POV-Ray : Newsgroups : povray.off-topic : How random... Server Time
19 Mar 2026 20:28:01 EDT (-0400)
  How random... (Message 1 to 9 of 9)
Subject: How random...
Date: 6 Jan 2012 06:57:42
Message: <4f06e1b6@news.povray.org>
http://software.intel.com/file/37157
Subject: Re: How random...
Date: 6 Jan 2012 09:48:56
Message: <4f0709d8@news.povray.org>
Neat.
I wonder what generation of processors will gain this facility?  It
won't be generally useful until it becomes widespread and even then what
is the fallback when software detects that it is not running on a
processor with the facility?  Use less secure PRNG and seeds as now?
Probably will be appear in crypto devices and gaming machines (i.e.
poker machines etc.) where the enabled processor is specified rather
than in general use.  Even there, in things like poker machines the
vendor has to be able to prove that the RNG is compliant with whatever
rules a jurisdiction sets.  True randomness may strangely not be
acceptable but I'm not sure.
It reminds me of the Integrated Cryptographic Facility available on IBM
S/390 mainframes circa 1990 (?).  It was a separate processor module
that offloaded crypto functions from the CPU.  From memory they
supported highly tamper proof key storage and hardware implementation of
DES, Triple DES etc. but not a hardware entropy source.
I saw an early hardware RNG device that relied on thermal noise.  It was
about the size of a microwave oven.  Most of it was I think to ensure
that the noise source was kept in a very narrow temperature range so
that physical randomness was never biased.  One of these was hooked up
to the Internet and you could get the random stream.  Sort of defeats
many of the possible uses of randomness when everybody can see the same
stream.  But for simulations and testing algorithms it was useful I guess.
Date: 6 Jan 2012 10:28:55
Message: <4f071337$1@news.povray.org>
> Neat.
Ivy Bridge. (I.e., the next release after Intel's current Sandy Bridge,
found in processors such as my shiny new Core i7 2600K.) Also whatever
the codename for the corresponding Xeon component is.
> It won't
> be generally useful until it becomes widespread and even then what is
> the fallback when software detects that it is not running on a processor
Depends on the use case, I suppose.
Gaming really does /not/ require true randomness. Human players suck at
distinguishing psuedo-randomness from true randomness. (Humans suck even
more at *producing* randomness...)
Numerical simulation sometimes *requires* repeatable "random" inputs.
And sometimes true randomness is desirable.
Cryptography is the real one where true randomness becomes a Big Deal.
Given how trivially easy it is to use this new system, I'm sure lots of
people will add support for it. But, as you say, you cannot rely on it
until it becomes widespread. I wonder if AMD will copy this?
> S/390 mainframes circa 1990 (?). It was a separate processor module that
> offloaded crypto functions from the CPU. From memory they supported
> highly tamper proof key storage and hardware implementation of DES,
I gather crypto devices like that are still quite popular.
> that physical randomness was never biased. One of these was hooked up to
> the Internet and you could get the random stream. Sort of defeats many
This implementation uses thermal noise for the truly random part. It
then uses a normal psuedo-random generator seeded from that.
Something like the Linux /dev/random driver collects things like
keypress timings, packet arrival times, etc., and puts it into a big
"entropy pool". It then computes a hash of that pool whenever somebody
wants a random number. Makes it very hard for an external attacker to
predict the numbers. It has problems though:
1. This might be running on a headless server, so no keypress events.
Indeed, if the server is mostly idle other than generating keys, there
might not be much entropy comming in at all.
2. It's implemented in software. If you can somehow subvert the OS, you
can take a peek at the entropy pool and predict the future. Similarly, a
DMA attack might be possible if you have hardware access. On top of
that, you might be able to change the driver implementation to make it
spit out NON-random numbers that you decide.
3. It's fairly slow. It fundamentally relies on I/O events, which are
glacial compared to the speed of the CPU.
4. Other users can see the random output. If the algorithm leaks, that
might help an attacker. Timing attacks might be possible. An attacker
might be able to suck the entropy pool dry just be requesting (and
throwing away) lots of random numbers very quickly. Depending on the
implementation, this causes either denial of service or reduced random
quality.
By contrast, Intel's new design is implemented in hardware. It's
impossible to see the output of the entropy source. It's impossible to
know exactly when reseeding happens. It's impossible to replace the
random number algorithm with a broken one. It's impossible to stick
probes onto the FSB and snoop the entropy pool. (You can still snoop any
actual keys generated, mind you.)
I also like how there's hardware to monitor the generated random data to
check it's random enough. The bizarre thing about randomness tests is
that they _should_ fail occasionally, because a truly random data series
always contains the occasional pattern by fluke.
Date: 6 Jan 2012 11:14:38
Message: <4f071dee$1@news.povray.org>
Yeh.  I read the PDF.
Thanks for the info on Ivy Bridge.  I haven't looked at processor
generations for a while.  Bought a laptop about a year ago with an I7
processor.  Still have a couple of desktops with Q6600 processors from a
few years back which are still absolutely fine for day to day use and
development.
Rendering is the only thing that is really processor bound and I don't
do much of that lately.  Oh, I did have a crack at the Eternity II
puzzle but there isn't enough CPU power on the planet for that yet.
On a meta-question - Why not post a brief summary when you provide a
link?  A lot of people wouldn't bother to follow an unknown link.  I
usually don't.  Then, some people would follow the link and find it a
waste of time to them and be less inclined to look at anything you post
in the future.
Is it a deliberate strategy to tempt people, are you too lazy, or do you
feel the Invisible brand of off-beat random linkage is sufficiently
powerful?  Probably the latter and I guess around this forum that is
true - except where Haskell is involved :)
Date: 6 Jan 2012 11:26:32
Message: <4f0720b8$1@news.povray.org>
One of the annoying things about this stuff is that if you stop paying
attention for a while, it becomes nearly impossible to easily get back
up to speed. Plenty of places will tell you about the latest and
greatest up-to-the-minute developments, but if you haven't been
following recently, you won't have the context to know WTF they're
talking about. Nothing seems to provide that context. Nothing that I've
discovered, anyway.
I do quite a bit of rendering, and I *have* been doing it recently. ;-)
Also, my current PC seems to be slowly dying. (!) My sister got me a
shiny new CPU for Christmas, I already have the motherboard, so now I
just need to buy an OS...
> link?
Eh, I don't know. I was just being playful really. It's a random link to
a paper about randomness. It amused me.
But yeah, sure. For most of the things I post, the description could be
absolutely anything and nobody would be interested. I guess I'm just a
really boring person...
Date: 6 Jan 2012 11:51:31
Message: <4f072693$1@news.povray.org>
On 7/01/2012 3:26 AM, Invisible wrote:
> ... I guess I'm just a really boring person...
Not at all.
I think it was a careers guide that had an entry "Boring - See tunnel
engineering".  Way to go sterotyping a whole profession that I'm sure
would have its fair share of interesting individuals.
Date: 7 Jan 2012 08:25:11
Message: <4f0847b7$1@news.povray.org>
When I was a cryptographic maintenance technician in the USAF, I did
work on one piece of gear which actually generated random bits, using
the thermal noise from a component chosen for this task.  The voltage
bias on the components had to be within precise limits.  I forget
exactly what the random bits were used for.  I recall that we were told
in no uncertain terms not to fiddle with any of the circuitry involved;
if it didn't work, we simply pulled the circuit card and sent it back to
the depot.  For the rest of the equipment, we troubleshot down to the
component level.  The equipment was phased out around 1990.
John
Date: 7 Jan 2012 13:25:39
Message: <4f088e23@news.povray.org>
On 1/6/2012 8:14, Paul Fuller wrote:
> On a meta-question - Why not post a brief summary when you provide a link?
While I normally agree, I must admit the title of the post and the "intel"
in the URL told me what was going to be at the other end. :-)
   People tell me I am the counter-example.
Date: 7 Jan 2012 19:23:34
Message: <4f08e206$1@news.povray.org>
> bias on the components had to be within precise limits. I forget exactly
> what the random bits were used for. I recall that we were told in no
> uncertain terms not to fiddle with any of the circuitry involved; if it
> didn't work, we simply pulled the circuit card and sent it back to the
> Regards,
> John
Wow.  Somebody with real world knowledge.
Thanks for sharing.
