POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
28 Jul 2026 19:53:55 EDT (-0400)
  Teach yourself C++ in 21 days (Message 61 to 70 of 168)
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 19 Apr 2012 13:08:09
Message: <4f904679@news.povray.org>
Francois Labreque escreveu:
>>> in any case, even humble C can do that, provided a Makefile is ready.
>>> heck, Makefiles are language-agnostic even...
>> Makefiles only work on Unix. :-P But hey, you can write a simple script
>> to build your project under Windows.
> WAT?
> http://gnuwin32.sourceforge.net/packages/make.htm
> http://msdn.microsoft.com/en-us/library/dd9y37ha%28VS.71%29.aspx
>> The /real/ problem, of course, is that you have to open a command
>> window, CD to the right folder, and type in "make program1" or whatever.
>> This takes significantly longer than pressing F7 (or whatever).
> Which you only have to do once... After that you only need to hit
> ALT-TAB and the up arrow.
>> Heck, KDevelop lets you have the terminal window embedded right there in
>> the text editor, and it /still/ takes longer switching back and forth
>> between windows than it would to just jab a key.
> Starting notepad++ and a command prompt take significantly less time
> than starting any IDE.  So you still have quite a few
> "F7-is-faster-than-alt-tab" to do before you catch up...
>>>> - Easily launch your application.
>>> like ./out ?
>> Sure, once you take your hands off the keyboard and onto the mouse to
>> switch from the text editor window to the command prompt window. :-P
> As mentioned previously,  ALT-TAB.  Much faster - and a lot easier on
> your elbow and shoulder tendons - than lifting your right hand going
> over the numeric keypad and using the mouse.
thank you ?)
Date: 19 Apr 2012 13:14:29
Message: <4f9047f5@news.povray.org>
Invisible escreveu:
> But as I say, a tiny amount of shell scripting will automate most tasks,
> without the need for Make.
yes.  It's easy to rewrite Make from scratch for your every projects.
BTW, do your scripts handle automatic compilation of only the parts that
were last updated?
> That works great - /until/ your command history has more than one
> command in it. E.g., if you use the same window to run the compiler, run
> the main program, and control your SCM. Then you end up jabbing up-arrow
> endlessly, or executing the wrong command, or both. Very annoying.
ctrl+Rghc
ctrl+Rmain
etc
oh, sorry.  Forgot you use a lameass DOS command prompt...
> (I wonder why nobody has yet thought of making an editor where you can
> add buttons to the toolbar and kind arbitrary commands to them? You
> could even give them keyboard shortcuts...)
emacs can do that.  And any decent text editor allows you to bind some
keyboard shortcut to some command.
>> As mentioned previously, ALT-TAB. Much faster.
> And if in the middle of your coding session, you quickly switch to your
> email client to check something, next time you try to use Alt+Tab, it
> takes you to the wrong window.
it`s much easier when you it all on the command-line. ;)
a game sig: http://tinyurl.com/d3rxz9
Date: 19 Apr 2012 15:10:47
Message: <4f906337$1@news.povray.org>
On 19/04/2012 06:14 PM, nemesis wrote:
> Invisible escreveu:
>> tasks, without the need for Make.
> were last updated?
No, my compiler does that. :-P
Besides, compiling the entire thing takes less than 400 ms. Why would I
care about speeding up compilation?
There's a DOS command prompt that /isn't/ lame?
> emacs can do that.
Emacs doesn't even have a GUI yet. :-P
I've yet to find one, but OK.
>> your email client to check something, next time you try to use
>> Alt+Tab, it takes you to the wrong window.
Yeah. That way you can't look at more than one file at once. Oh, wait...
Date: 19 Apr 2012 15:32:29
Message: <4f90684d@news.povray.org>
Orchid Win7 v1 escreveu:
>> were last updated?
so, all your programs are some monolithic piece of software with all
parts compiled in one go?
No, but there's at least powershell, which is lame *and* heavy.
>> emacs can do that.
it's GUI is useful enough to have buttons per-mode and to write a web
browser for.
you should look at any editor aside notepad.
you're nuts.  Any decent editor has support for several file buffers.
You may navigate them through with file buffer lists or tag files...
Date: 19 Apr 2012 15:56:16
Message: <4f906de0$1@news.povray.org>
>>> were last updated?
Yes. Why?
To be fair, SciTE allows you to define what F5, F7 and Ctrl+F7 do. (But
only once per file-extension.) Sadly it doesn't let you do "when I press
F7, compile THAT file, not the file I'm currently editing".
Any decent GUI-mode text editor, yes. On the a text terminal, you can't
do that.
(Correction: Emacs can do it. And it looks awful.)
Subject: Re: Day 6
Date: 19 Apr 2012 16:23:11
Message: <4f90742f$1@news.povray.org>
On 18/04/2012 12:17 PM, Warp wrote:
>    If you want to read something actually useful about C++, try the
> "Effective" book series by Scott Meyers (or at the very least "Effective
> C++" and "More Effective C++"). They actually contain some competent and
> easy to understand information.
>    "Effetive STL" is probably also good.
I had a look at Effective C++ on Amazon. They let you look at a handful
of pages before you buy it. By doing so, I already learned more about
C++ in a few pages than anything the naff book I'm currently reading
taught me.
On the other hand, it appears to be aimed at people who already know the
C++ language. That isn't really me, yet. I know some of the syntax, but
certainly not all of it, or what all of it actually does.
I'll see what kind of prices I can find for it...
Date: 19 Apr 2012 16:31:36
Message: <4f907628@news.povray.org>
>>>> that
>>>> were last updated?
> Yes. Why?
because it's both wrong and dumb.
yeah, while we're at it, it should also guess that THAT file is the
right file you have in mind...
> do that.
emacs, vi, pico etc...
it may look awful, but it behaves great.  Ever heard "don't judge a book
by its cover"?
Date: 19 Apr 2012 16:54:07
Message: <4f907b6f$1@news.povray.org>
>> Yes. Why?
That's right up there with saying that Haskell is better than C because
C is both wrong and dumb. Yeah, it's true, but it won't convince anybody...
>> (But only once per file-extension.) Sadly it doesn't let you do "when
>> I press F7, compile THAT file, not the file I'm currently editing".
How hard would it be to allow each directory to contain a file saying
what commands each key should be bound to? Or a text box to let you
change it just for this session? Or *something*...
>> can't do that.
> by its cover"?
The whole point of a text editor is for looking at text. Why make it
look awful when you can make it look good? Why make your job harder when
you can make it easier?
Date: 19 Apr 2012 18:13:31
Message: <4f908e0b@news.povray.org>
>>> Yes. Why?
The time of monolithic pieces of software is long buried in the past.
Today it's all composable by hundreds of small libs, perhaps even loaded
at runtime.  Ever even heard of web mashups?  Application servers?
well, ok, for sufficiently small toy applications and scripts,
monolithic is good enough.
with a Makefile file in each directory each time you press make on the
command-line it makes that part. ;)
>>> can't do that.
>> by its cover"?
no, the whole point of a text *editor* is for *editing* text.
> Why make it
Nobody is making it look awful.  But between spending time making it
look good and do nothing and looking awful and doing a shitton of stuff,
you know what open-source developers will do...
plus, looking awful does not your job harder.  On the contrary:  in my
experience the most beautiful-looking text editors out there are usually
the most featureless and useless there are.  Why implement features that
will make it complex and awful-looking?  Better just have a simple
interface and when the user wants to copy the next 5 long paragraphs and
paste them 5 times they should do it manually by constant repetition of
the basic, beautiful and simple mechanisms, rather than just typing
y5}5p... clearly the latter is making your job far harder!
Subject: Re: Days 1-5
Date: 19 Apr 2012 20:57:11
Message: <4f90b467@news.povray.org>
On 4/17/2012 1:52, Invisible wrote:
> Except that assembly generally follows a simple and consistent syntax,
... says the man who never programmed in an assembly language for machines
designed to be programmed in assembly language.
> an "obscure feature" which you don't need to know about. :-P
It *is* outside the C standard, tho, in terms of what it "means".
> I dislike code that's so littered with comments that you can't see the code
Except in assembler.
> That's pretty messed up.
Why is it messed up? Ada even has a type for "one byte of memory" and a
different type for "one byte of I/O".  You might read 8-bit strings from an
I/O channel into 9-bit memory.
>> One warning: sizeof() will return the size in char, not bytes.
> Oh, that's fun. Let us hope that char *is* one byte, otherwise... damn!
Nah. There's a header file that tells you how many bits per byte. I'm pretty
sure C assumes binary computers, tho. :-)
> I guess this is why autoconf exists. :-P
That and amongst many, many, *many* other reasons. Note that C isn't a
portable language. It just lets you stick many versions of the source code
into one file.
>> Second warning: the signedness of char is local to the compiler.
> Really? The book seems to say that all integer types default to signed,
> unless you request unsigned. (AFAIK, there isn't a way to request signed.)
Except characters. Because PDP-11.
> So much for C and C++ being for system-level programming. :-P
It was never very *good* for it. It was just better than its competitors of
the time.
> microcontroller, I might be worried. On a desktop PC, I'm not too concerned.
Now, yeah. Note that IEEE standardized floating point *long* after C was
around. Heck, even after x86 was around IIRC.
>> Usually, float is a 32 bits, double is 64 bits. But it is known that
>> some compiler would perform the computation on 80 bits registers...
> Is there a way to explicitly request 80 bits?
No, of course not. C doesn't provide any way to ask for a type based on what
you need. You can only ask for types based on what the CPU provides, and
header files to tell you what the CPU provides so you can write code to try
to compile the right version. In Ada, in contrast, you'd say "give me the
float with X range and Y precision."
> Right. So if I request a 2GB array, it won't actually sit there trying to
> zero all 2GB of RAM, right before my for-loop rolls over it to initialise it
> /again/.
The OS probably will, tho, if you have a multi-user OS.
> So, it always rounds downwards?
It might depend on the sign. Two positive integers always rounds down.
> Oh that's sick. So comma really /is/ an operator? Wow, that's evil.
Why? It's just an operator. Is it really worse than Haskell's "." or ">=="
operators, or whatever they're called?
> I was referring more to the fact that it's legal to not specify the return
> type, and if you don't, it defaults to something absurd.
It defaults to integer. Not sure what makes that "absurd".
>>> Next, we learn that function arguments can have default values. But get
>>> this:
>>> "Any or all of the function's parameters can be assigned default
>>> values. The one restriction is this: If any of the parameters does not
>>> have a default value, no previous parameter may have a default value."
>>> ...um, what?
>> At one point in the argument list, you must start providing default
>> values, for all argument at the right of that point.
> ...which makes infinitely more sense than what the book said. :-P
Really!?  What the book said was clearly and simply a mathematical-type
statement. No parameter without defaults can be preceeded by one with
defaults. Hence all defaults must come after all non-defaults.
The previous statement is inaccurate in that it does not take into account
no-defaults and all-defaults.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
