Le 2012-03-02 04:25, Invisible a écrit :
> On 02/03/2012 05:54 AM, Darren New wrote:
>> On 2/29/2012 1:24, Invisible wrote:
>>> As far as I know, there is no way of using XHTML entities without also
>>> declaring that this is an XHTML document.
>> Right. Because that would be meaningless.
> The point is, any XML document that contains text may potentially need
> non-ASCII characters. But only XML documents which are also XHTML can
> contain non-ASCII characters. How is that sensible?
Non-XHTML documents can and do contain non-ASCII characters. What you
meant to say is that you can't use their XHTML representations outside
an XHTML document. Case in point: a .DOCX file does not use é or
à but can most definitely contain the characters represented by
those entities.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
No. Only XML documents which are also XHTML documents can use the XHTML
standard for specifying ASCII-only names for non-ASCII characters.
You *can* put non-ASCII characters in an XML document. That's what the first
line is for, with the hard-to-remember code numbers, remember? Different
standards can have different entities. If I want an XML entity that
represents the symbol for the left eyeball, or an XML entity that represents
a internal link to the document management system of google, I can do that
-- just not in XHTML. Look at the triglyphs for C-on-punched-cards. Same
sort of thing. They're only applicable to C.
> Sure, having more than one DTD doesn't make a lot of sense. (Except that it
> would be nice to apply different DTDs to different namespaces. But that has
> little to do with entities.) The problem is that character entities are in
> the DTD, not defined in the XML spec for /everyone/ to use.
So type the characters directly. Nothing stops you from embedding a thron or
an omega in your document except that you don't want to learn how to type
one on the keyboard you have.
> OK. But it could make sense for different DTDs to apply to different
> subtrees, surely?
You still have to have one DTD that says where the trees are allowed to join
up. There's nothing that says that DTD isn't trivial to construct from two
other DTDs.
>>> I know that you /can/ stuff more than one namespace into an XML document.
>>> It's just that it doesn't /work/ when you try to use it.
>> It ... works for me. You just have to (a) do it right and (b) have a
>> tool that supports it.
> Write at XHTML document which contains some MathML. Unless you use the magic
> XHTML+MathML DTD, it doesn't work at all. Clearly it /should/, but it doesn't.
Sure. You have to have the right DTD, because MathML expressions can't
appear inside URLs, nor can they appear as a child of a <meta> link in the
header, etc. You have to know the rules of where each can appear in the
other if you want to actually check it's right.
> In summary, XML doesn't provide the necessary tools to solve common problems
> such as mixing more than one markup together.
It does. You just don't like the solution. It's like you're saying "Haskell
doesn't provide the necessary tools to incorporate C syntax into its type
declarations." No, they're completely different type systems.
People tell me I am the counter-example.
Why would you want three different standard names for the same character?
> thron or an omega in your document except that you don't want to learn
> how to type one on the keyboard you have.
Well, for that matter, you can just type the Unicode code number
directly. (This at least works with all operating systems and text
editors, doesn't break every five minutes, etc.) It's just that
memorising large quantities of code numbers isn't exactly trivial.
>> subtrees, surely?
> join up. There's nothing that says that DTD isn't trivial to construct
> from two other DTDs.
Well, if it were possible for one DTD to import several others, then it
could be pretty easy... As it is, constructing even one DTD is so
insanely hard that only the professionals can do it.
>> problems
What, a combinatorial explosion of DTDs for every possible combination
of XML applications that you might ever want to combine? No, that's just
silly.
> "Haskell doesn't provide the necessary tools to incorporate C syntax
> into its type declarations." No, they're completely different type systems.
Not relevant, but: Actually Haskell does let you do this. There's a
standard preprocessor for exactly this task. People use it when binding
to external C or C++ libraries.
What's the chinese word for "quotation mark"? For that matter, why would you
even want a "name" for a character, unless your text editor is too lame to
actually store the character? Leap-frog into the 21st century and start
using Windows Notepad to edit your text or something.
> Well, for that matter, you can just type the Unicode code number directly.
> (This at least works with all operating systems and text editors, doesn't
> break every five minutes, etc.) It's just that memorising large quantities
Right. So you're complaining that XML is broken because your text editor
can't handle Unicode? Just type the unicode characters directly into the
text document, without using any code numbers.
> could be pretty easy... As it is, constructing even one DTD is so insanely
... says the man who programs in Haskell. ;-)
You don't really have to *import* DTDs. You can pretty much just concatenate
them, as long as there aren't conflicting definitions, and fix up only the
places where they actually interact. I mean, if you have some java-specific
XML (say, a build system), and you want to embed SVG into that (say, to
define the splash screen for the completed program), your build system is
going to have to understand how to interpret SVG.
> What, a combinatorial explosion of DTDs for every possible combination of
> XML applications that you might ever want to combine? No, that's just silly.
Why not? You get a combinatorial explosion of types in your computer
programs for every new program you write.
Generally, your XML processor has to understand the combination you're using
anyway, so it's not really obvious there's a problem here. It's not like
you're going to combine SEP and XHTML in one program and expect to not do
more work than frobbing around the DTD.
> you even want a "name" for a character, unless your text editor is too
> lame to actually store the character? Leap-frog into the 21st century
> and start using Windows Notepad to edit your text or something.
It's not possible to type exotic characters. But it's trivial to type in
their names.
...aaaand then watch it break into a thousand pieces because raw text
files have no way of specifying what actual character encoding is being
used. :-P
The problem is, the only real documentation on how to write DTDs is the
antiquated SGML reference documentation, which is hardly easy going.
From what I've seen from other written DTDs, it's just damned hard,
that's all.
>> silly.
Actually... no, you don't.
In any half-decent language, you can implement sorting and searching.
Once. In a language that's not so good, you have to reimplement this for
every individual datatype. And that's what the DTD situation feels like;
endlessly reimplementing the same language specs over and over again.
And these aren't exactly trivial languages... It would be frighteningly
easy to come up with an XHTML+MathML DTD where the XHTML part doesn't
actually match the stand-alone XHTML DTD, for example.
Sure it is. I just turned on chinese for my wife. Use alt-shift to toggle
between languages. :-)
The problem is that your *editor* doesn't make it simple to type exotic
characters, yes? Why do you complain that your XML processor doesn't
understand exotic characters when its your editor that makes them difficult
to type?
> ...aaaand then watch it break into a thousand pieces because raw text files
> have no way of specifying what actual character encoding is being used. :-P
That's why the first line of your XML document includes the character set in
which the rest of the document is written. *right there* is the reason you
have to put <?xml ...> at the start, along with the funky code number for
your character set.
> antiquated SGML reference documentation, which is hardly easy going. From
> what I've seen from other written DTDs, it's just damned hard, that's all.
It's actually pretty straightforward. Google "dtd tutorial".
> It would be frighteningly easy to come up with
> an XHTML+MathML DTD where the XHTML part doesn't actually match the
Sure. And it would be frighteningly easy to come up with a generic sorting
algorithm that works incorrectly on certain types. Don't do that.
The point is that a DTD is a type specification. It also originally
specified what closing tags could be left out by specifying what could be
nested inside what. (You don't have to close a paragraph in a book if the
next tag opens a new chapter, because chapters don't nest and paragraphs
can't contain chapters.)
So don't use a DTD. Use an XSL or whatever they call it these days.
> toggle between languages. :-)
That doesn't make the characters available on your keyboard though. It's
not like you can just press a button and have a different set of
characters printed on your physical keyboard.
> difficult to type?
It's not the editor that makes them hard to type. It's the fact that
computer keyboards only have a few hundred keys, not several billion
keys. (Heck, even then it would be pretty difficult to actually /find/
the one you want...)
In most situations, that just means that you flat-out /can't/ use
unusual characters. HTML, and now XHTML, are fairly unusual in that they
let you type in the character's name if you can't easily type the
character itself. Unfortunately, rather than make this useful feature
available to all XML applications, they arbitrarily chose to make it
available to only one.
>> files
>> used. :-P
> set in which the rest of the document is written. *right there* is the
> reason you have to put <?xml ...> at the start, along with the funky
> code number for your character set.
That tells an XML processor what the character encoding is. It does not
tell your text editor what the encoding is.
> sorting algorithm that works incorrectly on certain types. Don't do that.
The point is, to make a DTD for a combination of trees, you have to
/copy/ the DTDs for each subtree - and hope that you don't do it wrong.
Talk above violating the DRY printiple...
On 3/4/2012 9:07, Orchid Win7 v1 wrote:
> That doesn't make the characters available on your keyboard though. It's not
> like you can just press a button and have a different set of characters
Actually, you can, yes. http://www.lcd-keys.com/english/history.htm
> computer keyboards only have a few hundred keys, not several billion keys.
And yet, oddly enough, billions of chinese people seem to get along OK.
It's still the case that you're addressing the wrong technology. The file
itself has no trouble storing the characters, yet you want the file storage
technology to compensate for your computer's inability to put the characters
into the file conveniently.
Fix your input mechanism, and store the characters. Don't fix every program
that reads characters to deal with names. Fix your *editor* to deal with
names. Make it so when you type &acut; into your editor, it replaces it with
the right unicode character. Problem solved.
> type in the character's name if you can't easily type the character itself.
Why doesn't your editor do this?
> Unfortunately, rather than make this useful feature available to all XML
> applications, they arbitrarily chose to make it available to only one.
Because different XML applications need different character entities.
> That tells an XML processor what the character encoding is. It does not tell
So always use UTF-8 or something. Or write your editor to recognize an XML
header and parse it.
> The point is, to make a DTD for a combination of trees, you have to /copy/
> the DTDs for each subtree - and hope that you don't do it wrong. Talk above
But to *use* a DTD for a combination of trees, you have to implement an
entire program to do so. So the actual concatenation of two files is rather
simple, comparatively speaking.
Am 04.03.2012 18:07, schrieb Orchid Win7 v1:
That /may/ depend on your keyboard...
http://www.artlebedev.com/everything/optimus/maximus/
Did anyone already mention that they did /not/ "arbitrarily" choose "to
make it available to only one", but rather /deliberately/ chose to make
it availabe to /this/ one (despite the general decision to keep the XML
set of character entities simple), because "we'll never get people to
convert from HTML if they can't do this in XHTML"?
>>> files
>>> used. :-P
How about rephrasing this: "It does not /necessarily/ tell your text
editor what the encoding is."
What part of "get a decent text editor" didn't you understand? :-P
... which is why there is XML Schema. And XML namespaces.
Can you name one single text editor which can actually change character
encoding based on a mere XML encoding specification?
I would bet emacs does it, since it does everything, including sorting
laundry and fixing tires.
But seriously, though, http://www.lmgtfy.com/?q=xml+editors
Yeah. But then I'd have to use Emacs...
Right. Because my text editor only needs to edit XML. Oh, wait...
In all seriousness though. I could probably just configure my editor to
always use UTF-8. That still doesn't solve the problem of typing obscure
characters in the first place. And it still doesn't change the fact that
as soon as I open the file in any other program, it's going to break
because that other program doesn't know what the hell character encoding
to use.
Am 05.03.2012 09:54, schrieb Invisible:
The integrated text editors of both MS Visual Studio 2010 and
BeyondCompare 3.0 definitely do it (and yes, I'm talking about plain
"ASCII" text editors, not dedicated XML editor components).
As for stand-alone text editors, I've not used any for years, but I
wouldn't be surprised if current versions of e.g. UltraEdit would be
doing this as well (it does have some "auto-detect UTF-8 encoding"
option after all, though I can't find any details about the magic used
in there).
Am 05.03.2012 19:19, schrieb Orchid Win7 v1:
Did you know that good text editors allow you to define your own fancy
keystroke combinations? So you can place your favorite special
characters on some easily memorizable combo of Alt-Shift-Explode or
whatever suits your needs.
> to use.
That's plain stupid nonsense. A non-UTF-8-aware text editor (or any
other piece of software capable of processing extended-ASCII text files)
confronted with a UTF-8 text file will display apparently random stuff
in place of any non-ASCII characters, but that random stuff saves fine,
and parses back as later UTF-8 without problem. Just make sure you don't
insert non-ASCII characters in the troublesome editor, and don't insert
anything into that random stuff.
This property is one of the fun things about UTF-8: Anything that can
handle at least /one/ extended-ASCII codepage can also handle UTF-8
transparently without even knowing.
(You /will/ get into trouble though if your <?xml ...?> declaration
doesn't match the actual character encoding of the file, but I guess
that should be obvious.)
On Mon, 05 Mar 2012 20:10:56 +0100, clipka wrote:
> Alt-Shift-Explode
I need a keyboard that has that as an option on it. :)
Jim
Actually, I'd be happy if once, once in my career, someone would provide me
"an XML feed" that could actually be parsed by an XML library without first
having to do a bunch of string crap to it to make it right.
I expect you could set up vim to do it, since you can set it up to recognize
Python, Bash, etc.
Invisible <voi### [at] dev null> wrote:
> On 26/02/2012 12:35 AM, Darren New wrote:
> > On 2/25/2012 2:37, Orchid Win7 v1 wrote:
> >> For example, to say "this XML file actually contains XHTML", you're
> >> supposed
> >> to add something like 5 separate headers, each about 25 million miles
> >> long,
> >> to the top of the file. Why? Would one header not be sufficient?
> > Really? What do you have to add? I suspect you exaggerate a bit.
> First, you must say
> <?xml version="1.0" encoding="ISO-8859-1" ?>
Gaah! No! Use UTF-8! 8859-1 is Western European/United States only! Any
characters that are not in this set will be rendered as ? or worse. UTF-8 gives
access to the whole of the Unicode codeset, so no data will be mangled by the
encoding. Sorry, I'm a big proponent of using a more universal character set,
especially when handling data.
> Which is fair enough, although the 5-digit ISO code number isn't exactly
> easy to remember. Then you have to say
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
> Yeah, I'm really going to remember that without looking it up. :-P No,
> you can't just say "this is XHTML". You really do have to write all that
> crap. And after /that/, you still have to say
Yeah, the DTD is a bear; what you do is set up a starting point and use that so
you don't have to remember the DTD all the time.
> <html xmlns="http://www.w3.org/1999/xhtml">
> Um, didn't I just declare this as XHTML already? At least this URL is a
> bit shorter, I guess...
You set a doctype processing instruction that gives a web browser information on
how to handle your document, remember, HTML comes in many different flavors.
Your xhtml document is an xml document. The xmlns attrubute is specifying that
this document should conform to the specifications of the xhtml standard. I
think this is actually optional, but allows better validation. This uses an xsd
file which defines the schema.
> In short, that's a /hell/ of a lot of typing, before I've even written
> my document. It's also a lot of typing that I have to go look up on
> three different websites every single damned time I want to write XHTML.
Meh. You create a starter file and copy that when you want to do an xhtml file.
> >> Then there's all that stupidity with character entities. It should be
> >> possible to include character entities in /all/ XML documents, not just
> >> XHTML. But to this day, I have never discovered a way of doing this.
> > You have to declare the entities. Otherwise, you run across &frump; and
> > don't know what it means. That's what DTDs are for.
> So why isn't there a DTD somewhere that contains all the entities that
> everybody uses, which I can just link to? More to the point, since
> everybody uses the same set of entities, why aren't they built in?
Because sgml is a standard that allows a large amount of flexibility in what it
actually is.
> >> One of the nice ideas of XML is that you can use namespaces to include
> >> one
> >> sort of XML document inside enought - e.g., you could put an SVG file
> >> inside
> >> an XHTML file. But nooo, apparently you need a specialised DTD to do
> >> that.
> > You can. Of course, your various processors have to know what the
> > various namespaces *mean*, so you have to declare them and you have to
> > have a processor that understands them (which is where the DTDs come in).
> You would /think/ you could just say "hey, this stuff here is in the
> XHTML namespace, this stuff here is in the SVG namespace", and that
> would work. But it doesn't. You need to use a DTD specially written for
> the exact combination of XHTML+SVG. To me, this indicates that the
> system is fundamentally broken. It should not be necessary to write a
> separate DTD for every possible combination of XML documents imaginable.
> You should just be able to refer to the DTD for XHTML and the DTD for
> SVG and have it work.
Thing is, the DTD and schema can be defined anywhere. That's why all of the
clunky URL's.
Le_Forgeron <lef### [at] free fr> wrote:
> Le 23/02/2012 10:11, Invisible a écrit :
> > This still leaves me with the problem of how to generate unusual
> > characters in the first place. Typing → is pretty simple. Figuring
> > out how to actually generate the arrow character is not.
> You just need the right documentation.
> Either you search it each time on the web (like "utf-8 chartable"... )
> or you call it correctly, and ask for unicode (utf-8 is one
> presentation, unicode is what you really want), and get to print the
> parts that you need often.
> See http://unicode.org/charts/
> And soon you will discover that there is no single font to display all
> possible unicode glyphs.
> You also need a unicode-compatible editor...
Code2000 comes close for Plane 1... The higher planes are a different story
alltogether, but most of those are rather specialized anyway.
Nothing stops you from using &#xx; codes regardless of the encoding.
> OK, so I've written a program that generates a bunch of XML as output.
> If you open that in a web browser, it shows up as a simple parse tree.
> Which is OK, but a little verbose.
> Fortunately, using the wonders of XSL (specifically, XSLT) you can have
> the browser transform the raw XML into a pretty-looking XHTML document.
> But *only* if you edit the original XML file to mention the XSLT file
> that you want to apply.
> Now, it ought to be simple to write a 3-line file that says "take this
> XML file and that XSLT file, and display the result". But after over a
> week searching the Internet and even consulting Stack Overflow, I cannot
> find any way of doing this. I literally cannot *believe* that something
> so trivially simple is also so utterly impossible.
> If there /is/ a way of doing this, every single XSL tutorial in
> Christendom fails to mention it. No XSL FAQs mention it either - it's
> not even that they say it can't be done, it's that none of them even
> contain a question about this topic. This raises the alarming
> possibility that what I'm trying to do might actually be impossible
> after all. (Which is slightly daft, given that it's the entire point of
> XSL existing in the first place...)
> To be clear: It seems to be perfectly possible to apply any XSL to any
> XML if you use an external 3rd-party tool. You just can't do it with a
> *web browser*. You know, those programs that know about XML and XSL and
> are installed on every computer in the world. No, you have to select and
> download a special CLI utility if you want to perform such advanced
> wizardry. *sigh*
> My first thought: XSL lets you include one stylesheet inside another, so
> maybe you can include one source document inside... erm, no. No you can't.
> It looks like it /might/ be plausible to do something with the XSL
> document() function - but I haven't figured out exactly how yet.
> Apparently XML itself has a general include feature called XInclude.
> According to Wikipedia, "Browser support: None". *facepalm* OK, so
> that's really going to help then.
> About the closest thing I've found is a website that says that if you
> copy and paste a few miles of convoluted JavaScript code, you can make a
> web page that runs the script which then loads the required XML in the
> background, lots the XSL, applies one to the other, and inserts the
> result into a specific position in the DOM of the current document. In
> particular, it cannot /replace/ the current document, it can only be
> /inserted into/ it. So if your XSL generates an entire XHTML document...
> forget it.
> (I presume it goes without saying that the first thing this code snippet
> has to do is test whether it's running on Internet Explorer or a
> standards compliant browser. :-P Some things never change...)
> So it looks like I'm going to have to sit down and write a special tool
> to take an XML file and copy it, inserting the correct XSL reference
> into the header. How pathetic...
I coded one up in C# in about 15 minutes. It doesn't take much if your language
of choice already has a library for handling xml/xslt.
I found this post rather interesting as my current project is one big stylesheet
to turn raw xml into a legible report. I've learned just how powerful the
language is. There's a ton you can do with it, and I now wonder why everyone
always moans and groans about how difficult it is to deal with.
On 09/03/2012 20:56, Warp wrote:
> Nothing stops you from using&#xx; codes regardless of the encoding.
Correction: The finite limitations of the human mind stop you using hex
codes. :-P
Tell it to [every piece of Windows software that inspects text files].
All of these programs seem to default to that encoding, not UTF-8.
It only takes 15 /seconds/ to type in a command if you have a 3rd party
external XSLT processor (e.g., Saxon). But apparently you can't get the
/web browser/ to do this. You have to create a new, separate,
transformed version of the file.
It might not sound like much, but it means every time you change the
program that generates the XML, you can't just rerun that program. You
have to rerun the program, and then rerun Saxon (or whatever), and then
reload the browser page. It's a PITA.
What I ended up doing, obviously, was providing a way to change the XSL
reference that the original program inserts into the XML file. :-P
[I presume you're talking about XSLT here.]
It's interesting that there's one set of facilities for processing the
input functionally, and a separate, redundant set for processing it
imperatively. The latter set is much less powerful to boot. (Perhaps
that was deliberate.)
What I can't figure out is this: How do I make it process an element one
way if it contains a "small" amount of content, and process it a
different way if it contains a "large" amount of content?
> codes. :-P
step 1: www.google.com
step 2: "unicode chart for _____ characters"
step 3: File | print
step 4: Tape to side of computer screen.
Back when dinosaurs roamed the Earth, that's what most of us did for
DOS-based editors when we needed accented characters, or for the more
daring, ASCII graphics.
Change your local settings to Bulgaria or Czech Republic and it won't!
Won't default to UTF-8? Yes, I know. ;-)
This is true, but, in general, UTF-8 is the better way to go, but if the
data displayed on the page comes form a different source...
That's because nobody bothers with the encoding. But what drives me nuts
is when web-authors stick in an encoding, then use UTF-8 characters in
it. You get all sorts of ugliness.
Use xsl:choose and have the when statements with the appropriate test?
I'm unclear as to what constitutes a small amount of content v.s. a
large amount of content.
You could have it trigger on the string-length of the node's value, for
instance. Or, you could trigger on the number of nodes (using count)
