POV-Ray : Newsgroups : povray.off-topic : PIPA and SOPA Server Time
29 Nov 2026 20:33:51 EST (-0500)
  PIPA and SOPA (Message 139 to 188 of 188)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: PIPA and SOPA
Date: 1 Feb 2012 11:45:18
Message: <4f296c1e$1@news.povray.org>
>>> The big advantage to adding disks virtually instead of physically is
>>> that you are not limited by the form factor of the server, the power
>>> output of the PSUs and most importantly, they can be done on the fly,
>>> without having to take an outage.
>> But you still need to (at a minimum) reboot the server after you change
>> the SAN mapping anyway.
> Obviously, Windows may complain if you try to pull the C: drive from
> under its feet, but you shouldn't actually boot from a SAN drive under
> normal circumstances anyway.
Oh, I see. Well, if you're not changing the OS partition, then yes, that
should work.
>>> In your environment, it may not be that big of an issue, but when you
>>> have contracted service level agreements that you will have 99.99%
>>> uptime, you have no other choice. Do the math, that means 1m42s of
>>> downtime per month... try powering off a server, taking it out of the
>>> rack, adding a disk and powering it back on in less than 10 times that!
>> Uhuh. And when one server physically dies, it's going to be down a tad
>> longer than 1m42s. So if you don't have the spare capacity to handle
>> that, a SAN still hasn't solved your problem.
> Need help moving those goalposts? They look heavy! We weren't talking
> about a server dying. We were talking about needing more disk space.
That was not clear to me. You made it sound like "hey, if you have a
SAN, then when one data centre dies, you can just use the other one!"
You're going to need more than just a SAN to do that.
I would have thought that needing more disk space is such a crushingly
rare event that it makes almost no sense to optimise for it. If you have
to take a server offline once every 5 years to add another disk, that's
still 99.99% uptime.
>> This makes no sense at all. How the hell can a 6 Gbit/s SATA link
>> perform the same as a 100 Mbit/sec Ethernet link? Never mind a 10
>> Mbit/sec Internet link. That makes no sense at all. (Unless your actual
>> disks are so feeble that all of them combined deliver less than 10
>> Mbit/sec of data transfer speed...)
> You're making a strawman argument. No one ever said that SANs run over
> 10Mbit ethernet.
Neither did I. I said 100 Mbit Etherhet. (It's quoted right there.)
You claimed that it's not insane to run a SAN over the Internet, despite
the fact that typical Internet speeds are roughly 10 Mbit/sec or slower.
> most SAN implementations run dedicated protocols over
> fibre at Gbps speeds.
It's news to me that such things even exist yet - but perhaps that was
your point?
Still, it looks like the UK site will soon be in possession of their
very own SAN, so I guess I'll be able to watch it fail up close and
personal. o_O
> Four 9s and Five 9s uptime is expensive.
Hell yes.
Actually, I think we can simplify this to "uptime is expensive". I've
yet to see a method of improving uptime that's cheap.
>> For that, you would need [at least] two geographically remote sites
>> which duplicate everything - disk and other hardware as well. I'm
>> struggling to think of a situation where the volume of data produced per
>> hour is so low that you can actually keep it synchronised over the
>> Internet. And if it isn't in sync, then a failover to from primary to
>> secondary system entails data loss.
> Not the Internet, multiple dedicated 10Gbps DWDM links. You'd be
> surprised to know that most Fortune 1000 entreprises actually do this
> already.
So what you're saying is that a handful of the richest companies on
Earth can afford to do this? Yeah, I guess that'll be why I haven't seen
it before. :-P
>>> That's because you keep forgetting that other people may have other
>>> needs than yours.
>> Perhaps. But saying "we work in the financial industry" doesn't tell me
>> how your needs are different than mine. Really, the only way you'd truly
>> come to understand this is by actually /working/ in that industry. And
>> that's just not possible.
> Are you saying it's impossible to work in the banking industry? Or are
> you saying that the banking industry is so secretive about their work
> that you can't even find out how they operate without working there?
I'm saying it's not possible to go work in every random industry just to
find out what makes it tick.
> Of course, you can also decide that it's not worth it to learn about
> these things and simply shrug it off, but don't complain that you can't
> get jobs outside of the little hole you dug yourself into.
I didn't say it's not possible to get a job, I said it's not possible to
get insight without getting a job.
Date: 1 Feb 2012 12:53:20
Message: <4f297c10@news.povray.org>
> should work.
No. I said that if you have two SANs in separate data centres, with data
replicated on both data centres, then it greatly reduces your down time
in case of a disaster.  I never claimed that all SANs were designed that
way, nor that it was the only requirement for instant recovery.
No it's not.  You may need to run an app in debug mode for a while and
need extra space to store the dumps.  You may run into seasonal peeks
and need extra storage just for that period. Etc...  Sizing hundreds of
servers for a worst case scenario is not efficient use of the company's
money.  You are much better off having some amount of slack space that
you can swing around when needed.
> If you have
Not if your contract says "monthly uptime of 99.99%". ;-)
>> 10Mbit ethernet.
When did I say that?
> despite
> your point?
Actually, it shouldn't be news to you.  We went over this in great
details a few months ago.  Remember my nice ascii-graphics chart with
the servers, SAN switches, drive enclosures and tape units?
> personal. o_O
Not that SANs are infaillible, but why do you assume that it will fail?
> Hell yes.
>> already.
There's more than a handful of companies who can afford it.  A few £M in
extra telco costs per year is nothing compared to the prospect of going
out of business because your data centre had a 110-story building crash
on top of it.
 > Yeah, I guess that'll be why I haven't seen it before. :-P
I have never seen the Merryll-Lynch data centre first hand, either, but
that isn't necessary to know that they were back up and running hours
after the WTC towers fell... Reading the story of how they restarted
their operations from their disaster recovery location was enough.  Then
the "Interesting...how'd they manage that?" questions popped up in my
head, and I started digging...
Which is the main point of this whole discussion: reading the newspaper
and other news-related web sites, once in a while, is not a bad thing,
even if the event in question doesn't affect you directly, there may be
bits of insight to be gathered.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 1 Feb 2012 13:25:45
Message: <4F2983AC.3090008@gmail.com>
This was a more general remark. We know that you are in a job where you
are not happy and that is probably below your capacities. At the same
time you repeatedly show that you are not interested in a wider view on
the field you work in. In this field you have to read a number of
different sources to get a feeling for what direction the industry is
taking (or if you are realy good: what direction it will be taking in a
couple of years). If you don't develop yourself there is no way you will
ever get a job elsewhere and it is quite likely that you loose the one
you have as soon as a competent manager enters. I know it is unlikely,
but such persons do exist, although few and far between, so you still
have a chance.
In short you have to choose: complain about your job or complain about
all sorts of technologies that you were not aware of, but you can not do
both.
tip: do not run in an unknown place when it is too dark to see the
floor, unless you prefer to not use uppercase.
Date: 1 Feb 2012 17:15:38
Message: <4f29b98a$1@news.povray.org>
On Tue, 31 Jan 2012 09:12:09 +0000, Invisible wrote:
>>>> It's easier to find jobs to apply to when you have a broader
>>>> awareness of the world than just what's relevant to you right now.
>>> I doubt you're going to get that by reading some text on a screen. To
>>> understand what a new capability means, you often need to experience
>>> it for yourself.
>> Hmmm, so let me see if I understand this correctly....You're asserting
>> that one of the methods that I actually use to keep up on technology
>> doesn't work?  Interesting that you'd have insight into what works for
>> me on such a deep level.
> I'm saying that if (for example) I read somewhere that a lot of
> companies use Citrix to host their applications, that doesn't really
> qualify me for a job managing Citrix. If I had actually /used/ Citrix,
> or something vaguely like it, then yes. But having read about how it
> exists and people use it? Not so much, no.
Knowing about the trend, though, in the use of Citrix for telecommuting
(for example) is something that's actually useful.  No, it doesn't
qualify you to manage a Citrix system - but that's not the point.  The
point is not looking like you're not aware of the trend when asked about
it in an interview.
Combine a demonstrated ability to quickly assimilate technologies with an
awareness of what's going on with the industry, and that is something
that looks good.
But if you're unaware of what Citrix even *does*, then that calls into
question (in an interview) whether you even know what's going on in IT.
>>> OK, I have to ask: What the hell is this "RSS" everybody keeps
>>> mentioning?
>> Google it.  If that doesn't work, try "Really Simple Syndication".
>> It's only all over the web.
> Ooo, because I haven't tried *that* before. :-P
> OK, so let's see... First hit from Google is
> http://en.wikipedia.org/wiki/RSS
> (Unless you meant Royal Statistical Society, which I'm pretty sure you
> didn't.)
> As usual with Wikipedia, the page babbles about updates and feeds and
> XML and "syndication" and something about RDF, but utterly fails to
> explain WHAT IT IS.
<sigh>
From wikipedia:
--- snip ---
RSS feeds benefit publishers by letting them syndicate content
automatically. A standardized XML file format allows the information to
be published once and viewed by many different programs. They benefit
readers who want to subscribe to timely updates from favorite websites or
to aggregate feeds from many sites into one place.
RSS feeds can be read using software called an "RSS reader", "feed
reader", or "aggregator", which can be web-based, desktop-based, or
mobile-device-based. The user subscribes to a feed by entering into the
reader the feed's URI or by clicking a feed icon in a web browser that
initiates the subscription process. The RSS reader checks the user's
subscribed feeds regularly for new work, downloads any updates that it
finds, and provides a user interface to monitor and read the feeds. RSS
allows users to avoid manually inspecting all of the websites they are
interested in, and instead subscribe to websites such that all new
content is pushed onto their browsers when it becomes available.
--- snip ---
Now, I read your blog and keep up on it by using - that's right - an RSS
feed.  I have the feed set up in Google Reader so that when you post
something new on your blog, I see it as part of the Reader page.
That way I don't have to visit your blog to see what's going on in your
blog.  I see an item show up in my reading list so, as wikipedia says, I
"avoid manually inspecting all of the websites [I] am interested in" and
can see what's new.
>>> I usually visit Tom's Hardware when I want to see what's happening in
>>> the hardware world.
> That's why I just built a new PC - to experience the Core i7 first-hand.
> :-P
So then why bother going to Tom's Hardware again?
> The BBC's iPlayer system "works". I mean, it's so horrifyingly blurry
> that you sometimes can't see people's faces clearly enough to recognise
> who's who, and often the end credits are unreadable. But technically
> that still counts as "works", right?
I don't know what kind of connection you use, but I stream on iPlayer
occasionally from halfway around the world (did that with last night of
the proms IIRC) and projected it onto a 10' screen.  Didn't look
particularly blurry to me.
> I just looked it up. The transfer rate of a DVD is 10.5 mbit/sec. The
> maximum broadband speed you can get is 8 mbit/sec. So... does that mean
> that people in America have something faster than ADSL or something?
I don't - I have 3 Mbps down ADSL.  I have to not be doing other things
with the network connection when I'm streaming Netflix, but I do get a
high quality HD image with 5.1 sound with programmes that include it.
But more to the point, do you now understand what streaming is?
Jim
Date: 1 Feb 2012 17:29:15
Message: <4f29bcbb$1@news.povray.org>
That's simply not true.
Case in point:  I worked as a system administrator and systems engineer
for years.  Then I moved into technical training and education.  I had no
formal background in technical training, course development, etc.  So I
talked to people in that line of work before moving into it to see if it
was something I might be good at.
I got insight without getting the job.
Similarly, I've never been a software engineer before, but I've gotten
insight into how things like SCRUM and Agile work by talking to people
who use them on a daily basis.  Again, no job, but insight.
Jim
Date: 1 Feb 2012 21:51:00
Message: <4f29fa14$1@news.povray.org>
On 1/31/2012 1:12, Invisible wrote:
> As usual with Wikipedia, the page babbles about updates and feeds and XML
> and "syndication" and something about RDF, but utterly fails to explain WHAT
> IT IS.
I have to ask... Do you start reading at the beginning of the article, or do
you skip over the part that comes before the table of contents or something?
First sentence in the article:
"RSS ...  is a family of ... formats used to publish frequently updated
works ... in a standardized format."
How is that not telling you what it is?
   People tell me I am the counter-example.
Date: 1 Feb 2012 21:55:58
Message: <4f29fb3e@news.povray.org>
On 2/1/2012 8:09, Francois Labreque wrote:
> I'm no Windows Server expert, so I don't know if it allows you to extend
> disk space on the fly, but I do know that many flavors of Unix do allow it.
It does.
Date: 2 Feb 2012 04:36:46
Message: <4f2a592e$1@news.povray.org>
> both.
I think that you are wrong, there. ;-)
Regards
Date: 2 Feb 2012 05:05:04
Message: <4f2a5fd0$1@news.povray.org>
>> explain WHAT
>> IT IS.
> or do you skip over the part that comes before the table of contents or
> something?
HTML is "a family of formats used to publish works [frequently updated
or not] in a standardized format". As is PDF. As is PostScript. How is
RSS different?
Sometimes the dictionary definition of what something is turns out not
to be very enlightening. For example, you could say that
   "A knife is a device constructed from a hard material, usually in the
shape of a triangular prism who's cross-section has a very acute angle
between two of the sides."
Or you could say "a knife is a device for cutting things". The latter is
infinitely more illuminating.
Date: 2 Feb 2012 05:24:48
Message: <4f2a6470$1@news.povray.org>
> it in an interview.
> that looks good.
I can see that knowing about how (say) Google manages their data centres
might be quite useful if you're applying to Google. If you're applying
to somebody who isn't Google, I'm not sure how that's useful.
...unless it *isn't* useful at all, it's just another one of those
worthless things that "create the right impression".
>> explain WHAT IT IS.
> <sigh>
>  From wikipedia:
> --- snip ---
> automatically.
WTF does "syndicate" mean?
Because XHTML isn't an XML format already. Oh, wait... actually yes it
is. And many different programs can view it. So...?
> They benefit
This at least hints at what RSS is actually about. But it still seems
quite vague. I'm still not clear exactly what it's getting at.
So... you need software that supports RSS in order to use RSS? OK, fair
enough.
We still haven't established exactly what point "subscribing" serves,
but OK...
This is all very abstract. It checks "regularly" for "new work",
downloads any "updates", and provides a UI to "monitor" such updates. So
what does that *mean*, in real world terms?
> RSS
As best as I can tell, the idea behind RSS seems to be that you can see
if any of your subscribed websites have been updated, without having to
visit each of them one at a time. (As if that's in some way "hard" or
something.) Why the heck the article doesn't just /say/ this on line
one, I don't know. Instead it talks obliquely about how "all new content
is pushed onto the browser when it becomes available". (Funny, when it
says a feed reader "regularly checks for updates", that sounds to me
like a /pull/ model, not /push/...)
> feed.
Damn... and I thought I'd turned that off... heh. Apparently not.
> can see what's new.
So what does that actually look like? I'm still trying to get my head
around how this actually works. What counts as "new content", how it
displays all this stuff in an intelligible form, and so on.
>>>> the hardware world.
>> :-P
Sarcasm? :-P
Want to bet that the BBC has servers all over the world?
With the latest update to our set top box, we can actually access
iPlayer and display it on a real TV. I can actually compare the recorded
TV broadcast directly next to the iPlayer version of the exact same
program. And let me tell you, the image quality is incomparable. (And
that's only SD, not HD.)
On top of that, at peak times iPlayer becomes almost unusable. It
freezes constantly. I'm not sure whether it's the BBC servers or the ISP
network that can't keep up, but you just can't watch anything. But then,
if you select "high quality mode", then it runs like that all the time.
I don't think an 8 Mbit/sec Internet connection would be considered
especially slow...
The sound isn't the problem, it's the video. Sound is easily streamable.
But I'm baffled as to how you can download video in anything approaching
real-time, unless the quality is diabolically poor.
Yes. Although I'm still puzzled as to how anybody could make money out
of selling such poor quality stuff...
Date: 2 Feb 2012 05:26:27
Message: <4f2a64d3$1@news.povray.org>
> need extra space to store the dumps. You may run into seasonal peeks and
Maybe that's the problem. I cannot imagine any task that would ever
require "hundreds of servers". I'm struggling to think of a task that
would require more than about a dozen at worst. I mean, unless you work
for one of the largest companies on the planet, which almost nobody does.
>> If you have
Mmm, good point.
 > We've also had the performance discussion before.  Yes, the
 > theoretical access speed of a local SATA drive is much faster than
 > that of a SAN attached logical disk, but in actual real world
 > practice, with real world data, there's not much of a difference,
 > even on SANs located halfway across town in another building.
>> your point?
> details a few months ago. Remember my nice ascii-graphics chart with the
I don't remember much of the detail of that discussion - in particular,
I don't recall there being any actual speed numbers involved. But still,
as I say, it looks like I will get to see for myself shortly.
They want to back up 200GB of data per day over a 5 Mbit/sec Internet
connection. You do the math.
Plus, since when does rolling out a brand new complex system go
smoothly? ;-)
> on top of it.
So you're saying that more than "a handful" of telco companies exist?
My first question would have been "who is Merryll-Lynch?", but OK.
Hmm. I'm now trying to remember how the hell we *got* to this topic in
the first place... (Just look at that subject line!)
At any rate, I agree there certainly isn't anything /bad/ about reading
news-related stuff. I just don't see how it is an absolutely mandatory
requirement of being alive, that's all.
Date: 2 Feb 2012 09:16:28
Message: <4f2a9abc@news.povray.org>
IT manager: "We have multiple data centres, built out of containers,
each with their own blah blah blah..."
Darren: "Ah.. Like Google?"
IT Manager (to himself) "Good.  I won't have to go over it with this
candidate."  (to Darren) "Yes, except that they do XYZ, whereas we rely
on ABC to do that... Yada Yada Yada...
Andy: "I didn't know you could do that!"
IT Manager (to himself) "Sigh.  I'm going to have to start from the
birds and Bees with this guy..."
Which of the two, do you think the IT manager will hire?
>>> explain WHAT IT IS.
>> <sigh>
>> From wikipedia:
>> --- snip ---
>> automatically.
>> They benefit
> enough.
> but OK...
>> RSS
>> feed.
>> can see what's new.
>>>>> the hardware world.
>>> :-P
> Sarcasm? :-P
> especially slow...
Date: 2 Feb 2012 09:19:16
Message: <4f2a9b64$1@news.povray.org>
While it's true that most tasks performed by the Fortune 1000 rarely
take more than a dozen or so servers.  Each of those companies have
dozens of such tasks.
For example:
- A bank of web servers for their corporate web site
- A handfull of DNSes
- A couple entreprise directory servers, authentication servers, etc...
- 1 mail server per 1000 employee
- 1 file server per 1000 employee
- A dozen servers for the HR apps
- A dozen servers for the Finance/accounting dept.
- A couple dedicated server for the law dept. (Confidentiality)
- Server monitoring servers.
- Network monitoring servers.
- Environment monitoring servers (Heating/air conditioning, power
consumption, generators, battery banks, etc...)
- and then... more servers for the actual business that company does, be
it putting people on planes, managing people's money, building cars, or
selling drugs.
Split those across a few data centres for geographical proximity to the
user base and duplicate all the mission-critical servers.
Tada!
I don't understand why you somehow think one needs to actually work for
British Airways, Siemens, Yamaha or IBM to be able to imagine what's
it's like to work in a company with 100,000+ employees.
"In another building" DOES NOT mean "over the Internet".  Private data
circuits predate the internet, and no company would use the Internet to
link two data centres together.  Remote offices, maybe, but definitely
not data centres.  15 years ago, it would have been done via data-grade
telco circuits (such as an E1 or E3 line, usually called a WAN circuit).
  Nowadays, it's done via DWDM optical circuits (usually called a MAN or
Metronet).
So their backup strategy will fail.  Not the actual SAN.  Gotcha.
> smoothly? ;-)
When it's planned properly.  I've seen it happen.  But, I must admit,
that I've seen quite a few disasters, too.
>> on top of it.
There are, in fact, more than a handful of telcos in most countries.
while the actual wires underground usually belong to one or two
companies, the other ones will buy bandwidth from the
cable-owning-entity and resell it to other corporations.  This is why,
for example, I can rent circuits from BT in Canada, even though they do
not own any of the fibre optics here.
But this has nothing to do with the fact that I was talking about
businesses buying telecommunications services from the telcos, not the
telcos themselves.  Last time I checked HSBC was not a telco, and I do
know that they've had 10Gbps links between their data centres for over
10 years.
Date: 2 Feb 2012 10:05:05
Message: <4f2aa621$1@news.povray.org>
It's like the thing with Google's data centre. A "computer" is a
low-power device. Unless you've ever worked with thousands of them at
once, it just doesn't occur to you what there might be power supply or
cooling issues to overcome.
I imagine the reverse also applies; somebody who works for Google would
probably think that the solution to "our tape drive just died" is "so go
buy a new one". They probably wouldn't even realise that to a small
company, £3,000 for a new tape drive is actually /a crapload of money/.
It probably wouldn't even occur to them.
In short, you don't really understand what it's like to work within a
given set of constraints unless, you know, you've had to work within
that set of constraints...
How is that even *possible*? It's not like you can just go to the
hardware store and buy 25km of copper wire and then put it into the
ground with a shovel on your day off or something...
Well, given that backup is what this SAN is *for*, I guess I mixed up
the two things.
>> smoothly? ;-)
> When it's planned properly. I've seen it happen. But, I must admit, that
Given the company that *I* work for, would you expect a smooth rollout? ;-)
> 10 years.
OK, so a major /bank/ can also accord crazy technology. None of this
alters the fact that the next tiny company I end up working for won't be
able to afford this kind of thing.
Date: 2 Feb 2012 16:06:42
Message: <4f2afae2$1@news.povray.org>
Agreed.  When I have a $250,000* piece of equipment that fails, I call
the toll-free number of the hardware vendor and they send me a
replacement in less than 24 hours, meanwhile its redundant mate keeps
the network running.  I don't have to deal with purchasing, maintenance
contracts or any of that.
BUT - and that's the important part - I thanks the FSM every chance I
get to not have to deal with these issues.  I've read too many horror
stories in comp.dcom.sys.cisco of people who had mission-critical
hardware fail and were asking for help trying to get the device back up
while trying to convince management to buy a new one, or looking for
spare parts on eBay.
*I assume that's how much these things cost as I have absolutely never
had to use the $ key on my keyboard, unless I was programming in Perl.
You don't do it yourself, unless you are in a campus environment and can
easily rip up the parking lot and lay down your own fibre or copper.
Step 1.  Call your telco rep and order a circuit between site A and site A.
Step 2.  Telco will forward the request to a planner who will determine
if the existing cabling between both sites and central offices (CO) has
enough available bandwidth.
Step 3a.  If not, the planner will forward the request to their
infrastructure group who will get diging permits from the
city/county/whatever and lay down new bundles of cables.
Step 3b.  If the answer is yes, or once the new cables have been laid,
the telco planner will forward your request to an enabler who will
configure the CO switches to map the circuit from Site A's demarcation
point to Site B's demarcation point.
Step 4.  Technicians will come on site, at both locations, and terminate
the circuit from their demarc point to the exact rack you ask them to.
Step 5.  You plug in the circuit in your equipment (router, switch, or
mainframe front-end-processor, to name a few)
Tada!
Usually, all of this is done for a small nominal fee.  Any work they
have to do between demarc points will be undertaken at their own
expense, which they will recoup on your monthly usage bill, of course.
By the way, if you ordered an "internet" link, the exact same steps
would have to take place, except that they would be duplicated for site
A to ISP and ISP to site B, and then the ISP would add its own routers
at both ends and charge you twice as much and more for the "managed
services".
> the two things.
I thought the SAN would replace some of the servers' internal disks. Sorry.
>>> smoothly? ;-)
>> 10 years.
What makes you think you can't find work in a large company?
Date: 2 Feb 2012 17:20:19
Message: <4f2b0c23$1@news.povray.org>
>>> explain WHAT IT IS.
>> something?
> RSS different?
You're being fairly obtuse here, Andy.
Go have a look at reader.google.com.  There's a tour on the site that
shows you how RSS feeds are useful.
Jim
Date: 2 Feb 2012 17:30:35
Message: <4f2b0e8b@news.povray.org>
Being aware of technology is important.
You find yourself in a job that you'd like to get out of, but you have no
idea how to do it.
People give you ideas, and you assert "that can't possibly work" or "that
can't possibly be useful".
But people who do those things actually find other jobs.
You don't do those things, and you don't have luck finding another job.
What does this tell you?
>>> explain WHAT IT IS.
>> <sigh>
>>  From wikipedia:
>> --- snip ---
>> automatically.
http://dictionary.reference.com/browse/syndicate
Definition 8.
>> A standardized XML file format allows the information to be published
Again, go look a the tour of Google Reader.
>> They benefit readers who want to subscribe to timely updates from
>> favorite websites or to aggregate feeds from many sites into one place.
Look at the tour.
> enough.
Yes, now you're understanding it.  Software or - surprise - another
website.
>> The user subscribes to a feed by entering into the reader the feed's
>> URI or by clicking a feed icon in a web browser that initiates the
> but OK...
Yes, actually, we have.  Subscribing means that instead of going to
Orphi's blog to see what he's written recently, I can go to my reader and
see what he's written recently.  Along with a bunch of other sources all
at once.
>> The RSS reader checks the user's subscribed feeds regularly for new
>> work, downloads any updates that it finds, and provides a user
It means I can see that you've written something new in your blog without
going and visiting your blog.
And about 100 other sites that I keep an eye on without visiting them
each every day to see what's new.
>> RSS allows users to avoid manually inspecting all of the websites they
>> are interested in, and instead subscribe to websites such that all new
It's time consuming to visit 100 sites to see if there's anything new.
It's far easier to be alerted when there's something new that might be of
interest.
>> I have the feed set up in Google Reader so that when you post something
>> I "avoid manually inspecting all of the websites [I] am interested in"
>> and can see what's new.
Look at the Google Reader tour.
>>>>> in the hardware world.
>>> first-hand.
>>> :-P
> Sarcasm? :-P
Or perhaps to find out what the latest processor is that you might be
able to afford?
>>> recognise who's who, and often the end credits are unreadable. But
>>> technically that still counts as "works", right?
So you just happened to get a crappy connection, while I got a good one?
Then your eyes are better than mine, or you got a really crappy
connection.
> especially slow...
And yet I apparently get a better picture at half the speed from the
other side of the planet....
>>> mean that people in America have something faster than ADSL or
>>> something?
Except that it isn't.  Part if it is called compression.
Convenience is a huge motivational driver for consumers.  But more to the
point, most people don't see the quality as being "poor".
Jim
Date: 2 Feb 2012 21:48:04
Message: <4f2b4ae4$1@news.povray.org>
On 2/2/2012 7:05, Invisible wrote:
> £3,000 for a new tape drive is actually /a crapload of money/. It
probably
When I first started at Bellcore, I joined during the budgeting time of
year. My manager asked "Do you foresee needing any equipment for your wor
k?"
I said "Well, I'll need a desktop computer of course." He says "No, I mea
n
equipment. Anything over $50K? If so, we need to budget it." :-)
That said, google does everything with such redundancy that it's not a
question of spending $3K to buy a tape drive, but a question of how many
$3K
tape drives you need to buy to back up 3 petabytes/day of data[*] and how
long are those drives going to last before you need to replace them,
factoring the salaries of the guys doing the fixing and the writing of th
e
code to allocate tapes to data.  ([*] All numbers ass-pulled, mind.)
> How is that even *possible*? It's not like you can just go to the hardw
are
> store and buy 25km of copper wire and then put it into the ground with
a
That's exactly what the companies that do this for a living do.
Date: 2 Feb 2012 21:52:31
Message: <4f2b4bef$1@news.povray.org>
> HTML is "a family of formats used to publish works [frequently updated or
> not] in a standardized format". As is PDF. As is PostScript. How is RSS
> different?
Well, maybe you need to read the *second* sentence, hmm?
Date: 3 Feb 2012 04:22:18
Message: <4f2ba74a@news.povray.org>
This comment makes the whole discussion worth it! :-D
> Tada!
> Usually, all of this is done for a small nominal fee. Any work they have
> to do between demarc points will be undertaken at their own expense,
> services".
Think is, if you order an Internet link, the telco has to run a few
hundred yards of cable to the nearest junction box at one end, and a few
hundred yards at the other end. If you want a dedicated circuit from one
end to the other without going via the Internet, they have to run
several miles of cable just for you. Who the /hell/ can afford that? o_O
>> the two things.
Actually, I am now 100% sure what the plan is here. Certainly the /main/
function of the SAN is routine data backup. I'm unsure whether we're
also going to use it for online storage too. (Hey, why would they tell
*me* such things? I'm only the person who's going to be running it...)
1. How many large companies are there? How many small companies are
there? Exactly.
2. How many people apply to each large company? How many people apply to
each small one?
To be sure, it's not /impossible/ to work for a large company. Just less
likely.
Date: 3 Feb 2012 04:23:28
Message: <4f2ba790$1@news.povray.org>
On 03/02/2012 02:48 AM, Darren New wrote:
> "No, I mean equipment. Anything over $50K? If so, we need to budget it."
That's more than our entire IT budget for a year. As in, the entire
corporation.
Then again, I think it may also be more *profit* than we make in a year,
so... :-P
Date: 3 Feb 2012 06:19:04
Message: <4f2bc2a8@news.povray.org>
> idea how to do it.
Well, for one thing, it tells me that now Christmas is over and it's
February, I really ought to start applying for jobs again. I haven't
done that in ages...
Not something I've ever heard of, but sure. That sounds like it might be
much more enlightening than Wikipedia.
> interest.
100 sites?! o_O
Damn, you actually follow that much stuff? Jees...
>>>> first-hand.
>>>> :-P
>> Sarcasm? :-P
> able to afford?
For that, I go to various shopping websites. I visit Tom's Hardware to
find out which products have good performance.
Or the BBC offers different quality levels in different parts of the
world? Heck, maybe they're even using a different codec or something? I
don't know.
> connection.
Yes. Because it's the connection that determines the picture quality,
not the sender. Oh, wait...
>> especially slow...
*sigh*
Do you want me to go grab a frame? Would that make you happy?
Sure, it's all compressed. But that almost always means lossy
compression. You have to trade how much bandwidth you have for what
level of picture quality you want. And that's the problem - it seems
that to stream realtime over the Internet, you have to accept really low
picture quality.
Well, FM radio isn't exactly "high fidelity", and yet it's quite popular.
Then again, FM isn't so bad as to render the content /unrecognisable/.
Right, let me go grab a frame from iPlayer...
Download '0006.png' (111 KB)
Preview of image '0006.png'
Date: 3 Feb 2012 07:45:39
Message: <4f2bd6f3@news.povray.org>
There is free software you can use that will download and save the
streaming media to your hard drive. So that you can watch or listen to
the programmes without all those buffering waits.
Regards
Date: 3 Feb 2012 07:58:35
Message: <4f2bd9fb$1@news.povray.org>
Oh, iPlayer lets you do that anyway. But yeah, it would be kinda useful
if I could do that to YouTube. (E.g., there used to be a video of a
really great performance on a Wurlitzer. It's now vanished...)
Date: 3 Feb 2012 08:03:29
Message: <4f2bdb21@news.povray.org>
http://www.youtubedownloadersite.com/
Regards
Date: 3 Feb 2012 09:09:52
Message: <4f2beab0$1@news.povray.org>
>> site A.
>> Tada!
>> services".
Which is exactly what I have described above, except the dealing with
the telco is done by the ISP's engineers, not you.
No. No. No. No.  What makes you think they would have to lay more cable
for a dedicated circuit than for an internet connection?  Re-read step 2.
A dedicated circuit from my company's site A to site B goes:
Site A -> Telco CO 1 -> Telco Cloud -> Telco CO 2 -> Site B.
An Internet VPN goes:
Site A -> Telco CO 1 -> Telco Cloud -> Telco CO 3 -> ISP -> Telco CO 3
Now, can you see that connecting to an ISP is effectively ordering TWO
dedicated circuits instead of one?
Using an Internet VPN only makes sense when the costs of a dedicated
cricuits becomes prohibitive and you must share the cost with others, at
the expense of latency and garanteed bandwidth.
Date: 3 Feb 2012 09:49:14
Message: <4f2bf3ea$1@news.povray.org>
The fact that rather than connecting you to an existing circuit, they're
building a brand new one from scratch.
If it goes through their main cloud, it isn't a dedicated circuit. It's
a shared circuit.
Date: 3 Feb 2012 12:36:45
Message: <4f2c1b2d$1@news.povray.org>
I never said they would build a new one from scratch, unless there was
no bandwidth available on their existing infrastructure.
> a shared circuit.
You can have dedicated bandwidth allocated to you on a shared physical
circuit.  For example, on a DWDM link, if I assing the 720nm frequency
to you, and the 680nm frequency to me, we would both have dedicated
bandwidth on that fibre strand as it is physically impossible for our
signals to suddenly merge or impact the other.  Likewise for TDM
circuits, where each fram is divided into timeslots, and each customer
is allocated a certain amount of timeslots.  There is no possibility of
overlap or oversubscription.
A "shared" bandwdith scenario would be ATM, Frame-Relay SVCs, X.25,
etc... where packets are sent through the cloud on a
first-come-first-serve basis and where there is the possibility of
oversubscription.
I apologize for using the word dedicated, instead of point-to-point.
Date: 3 Feb 2012 20:31:48
Message: <4f2c8a84$1@news.povray.org>
On 2/3/2012 6:49, Invisible wrote:
> If it goes through their main cloud, it isn't a dedicated circuit. It's a
> shared circuit.
SONET. That's what it's for.  It's dedicated isochronous bandwidth on a
shared circuit, designed to let you merge them together onto a faster
circuit and back out again.
You think when you make an ISDN call you're not getting a 64kbps dedicated
circuit for the duration of the call?
In any case, when you lay cable, you lay down way more than you need,
because the cost of the physical cable is trivial. THe first guy who asks
for a connection causes 900 pairs to be laid. The next 899 require none of
that work.
Date: 3 Feb 2012 20:33:08
Message: <4f2c8ad4$1@news.povray.org>
On 2/3/2012 4:58, Invisible wrote:
> Oh, iPlayer lets you do that anyway. But yeah, it would be kinda useful if I
> could do that to YouTube. (E.g., there used to be a video of a really great
It is called, not surprisingly, "Download Helper"
Date: 5 Feb 2012 18:05:35
Message: <4f2f0b3f$1@news.povray.org>
>> of interest.
> 100 sites?! o_O
Yes, I do.  Now for things like Slashdot or The Register, I skim
headlines in Google Reader.  I don't always read the full article - but
if a headline is intriguing, I'll dig in a little deeper.
With Slashdot, if I read the headline and it looks interesting, I'll read
the story there.  If it looks more interesting, then I'll open the link
to the /. story and follow the links to the actual story.
>>>>> first-hand.
>>>>> :-P
>>> Sarcasm? :-P
>> able to afford?
Bingo.  Thank you, you've made my point.  You *can* actually learn stuff
by reading about it on the 'net.
>> one?
> don't know.
I see.  So the BBC offers really crap quality to those who pay the
licensing fee in the UK, but offers really good quality to those who
don't?
>> connection.
Yes, it is the connection that determines the picture quality.  If I only
have a 32 Kbps connection, I'm not going to get a good quality HD picture.
> picture quality.
Would you like me to take a picture of Netflix streaming on my 10' wide
screen with a 3 Mbps ADSL connection?  Would that make you happy?
Jim
Date: 5 Feb 2012 18:28:00
Message: <4f2f1080@news.povray.org>
> don't?
Hmm!
I use get_iplayer to download progs and the blurb on the site says:
The iPhone H.264 feeds from the BBC are higher quality than in the Flash
iPlayer (normal quality). See the beebhack wiki for a comparison. They
are intended for the Apple iPhone and are consequently difficult to
download for any other OS. The same goes for the iPhone MP3 radio
streams. get_iplayer also allows recording of the high-quality (even HD
720p) flash based content using rtmpdump. None of the above content is
‘protected’ by DRM. get_iplayer cannot remove DRM.
http://www.infradead.org/get_iplayer/html/get_iplayer.html
BTW Just a minute starts its 62nd series on Monday. Happy 45th Birthday,
Just A Minute!
http://www.bbc.co.uk/programmes/b01blgp6
Regards
Date: 5 Feb 2012 18:55:06
Message: <4f2f16da@news.povray.org>
>> don't?
> Hmm!
That's the same software I use.  :)
It does seem odd, though, that they don't do HD streaming for iPlayer
itself.  I thought I saw a switch for that (but then again, iPlayer video
isn't something I can get my hands on easily without using get_iplayer
and a UK-based proxy).
> Just A Minute!
Jim
Date: 6 Feb 2012 04:20:29
Message: <4f2f9b5d$1@news.povray.org>
>> 100 sites?! o_O
> Yes, I do.
Damn. How do you ever get anything done?! o_O
You can /totally/ find out prices or technical specifications or look up
instructions. I'm saying you can't really comprehend a fundamentally
different world-view just by reading about it.
>>> connection.
Erm, no. It's the quality that the file is transcoded at.
>> picture quality.
It still wouldn't explain how it's possible... Every Internet video
system I've ever seen either has awful image quality or isn't realtime.
And it appears that's because the necessary bandwidth doesn't exist yet.
Date: 6 Feb 2012 13:42:33
Message: <4f301f19$1@news.povray.org>
On Mon, 06 Feb 2012 09:20:31 +0000, Invisible wrote:
>>> 100 sites?! o_O
>> Yes, I do.
I use Google Reader so I don't have to visit all those sites to see
what's new.  Takes me about an hour in the evening to go through the
day's posts and see what's new.
>> stuff by reading about it on the 'net.
Depends on who's written it.
>>>> connection.
A connection that isn't fast enough isn't going to show you the full
definition.  I defy you to demonstrate a high quality video over a slow
connection.
>>> And that's the problem - it seems that to stream realtime over the
>>> Internet, you have to accept really low picture quality.
<sigh>
https://lh6.googleusercontent.com/-UJGO-U7Whto/TzAdp1huWOI/
AAAAAAAABbs/1IPtFRGNv6Q/s912/2012-02-06.jpg
Now consider that's a quick photo of a 10' screen streaming realtime at 3
Mbps.  The bluriness you see there is an artifact of the camera used, not
the actual image on the screen.
Obviously the necessary bandwidth exists.
Jim
Date: 6 Feb 2012 14:33:18
Message: <4f302afe@news.povray.org>
Euch! The ubiquitous banker Mr Fry.
The quality looks okay or even good to me.
Regards
Date: 6 Feb 2012 14:38:09
Message: <4f302c21$1@news.povray.org>
We're watching "Stephen Fry Across America", just happened to think of
grabbing a pic while watching it last night. :)
That quality is reported by NetFlix as "Medium/HD", which is usually what
we get if nothing else is using the connection.
It's quite viewable.  We also tend to get full 5.1 sound with movies that
have it along with the good quality.
Jim
Date: 6 Feb 2012 14:45:00
Message: <web.4f302d50d1155342773c9a3e0@news.povray.org>
he's great as Sherlock's brother Mycroft in the latest flick...
Date: 6 Feb 2012 15:03:21
Message: <4f303209$1@news.povray.org>
He might be but personally I find him hard to watch because of his past.
Regards
Date: 7 Feb 2012 04:16:18
Message: <4f30ebe2@news.povray.org>
It used to take me about 4 hours in the evening (i.e., my entire
evening) just to read this newsgroup. (Although it seems a lot quieter
lately...)
> connection.
If the bitrate of the source is higher than the available bandwidth, it
just won't play in realtime. It'll constantly stall to rebuffer. So
presumably the guys behind iPlayer (and every other Internet video
system) have to transcode to a low enough bitrate that it will actually
play in realtime. The result is obviously poor image quality.
Consider, for example, that it took me 3 days to download Star Wreck,
which is only about an hour long. OK, that was only using a 2 Mbit
connection, but I don't suppose you can download almost 4GB of data over
an 8 Mbit connection in one hour flat either.
> <sigh>
Yes, the picture looks fine. I still don't understand how that can be
possible though. The Internet isn't fast enough. I don't see how you can
get the data from A to B fast enough for realtime playback.
Date: 7 Feb 2012 08:28:34
Message: <4f312702$1@news.povray.org>
> lately...)
>> connection.
Once again, you presumed wrong, since other people are able to see the
full image!
Bad example.  Assuming you downloaded it via bit-torrent from other
users, you were constrained by their very limited upload speeds.  If you
downloaded it from an FTP server, you were also porbably constrained by
the number of connections clobbering said server.
Netflix, and other streaming sites have banks of high performance
servers connected to very large internet pipes, in multiple sites that
are close to the users.  This way, there are fewer bottlenecks and
little to no latency issues that can interfere with the stream.
>> <sigh>
Which part of the Internet isn't fast enough?
Is HD tv available in the UK, from cable tv providers?  Stop and think
for a few nanoseconds how that signal is delivered to your cablebox.
Netflix and co. are the same thing, except the source server is just a
few 10Gbps hops further away on the Internet backbone.
Date: 7 Feb 2012 09:06:34
Message: <4f312fea$1@news.povray.org>
Except that you're downloading it from dozens of clients at once, should
should counteract that problem.
The last mile, as always.
I have no idea what "cable" is. I do know you can receive HD TV with an
aerial; presumably this uses higher bandwidth than a normal Internet
connection.
Date: 7 Feb 2012 11:15:01
Message: <web.4f314d6dd1155342352a052d0@news.povray.org>
> connection.
it's also far cheaper, since it's broadcast, i.e. all users receive the very
same stream, not a stream per millions of users...
Date: 7 Feb 2012 15:00:05
Message: <4f3182c5$1@news.povray.org>
> lately...)
I probably spend a couple hours a day reading my 200+ newsgroups.  Again
usually just skimming subjects for things that are interesting.
>> connection.
Clearly not, as shown in my photo.  In the case of Netflix, they use a
dynamically adjusting algorithm so it can display lower quality if the
bandwidth is throttled.  You'll note that I noted to Stephen that Netflix
shows "Medium/HD" as the quality for that image - that's usually what I
get.  If I had a slower connection, I get "High/SD" or "Low/HD".  If I
had a faster connection, I'd get "High/HD".
That was at a fixed quality setting, not being streamed.
>> <sigh>
>> 3 Mbps.  The bluriness you see there is an artifact of the camera used,
>> not the actual image on the screen.
Compression.  We've been over this before.
Jim
Date: 8 Feb 2012 04:05:50
Message: <4f323aee$1@news.povray.org>
Damn. If I had that much stuff to look at, I'd *never* get any work
done... Oh, wait.
So they actually offer multiple quality levels? Well, I guess that makes
good sense. I'm not sure how you'd automatically detect which one to
use, but I guess with the right client software it ought to be possible.
Lossy compression allows you to make the file size be anything you want
it to be. But this does not happen by magic; it happens by degrading the
picture quality. So while it obviously /is/ possible to reduce a video
stream to, say, 3KB per second, it wouldn't be worth watching. What I
can't figure out is how they can shrink it down to realtime download
speeds without it looking awful.
Date: 8 Feb 2012 08:25:40
Message: <4f3277d4@news.povray.org>
Not always.
Which varies a lot from place to place.  First, because your DSL speed
will be affected by the distance or the CO from your house, and by the
quality of the wires.  On top of that, different carriers have different
services.  For example, on top of various DSL packages, my telephone
company offers fibre connections at 7, 10, 16 or 25 Mbps.  My Cable
provider offers comparable packages as well.
> connection.
Presumably?  Again.  After having been shown 4759483758975 times in this
thread alone that your assumptions were wrong, you still persevere!!!
Also, http://en.wikipedia.org/wiki/Cable_television
Date: 8 Feb 2012 09:08:10
Message: <4f3281ca$1@news.povray.org>
> Not always.
As in "you're not always downloading from that many clients", or as in
"downloading from many clients doesn't give you greater bandwidth"?
> will be affected by
Yes, but given that 8 Mbit/sec is the maximum speed that current ADSL
standard allow, we can take it as read that nobody is going faster than
that.
Oh, really? Well, if you're getting 25 Mbit/sec then yes, streaming
full-quality video in realtime /should/ work just fine.
(At least, for SD video. Apparently BRD has a transfer rate of 36
Mbit/sec, so it looks like HD video still wouldn't work.)
>> connection.
And to think people tell me I don't persevere enough...
At any rate, a cursory inspection of Wikipedia seems to indicate that,
yes, digital TV is higher bandwidth.
Oh, is /that/ what that means? OK. I didn't know you could use this for
anything other than analogue TV. Our house used to have this, before
everything went digital.
Date: 8 Feb 2012 15:37:02
Message: <4f32dcee$1@news.povray.org>
>> Again usually just skimming subjects for things that are interesting.
> done... Oh, wait.
Certainly if you didn't have a way of handling it more quickly, you
wouldn't.  That's kinda my point.
You start with the lowest quality and increase the quality until you hit
some sort of limitation.  Buffer enough so it doesn't stutter when you
hit the limitation, and then back off.
>>> can get the data from A to B fast enough for realtime playback.
Measuring latency and throughput.  It's not magic.
Jim
Date: 8 Feb 2012 22:35:23
Message: <4f333efb$1@news.povray.org>
> standard allow, we can take it as read that nobody is going faster than that.
It depends entirely over the distance you are from the head end. I get
12Mbps on the DSL line that only has to go down to the street from my condo.
> (At least, for SD video. Apparently BRD has a transfer rate of 36 Mbit/sec,
Have you tried watching an HD youtube video, out of curiosity?
Date: 9 Feb 2012 04:25:15
Message: <4f3390fb$1@news.povray.org>
>> than that.
No, it does not.
http://en.wikipedia.org/wiki/ANSI_T1.413_Issue_2
"The maximum achievable downstream data rate is 8.128 Mbit/s."
If you're too far from the exchange, you will get less than 8 Mb, but
you will never get /more/ than 8 Mb. That's like saying that if you
connect a USB 1.0 device with a short enough cable, you can make it go
faster than 12 Mb. Erm, no, no you cannot, because the USB 1.0 standard
specifies a maximum data rate of 12 Mb.
So, like I said, unless you're using something other than ADSL, you
cannot go faster than 8 Mbit/sec.
I think I've tried flicking the quality switches at some point. From
what I recall, turning the quality up makes playback a bit less
reliable, and the picture quality a bit less awful. But it's certainly
not as good as SD TV picture quality.
(Or rather, certain SD channels. I've noticed that some digital TV
channels are also fairly heavily compressed...)
