POV-Ray : Newsgroups : povray.off-topic : The trouble with XSLT Server Time
30 May 2026 18:32:29 EDT (-0400)
  The trouble with XSLT (Message 15 to 24 of 84)
Subject: Re: The trouble with XSLT
Date: 21 Feb 2012 14:25:28
Message: <4f43efa8@news.povray.org>
On 21/02/2012 17:14, Warp wrote:
> Invisible<voi### [at] devnull>  wrote:
>> Sure, that works. But now suppose I have /more than one/ XSL file. In
>> order to select which one I want applied, I have to actually edit the
>> XML file.
>    What do you expect? For the XML file to read your mind?
No, I wanted to put that information into a separate file, that's all.
It's not a complex idea.
Date: 21 Feb 2012 15:40:07
Message: <4f440127@news.povray.org>
> >> XML file.
  Create an xml file that includes (using XInclude) the other XML file
you want as well as the xsl file?
Date: 21 Feb 2012 21:55:35
Message: <4f445927$1@news.povray.org>
Am 21.02.2012 11:09, schrieb Invisible:
>> The spec concludes that "Since disabling output escaping may not work
>> with all XSLT processors and can result in XML that is not well-formed,
>> it should be used only when there is no alternative."
> Ah. So in fact, the W3C specification is broken, since /clearly/ a
> system should not be specified to suddenly produce completely incorrect
> output if an optional feature is not implemented.
That's why they warn about this possible difference, so that the user
can decide whether to (a) make sure that the XSLT file is only used with
an XSLT processor that supports the feature, or (b) make sure that the
output is not *completely* incorrect if the feature is unavailable.
That's not broken spec, that's just perfectly normal optional features.
> Meanwhile, it looks like my only options are either to start memorising
> Unicode code points by ID, or to save my XSL file as UTF-8 and watch the
> encoding get screwed up every time I touch the file...
Ah, so your /real/ problem is a crappy text editor.
> (Let's not even get into the question of why the standard character
> names /only/ work in HTML, and not all SGML file types...)
Because they're a HTML-specific invention?
Date: 22 Feb 2012 04:04:13
Message: <4f44af8d$1@news.povray.org>
>>>> XML file.
That's a great idea. Except that apparently no browser supports XInclude
yet. As I pointed out in my original post.
Date: 22 Feb 2012 04:07:53
Message: <4f44b069@news.povray.org>
It's a broken spec, in that it provides no way to design a transform so
that if DEO is not implemented, the output still looks sane. There isn't
even a way to say "sorry, the required feature is not available".
Instead, it just prints random gibberish without telling you or giving
you any chance to correct it.
The /real/ problem is that there is no way of knowing what encoding a
given text file has. So it's not safe to use non-ASCII characters in a
text file. Which is why character entities were invented in the first
place...
Um, why?
It's not like only HTML could possibly need non-ASCII characters.
Date: 22 Feb 2012 15:42:12
Message: <4f455324@news.povray.org>
Am 22.02.2012 10:07, schrieb Invisible:
> place...
Use an editor that places a BOM at the start of UFT-8 files and bob's
your uncle.
Date: 22 Feb 2012 16:28:49
Message: <4f455e11$1@news.povray.org>
>> place...
> your uncle.
In other words, "there is this informal undocumented /convention/ that
if a file starts with a BOM [even though UTF-8 does not require such a
mark, since there /is/ no byte order], then it is presumed to contain
UTF-8".
I wonder how widely implemented this undocumented feature is?
Date: 22 Feb 2012 16:47:21
Message: <4f456269$1@news.povray.org>
Am 22.02.2012 22:28, schrieb Orchid Win7 v1:
>> your uncle.
> UTF-8".
Most likely more widespread than you think.
As an alternative, forget UTF-8 and go for UTF-16.
Date: 23 Feb 2012 04:11:08
Message: <4f4602ac$1@news.povray.org>
I got the distinct impression that this is a Windows-specific
convention. (Doesn't Linux do something strange with using environment
variables to define the "system locale"?)
Or that, I suppose.
This still leaves me with the problem of how to generate unusual
characters in the first place. Typing → is pretty simple. Figuring
out how to actually generate the arrow character is not.
Date: 23 Feb 2012 04:39:02
Message: <4f460936$1@news.povray.org>
You just need the right documentation.
Either you search it each time on the web (like "utf-8 chartable"... )
or you call it correctly, and ask for unicode (utf-8 is one
presentation, unicode is what you really want), and get to print the
parts that you need often.
See http://unicode.org/charts/
And soon you will discover that there is no single font to display all
possible unicode glyphs.
You also need a unicode-compatible editor...
