>> /Windows/ doesn't support it? Or just that every 3rd-party
> Maybe it's just so clunky for devlopers to support it they don't bother?
I don't know. I haven't looked into this sort of thing. I thought there
was a "change DPI" setting somewhere in the control panel, but I've got
no idea how various programs would react to that.
> Android is an example of a better way to do it (but probably not the
> best way).
I know nothing about Andriod.
> You need to learn how to make 4GB ones, or more correctly, how to build
> a factory to mass produce 4GB ones. And you're not going to do that
> overnight in the lab if you are currently only making 64MB ones. It
> simply won't happen, you'll go bankrupt (because your competitors
> figured out how to make 256MB ones and you didn't) before you figure it
> out.
> The only way to do it is to stretch your existing process to make 128MB
> or 256MB ones, trying to fix the odd few problems that will no doubt
> come up. That is called research and development.
> Once you have a stable process for 256MB ones, you can again try and
> push to make 512MB or 1GB ones, you will no doubt come up against
> different problems than you had last time, you might need some fairly
> big steps in technology development, but it's possible.
Perhaps it's because I don't work in that sort of industry. All this
sounds kind of abstract to me. I don't see how going to 10x is "harder"
than going to 2x. I'm not saying it isn't, I'm saying I don't understand
why.
>> Then again, cars don't improve in performance at all. Today's cars have
>> performance within a few percent of cars made 40 years ago. And yet,
>> people still buy cars.
> Compare pretty much any criteria and cars have vastly improved.
How about, uh, speed?
30 years ago, cars could do 70 MPH. Today, cars can do 70 MPH. As far as
I know, there's little to no improvement in acceleration either.
Expensive cars were always faster than cheap cars, but other than that,
not much change in three decades. Braking is the only thing I can think
of which might have improved; we have ABS now.
Cars do seem to have more "gadgets" now than they used to. Once upon a
time, if you wanted electric windows, you'd have to buy a luxury sports
car. Today it's hard to find a car /without/ electric windows. I'm not
sure how or why that happened, BTH.
>> On the other hand, pens and pencils don't improve in performance either,
>> and they still sell plenty of those.
> That's just because you don't work with designing pens :-) I'm pretty
> sure they are continually using the latest materials and inks available,
> you just don't notice that your pen doesn't snap as easily or
> clog-up/stop working as often as it used to.
To some extent, it's the sort of device that you only notice when it
/stops/ working. That said, there's been no /noticeable/ improvement.
And my point, of course, was that even if pens never did improve ever
again, people would /still/ buy them. Because they're a consumable item.
This is what happens when you hit [send] too fast. ;-)
I wonder how much computers would have improved if it was illegal for a
computer to perform more than seventy billion instructions per second?
Brings a whole new meaning to the words "Internet Explorer has performed
an illegal operation and must be shut down". ;-)
> why.
Short answer: Go and research how ICs are made.
Long answer: Think of something you could teach yourself to make (eg an
origami bird or something) and imagine making those and selling them.
Now consider how hard it would be to make them 2x smaller, a few folds
might be a bit tricky, but you'd probably manage after a few tests. Now
consider if you had to make them 10x smaller, suddenly some folds might
become impossible unless you use tweezers or something, you might need
to buy different paper, change the design slightly, it is going to take
orders of magnitude longer to teach yourself how to reliably make them
repeatedly, and while you're doing that you're not making the bigger
ones so you're not getting any money.
If you instead started making the 2x smaller version and got happy with
that, you could then go 2x smaller again, maybe having to make 1 design
change. At each step you have far fewer problems, if you try and jump
10x or 20x you're just going to give it up because it won't work and you
won't be able to figure out why.
The problem with speed is that for most people buying a car, price and
economy comes before top speed, and especially in most countries it's
illegal to drive much above 70 or 80mph. So obviously car companies
have concentrated on keeping price low and reducing fuel usage rather
than top speed. But then saying that, if you want to you can easily buy
a cheap family car that will comfortably go well above 100 mph without
shaking itself apart - how many cars could do that 30 years ago?
All the other things I mentioned too, particularly MPG is the main one
that is top of most manufacturers list of things to improve.
Same for air-con, electric mirrors, information displays, immobilisers,
CD players, navigation etc. All stuff starts out on the
top-of-the-range models and works it way down to standard on the
cheapest ones.
>> best way).
This is a good overview, there are no pre-requisites!
http://developer.android.com/guide/practices/screens_support.html
There is. Display properties, Advance button, general tab.
Defaulted to 72 DPI in win 9x and 2000.
Defaults to 96 in Windows XP and probably Vista. Can be set to a
"standard" 120 DPI or an arbitrary custom value.
The main problem, is that many applications' display will break down if
you increase the DPI setting past 96. Some web page layout will also get
broken if you change your DPI setting. That's why using absolute PIXEL
values is realy bad.
A viable solution is to sellect the apearance tab and increase the point
size of your characters. That won't affect the graphics elements but
will make your text large enough to be read.
Selecting a good high readability font also help.
> There is.
I thought so.
Any specific reason?
Well, yeah, we all knew that. ;-)
(Though of course if the page is loaded with graphics, all of those are
rendered at fixed pixel sizes, so...)
Look at cars where speed above 70MPH actually matters. Like, say, race cars.
They've gotten much faster.
Cars certainly go faster than 70MPH. Have you tried the difference in ride
quality at 140MPH between a modern car and a 30-year-old car?
"Oh no! We're out of code juice!"
"Don't panic. There's beans and filters
in the cabinet."
On 4/10/2012 7:55, scott wrote:
> text was all a bit blocky or blurry depending what setting you used.
300DPI is still a bit blocky and blurry on paper.
in the cabinet."
On 4/10/2012 8:47, scott wrote:
> Maybe it's just so clunky for devlopers to support it they don't bother? I
One of my huge regrets in this profession is that we gave up NeWS in favor
of HTML.
in the cabinet."
> cars. They've gotten much faster.
Pfft. Every time the engineers find a way to make the cars faster, the
FIA finds a way to make them go slower again. :-P
I still think you're insane. :-P
Another important point when discussing resolution is what the source
data is you are trying to display. If it's vector based then you can
decide each pixel value perfectly using a simple algorithm, however if
you're trying to scale a bitmap to display (eg from a webpage or camera
data) it's very hard to make it look as good as the vector based data,
no matter what AA algorithm you use.
http://en.wikipedia.org/wiki/List_of_fastest_production_cars
The problem with top speed is that it depends on the cube root of power,
so you need huge increases of power to get any significant top speed
improvements.
The bigger improvements have been in cornering speeds and braking
ability (both in racing cars and road cars). If you look at videos of
old F1 races there are many corners where they used to brake and change
gear whereas in today's cars they just run flat out (Eau Rouge at Spa is
the classic one, or 130R at Suzuka). Tyres, suspension and aerodynamics
have improved vastly to make such things possible. Even in your road
car braking distances have vastly reduced due to tyre, suspension and
brake design (not ABS, that only really helps if you want to steer and
brake or it's wet).
scott <sco### [at] scott com> wrote:
> The main problem is that Windows doesn't work nicely with higher
> resolutions.
I think a bigger problem is that the amount of data that needs to be
transferred from the computer to the display becomes prohibitively large
as the resolution grows.
There is, after all, a physical limit on how many bits of information
per second can be transferred through circuitry and cables.
On 11/04/2012 10:07 AM, Warp wrote:
>> resolutions.
I think the bigger problem is Windows. If that could be fixed and
resolutions started climbing, eventually what you're talking about would
become the next problem. But I don't think we're currently near that
limit yet.
DisplayPort already allows up to 3840x2160x30bpp @ 60 Hz, so that should
be enough for a few years before they come up with something else (which
they surely will if there is demand for it).
> improvements.
> have improved vastly to make such things possible. Even in your road car
> braking distances have vastly reduced due to tyre, suspension and brake
> design (not ABS, that only really helps if you want to steer and brake
> or it's wet).
ABS is very often bad. Most are all/nothing affairs taking only one
sample per wheel rotation that can jerk you around and make you loose
controll. In some cases, the brake pedal will shake and hit your foot
real hard, even to the point of causing some injuries...
A real good ABS must be progressive, take MANY samples per rotation,
gradualy reduce the breaking power as needed acording to the breaking
related torque and wheel load. In short, find the limit of adherance and
stay around it untill you stop.
That won't work, as once you get past the limit of adherence, gradually
reducing the braking power will not stop the wheel locking. The
friction gets less, so you need less brake power to lock the wheel, it
gets slower so friction gets even less etc. it's in a positive feedback
loop condition.
Once you are past the limit, the best thing to do is to instantly reduce
the brake pressure completely, this will move the wheel back into the
region of higher friction as quickly as possible and you can then
reapply the brake pressure. It may not seem intuitive though that
totally releasing the brake pressure will make you stop quicker in the
end, but consider that 99.9% of the time is probably spent below the
limit and only 0.1% above the limit with the brake pressure cut.
Of course the faster your system is the less noticeable the "pulsing" is
and the more you can stay around the limit, but a progressive or gradual
system is not the best way to do it, and would be much more expensive.
One winter I was driving along. I forget why, but I pulled into a side
street, which turned out to have half an inch of solid ice coating it.
The ABS cut in when I tried to coast to a stop. It sure juddered my foot
around. (But then, it's a cheap car.) The car did stop, however. If only
they could make a way for the steering to also continue working. :-P
The only flaw I noticed was that once the car is moving slowly enough,
the wheels just lock, and won't unlock. (And by "slowly enough", I mean
"slow enough that you could walk up to the car and play curling with it.")
