POV-Ray : Newsgroups : povray.off-topic : Git Server Time
10 Apr 2026 22:03:15 EDT (-0400)
  Git (Message 1 to 10 of 51)
Subject: Git
Date: 10 Apr 2012 08:55:16
Message: <4f842db4$1@news.povray.org>
My version control system of choice is Darcs. But obviously nobody
actually uses that. I gather a number of people do use Git, however. And
NetBeans has Git capabilities built-in.
I did look to see where it installs the Git binaries. It doesn't. It
uses JGit, a complete reimplementation of Git in Java. (This makes me
nervous... How do we know the two implementations work the same way?)
So anyway, I downloaded the /real/ Git implementation, which comes with
some visualisation tools. (NetBeans does a really useless job of showing
you the current state of your repository. It shows you the ID of the
current commit and that's about it.)
I had another look over "Understanding Git"
http://www.eecs.harvard.edu/~cduan/technical/git/
If I'm understanding this correctly, history is stored as commit
objects, which one storing the complete state of the entire codebase,
plus the IDs of its ancestor commit(s). The "branches" or "heads"
themselves are merely bookmarks into this tree of commits. They let you
conveniently get from place to place and label your stuff, but you can
create new ones or destroy existing ones at will. The commits themselves
are the actual history.
So far, that understanding hasn't caused me too many problems. And I
quite like the way that a single repository holds multiple branches.
Darcs follows an "every repository /is/ a branch" mentality. Which
works, but makes it kinda long-winded to change branches. In NetBeans, I
can click "switch branch" and all my code suddenly changes.
OTOH, it's irritating to have to switch branches, click "merge
revision...", select the branch I was just on, and then switch back
again every single time I want to update one branch to match another. I
imagine this is a limitation of the NetBeans, and if I used Git directly
there would be a command to immediately update a branch without actually
switching to it.
One extremely irritating issue is that it's apparently impossible to
create a commit object of a completely empty repository. So there can
never be a branch where you start again from scratch. Every branch must
always start out with /something/ in it. I suppose I could just create a
dummy file to create commit 0, and then delete it again. But it's
irritating.
Rather /more/ irritating is this: I made a commit, and then realised the
description was wrong. (NetBeans defaults to using the exact same
description as the previous commit - because that's SO USEFUL, right?)
So I looked for the command to undo the last commit. Apparently there
isn't one. I even found a question on Stack Overflow about it. Lots of
people suggesting various complex workarounds to try to solve it, but
nothing that says "just delete the last commit object!"
Using the GUI, I was able to create a /new/ commit object identical to
the old one but with a different description. The old commit object is
still there though, showing up is a dangling branch. And I cannot find
any way to get rid of it. It's all very annoying.
(I could mutter something about how in Darcs this problem takes about 15
seconds to fix... But what would that prove?)
One mildly niggling thing is that Git imposes an artificial order on
things. Like, with Darcs, if I edit file X, and then make some
completely unrelated change to file Y, then as far as Darcs is
concerned, there is no ordering relation between these unrelated
changes. But to Git, one commit is descended from the other, even though
there's no logical relationship.
Conversely, with Darcs, if I edit file X to add a new function, and then
edit file Y to /use/ that new function, then Darcs doesn't see any
relationship, but there /is/ one, and Darcs' idea that the two changes
are unrelated is flat-out wrong. Then again, shouldn't you be recording
those two changes in the same commit?
The way Git does things does have the advantage that a situation like
this just never happens. On the other hand, if I change file X on one
branch and file Y on another branch (so the changes are /definitely/
unrelated), you still have to "merge" the changes to get back to a
single branch. To Darcs, this would just be adding in a few more
changes. Still, it seems to /work/ just fine, so who's complaining?
All of this stuff gets /much/ easier to follow with gitk to show me WTF
is actually happening. Unfortunately, Git seems to be a Unix
application, meaning that you cannot install it without first installing
a Unix emulator. The default installer binary seems to install MSYS,
including Bash, Perl, Tk, and a whole bunch of other stuff. *sigh*
Subject: Re: Git
Date: 10 Apr 2012 11:08:35
Message: <4f844cf3$1@news.povray.org>
> switching to it.
Another irritating thing is that creating a new branch does not /switch
to/ that branch. Just now I created a new branch, did a commit, and then
realised it updated the old branch, not the new one.
Fortunately, since a "branch" is simply a bookmark, all I need to do is
wind the new branch forward and wind the old one backwards.
Unfortunately, NetBeans can wind a branch forward, but cannot easily
wind backwards. Fortunately gitk can, but then NetBeans is confused,
until I switch branches back and forth a few times.
Damn that was irritating! LOL.
Subject: Re: Git
Date: 10 Apr 2012 14:17:23
Message: <4f847933$1@news.povray.org>
Le 10/04/2012 14:55, Invisible nous fit lire :
Trick learned from mercurial (hg): always work on a secondary repository
(not the "reference" one). Even better, a tertiary or deeper one.
If you did a wrong commit on the secondary, instead of pushing back
(well, its "git push" !)  to the parent, just delete it and start over
(you might keep your delta first with some patch-compatible commands, so
as to reply them automatically: "hg diff" is very useful, i guess there
is some version for git too)
Basic of distributed revision control: as long as you did not export
your commit, you can hide your fault by just deleting the whole issue.
Once exported, you're doomed.
(Well, there is a few extension in hg to move/rewrite commits (even
regroup a few one), but they work only as far as the repositories which
know the details are erased from existence in order to never provide the
original pieces of information again)
As they say: Mount a scrap monkey!
Subject: Re: Git
Date: 10 Apr 2012 14:52:36
Message: <4f848174$1@news.povray.org>
>> isn't one.
Presumably you could just delete the .git subfolder and recopy... oh
wait, you're supposed to do git clone, aren't you? I wonder if that does
anything extra beyond just copying the files...
Well, yes. Once it's public, it's part of history. And then if you want
to change it, you must rewrite history. Which isn't easy...
Subject: Re: Git
Date: 10 Apr 2012 15:05:49
Message: <4f84848d$1@news.povray.org>
Invisible escreveu:
the understatement of the year!  well, since it's Andrew, perhaps just
of the month, we'll see...
It's now all around us.  Plus, it's a cool word.  I hope Gimp uses Git. :)
way to go!
You know git was written as a reverse engineering of the proprietary cvs
the Linux kernel project was using at some point, right?
a game sig: http://tinyurl.com/d3rxz9
Subject: Re: Git
Date: 10 Apr 2012 15:38:27
Message: <4f848c33@news.povray.org>
Le 10/04/2012 20:52, Orchid Win7 v1 nous fit lire :
Lesson learned a long time ago: never try to be smarter by going in the
backstage. Just play fair, respect the rules.
(of course, as you become a wizard, the limit of the backstage moves)
Subject: Re: Git
Date: 10 Apr 2012 15:56:09
Message: <4f849059$1@news.povray.org>
Indeed. This definitely works with Darcs. But I'm not sure if it works
for Git. I don't see why it wouldn't, but you never know...
Subject: Re: Git
Date: 10 Apr 2012 16:02:40
Message: <4f8491e0$1@news.povray.org>
On 10/04/2012 08:05 PM, nemesis wrote:
> Invisible escreveu:
It's only April.
A number of people use Git. A number of others use RCS, CVS, Subversion,
Mercurial, BitKeeper, Bazaar, Perforce, Visual Source Safe...
(Hell, there are even large projects which use Darcs. Though the main
one, GHC, recently switched to Git. It is unclear to me whether this is
because Darcs wasn't good enough, or just because all the would-be
contributers use Git not Darcs.)
Subject: Re: Git
Date: 10 Apr 2012 21:15:25
Message: <4f84db2d@news.povray.org>
On 4/10/2012 12:05, nemesis wrote:
> You know git was written as a reverse engineering of the proprietary cvs the
Are you sure? I thought it was written to replace the reverse engineering of
the proprietary cvs?
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Subject: Re: Git
Date: 10 Apr 2012 21:26:57
Message: <4f84dde1@news.povray.org>
Given thatall objects in the repository are looked up by the cryptographic
hash of their contents, the whole thing would fall apart if they weren't.
That said, the git book extensively documents the format of the repository,
which is completely trivial in practice. So... it's not hard.
> If I'm understanding this correctly, history is stored as commit objects,
Basically, yes.
Try this: http://book.git-scm.com/
It's excellent. (If it's the one I remember, which I think it is.)
> OTOH, it's irritating to have to switch branches, click "merge revision...",
> select the branch I was just on, and then switch back again every single
> time I want to update one branch to match another. I imagine this is a
> limitation of the NetBeans, and if I used Git directly there would be a
> command to immediately update a branch without actually switching to it.
Yes. Or you'd write a shell script. :-)
> One extremely irritating issue is that it's apparently impossible to create
> a commit object of a completely empty repository. So there can never be a
> branch where you start again from scratch. Every branch must always start
> out with /something/ in it. I suppose I could just create a dummy file to
> create commit 0, and then delete it again. But it's irritating.
Your commit has to point to a tree (aka directory). But you can start a
repository with an empty directory.  If you manipulate things with the
lower-level commands, you can stick stuff in the repository without any
commits at all. (Which is how "commit" creates a commit - it puts the things
in the repository, then points a commit at them.)
> description as the previous commit - because that's SO USEFUL, right?) So I
> looked for the command to undo the last commit. Apparently there isn't one.
You can only add to the repository, unless you prune it. But that doesn't
mean you need to see it.
http://stackoverflow.com/questions/927358/git-undo-last-commit
> I even found a question on Stack Overflow about it. Lots of people
> suggesting various complex workarounds to try to solve it, but nothing that
Uh, pretty much the first hit on google for "git revert commit."
> Using the GUI, I was able to create a /new/ commit object identical to the
> old one but with a different description. The old commit object is still
> there though, showing up is a dangling branch. And I cannot find any way to
"git gc" with the appropriate options to prune.
It proves that Darcs isn't too worried about losing commits? ;-)
> One mildly niggling thing is that Git imposes an artificial order on things.
> Like, with Darcs, if I edit file X, and then make some completely unrelated
> change to file Y, then as far as Darcs is concerned, there is no ordering
> relation between these unrelated changes. But to Git, one commit is
> descended from the other, even though there's no logical relationship.
Git doesn't store changes. It stores snapshots. The order isn't so much
artificial as irrelevant to what you happen to be doing right now.
> Then again, shouldn't you be recording those
Heavens no!
> The way Git does things does have the advantage that a situation like this
> just never happens. On the other hand, if I change file X on one branch and
> file Y on another branch (so the changes are /definitely/ unrelated), you
> still have to "merge" the changes to get back to a single branch.
Which makes sense. Commits are the fundamental unit of atomic change in git.
Now you have a snapshot with X changed, a different snapshot with Y changed,
and a snapshot with the two changes together. What could be easier?
    in the cabinet."
