax and weak typing?
No, I didn't think so. :-P
You're aware of the prior art on this subject, I assume? You know about
the project where they managed to actually implement typed message
sending and remote code execution? Transparently? Without altering the
Haskell language at all, just the compiler?
Sure, it didn't do /everything/ that Erlang does. It was only a
prototype. But it refutes the whole "it would make Haskell identical to
Erlang" argument.
> in C# by writing an Erlang interpreter in C# and linking in a bunch of C
> code for the stuff that C# can't do natively (like reboot the machine
> it's running on). But that's not comparing language strengths. That's
Being able to implement something is one thing. Being able to implement
it /easily/ is another. And that's the goal of designing a good
language: to make stuff easy.
Subject: Re: C#
Date: 20 Aug 2012 04:31:42
Message: <5031f5ee$1@news.povray.org>
>>>> code.
> it did.
No.
You said C# lets you call arbitrary machine code as easily as calling
another C# function. I said it doesn't.
> or something like that, then yeah, it can be hard to pass such things
> across computation boundaries, let alone lazy expressions.
You cannot pass arbitrary Haskell expressions to C. You can only pass
primitive data types that C understands. (Things like int or long or
void*.) If C needs to access Haskell stuff, you write Haskell functions
that inspect the Haskell stuff and return something that C understands,
and then have C call that.
> And of course
> if the C isn't actually a function in the functional sense, I'm not sure
> how Haskell handles it.
If the code you're trying to call has no observable side effects (e.g.,
sinh() or something) then you mark it as a pure function. If it /does/
have observable side-effects, then you mark it as an I/O action, and
handle it the same way as any other I/O action. Really, it's not hard.
> would be to invoke a C function that takes as one of its arguments a
Do you remember that time I used the C sort() function to work a Haskell
data structure? Do you remember how I don't even know all that much
about C, and yet it only took me about 20 minutes to figure it out?
Seriously, it's not "trivial". But it's pretty damned simple.
> right to me.
And, as I keep pointing out, that isn't what I said. I said the core
language design is simple and clean. I didn't say it has a library for
every possible task. However, the language design itself doesn't rule
out any particularly large possibilities, as far as I can tell.
>> don't know of anything else that runs it.
Really?
> For example, MongoDB interprets javascript to decide how to do queries
> and build indexes.
I've /heard of/ node.js; I have no idea what it /is/ though.
Haskell is statically typed. But there's a library for doing stuff with
dynamic types. Basically, it lets you convert any suitable value to a
special "Dynamic" type. You can then later try to cast it back to
something else, which succeeds iff that is actually the correct type.
You know, the usual deal.
At worst, if you wanted to talk to something dynamic, you could just
mark every single thing it touches is "type unknown" until you try to do
something with it. It isn't that hard.
Subject: Re: C#
Date: 20 Aug 2012 06:29:05
Message: <50321171$1@news.povray.org>
Am 20.08.2012 10:31, schrieb Invisible:
The thing is that this is NOT what you said (or rather, what you
implied). Your claim was (or appeared to be) that Haskell is simple and
elegant AND a "solution for everything".
We keep disputing the latter, while you keep insisting on the former
(which we're not disputing in any way).
Subject: Re: C#
Date: 20 Aug 2012 07:02:37
Message: <5032194d$1@news.povray.org>
It seems the confusion here is "solution for everything".
It seems you guys think that I meant "every possible computing task that
can ever exist". Obviously Haskell does /not/ solve every such problem.
Indeed, it doesn't solve /most/ of them, due to the much-discussed
extreme lack of libraries. Want to load a JPEG image? Good luck with
that. I could come up with dozens of other examples off the top of my head.
What I meant was to contrast Haskell against C# and languages like it.
With most mainstream languages, somebody will be writing a program, and
find that some facet of it is really awkward to structure. Basically,
the language doesn't solve that well. So they invent yet another new
feature to solve that problem - or rather, to solve one particular
instance of it. And then later somebody else invents another, in
compatible, new feature to solve a slightly different instance of it.
And so, after a few decades, we have a feature-encrusted language which
/still/ doesn't solve all the problems.
The "problems" that I was discussing are not "can I interact with legacy
systems?" or "have I got good multimedia support?" or "does my toolchain
support distributed processing well?" Rather, I was talking about
problems such as "can I express the core application logic in a robust,
maintainable, bug-free way?"
Object-oriented programming was supposed to make everything polymorphic
and wonderful. But then they discovered the container problem, so they
invented generics. And then they figured out that sometimes, you want
multiple inheritance. So they invented multiple inheritance, and decided
to not use it and have "interfaces" instead, for no really defined
reason. And then they decided that having eight-billion interfaces like
"Runnable", "ScrollEventListener", "DragEventListener",
"CheckBoxEventListener" and so on was just stupid. So Eiffel invented
"agents", C# invented "delegates", and Java offered the "reflection
API"; all of them different attempts to solve the same language design
problem.
This is the kind of stuff I'm talking about. All these different
languages, all with lots and lots of "features" for trying to solve
stuff. And then there's Haskell, which consists of just 6 constructs in
the entire language, and solves all of it.
[OK, I take that back: Records with named fields is a joke in Haskell.
But the language solves everything /else/ pretty damned well.]
Subject: Re: C#
Date: 20 Aug 2012 09:37:33
Message: <50323d9d@news.povray.org>
Am 20.08.2012 13:02, schrieb Invisible:
And here here we are maintaining that how best to express the core
application logic in a robust, maintainable, bug-free way depends on the
type of problem the application is supposed to solve.
If you are tied to a particular language, then for some problems you
WILL end up with writing libraries, metaprogramming tools and the like,
and you're actually no longer programming in that language - you're only
using it as glue code here and there. (Provided you do aim for that
robust, maintainable, bug-free way of expressing stuff of course.)
> problem.
I think you're getting the order of events somewhat wrong here.
Anyway - at present it looks like function-oriented programming is
supposed to make everything functional and wonderful now. But what
problems will they discover (if they haven't done so already and you
just haven't heard of it yet)? I betcha there will be quite a few and
then some, just like with every other programming paradigm we've had so
far under the sky.
Subject: Re: C#
Date: 20 Aug 2012 10:34:37
Message: <50324afd$1@news.povray.org>
OK. But if you have an inflexible language, then you have only one way
to express your solution. And if that isn't a good way for a certain
problem, things get tricky. If you have a powerful and expressive
language with the flexibility to support multiple ways to solve the
problem, it's far more likely you can find one that works well. No?
And this is bad somehow?
> far under the sky.
 From what I've seen, "every other programming paradigm so far" has been
ad hoc without much in the way of a strong, consistent theoretical basis.
I mean, take SQL. It solves only one problem, but it solves it so damned
well that it is basically the /only/ language of its type. And oh look,
it's based on a theoretical model. Funny coincidence, that...
Subject: Re: C#
Date: 20 Aug 2012 16:29:10
Message: <50329e16$1@news.povray.org>
Am 20.08.2012 16:34, schrieb Invisible:
>> far under the sky.
Structured paradigm being ad-hoc? Don't think so. It's the result of
people wrecking their brain about what was wrong with their previous
coding approaches, and revolutionizing the world of software development
with essentially just ONE strong rule.
OO paradigm being ad-hoc? Don't think so either; it only got ad-hoc the
moment it left the realm of scientific studies and entered the realm of
real-world hype.
Finite state paradigm? DEFINITELY has a well-analyzed, theoretical basis.
Actually, I can't think of how a programming paradigm could be ad-hoc
without a consistent theoretical basis; I mean, that's why it is called
a /paradigm/ rather than just coding style or some such.
Maybe you're confusing programming paradigms with programming languages
here.
Yes, virtually ALL mainstream programming languages have something
ad-hoc-ish about them, in how they're not strictly adhering to any
single programming paradigm.
But wait... maybe that's why they ARE mainstream after all - because you
can mix & match different paradigms with just one language? You know,
solve the different parts of the software in the way that's most suited
to each one. Get around some problems with one paradigm by offering
alternative paradigms to base your software (or module) design on.
After all, for practical purposes it is perfectly irrelevant whether
your language is simple and elegant at its core - all that matters is
whether it can solve YOUR problems in a way that YOU can wrap your
brains around after a reasonable amount of training.
Oh, wait... you're probably right: C# sucks - for YOU. Because if
everything you're familiar with are dremel tools, the cassic cluttered
tool box will look extremely unelegant and inefficient to you.
Speaking of wrong tools for the job, here's a mandatory viewing. No, not
hammers this time:
http://www.youtube.com/watch?v=WxxG0faDT_M
Yeah, strange though that they didn't use a functional paradigm for
those databases...
Subject: Re: C#
Date: 21 Aug 2012 04:57:06
Message: <50334d62$1@news.povray.org>
> here.
Yeah, perhaps.
The thing is, there /are/ programming languages which stick consistently
to one programming approach. Unfortunately, it tends to be the mish-mash
languages which have backwards compatibility to all the pre-existing
crap that tend to be popular.
I would argue that it's just because they continue the poor design
choices that came before. Half the complexity in C++ is due to backwards
compatibility with C. Java and C# just copy the syntax from C++. Visual
Basic even has "basic" in the name. And so on.
Sure. And having a complicated, messy language which lacks internal
consistency makes it so much easier to learn. Oh, wait...
When I hear [yet another] story about people storing XML in the database
rather than change the schema, this is what I think it sounds like.
> those databases...
Functional programming is a model of computation, but databases don't
compute anything. They just store stuff. Far more logical to use a model
of knowledge for that, no?
Subject: Re: C#
Date: 21 Aug 2012 06:37:34
Message: <503364ee$1@news.povray.org>
Am 21.08.2012 10:57, schrieb Invisible:
Definitely NOT. They do copy the syntax from C (not C++) for the short
imperative snippets, but that's about it.
They also do make some features of their language /look/ akin to similar
C++ features, like C# generics vs. C++ templates. Again, they're totally
different breeds there though. Even exceptions are fundamentally
different, in that both Java and C# require the thrown exception to be
of a special type.
I don't know a single feature of the C++ language (aside from what's
also available in C) that also features in Java and/or C# in the same
way. Well, maybe line comments - but even the C++ line comments also
feature in C99.
>> those databases...
See?
Subject: Re: C#
Date: 25 Aug 2012 23:30:46
Message: <50399866@news.povray.org>
Assuming it uses one of the calling conventions that C# understands, then
yes, it does.
> primitive data types that C understands. (Things like int or long or void*.)
> If C needs to access Haskell stuff, you write Haskell functions that inspect
> the Haskell stuff and return something that C understands, and then have C
> call that.
So it's hard to call across the boundaries there.
>> And of course
> sinh() or something) then you mark it as a pure function. If it /does/ have
> observable side-effects, then you mark it as an I/O action, and handle it
OK, cool.
> data structure? Do you remember how I don't even know all that much about C,
OK. Again, note that I didn't say it's not easy. I said it's not obvious to
me how easy it is. I don't know Haskell very well, remember?
> Really?
I gave you a wikipedia link to a giant list, even! :-)
> special "Dynamic" type. You can then later try to cast it back to something
> else, which succeeds iff that is actually the correct type. You know, the
> usual deal.
OK.  Still a bit clunkier than C#. :-)
> At worst, if you wanted to talk to something dynamic, you could just mark
It sounds more clunky than difficult.
    in the cabinet."
Subject: Re: C#
Date: 25 Aug 2012 23:36:14
Message: <503999ae$1@news.povray.org>
On 8/20/2012 4:02, Invisible wrote:
> Object-oriented programming was supposed to make everything polymorphic and
> wonderful.
Uh, no.
> But then they discovered the container problem, so they invented
> generics.
The container problem you describe is only a problem for statically typed
languages.
> they decided that having eight-billion interfaces like "Runnable",
> "ScrollEventListener", "DragEventListener", "CheckBoxEventListener" and so
> on was just stupid.
It was always stupid, and most languages don't need that.
> So Eiffel invented "agents", C# invented "delegates",
> and Java offered the "reflection API"; all of them different attempts to
> solve the same language design problem.
The reflection API has nothing to do with delegates or agents. Indeed, C#
has a reflection API also.
> This is the kind of stuff I'm talking about. All these different languages,
> all with lots and lots of "features" for trying to solve stuff. And then
> there's Haskell, which consists of just 6 constructs in the entire language,
And Smalltalk, which also solves all of it with the same level of
constructs. But the stuff you're complaining about in C# isn't the core
language either. Threads and the reflection API aren't part of the "core
language" of C# either.
    in the cabinet."
Subject: Re: C#
Date: 25 Aug 2012 23:37:30
Message: <503999fa$1@news.povray.org>
Yes. Quite a bit.
    in the cabinet."
Subject: Re: C#
Date: 25 Aug 2012 23:47:16
Message: <50399c44$1@news.povray.org>
> No, it isn't.
OK, show me a Haskell library that lets me replace any function of the
language with a new version of that function, keeping the old function for
any lazy values that might refer to it, until all those lazy values have
turned strict.
Can you write a Haskell function that wraps every other Haskell function
declared?  Maybe. I know a few languages like that. But it still doesn't
make adding that feature easy.
> transaction, you don't try to do anything observable to the outside world.
Except that makes it useful for the areas in which C# is used, namely
calling library code. You can't know if the code you're calling does
something observable. That's the point.
> The trouble is, they tried to make it so that any arbitrary code can be run
Right. More to the point, they tried to make it so you could use arbitrary
library code for which you don't have the source inside a transaction.
> You might say "but almost all C# code would be disqualified!" But remember,
> the purpose of a transaction is /only/ to coordinate threads. You don't run
> the entire application inside STM, just the tiny bits related to
> synchronisation.
Right. But say the bit you want to synchronize is implemented in someone's
library, and they log a message when something fails.
> Would it, now?
> Adding features for distributed concurrency and hot code replacement would
Well, I think "crap syntax" is debatable, but I'm tending to agree with you.
Weak typing? Most certainly.
> You're aware of the prior art on this subject, I assume? You know about the
> project where they managed to actually implement typed message sending and
> remote code execution? Transparently? Without altering the Haskell language
That's not the main part of Erlang. You're talking about Erlang as if we
were talking about SQL and one of us is focusing on the fact that it's also
a functional language. That's not the point.
The fact that Erlang has remote code execution and sends messages is a
*result* of the Erlang design goals, not a fundamental property. (For
example, Hermes has the same design goals, and it doesn't support remote
execution in the language either.)
> Being able to implement something is one thing. Being able to implement it
> /easily/ is another. And that's the goal of designing a good language: to
> make stuff easy.
You keep asserting that it's easier in Haskell to do some of these things
than it is in Erlang or C#. But you've yet to actually provide any evidence
of this beyond vigorous assertions.
    in the cabinet."
Subject: Re: C#
Date: 26 Aug 2012 04:01:21
Message: <5039d7d1$1@news.povray.org>
> then yes, it does.
And if some machine code has the same calling convention as Haskell,
then it's trivial to call. Admittedly, no such code exists anywhere,
because the Haskell calling convention is insanely complicated and
changes every few years, but you see my point. :-P
>> void*.)
>> inspect
>> have C
>> call that.
Not so much "hard" as "non-trivial".
>>> And of course
>> have
> OK, cool.
Three guesses how I/O actions are "really" implemented. ;-)
>> something
>> usual deal.
What? C# doesn't ask you to write explicit upcasts and downcasts sometimes?
Subject: Re: C#
Date: 26 Aug 2012 04:51:34
Message: <5039e396$1@news.povray.org>
> things than it is in Erlang or C#. But you've yet to actually provide
> any evidence of this beyond vigorous assertions.
And you keep asserting that Haskell is a bad language, without much
evidence either. :-P
Erlang is /obviously/ much better at hot code swapping than Haskell
currently is. This is not in debate. But you keep asserting that Haskell
/can never/ be as good as Erlang. Because it's somehow /impossible/ for
somebody to come up with a Haskell implementation that does what Erlang
does. You still haven't explained why that is.
Likewise, C#.Net gives you access to the entire .Net platform library.
This has vastly more functionality than what's available for Haskell.
This is because C# is MORE POPULAR than Haskell, and NOT because Haskell
is badly designed.
My argument was never about how much external stuff is available for
Haskell. My argument was that Haskell is a clean, simple language that
manages to solve the same problems that other languages can only solve
using a vast swathe of complicated "features" hard-wired into the language.
C# has methods and inheritance and subtype polymorphism and dynamic
dispatch and delegates and lambda abstractions and broken multiple
inheritance and reflection and... Haskell just has first-class
functions. Solves all of the above, with a fraction of the complexity.
It's simpler to explain, it's simpler to use, it's simpler to read.
That's what I'm talking about.
Subject: Re: C#
Date: 26 Aug 2012 12:30:52
Message: <503a4f3c$1@news.povray.org>
>> then yes, it does.
> And if some machine code has the same calling convention as Haskell, then
> it's trivial to call. Admittedly, no such code exists anywhere, because the
> Haskell calling convention is insanely complicated and changes every few
I see your point. But you seem to be missing mine.
>>> void*.)
>>> inspect
>>> have C
>>> call that.
Well, yes. You have to restructure your Haskell code and basically re-write
it in C style in order to call it from C.
>>> something
>>> usual deal.
Not for dynamic variables. And almost never for regular C# values either.
    in the cabinet."
Subject: Re: C#
Date: 26 Aug 2012 12:45:38
Message: <503a52b2$1@news.povray.org>
> And you keep asserting that Haskell is a bad language, without much evidence
> either. :-P
No I didn't. I simply said a tiny elegant language where you can do
everything in libraries is usually not superior to a language designed for
the kind of coding you're doing.
It can't be as good at Erlang as what's built into Erlang. OK, granted,
Erlang may not be the best example, because it's a hacky kludge of a
language, but you know what I mean. Were Erlang not based on an interpreter
written in Prolog, taking the same concepts and building them into a
language (like Hermes or NIL perhaps) instead of having them as libraries is
superior.
Because when you write a library, you get inefficiencies, you get different
people using different libraries, you get non-portability, and you get weird
type sorts of things, and incompatibilities between libraries. No, really.
That's what happens. I used to be a big fan of these very meta languages
(and I still am), but it turns out that once they're too meta, every program
takes tremendously more study to understand and modify.
There's a reason that LISP, Tcl, and FORTH didn't really take off any more
than Haskell did.
> Likewise, C#.Net gives you access to the entire .Net platform library. This
> has vastly more functionality than what's available for Haskell. This is
> because C# is MORE POPULAR than Haskell, and NOT because Haskell is badly
> designed.
No. It's because C# and .NET are *explicitly designed* to provide access to
vast libraries.
> manages to solve the same problems that other languages can only solve using
> C# has methods and inheritance and subtype polymorphism and dynamic dispatch
> and delegates and lambda abstractions and broken multiple inheritance and
> reflection and... Haskell just has first-class functions. Solves all of the
> above, with a fraction of the complexity. It's simpler to explain, it's
> simpler to use, it's simpler to read. That's what I'm talking about.
And the problem comes when you look at the use of a first class function and
try to figure out what is happening with it. And methods, inheritance,
subtype polymorphism, and dynamic dispatch are all the same thing. Delegates
and lambda abstractions are all the same thing. So you're listing a whole
bunch of ideas that let you express exactly what you mean precisely, and say
"but they're all subsumed by this really general mechanism."
Basically, you're saying "we could use a very simple and straight-forward
Haskell language, and replace methods and inheritance and subtype
polymorphism and ... and access to vast libraries with libraries that take
functions as function. But then those libraries would not only be as
complicated as the features you're decrying(*), but they'd also vary from
program to program. You'd never know whether the library you're using has
the same semantics, because it's not part of the standard and just a library.
(*) Yes, they would be, because a specific functionality built into the
compiler and language are going to be simpler than a hand-crafted library in
source code trying to provide the same functionality on top of a generic base.
It would be like driving a car with a mouse and keyboard. There's a reason
that all those "features" are there, and that reason is that they let you
say what you mean, instead of building a structure that says what you mean.
Why do we have while loops, for loops, recursion, if statements, case
statements, if then elseif and else, when all we really need is an if and a
goto?
    in the cabinet."
Subject: Re: C#
Date: 26 Aug 2012 14:15:46
Message: <503a67d2$1@news.povray.org>
> library in source code trying to provide the same functionality on top
> of a generic base.
This is really the central thing I disagree with.
STM is implementable as an external 3rd party library. (I have
personally done this.) And yet, it works beautifully.
Just because something isn't hard-wired, doesn't mean it has to work
badly or be hard to use.
Subject: Re: C#
Date: 27 Aug 2012 07:33:43
Message: <503b5b16@news.povray.org>
> > wonderful.
> Uh, no.
What do you mean? Isn't *everything* in a pure OO language an object (that
can be inherited from and specialized)?
> > generics.
> languages.
I'm not sure the problem is any better in dynamically typed languages.
In a statically typed language you get an error at compile time if you
try to put an object of the wrong type in a container. In a dynamically
typed language you get an error at runtime when you try to use it. Is this
really "better"? I wouldn't say so.
> And Smalltalk
Don't forget Lisp.
Subject: Re: C#
Date: 27 Aug 2012 11:11:12
Message: <503b8e10$1@news.povray.org>
Am 26.08.2012 10:51, schrieb Orchid Win7 v1:
Nobody is asserting THAT.
What we're talking about is that Haskell, Erlang and C# are each good
languages for DIFFERENT types of problems.
Of course it manages to solve the same problems - after all, it's Turing
complete (it is, isn't it?) - and from all I've heard it is indeed a
very clean, simple language. All that's disputed is whether it solves
those same problems as developer-friendly and efficiently as those other
languages with a vast swathe of complicated hard-wired features.
Subject: Re: C#
Date: 27 Aug 2012 14:35:03
Message: <503bbdd7$1@news.povray.org>
>>> wonderful.
>> Uh, no.
It was the "and wonderful" I was referring to.
>>> generics.
>> languages.
Well, if you don't like dynamically typed languages, then generics seems to
be a decent solution. They didn't "discover the container problem then
invent generics."
>> And Smalltalk
> Don't forget Lisp.
None of which are particularly popular. Do you wonder why?
    in the cabinet."
Subject: Re: C#
Date: 27 Aug 2012 14:36:23
Message: <503bbe27$1@news.povray.org>
>> of a generic base.
> STM is implementable as an external 3rd party library. (I have personally
OK, now without changing the interface, make it work across process address
space boundaries. Make it work with machines across the network.
> Just because something isn't hard-wired, doesn't mean it has to work badly
> or be hard to use.
No. But just because it's simple and elegant doesn't mean it's easy to use,
either.
    in the cabinet."
Subject: Re: C#
Date: 27 Aug 2012 16:51:31
Message: <503bddd3$1@news.povray.org>
> address space boundaries. Make it work with machines across the network.
Did I not already post a link to the on-going project to do precisely
this? (It only "changes the interface" in that it exposes a way to say
where you want stuff computed.)
> use, either.
Sure. BASIC is a simple language. But it's the "wrong kind" of simple -
the kind of simple that makes everything wickedly hard to do. Finding
the right kind of simple? Well, that's pretty hard... But just throwing
lots and lots of "features" at the problems? That's not really a very
good solution.
Subject: Re: C#
Date: 27 Aug 2012 21:54:24
Message: <503c24d0$1@news.povray.org>
On 8/27/2012 13:51, Orchid Win7 v1 wrote:
> Did I not already post a link to the on-going project to do precisely this?
I don't know. Honestly, I don't really memorize every Haskell feature you
talk about. :-)
> Sure. BASIC is a simple language. But it's the "wrong kind" of simple - the
> kind of simple that makes everything wickedly hard to do. Finding the right
> kind of simple? Well, that's pretty hard... But just throwing lots and lots
> of "features" at the problems? That's not really a very good solution.
It depends on your goals for the language. If everything looks the same, it
can be very difficult to understand some piece of code. Every time I see a
declaration of an event in C#, I know exactly what it's for and how it
works. I'm not sure the same semantics would be any simpler if it was in a
library, and I'm pretty sure you'd wind up with multiple subtly different
implementations of the same ideas, in a way that wouldn't work together.
(Which is exactly what happened to every other such language, inclulding
LISP, Tcl, and FORTH.)
The advantage of having the "normal" stuff built in is that everyone tends
to use it in preference to one-off functionality in libraries.
For example, FORTH does not have directories, or even files. What's the
likelihood that you take a disk from one FORTH-like implementation and plug
it into another FORTH-like implementation and you'll be able to use it?
Remember that the vast amount of difficulty in software engineering in at
least the business world is the vast numbers of simple interactions with
other systems. My program (www.google.com/ads/agencyedge/) for example looks
simple. But it uses... let's see... at least nine languages off the top of
my head, interacts with 14 services that I know of, oh wait add another 10
or 12 just to run the damn thing and another five or six languages
describing where to run it and how to let people connect and such... It's
all pretty straightforward stuff. There's not a single thing out there I'd
call "an algorithm." No complex data structures. The hardest individual bit
of code I've worked out is a distributed processing queue that handles
failures of processes in progress, on top of a system that offers nothing
but atomic updates. But nevertheless, it's interacting with literally dozens
of custom servers (not even counting java libs, the kernel, etc.)  *That* is
the problem your language has to solve for it to not be a niche language.
    in the cabinet."
Subject: Re: C#
Date: 28 Aug 2012 04:29:54
Message: <503c8182$1@news.povray.org>
>>> And Smalltalk
>> Don't forget Lisp.
Ooo, I think I know this one... Is it because it requires people to
actually learn new ideas and concepts? Or because it isn't backwards
compatible with the massive legacy codebases that already exist?
Subject: Re: C#
Date: 28 Aug 2012 04:34:02
Message: <503c827a@news.povray.org>
That different languages solve different problems are hardly a
contentious assertion - more like a verified FACT.
What I take issue with is the claim that for a language to be useful for
anything it MUST be complex and badly designed.
Subject: Re: C#
Date: 28 Aug 2012 08:27:04
Message: <503cb918@news.povray.org>
> >> And Smalltalk
> > Don't forget Lisp.
They are too awesome to be handled by mere mortals?
Subject: Re: C#
Date: 28 Aug 2012 08:35:57
Message: <503cbb2d$1@news.povray.org>
>>>> And Smalltalk
>>> Don't forget Lisp.
Thanks for filling my daily LOLs quota. :-D
Subject: Re: C#
Date: 28 Aug 2012 11:22:51
Message: <503ce24b$1@news.povray.org>
>> >> And Smalltalk
>> > Don't forget Lisp.
When I was at uni, we had an 'intelligent' air traffic control program we
were working on.  The first version was written on a machine that used
lisp as its shell interface - and you could do weird things like reverse
the direction the instruction pointer ran using a CLI script written in
Lisp.
Wish I could remember what the machine was.  It wasn't very fast (this
was in the 1989-1991 timeframe), but it was pretty amazing tech.
Jim
Subject: Re: C#
Date: 28 Aug 2012 12:01:37
Message: <503ceb61$1@news.povray.org>
> Lisp.
Probably one of the various "Lisp machines", I should think... I gather
there were similar systems powered by Smalltalk.
At uni, we used Smalltalk VisualWorks(tm). The entire environment is
written in Smalltalk. Which means that with a few simple variable
assignments, you could TOTALLY SCREW THE SYSTEM. The canonical example is
   Smalltalk := nil.
This causes all the windows to stop repainting and the mouse pointer to
disappear. The only solution is to terminate the process via Task Manager.
In a less stupid note, one time I was writing an application, and it had
various "components". Each component is implemented by a class, and I
tried to add a #name method to return the name of the component...
...oh dears. Yeah, it turns out that Class already *has* a method named
#name. And by overriding it, I made the system do some *weird* crap...
It took me ages to figure out what the hell has happening.
A bit like the time I had a method that returns an array constant. It
turns out it isn't actually constant. So if you mutate the array, you
now have a method that /appears/ to return one thing, and /actually/
returns something completely different. (Until you reload the source
code from disk...)
Mutable state is evil. :-P
Subject: Re: C#
Date: 29 Aug 2012 11:21:51
Message: <503e338f$1@news.povray.org>
On 8/28/2012 1:29, Invisible wrote:
> Is it because it requires people to actually learn new ideas and concepts?
Nope!  Remember, everyone has to learn new ideas and concepts for their
first language.  People who learned assembler have to learn new ideas for
Java, as do people who know C already. Javascript has lots of new ideas and
it's quite popular.
> Or because it isn't backwards compatible with
Again, no. Remember that LISP predates COBOL and C++ and probably even C.
All of that predates Java and Javascript.
    in the cabinet."
Subject: Re: C#
Date: 29 Aug 2012 11:23:17
Message: <503e33e5$1@news.povray.org>
Nobody is claiming that.
    in the cabinet."
Subject: Re: C#
Date: 29 Aug 2012 11:29:04
Message: <503e3540$1@news.povray.org>
...and yet, 200-post newsgroup thread... :-P
Subject: Re: C#
Date: 29 Aug 2012 11:30:05
Message: <503e357d$1@news.povray.org>
>> concepts?
> first language.
Sure. But the vast majority of programmers already know how to write
imperative code. Learning a fundamentally new way of structuring stuff
is no small feat.
> C. All of that predates Java and Javascript.
Remember also that Lisp never actually became popular...
Subject: Re: C#
Date: 29 Aug 2012 11:34:37
Message: <503e368d$1@news.povray.org>
Am 29.08.2012 17:21, schrieb Darren New:
With COBOL predating C by a dozen years or so, yes - if LISP predates
COBOL it /obviously/ predates C as well ;-)
(According to Wikipedia, LISP indeed predates COBOL by one year.)
Subject: Re: C#
Date: 31 Aug 2012 19:53:28
Message: <50414e78$1@news.povray.org>
>>> concepts?
>> first language.
> imperative code. Learning a fundamentally new way of structuring stuff is no
> small feat.
True, but irrelevant to the point being made.
Exactly the point being made, but you seem to have missed that.
    in the cabinet."
Subject: Re: C#
Date: 31 Aug 2012 19:55:53
Message: <50414f09$1@news.povray.org>
> With COBOL predating C by a dozen years or so, yes - if LISP predates COBOL
Right. Which means LISP, as elegant as it is, did not fail due to a lack of
backward compatibility, which is the point I'm making.
    in the cabinet."
Subject: Re: C#
Date: 1 Sep 2012 03:51:09
Message: <5041be6d$1@news.povray.org>
My point is, for whatever reason, C-like languages became mainstream.
Thus, these are the languages that everybody is used to, these are the
languages that legacy code is written in, these are the languages that
there are books about and courses for, these are the languages that have
extensive libraries and tool support, etc.
In short, if you design a language which is /not/ C-like, it's going to
be quite difficult for it to be popular. Regardless of how good the
actual language design it, all of the factors above work against you.
Now, it depends just /how/ different your new language is. I'm not
really sure why Lisp never took off; I'm going to go with "historical
accident". (Back when Lisp was around, computing power was extremely
scarce, and you couldn't possibly waste it by using a language that is
even slightly inefficient. That probably put a lot of people off.) The
various OO languages have done quite well, presumably because once you
understand imperative and structured programming, OO is reasonably easy
to assimilate.
Of course, there are factors other than language design in play. Java is
a very mainstream language. Eiffel is an OO language like Java, but with
a vastly superior design. In my limited experience, nobody has even
/heard/ of Eiffel. Maybe it's because there isn't a huge multi-billion
dollar corporation behind it. Maybe it's because there are really only
two extant Eiffel compilers, one of which is commercial and extremely
expensive. I don't know. What I /do/ know is that if you want a C
compiler, you can find one for almost every platform on Earth which
could be described as a "personal computer", and many others besides.
How many of these platforms have Java compilers? Quite a few. How many
have Eiffel compilers? Uh... not many.
(How many have a Haskell compiler? Well, let's see... MS Windows, Apple
Mac OS X and later, hypothetically anything that runs Linux... but only
hypothetically...)
Of course, in the case of Haskell, if you already know how to write C,
the learning curve is pretty vertical, and there is minimal written
material to help you on your journey. (And what exists is mostly out of
date now.) I guess it's a bit like Linux 10 years ago. Only the hardcore
need apply. Only time will tell if that ever changes...
I still do not agree that a language must be badly designed to be
popular. Rather, it seems to me that all the languages that turned out
to be popular are so for reasons other than just language design.
Subject: Re: C#
Date: 1 Sep 2012 14:11:48
Message: <50424fe4$1@news.povray.org>
Right. And you should be asking yourself, given that the competition was C,
COBOL, Fortran, Assembler, and Lisp, why it is that Lisp is the only
language that never really persisted.
> In short, if you design a language which is /not/ C-like, it's going to be
> quite difficult for it to be popular. Regardless of how good the actual
Unless it's so orthogonal in capabilities to what C offers, yes.
> Now, it depends just /how/ different your new language is. I'm not really
> sure why Lisp never took off; I'm going to go with "historical accident".
There are other arguments. For example, LISP is so powerful that nobody ever
really needed to build up a standard library like you see in Java and C#,
and therefore everybody wound up reinventing events, OOP, complex data
structures, etc etc etc.  Kind of like the same reason nobody programs to
raw X-Windows, even though it's much more flexible than using widget sets.
> imperative and structured programming, OO is reasonably easy to assimilate.
I'd say more because it's an excellent fit for some kinds of very popular
problems, while putting little in the way of those who need a different
paradigm.
> Of course, there are factors other than language design in play. Java is a
> very mainstream language. Eiffel is an OO language like Java, but with a
> vastly superior design. In my limited experience, nobody has even /heard/ of
> Eiffel. Maybe it's because there isn't a huge multi-billion dollar
> corporation behind it. Maybe it's because there are really only two extant
> Eiffel compilers, one of which is commercial and extremely expensive. I
> don't know.
The lack of libraries is a killer too. You can no longer create a language
that expects to be in its own little world without even a GUI language and
expect it to fly.
> I still do not agree that a language must be badly designed to be popular.
> Rather, it seems to me that all the languages that turned out to be popular
Exactly. Yet if you create a brand new language that's not tremendously
*more* productive in your chosen niche(*), then you've tossed away all the
libraries, including conceptual library designs(+), that everyone else has
already proven works.
(*) See, for example, Erlang, which succeeded because it's tremendously more
productive in its niche (high-reliability computing) than its competitors.
Or SQL.
(+) Conceptual library designs like threads, networking, data structures,
GUI design, etc. You have to reimplement them for every language, but if you
see a Thread class with a run() method and a wait() method and a notify()
method, you pretty much don't have to read the documentation to know how to
use threads.
    in the cabinet."
