POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
30 May 2026 23:12:56 EDT (-0400)
  Teach yourself C++ in 21 days (Message 59 to 68 of 168)
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 19 Apr 2012 09:00:44
Message: <4f900c7c$1@news.povray.org>
>> in any case, even humble C can do that, provided a Makefile is ready.
>> heck, Makefiles are language-agnostic even...
> Makefiles only work on Unix. :-P But hey, you can write a simple script
> to build your project under Windows.
WAT?
http://gnuwin32.sourceforge.net/packages/make.htm
http://msdn.microsoft.com/en-us/library/dd9y37ha%28VS.71%29.aspx
> The /real/ problem, of course, is that you have to open a command
> window, CD to the right folder, and type in "make program1" or whatever.
> This takes significantly longer than pressing F7 (or whatever).
Which you only have to do once... After that you only need to hit
ALT-TAB and the up arrow.
> Heck, KDevelop lets you have the terminal window embedded right there in
> the text editor, and it /still/ takes longer switching back and forth
> between windows than it would to just jab a key.
Starting notepad++ and a command prompt take significantly less time
than starting any IDE.  So you still have quite a few
"F7-is-faster-than-alt-tab" to do before you catch up...
>>> - Easily launch your application.
>> like ./out ?
> Sure, once you take your hands off the keyboard and onto the mouse to
> switch from the text editor window to the command prompt window. :-P
As mentioned previously,  ALT-TAB.  Much faster - and a lot easier on
your elbow and shoulder tendons - than lifting your right hand going
over the numeric keypad and using the mouse.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 19 Apr 2012 09:21:54
Message: <4f901172$1@news.povray.org>
> WAT?
To tell you the truth, I don't even /like/ Make all that much. (I think
it's the tab characters. Or the slightly clunky way it deals with
targets that aren't files.) I only really use it for building C, because
it's either that or work out how to invoke the compiler manually...
But as I say, a tiny amount of shell scripting will automate most tasks,
without the need for Make.
That works great - /until/ your command history has more than one
command in it. E.g., if you use the same window to run the compiler, run
the main program, and control your SCM. Then you end up jabbing up-arrow
endlessly, or executing the wrong command, or both. Very annoying.
(I wonder why nobody has yet thought of making an editor where you can
add buttons to the toolbar and kind arbitrary commands to them? You
could even give them keyboard shortcuts...)
Depends on the IDE. Some are slower than others. I do take your point
though - some of them do take an absurd amount of time to start. Then
again, "you only do that once". :-P
> As mentioned previously, ALT-TAB. Much faster.
And if in the middle of your coding session, you quickly switch to your
email client to check something, next time you try to use Alt+Tab, it
takes you to the wrong window.
It sounds trivial, but it's really very, very annoying.
(It becomes even more fun when what you're working on involves more
windows. E.g., right now I'm writing some TeX, so I have my text editor
open, my command window open, and my DVI window open. You can 100%
guarantee that almost every time I change window I change to the wrong
one...)
Date: 19 Apr 2012 13:08:09
Message: <4f904679@news.povray.org>
Francois Labreque escreveu:
> WAT?
>>> like ./out ?
thank you ?)
Date: 19 Apr 2012 13:14:29
Message: <4f9047f5@news.povray.org>
Invisible escreveu:
yes.  It's easy to rewrite Make from scratch for your every projects.
BTW, do your scripts handle automatic compilation of only the parts that
were last updated?
ctrl+Rghc
ctrl+Rmain
etc
oh, sorry.  Forgot you use a lameass DOS command prompt...
emacs can do that.  And any decent text editor allows you to bind some
keyboard shortcut to some command.
it`s much easier when you it all on the command-line. ;)
a game sig: http://tinyurl.com/d3rxz9
Date: 19 Apr 2012 15:10:47
Message: <4f906337$1@news.povray.org>
On 19/04/2012 06:14 PM, nemesis wrote:
> Invisible escreveu:
>> tasks, without the need for Make.
> were last updated?
No, my compiler does that. :-P
Besides, compiling the entire thing takes less than 400 ms. Why would I
care about speeding up compilation?
There's a DOS command prompt that /isn't/ lame?
> emacs can do that.
Emacs doesn't even have a GUI yet. :-P
I've yet to find one, but OK.
>> your email client to check something, next time you try to use
>> Alt+Tab, it takes you to the wrong window.
Yeah. That way you can't look at more than one file at once. Oh, wait...
Date: 19 Apr 2012 15:32:29
Message: <4f90684d@news.povray.org>
Orchid Win7 v1 escreveu:
>> were last updated?
so, all your programs are some monolithic piece of software with all
parts compiled in one go?
No, but there's at least powershell, which is lame *and* heavy.
>> emacs can do that.
it's GUI is useful enough to have buttons per-mode and to write a web
browser for.
you should look at any editor aside notepad.
you're nuts.  Any decent editor has support for several file buffers.
You may navigate them through with file buffer lists or tag files...
Date: 19 Apr 2012 15:56:16
Message: <4f906de0$1@news.povray.org>
>>> were last updated?
Yes. Why?
To be fair, SciTE allows you to define what F5, F7 and Ctrl+F7 do. (But
only once per file-extension.) Sadly it doesn't let you do "when I press
F7, compile THAT file, not the file I'm currently editing".
Any decent GUI-mode text editor, yes. On the a text terminal, you can't
do that.
(Correction: Emacs can do it. And it looks awful.)
Subject: Re: Day 6
Date: 19 Apr 2012 16:23:11
Message: <4f90742f$1@news.povray.org>
On 18/04/2012 12:17 PM, Warp wrote:
>    If you want to read something actually useful about C++, try the
> "Effective" book series by Scott Meyers (or at the very least "Effective
> C++" and "More Effective C++"). They actually contain some competent and
> easy to understand information.
>    "Effetive STL" is probably also good.
I had a look at Effective C++ on Amazon. They let you look at a handful
of pages before you buy it. By doing so, I already learned more about
C++ in a few pages than anything the naff book I'm currently reading
taught me.
On the other hand, it appears to be aimed at people who already know the
C++ language. That isn't really me, yet. I know some of the syntax, but
certainly not all of it, or what all of it actually does.
I'll see what kind of prices I can find for it...
Date: 19 Apr 2012 16:31:36
Message: <4f907628@news.povray.org>
>>>> that
>>>> were last updated?
> Yes. Why?
because it's both wrong and dumb.
yeah, while we're at it, it should also guess that THAT file is the
right file you have in mind...
> do that.
emacs, vi, pico etc...
it may look awful, but it behaves great.  Ever heard "don't judge a book
by its cover"?
Date: 19 Apr 2012 16:54:07
Message: <4f907b6f$1@news.povray.org>
>> Yes. Why?
That's right up there with saying that Haskell is better than C because
C is both wrong and dumb. Yeah, it's true, but it won't convince anybody...
>> (But only once per file-extension.) Sadly it doesn't let you do "when
>> I press F7, compile THAT file, not the file I'm currently editing".
How hard would it be to allow each directory to contain a file saying
what commands each key should be bound to? Or a text box to let you
change it just for this session? Or *something*...
>> can't do that.
> by its cover"?
The whole point of a text editor is for looking at text. Why make it
look awful when you can make it look good? Why make your job harder when
you can make it easier?
