POV-Ray : Newsgroups : povray.off-topic : I giggled a bunch at this. Server Time
16 Jun 2026 16:15:53 EDT (-0400)
  I giggled a bunch at this. (Message 11 to 20 of 41)
Subject: Re: I giggled a bunch at this.
Date: 29 Sep 2011 09:55:52
Message: <4e8478e8@news.povray.org>
Francois Labreque <fla### [at] videotronca> wrote:
> Origin of INDEX
> Latin indic-, index, from indicare to indicate
> First Known Use: 1561
  The first known use of the word doesn't necessarily mean it's the first
known use of an index in a book.
Date: 29 Sep 2011 10:15:58
Message: <4e847d9e$1@news.povray.org>
On 29/09/2011 02:55 PM, Warp wrote:
> Francois Labreque<fla### [at] videotronca>  wrote:
>> Origin of INDEX
True - but I think we can safely say that books had indicies /long/
before working computers even existed, which was my original assertion.
Date: 29 Sep 2011 14:11:38
Message: <4e84b4da$1@news.povray.org>
On 29/09/2011 12:04 PM, Invisible wrote:
> The first "computer" was arguably the design by Babbage, and the first
> "algorithm" was allegedly written by Ada Lovelace, who died almost
> exactly 1 century before Turing.
I would argue that algorithms go further back than that. Consider
control mechanisms. If you want an engine to run at a constant speed
with a variable load. You would use an algorithm like this.
Test the speed of the motor.
If the speed is lower than the target speed then increase the power.
If the speed is greater than the target speed then decrease the power.
If the speed is within limits then neither increase nor decrease the power.
solution to the algorithm. Roman engineers maintained water levels for
their aqueduct system by means of floating valves that opened and closed
at appropriate levels. Someone had to create an algorithm no matter how
simple.
> Now if we could establish when the first book with an index was created...
For library catalogues see
http://en.wikipedia.org/wiki/Library_catalog#History
Long, long ago.
Regards
Date: 29 Sep 2011 15:38:03
Message: <4e84c91b@news.povray.org>
>> Origin of INDEX
The first use of the word set a key date.
The first book with an index, even if named diferently, was made
strictly before that year.
Date: 29 Sep 2011 17:19:59
Message: <4e84e0ff$1@news.povray.org>
>> Origin of INDEX
Agreed.
but if the first documented use the word index to was in 1561, we can
safely assume that the first use of the index itself predates it.  I was
only establishing the upper bound.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Sep 2011 22:14:29
Message: <4e852605$1@news.povray.org>
> simple.
Depending on your definition of "computer", there is evidence of a one
of a kind "Roman" device that was capable of predicting eclipses, and
timing the correct date to start the Olympic games, among other
features. In other words, an electronic calender. But, at that time,
such things where nearly impossible to replicate, so when the ship it
was one sank... Arguably, its gearing system had to have some sort of
"algorithm".
https://secure.wikimedia.org/wikipedia/en/wiki/Antikythera_mechanism
Date: 30 Sep 2011 04:08:13
Message: <4e8578ed$1@news.povray.org>
At this point, it becomes necessary to define what you mean by "algorithm".
Is long division an "algorithm"? Because the ancient Babylonians
apparently had that waaay back in 3100 BC. That's some FIVE MILLENNIA ago.
What I actually /said/ was that computers (by which I mean fully
autonomous computational devices) had O(log N) lookup way later than
books (by which I mean large textual documents stored as visible marks
on some sort of medium) had it. Given how ancient writing is and how
comparatively new functioning computers are, I think that's a safe
assertion.
Date: 30 Sep 2011 04:18:09
Message: <4e857b41$1@news.povray.org>
There is that too.
Turing-completeness is a reasonable definition, until you consider that
a sheet of paper and a pen is Turing-complete given a suitable human to
operate it. So perhaps the significant thing is the sophistication of
computations that the device can perform without human aid.
> features.
Last I heard, nobody had decided exactly what that device was for. It
seems opinions have changed...
I think you mean /automated/ calendar. It's only /electronic/ if it
operates by moving electrons around. :-P
> But, at that time,
> was one sank...
We're talking about something from a /long/ time ago. The fact that no
others have been found yet doesn't mean none existed.
> Arguably, its gearing system had to have some sort of "algorithm".
By that description, the way that trees use the laws of physics to move
exactly the right amount of water from their roots to their leaves could
be considered an "algorithm". Which would mean that algorithms predate
mankind by several billion years...
Date: 30 Sep 2011 05:48:45
Message: <4e85907d$1@news.povray.org>
I would define an algorithm the same way the Wiki does.
An algorithm is an effective method expressed as a finite list of
well-defined instructions for calculating a function.
So I would say that the steps for doing long division are an algorithm.
What do you mean by "fully autonomous computational devices"?
I am not familiar with the Big O notation so I misread your sentence. As
usual I tried to make some sort of sense out of what could have been
typos and or bad grammar and spelling.
So in English, if possible, what do you mean?
That is just juvenile and pompous. Only funny to a teenager.
> assertion.
using ones and zeros.
I have worked on computers that were solely pneumatic. They could add,
subtract multiply and divide. Standard components could extract square
roots integrate and average.
Regards
Date: 30 Sep 2011 05:59:54
Message: <4e85931a$1@news.povray.org>
On 30/09/2011 9:18 AM, Invisible wrote:
> Which would mean that algorithms predate mankind by several billion
> years...
Let's not go down that road again :-P
Regards
