POV-Ray : Newsgroups : povray.off-topic : Adrenaline Server Time
16 Jun 2026 15:00:57 EDT (-0400)
  Adrenaline (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Adrenaline
Date: 3 Nov 2011 08:28:11
Message: <4eb288db$1@news.povray.org>
On 10/25/2011 7:51 AM, Invisible wrote:
> Take the company's mission-critical server. Take a disk image of the OS
> partition. Boot from a Linux live CD. Reformat the system partition.
> Restore the system partition from the image file, and pay to God
> almighty that it actually boots up again.
Why would you do such a thing to begin with?
Date: 3 Nov 2011 08:56:47
Message: <4eb28f8f@news.povray.org>
  You have to look busy or else management will start doubting your
necessity.
Date: 3 Nov 2011 09:45:09
Message: <4eb29ae5$1@news.povray.org>
The server is persistently experiencing NTFS corruption errors, and I
just can't get rid of them. Which is strange, because if I restore the
image file to a virtual machine, it runs completely without issue...
You won't be surprised to learn that the elaborate procedure above
utterly failed to fix the problem. But hey, it was worth a shot.
http://blog.orphi.me.uk/
Date: 3 Nov 2011 10:19:41
Message: <4eb2a2fd@news.povray.org>
  I assume you have checked the disk for errors. Thoroughly.
Date: 3 Nov 2011 11:19:16
Message: <4eb2b0f4$1@news.povray.org>
1. Would a physical disk error actually affect a logical RAID-1 volume?
(And shouldn't that affect *all* the partitions, not just one?)
2. Yes, I asked CHKDSK to do a full surface scan. It found nothing wrong.
I've seen fleeting references that say that CHKDSK doesn't fix all
possible filesystem errors, so perhaps that's the problem I'm seeing
here... Still doesn't tell me how to fix it though.
Date: 3 Nov 2011 12:22:45
Message: <4eb2bfd5$1@news.povray.org>
When you write "logical RAID-1 volume", are you referring to a volume
created by mirroring two drives in the Windows OS, or is it a volume
created via the adapter hardware+software?  Also, what Windows OS,
drives and adapter(s) are you using?
Date: 3 Nov 2011 15:56:19
Message: <4eb2f1e3$1@news.povray.org>
> created via the adapter hardware+software? Also, what Windows OS, drives
It's a hardware RAID controller, transparent to the OS. I don't know
precisely what model off the top of my head, but considering it's a Dell
rack-mount server, it's probably a Dell OEM device of some kind.
Server OS is Windows 2003 Server R2 Enterprise.
Date: 4 Nov 2011 09:06:45
Message: <4eb3e365$1@news.povray.org>
Replace the batteries on the RAID controller.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 4 Nov 2011 09:12:50
Message: <4eb3e4d2$1@news.povray.org>
You think failing batteries would cause one partition on the RAID volume
to persistantly suffer NTFS corruptions, but the other (much busier)
partition on the same logical volume works correctly?
Hmm, I wonder how much money Dell want for a new battery? ;-)
Date: 5 Nov 2011 08:42:33
Message: <4eb52f39$1@news.povray.org>
It may not read and write the same number of bytes, but as far as the
number of IO requests go, the system partition is probably as busy as
the other user data volumes.  Event viewer logs, DLLs loading, swap file
usage, etc...
I don't know about Dell RAID controllers, but on the ones I've seen
(Compaq (back in the mesozoic era), HP and IBM) they were standard
batteries that you can find in most electronic stores (e.g. Radio Shack
in North America)
