POV-Ray : Newsgroups : povray.off-topic : Is this the end of the world as we know it? Server Time
23 Nov 2026 02:37:51 EST (-0500)
  Is this the end of the world as we know it? (Message 431 to 480 of 545)
<<< Previous 50 Messages Goto Latest 50 Messages Next 50 Messages >>>
Subject: Re: Is this the end of the world as we know it?
Date: 18 Oct 2011 16:19:02
Message: <4e9ddf36$1@news.povray.org>
On 10/18/2011 2:20 AM, Invisible wrote:
>> Some dependencies are very coarse, yes. Some are not. Your assumption,
>> based on a high level understanding, is incomplete - and you certainly
>> *could* ask for more information about it and possibly even contribute to
>> making it better.
> IME, although the open source development model means that theoretically
> anyone can contribute to improving the product, in practise this doesn't
> work. It's extremely rare for submitting a bug report to actually result
> in a fix. [That's assuming the problem is even strictly speaking a "bug"
> and not merely a "hey, maybe if the system looked more like THIS it
> might be better".] Actually contributing code is usually a practical
> impossibility, for various reasons.
> I'm sure somebody somewhere is committing code. But for most of us, it's
> just not an option.
This is *highly* dependent of which distro and/or project you are
talking about. There is a habit, once a project, or even a distro of an
OS, gets beyond a certain popularity, either bugs start getting ignored,
due to the number reported spiking, or they start munging with the
interfaces, and features, and neglect actual problems. There is probably
also an unfortunate tendency for some people to think, "Wow, everyone is
using this, so everyone must be fixing it, so I will just sit and wait
for them to do so." All of those things combined result in the smaller,
less known, ones often progressing faster than the really well known
ones, in some cases. The latter loose focus on what matters, which is
everything bloody working right, even after you added some new feature.
This can also even result in, "We are too busy to fix that right now, so
your code that *does* fix it is going to vanish into a black hole."
Or, so it seems to me, from things I have read off and on, with various
things, once enough people started paying attention to them, versus when
they where "new".
Date: 18 Oct 2011 16:24:43
Message: <4e9de08b$1@news.povray.org>
On 10/18/2011 10:14 AM, Orchid XP v8 wrote:
>> I've never had software from a repository not "just work" when I
>> installed it. Certainly no worse than Windows, which will still
>> occasionally get confused enough to need you to uninstall and reinstall
>> a device driver.
> Problem #1 is when the software you want isn't in the repository, or is
> in a different repository. Problem #2 is when the package depends on a
> different version of some core library that everything in the entire
> system uses.
> I've seen crappy Windows drivers do lame things. Applications tend to
> work reasonably well - except stuff written for Windows 3. (It depresses
> me how much software of that kind I still have to deal with at work...)
No, depressing is realizing that most of those things "would work" well,
if you still have Windows 3, because fixing them usually amounted to
updating every single damn system file, to the most stable version, and
in the right order, due to the tendency of one program to install and
destroy the prior, better, version of that library (which might have
been 2.4, while the one your "new" program replaced it with was 1.3). I
really fail to comprehend how MS ***never*** thought of version checking
back then, and why the hell, even after they did, all they did was go,
"Do you want me to screw this up, by replacing the newer version with
one that won't work?" Huh??? Gosh, sure...!
Date: 19 Oct 2011 03:58:42
Message: <4e9e8332$1@news.povray.org>
>> By an unusual coincidence, I've just come back to my desk after trying
>> to fix one of the three Windows NT machines we're still using... I
>> wonder if that control software works on XP?
> Should. XP was the "upgrade" for both 98 and NT, replacing both. So,
> there isn't likely a reason it wouldn't. Unless, of course, there is
> some wrench in the gears, due to some minor quirk they changed between
> NT and XP, which suddenly hosed those specific applications. That is
> generally why, combined with pure ignorance of even if they would work,
> and how well, that keeps old crap in the system.
We have an application for Windows NT which doesn't work under XP
because it replaces serial.sys with its own custom version. (I'm not
kidding!) Fortunately, we don't use that damned useless program any more...
The application I was fixing yesterday does communicate via the serial
port, but I don't think it does anything particularly special. Indeed,
it appears to be designed for Windows 3, not NT.
Date: 19 Oct 2011 12:20:44
Message: <4e9ef8dc@news.povray.org>
On 10/19/2011 0:58, Invisible wrote:
> We have an application for Windows NT which doesn't work under XP because it
> replaces serial.sys with its own custom version. (I'm not kidding!)
That's exactly why in later versions of Windows, you started seeing code in
the OS to roll back such changes automatically.
> The application I was fixing yesterday does communicate via the serial port,
> but I don't think it does anything particularly special. Indeed, it appears
One of the biggest upgrade problems between Win3/Win98 and the NT series was
stuff that used the serial port, because on NT you had to go thru the
drivers and on the single-user OSes you could access the hardware directly.
   How come I never get only one kudo?
Date: 19 Oct 2011 15:04:15
Message: <4e9f1f2f$1@news.povray.org>
On Mon, 17 Oct 2011 21:00:16 -0700, Darren New wrote:
> On 10/17/2011 16:05, Jim Henderson wrote:
>> And I suppose it's possible to put stuff in the registry that IIS won't
>> read, so I'm not sure what your point is with that...
> That you'd have to put it under a name that IIS won't look at, whereas
> grep has no way of knowing what files Apache won't look at. It's much
> easier to say "IIS roots are stored under \HKLM\blah\yadda\*\docroot"
> and get all of them than it is to parse XML with include files using
> grep.
Well, sure, you'd have to put them someplace where IIS won't look at it.
With Apache, the same holds true - if you want to put it someplace where
Apache won't care, don't put it in /etc/apache2. :)
Jim
Date: 19 Oct 2011 15:04:36
Message: <4e9f1f44$1@news.povray.org>
On Tue, 18 Oct 2011 09:04:49 +0100, Stephen wrote:
> On 18/10/2011 4:47 AM, Jim Henderson wrote:
>>>> >>  I think you've just got my Halloween costume selected.;)
>>> >  OMG A six foot guising penguin. I bet you won’t be dooking for
>>> >  Apples. ;-)
>> I wouldn't take that bet.;)
> No! You jailbroke your Apple and put Linux on it. 8-)
And then Apple sued me into oblivion. ;)
Jim
Date: 19 Oct 2011 15:15:42
Message: <4e9f21de$1@news.povray.org>
On Tue, 18 Oct 2011 10:29:40 +0100, Invisible wrote:
>>>>> Wait - YaST has documentation?
>>>> Um, yes.  man yast for starters.
>>> Surely that just tells you the command name and what switches it has?
>> TRY IT.
>> That *is* in fact what documentation is, though, so yes - it has
>> documentation, and it's included in the man page.
> Right. Well knowing what the command switches are isn't going to help me
> configure Apache, is it?
Yes, it won't.  But if you want to configure apache, you read the Apache
documentation.
Or if you've got the yast http module installed, you can try yast2 http-
server longhelp for command-line help.
Or in interactive mode, you would click the "Help" button.
Similarly, reading a book about how to use OS/2 isn't going to tell me
how to use OS/400.  You have to read *relevant* documentation.
>>> You're assuming that I'm just doing it wrong, and not that it's
>>> actually a poorly designed system.
>> I'm assuming you can be taught.  You seem to have an aptitude for
>> learning, but you also seem to think that if you believe something is
>> impossible, then it damned well is impossible - and nothing anyone says
>> is going to change your mind.
> If somebody told you that the Earth is in fact flat, would you take the
> time to sit down and have a rational conversation with them? Or would
> you just be like "psssh, yeah RIGHT! Bye..."
So, to carry the analogy out, you believe the "Earth is flat" and you're
not willing to be convinced otherwise?
> Likewise, if you use a piece of software and it's clunky and awkward to
> use, and somebody else is all like "it's divine and perfect and flawless
> in every way, you're just using it wrong", are you likely to investigate
> what they're saying?
Um, nobody's saying that.  What I'm saying is that if you ask questions
on relevant forums, you can actually get help to configure it and learn
how it works.
Unless you'd rather just bitch about how impossible everything is.
But you seem to enjoy learning new things.  Which means more than just
reading books and websites - occasionally it means talking to people who
know more about the topic than you do.
See how that works?
>>> In my experience:
>>> 1. The user-friendly front-ends tend to be quite fragile. If something
>>> breaks, you still need to go edit the underlying text file by hand.
>> My experience with the supposed 'fragility' of those tools is
>> different. <shrug>   Maybe 10 years ago it was, but not today.
> Well, I suppose short of me spending the next 10 years using Linux all
> day, there's not much we can do to resolve this particular point.
You could try asking some questions!
>> Or you use Webmin, which actually *does* (a) work the same regardless
>> of distribution, and (b) can manage the services on multiple
>> distributions.
>> I mean really - I used it to manage configuration on SunOS, exactly the
>> same way I used it on RedHat and SUSE.
>> But of course, you want to believe that doing so is impossible, so I
>> must've imagined it, right?
> Like I said, the normal way to configure Linux applications is via
> exiting textual configuration files. I never said it was "impossible" to
> do it any other way. I just said that that is the main cultural focus.
> Which is different from the cultural focus on Windows. That's all I was
> trying to say. Sheesh...
When I pointed out that, hey, there are some tools (some of which are in
fact standardised across different distributions) that mean you *don't*
have to edit text files, you responded with incredulity.
As if my experience in doing so was actually invalid or something.  Or
that I was lying, or that I had invented it in order to make you feel
foolish.
I assure you that *none* of those are the case.
>>> I haven't seen much "evidence to the contrary". The entire Unix
>>> philosophy seems to revolve around doing everything from the command
>>> line.
>> If you haven't seen much evidence to the contrary, you haven't been
>> looking.  Really, you haven't.  I talk to Linux developers fairly
>> regularly, and to application developers on occasion who work on OSS
>> applications for Linux.  Banshee isn't just a front-end to CLI tools.
>> Neither is F-Spot.  Neither is Photivo.  Neither is OpenOffice.
>> Neither is [...] - the list goes on and on and on and on and on and on
>> and ON.
> OK. So I've actually heard of one of the items on that list. I'll give
> you that.
My point is that while hard-core *nix utilities do tend to be that way,
it's a mistake to think that that's the *only* way Linux programs are
created - as a front-end to some cryptic CLI interface.
More and more Linux programs (especially end-user programs) are not front-
ends to CLI tools but are programs in their own right.
Oh, GIMP - another Linux tool that's not a GUI front-end to cryptic CLI
tools.
Banshee - Mono-based music player
F-Spot - Mono-based photo management tool
Photivo - photo manipulation software
OpenOffice - Office productivity suite
GIMP - Image manipulation program
>> As I recall, it was seen as an appropriate punishment.
>> As I recall, they have a specific release of Windows for the EU that
>> allows IE to be removed (completely, IIRC).
> My spider-sense says something about Windows Media Player... I guess I'd
> have to spend a few hours Googling it to find the real answer.
Yeah, there might've been something about WMP as well.  I didn't follow
it that closely.
Jim
Date: 19 Oct 2011 15:17:46
Message: <4e9f225a$1@news.povray.org>
On Mon, 17 Oct 2011 20:57:08 -0700, Darren New wrote:
> On 10/17/2011 16:29, Jim Henderson wrote:
>> On Sun, 16 Oct 2011 20:31:06 -0700, Darren New wrote:
>>> On 10/16/2011 20:18, Jim Henderson wrote:
>>>> I cited a counterexample, and you changed the criteria.
>>> Yes. I clarified.  Why, are we keeping score?
>> Not much point, just hard to debate when the criteria keep changing.
> I wasn't aware either of us was trying to convince the other of any
> particular point. I thought it was a conversation, not a debate. :-)
That's fair. :)
But even in conversation, it's difficult to make a point when the
criteria for the point is constantly changing.
>>> My point is that in spite of how I'm interpreting your claims, Windows
>>> does indeed have "software management elements" in their OS and
>>> supporting software.
>> I never said that they didn't have "software management elements" in
>> the OS and supporting software.  I'm talking about those elements in a
>> software distribution system.
> Windows Update and ClickOnce don't count? :-)
Never heard of ClickOnce.  Windows Update is typically for kernel-level
stuff or MS-specific stuff, not third party software.
Jim
Date: 19 Oct 2011 15:36:17
Message: <4e9f26b1@news.povray.org>
On Tue, 18 Oct 2011 10:20:58 +0100, Invisible wrote:
>> "I don't know of anybody who's using it yet."
>> I'm using it.  In a VM.  So there's one. ;)
> There's always one. ;-)
> No, seriously. I'm not saying nobody on Earth is using it. I'm sure
> people are. I just said that not /many/ people are using it yet. I
> imagine that will gradually change over time.
Every new PC that ships with Windows ships with it.  While some
manufacturers are dropping PC lines, they still make enough money selling
kit.
>> When I'm giving technical interviews, you might recall, I ask questions
>> I know the candidate doesn't stand a chance of asking.  The reason I do
>> this is to find out how they learn beyond their current skill.
> That's kind of evil. I'm not sure how somebody sitting in an interview
> chair is supposed to solve a problem right there on the spot. I mean,
> it's not like they can go away and look stuff up...
I don't ask them to solve it.  I ask *how* they would solve it, and what
resources they would use.
It's real-life.  If a system is down, the candidate will need to actually
fix it and leverage what resources are available to them.  If I recommend
someone be hired, I don't want them to freeze when a system goes down and
they're the only one available to fix it.  I want them to be resourceful,
and that's something you have to figure out before you make an offer.
Hiring people is expensive.  Hiring the wrong person is much *more*
expensive.
>> You seem to think there's no point in asking questions to learn more.
>> That's troubling.  You *have* the ability to learn, and you seek out
>> information when it suits you.  But at the same time, you declare
>> something as "impossible"
> If I wanted to know how to live forever, I wouldn't bother posting a
> question in an online forum. You know why? Because... it's...
> impossible. It's not that I don't know how, it's that IT CANNOT BE DONE.
But if you want to know how to configure Apache on Linux, *that is NOT
impossible*.  Clearly.  People have done it.  A significant portion of
the web's web servers actually run that configuration.
So why wouldn't you bother asking a question in an online forum in that
instance?
> Now with software we're dealing with somewhat less absolute quantities.
> I gather that if you read Linux From Scratch, it actually directs you to
> where you can download the source code for an entire Linux/GNU system
> and compile just the parts you want from source. YOU do the dependency
> management by hand, and in theory you can alter the source code to
> remove dependencies you don't want. So hypothetically it's *possible* to
> work around any given distro's poor dependency management. Does that
> mean I actually want to go to such extremes? Not really, no.
And you *don't have to*.  So, what you're saying is that if you want to
figure something out, you try the absolute most difficult way of doing
it, and then declare it impossible?
Why not try the *easiest* way to do it, and if it doesn't make sense, ask
a few questions so you can learn?
>> (remember the discussion we had a couple years ago about debugging a
>> kernel?  You uncategorically declared it was impossible to do so, and I
>> told you that I had actually *done* so myself, but you still refused to
>> believe it was possible to use a kernel debugger to get anything useful
>> out of a crash).
> I still don't get how you can take megabytes of unformatted raw binary
> and glean anything remotely useful from it, but hey. Apparently there's
> some kind of black magic that makes this possible...
It's called education.  It's also not unformatted - the format of a stack
dump is known, you just need to know how to interpret it.
That's what I've done - I've learned how to interpret the data I'm
looking at in a kernel debugger.  It's not actually a pipe of /dev/
urandom, it actually does have a logical structure that can be learned.
I know.  I did learn it for that particular platform.
>> You need to revise your view on that kind of thing and admit that you
>> don't know *everything*, but that there are people who know *more* than
>> you do and that you could *learn* from them.
> The greatest knowledge is in knowing that you know nothing.
The greatest knowledge is in knowing that you can learn something.
> On the other hand, if you punch a brick wall with your fist, it hurts. A
> lot! Now do you assume you're just doing it wrong, and go ask an online
> forum how to do it "right"? Or do you just stop punching walls? I know
> which one I'd go for... I guess that makes me ignorant then.
Straw man alert.  Learning to read a stack dump is not like punching a
brick wall.  Learning to configure apache is not like punching a brick
wall.  Learning how to use Linux is - you guessed it - NOT LIKE PUNCHING
A FRIGGING BRICK WALL!
Stop drawing false equivalencies.
>>> My limited experience is that when you ask for help, you get no reply.
>>> Or you get a few replies from people who don't really know how to help
>>> you, but they try to offer you some kind of useful information anyway.
>> Your experience is limited; you need to gain more experience.
> If you try something, and it doesn't work, you can keep trying it over
> and over again, or you can try something else. Which option is the most
> rational?
Neither - asking for help is the most rational option if it's something
you think is important enough to try to learn in the first place.
> (I guess it's a question of degree, of course. If you give up at the
> first try, you'd never get anywhere. Then again, if you keep doing
> something that clearly doesn't work, you're also not going to get
> anywhere...)
Yes, which is why you ask questions of people with more experience.  Do
you sense a common theme here yet? ;)
>>> What's to understand? Dependencies are tracked at a fairly coarse
>>> level. It is what it is. Just live with it...
>> So, there's absolutely nothing more you can learn about dependency
>> tracking in Linux?
> Package managers track package dependencies. Packaging teams write those
> dependencies. Sometimes their structure is a little coarse. What more is
> there to learn?
That "sometimes" doesn't mean "always", for a start.  It isn't always a
question of packaging, for example - it can be a question of what
components are compiled together into a single library.
>> assumption, based on a high level understanding, is incomplete - and
>> you certainly *could* ask for more information about it and possibly
>> even contribute to making it better.
The OSS model actually doesn't mean that "anyone can contribute", but
rather that those who demonstrate skills can.  They don't call it a
'meritocracy' for nothing. :)
> just not an option.
If you've never committed code to the kernel, Linus isn't likely to let
you rewrite an entire subsystem to suit your needs.  But if you write
patches/fixes for known bugs and your code is good, yes, you can get into
the team that does the work.
Again, "meritocracy".  One's ability to contribute is directly relative
to the merit of one's contributions, and to do so, you have to start
small.
>> Or at least understand it better, instead of parroting an explanation
>> that the MS-fanbois just love.
> The irony is, I used to be the biggest Microsoft hater ever. I was used
> to using AmigaOS, an operating system which ACTUALLY WORKS PROPERLY.
> Compared to that, everything to come out of Redmond seemed like the
> biggest pile of junk ever. And then along comes Linux. It's based on
> tried and tested technology. It has powerful tools. It has uptimes
> measured in decades. It's faster and more efficient. It sounded so
> exciting!
> Of course, initially Linux was a total PITA to set up and actually use.
> You needed to know all sorts of exotic technical details about your PC
> in order to get it to install. Making X11 work was basically a hopeless
> task.
At the time it came out, maybe 10 years ago for that matter (half it's
life), that was true.  It's much less true now, though one can run into
problems.  Which is why there's a community to help you out when you have
issues.
I installed openSUSE 12.1 Beta 1 on my laptop.  The video went all
wonky.  What did I do?  I posted a question on the openSUSE forums (where
I'm staff) and asked if anyone else had seen the issue.  Turns out
there's a bug submitted for it, and in a more recent kernel being tested,
it's supposed to be fixed now.
So, I asked a question and learned (a) that it's a known issue, (b) it's
being worked on, and (c) a fix has probably been committed that I can
test out.
So when I have a chance, I'm going to try that fix and report back
whether it worked or not.
What I *didn't* do was just declare "it's hopeless to get this to work"
and give up.
See how that works?
> Over time, however, I came to realise that Linux doesn't actually seem
> to be much more efficient than Windows. That used to be one of the big
> things people talked about: you can run Linux on a 283 with 16MB RAM,
> and it WORKS, and it WORK WELL. Try doing that with Windows! But you
> know what? It's a long time since I've seen a distro that can still do
> that.
Puppy Linux, Damn Small Linux...there are a few left, but yes, most
kernel developers have moved on from providing 286 support, because
there's not much call for it.
> Essentially, things have evolved to the point where you can compare
> Windows and Linux, and see that each of them actually have merits
> compared to the other. And the point we're currently arguing about is
> one of them. On Windows, you just *install* stuff, and it works. Under
> Linux, you try to install stuff, and mostly it just works... except when
> it doesn't. And then all hell breaks lose.
And when it doesn't work on Windows or Linux, one asks questions to get
help.
And I would debate "all hell breaks loose" with Linux when it doesn't.
When it doesn't, it doesn't.  Usually (for me) on the rare occasions it
happens, it's a missing dependency, and that's pretty easy to figure out
these days.
> I'm not saying the entire Linux system sucks. I'm saying one specific
> aspect of it is annoyingly difficult. And yet, everybody is yelling at
> me like I'm some noob who installed Linux, tried it for ten minutes, and
> couldn't figure out what the A: drive is called now so I gave it. It's
> not LIKE that AT ALL. And it irritates me when people tell me I don't
> know what I'm talking about...
Well, it irritates several of us when you say "it's f-ing impossible!@!!@!
@!!" when in fact it's not, and you just haven't asked for help.
There's *always* someone with more experience.  In the Linux community,
most of those with more experience are more than happy to help those with
less, but in order to get that help, you have to ASK for it.
Jim
Date: 19 Oct 2011 16:50:52
Message: <4e9f382c@news.povray.org>
I've heard good things about Oblivion...
http://blog.orphi.me.uk/
Date: 19 Oct 2011 17:21:34
Message: <4e9f3f5e$1@news.povray.org>
Well, OK... but since the only possible answer is "I would go read the
manual and/or search Google", that doesn't seem like a particularly
searching question.
Either that or I just failed to get hired - again...
> impossible*.
Sure. You just need to read through the manual for a while. The question
at hand was "is it possible to make the package manager do what you
want?" To which the answer is "no, not really".
> instance?
IME, if you ask anything more complicated than "why doesn't Flash
work?", either nobody understands the question, or nobody has the
answer. Most likely you'll just get no reply at all. Or maybe one reply
from a guy who doesn't speak English well. None of which helps fix the
problem...
The problem is pretty simple: The package manager tracks dependencies on
a rather coarse level. (In some instances. Sometimes it's fine,
sometimes it's less than ideal.) Either you just put up with it, or you
bypass the package manager, which is stupendously difficult.
I'm not sure what you think there is to "learn" here. It's not like I
don't know why the problem exists or what causes it.
How do you know which part is the stack? How do you know which parts are
code and which parts are data? How do you know where in the program the
processor was executing?
You say "the format of a stack dump is known", except that... no, it
isn't. The stack holds whatever arbitrary data the program decides to
write to it. Without knowing how the program works, how can you get
anything useful out of that?
My point being, if you're trying to do something that's clearly
infeasible, do you continue trying to do it? Or do you go try some other
approach?
>> rational?
And if "asking for help" is the thing that isn't working?
>> there to learn?
Sure. I didn't say it *never* works right. I said that sometimes it
doesn't, and then it's a real pain to deal with.
> It isn't always a
Every distro manages their stuff in a slightly different way. I seem to
recall that if you installed POV-Ray under Debian, it used to insist on
installing PVM, because the Debian POV-Ray package was a heavily
modified PVM-patch of the official POV-Ray sources or something weird
like that. (I presume this has been fixed now...)
Actually I've never heard anybody call it that, but sure, whatever.
People say "if you want something fixed, file a bug report". IME, this
achieves next to nothing. Last time I filed a bug against something on
Linux, a got one or two replies from the dev team, and then I heard
nothing for THREE YEARS, and then I got an email saying they think
they've fixed it and could I test it? I mean, I stopped using that
package and that distro two years ago... like I *care* anymore!
I've submitted patches to product documentation. Like, literally, all
somebody has to do is check that my DocBook markup is sane, and that the
few paragraphs I've changed are factually correct, and then hit "merge".
They HAVE the patch right there. I've done all the work of finding the
right source files, filling in the right info, and so forth, so all the
busy dev team has to do it hit a button instead of spending five minutes
writing the stuff themselves.
It still took 6 months for the changes to get applied. Just because
that's how long it took for my patch to be looked at. I guess since it
was only documentation, it was low priority. (Compared to patches for
stuff that are actually stopping people doing stuff...)
All I'm saying, people say "well it's open source, if you don't like it,
you can fix it". Erm, no. No you can't. Unless you're very fortunate.
> life), that was true.  It's much less true now.
Sure. I thought I wrote that somewhere...
There's an old joke that "Ubuntu" is an African word meaning "I can't
install Debian". And, let's face it, the first time I tried to install
Debian, it was a highly complex process. Today things are much simpler;
often you can run Linux without even /bothering/ to install it. Heck,
sometimes you don't even need to reboot...
> Which is why there's a community to help you out when you have issues.
In my experience, the "community" is absolutely useless.
> test out.
> and give up.
> See how that works?
Now, see, I would have just assumed "It's a beta. It's not supposed to
actually work. Obviously there's nothing I can do about this. I should
go try a different version or something." Because, let's face it, I know
nothing about how device drivers work in Linux, and if the masterminds
who put SUSE together couldn't get this right, there's no way in hell
that *I* can possibly fix it. So that's the end of that.
>> that.
Most of them seem to start at 386 and up. (Having recently looked at the
IA32 reference manuals, I now understand why...)
I don't suppose you happen to know of a distro that's particularly
optimised for running in a VM?
> help.
Getting help for Windows is roughly as difficult as getting help for
Linux. If you ask a question, typically an MSVP will point you to a KB
article. This may or may not be relevant to what you actually asked, and
may or may not actually fix your problem. If it does fix it, it usually
works great. If there isn't a KB article about your specific issue...
good luck!
> these days.
So you've never had the package manager try to replace glibc and utterly
break your install to the point where you have to replace the entire OS?
Or you mean you've learned what I learned: if it mentions touching
glibc, abort the operation. (?)
It irritates me when people say something is possible when it damned
well isn't. :-P
Like I said, when I ask, nobody helps.
Date: 19 Oct 2011 17:30:17
Message: <4e9f4169$1@news.povray.org>
> documentation.
...which will only tell you how to do it via the configuration file
interface which you keep insisting it isn't necessary to touch.
Which presumable again just tells you about command switches, not how to
configure Apache using YaST.
More like you keep insisting that the Earth is flat, and then act all
surprised when I don't immediately believe you.
> how it works.
I know how it works - not very well. (In varing degrees, anyway.) What's
to ask?
Let's be clear about this: I said that package management can be a pain
sometimes. WHICH IS TRUE. I didn't say it was *impossible* to install
anything. I just said sometimes it's very difficult to make it do the
correct thing.
I pointed out a small deficiency in a piece of software, and everybody
is like "no, you're just too stupid to work it correctly". As if no
software ever has deficiencies...
> See how that works?
Reading documentation can be quite enlightening - or not. It depends on
how good the documentation is. IME, asking people is almost always an
utter waste of time.
The standard Unix philosophy is that programs are controlled mainly via
the command line and via textual configuration files. Does every single
piece of software available for Linux follow this model? No. Do the vast
majority of them follow this model? Yes.
OK, fair enough.
Date: 19 Oct 2011 17:59:00
Message: <4e9f4824$1@news.povray.org>
I intended it more as "yes, you're right in this instance, but I was
thinking about that situation instead."
I bet you did, if you heard the crap about MS installing "without asking"
extensions to support it in firefox. :-)
Date: 19 Oct 2011 21:30:25
Message: <4e9f79b1$1@news.povray.org>
Oh, I see. :)  That's what I get for being overtired for the past week
(last week I ended up at a conference working - but it was a good way to
network - and this week I'm doing some additional contract work writing
some documentation for some low-level Linux kernel stuff).
> asking" extensions to support it in firefox. :-)
Ah, *that* thing.  I hadn't heard it called that, just heard about the MS
extensions being installed without the user being asked. :)
Jim
Date: 19 Oct 2011 21:30:53
Message: <4e9f79cd$1@news.povray.org>
I hear it's rent/mortgage free. ;)
Jim
Date: 19 Oct 2011 21:37:28
Message: <4e9f7b58$1@news.povray.org>
>>> me configure Apache, is it?
>> Apache documentation.
Which is why you use the HELP button.
>> http- server longhelp for command-line help.
Try it.  It's more than that, again, pay attention to those who actually
have used it instead of making assumptions and then declaring those
assumptions to be true, regardless of how true you believe them to be.
BTW, you do know the world is not in fact flat, right?  Just checking. ;)
>>> the time to sit down and have a rational conversation with them? Or
>>> would you just be like "psssh, yeah RIGHT! Bye..."
>> you're not willing to be convinced otherwise?
Except that I'm telling you the Earth is round, and you're insisting that
it's flat.  (Your ideas are not based on current implementation; if they
were, you'd see that they're incorrect).
>> how it works.
> to ask?
*sigh*
You don't know how it works.  You have an opinion about how well it
works.  How well it works != how it works.
> correct thing.
Yes, package management can be a pain sometimes.  But you've also claimed
that it's impossible to learn how to manage apache using YaST.  It isn't,
as evidenced by the thousands of people who *do just that*.
>> who know more about the topic than you do.
>> See how that works?
Yeah, again, because I've only spent 20 years answering questions on
online forums, and I *love* wasting my time.
I accept that your experience has not been so good.  I'm telling you it
isn't always that way and that you could certainly try over in the
openSUSE forums when you have questions about openSUSE.  I tell you this
because we have a significant number of users who *have* received help
and *have* been able to make things work after being told how to use the
software.
You continuing to deny that you could ever possibly get help in an online
forum by asking questions, when you're told that there is a place you can
ask questions and generally people are VERY HAPPY when they get
answers....well, it's just silly.
Your experience can change, but only if you continue to try asking
questions.  Giving up because you've had little to no success in the past
isn't ever going to get you out of that rut.
Just like searching for a job - if you stop searching, nobody's ever
going to offer you something better.
>> in fact standardised across different distributions) that mean you
>> *don't* have to edit text files, you responded with incredulity.
*No*.  That's my point.  Low level system stuff, yes; end-user
applications DO NOT DO THIS.
> OK, fair enough.
*Finally*, I think we're making progress. ;)
Jim
Date: 19 Oct 2011 22:10:10
Message: <4e9f8302@news.povray.org>
>>>> questions I know the candidate doesn't stand a chance of asking.  The
>>>> reason I do this is to find out how they learn beyond their current
>>>> skill.
>> what resources they would use.
> searching question.
That is a legitimate answer.  It isn't the only answer, though - because
one could ask people with more experience.  They could get in touch with
teammates who know the systems better, or with people they know from
other companies.  They could ask at a user group meeting (if it's not a
critical system-down issue, obviously - waiting until your next LUG
meeting isn't really good if the users can't work).
Point is, there are many options.
>>> DONE.
>> impossible*.
The answer is "it depends on what you want to make the package manager
do".
And if I want to know how to configure a specific aspect of Apache, say,
enabling PHP5 on it, I look at the relevant Apache docs, compare to
what's in YaST or Webmin, and if it doesn't make sense, I ask a question.
While waiting for an answer to the question, I continue to research.
>> instance?
> problem...
*sigh*
Again, because of course, I have enjoyed wasting 20 years of my life
helping people in online forums.
Yes, your experience varies from mine.  I'm telling you that it needn't
be that way.
I had a problem with openSUSE 12.1's support of the Radeon X300 video
controller in my laptop.  I asked a question.  I got an answer that
pointed me to a bug indicating a known issue.  I got a follow-up answer
that a newer kernel seems to have fixed it, and asked if anyone could
confirm.
This evening, I got an answer from someone saying that one issue seems to
be fixed, but there's still some video corruption, indicating it's not
completely solved.
But it's being worked on, and I'm learning more about what's going on
with the issue.
Now, did I waste my time?  You tell me.  Remember that it's beta and the
fix is in progress, though, before you answer that question.
>> ask a few questions so you can learn?
It's not really that difficult to "bypass" the package manager, but it
can create more problems for you.  (rpm -ihv --nodeps is one way to
bypass; download the source and compile is another.  The first is easier,
but may lead to a non-working package.  The latter may uncover some
dependency conflicts in library versions etc.)
But if you're having difficulty with dependency resolution, you ask a
question about it and then perhaps someone builds the package for you.
I hear you laughing.  Don't.  We've got a guy over in the openSUSE forums
who does this for people who need a package built for their installation
if there's no pre-built RPM available.  His user ID is malcolmlewis, and
he's been happy to do this for anyone who asks.
He uses the Open Build Service (build.opensuse.org), which incidentally,
can build packages not just for openSUSE, but for many distributions -
including Debian, Ubuntu, Redhat, CentOS, SUSE Linux Enterprise,
openSUSE, and probably a few others.
You don't know how to deal with it.  That's what there is to learn; you
think you just have to live with it, but you don't always have to do that.
>>> there's some kind of black magic that makes this possible...
>> stack dump is known, you just need to know how to interpret it.
The debugger tells you those things, especially if you are in a live
kernel debugging session.
Well, yes, it is.  Because you have structural elements from the software
known to the debugger.  You frequently have symbolic debug information
available to you.  You may refuse to believe this, but I know it from
having *actually done it*.
The CPU "knows" how to process the instructions, and it knows what the
data is that's going through it.  It "knows" what functions it's running,
what the call stack is, and how to return to the previous functions.
A kernel debugger just gives you the tools to ask the CPU what it's doing
in a particular stack frame.
It really *isn't* rocket science.
>> PUNCHING A FRIGGING BRICK WALL!
> approach?
If it is clearly infeasible, then how come so many people actually
succeed at using it?
>>> most rational?
Then ask for help asking for help.  Posit - a user opens a bug in
bugzilla, but doesn't know what information is useful to the developer.
You can either open the bug and say "I don't know what would be useful to
help debug this, if you tell me what and how to get it, I'll get that
information for you", you've just asked how to ask for help.
Have you read Eric Raymond's essay on "asking questions the intelligent
way"?  (I believe that's the title).  It's a very good overview on how to
get help in online forums, mailing lists, IRC, whatever.
For example, ESR says (quite truthfully) that if you ask someone to read
the manual to you, you're not likely to get help.  If you say "I've read
the manual on this, and am having trouble parsing it", you're more likely
to get help.  If you don't assume an outcome ("I'm having trouble with my
video resolution and think it's due to microfractures on my motherboard,
how do I repair those motherboard problems") but say something like "I'm
having video problems, here is what my video controller is, operating
system and release, and drivers - and here is what I've tried so far",
you're likely to get help.
>>> those dependencies. Sometimes their structure is a little coarse. What
>>> more is there to learn?
So if it's being a pain, ask if that's normal, and if it isn't, then
there's a problem to fix.  If it is in that instance, then you know it's
expected behaviour.
You seem to be saying "it's a pain" and assuming that it's expected to be
that way.  There may actually be an underlying problem that needs to be
fixed that would make it less of a pain for you.  But you'd rather
complain, apparently, that it's a pain.
That's what's frustrating me in this conversation.
>> It isn't always a
It may have been.  Or you could install povray from the sources or a
binary package here.  Then you get the latest version that Chris & team
have put together, and you don't have to deal with the Debian dependency
issues.
Well, look up the term - you'll learn more about how patching actually
works in many OSS projects.
Some projects do tend towards more monolithic management (where one
person leads and codes), but larger projects do tend towards the idea
that you can contribute if you prove yourself.
Sometimes that happens.  It depends on the severity of the bug and how
frequently it happens or is reported.
A bug that one person once saw a couple years ago but nobody else has
reported an issue with isn't likely to get attention.
A video problem (like my radeon driver bug) affects lots of people and
clearly is a serious issue.  It's actually getting attention right now
before the oS 12.1 release.
>> into the team that does the work.
Doc is a lower priority, which isn't a good thing - but it's also
necessary for doc patches to be reviewed for accuracy.
You can always write a patch for the code you're running and submit it
upstream.  If it works for you as you've patched it, you've done what you
should.  If you distribute the code with your patch, you have to make
your patch available (if it's GPL'ed code that you're modifying), but if
you don't distribute it, you're not actually legally required to
distribute your patch, and you can certainly run the code on your own
system with your own customisations.
So yes, you can fix it if you don't like it.  The dev team also isn't
obligated to accept your patch, but that doesn't mean your patch can't be
used in your system and that you can't share it independently of their
code distribution.
>>> use.
I've heard that joke before.  It's a good one.  (says the openSUSE guy) ;)
I can't see that you've asked any questions in the openSUSE or SUSE
communities about your upgrade woes.  Seems there's an avenue that you
haven't looked at.  So I'm not sure how you can say the openSUSE
community is useless, as you haven't tried it.
>> (where I'm staff) and asked if anyone else had seen the issue.  Turns
>> out there's a bug submitted for it, and in a more recent kernel being
>> tested, it's supposed to be fixed now.
>> it's being worked on, and (c) a fix has probably been committed that I
>> can test out.
>> and give up.
>> See how that works?
I don't know much about how device drivers work either, but there's a
reason betas are released publicly.  So people can try them and report
issues they have so they can get fixed before release.
It's not about you or me being able to fix a radeon driver issue.  It's
about being able to say "hey, this doesn't work" and having someone look
at it.  Something like this video issue, I asked because if it's more
than just my lowly X300 card, it's an important issue to get addressed.
If it were just my system, I'd probably still raise an issue because the
same driver on the 2.6.xx kernel in 11.4 works flawlessly.  12.1 uses the
new 3.1 kernel, so it's probably a kernel driver issue, and that's
something that the openSUSE folks will report upstream to the kernel dev
team (if they're not actually on the kernel dev team already).
Point is, if you use it and don't report the problem, unless someone else
has the issue and reports it, it's guaranteed not to get looked at.
>>> that.
There are some pretty significant differences, yes.
Depends on what you want to do with it.  Custom SUSE builds done in
Studio can be built as a VMDK or OVM (I think is the extension) format
for use in virtual environments.
>>> when it doesn't. And then all hell breaks lose.
>> help.
> good luck!
The Microsoft MVPs generally do a good job answering questions in the
Microsoft forums, from what I've seen.
Of course, going in there and saying "this piece of crap just sucks and
doesn't work right" isn't likely to get you an answer, either.
>> out these days.
Nope, I haven't.  Because when I update using the package manager, it
tells me what is going to need to change because of the glibc update/
change, and if it's not acceptable to me, I refuse the update.
It means look at the possible effects.
>> impossible!@!!@! @!!" when in fact it's not, and you just haven't asked
>> for help.
> well isn't. :-P
Except that it *is*, otherwise, how is it that millions of people use
Linux every single stinking day?
>> with less, but in order to get that help, you have to ASK for it.
Come over to the openSUSE forums and ask for help when you're next using
openSUSE.  You'll *probably* be pleasantly surprised.
If you don't ask, you're *guaranteed* not to get any help.
It's like the old joke about playing the lottery - you have to play to
win.  Except the odds of getting a useful answer on a Linux forum are
far, *FAR* better than the odds of winning the lottery.
Jim
Date: 20 Oct 2011 00:08:22
Message: <4e9f9eb6$1@news.povray.org>
Yeah, no problem. Lots of people *try* to turn conversations into debates.
Certainly I'm not going to mind that you thought I was doing that. :-)
Yeah. It's their package manager for applications you install and update
over the web. I'm honestly not sure why they felt the need to add support in
firefox, but there you have it.
Date: 20 Oct 2011 00:48:41
Message: <4e9fa829$1@news.povray.org>
Does Apache load all configuration files in /etc/apache2? I thought there
were like include directives or something.
Date: 20 Oct 2011 05:11:23
Message: <4e9fe5bb$1@news.povray.org>
>> searching question.
I keep forgetting that other people actually work in teams.
If I were to ask someone from my team for a solution, their first answer
would be "did you try rebooting it?", followed by "hold on, let me check
Google..."
> be that way.
Well, like I say, short of spending 10 years using Linux and seeing if
anything is different this time, there's not really any way for me to
verify your claim objectively. Either I believe you or I don't.
Now, again, I wouldn't have even attempted to use a beta version in the
first place. (But then, that's why they label it as beta. If you don't
want the risk, you don't use it. If the risk is acceptable, you try it
out...)
I couldn't get anybody to tell me the command name to turn off the
firewall [which would have taken then 3 to 4 seconds], and you expect
that somebody is going to build a custom package just for me? [Which
would presumably take several hours if not days.]
Can you see why I might be reluctant to believe this?
OK, so how the heck does the debugger know which chunk of unformatted
data is the stack?
I don't follow. What do you mean by "structural elements"?
Wait - you mean the debugger can actually see what the processor is
doing, not just what's in memory?
I can see how that might be possible for a live debugger session. (I
mean, assuming the debugger can take over control of the CPU somehow.)
I'm not sure how that would be possible for a raw memory dump.
Managing packages in Linux has *always* been a pain. It's gradually
improved over the years, but sometimes it still falls down. What I can't
figure out is why you seem to be denying that there's anything wrong
with it.
> binary package here.  Then you get the latest version that Chris&  team
> issues.
I would have presumed that building POV-Ray from source would simply be
intractably difficult. It would probably be simpler to find a binary
package from somewhere else and try to convince that to install somehow.
Regardless, hopefully Debian fixed this particular stupidity long ago.
(I seem to recall POV-Ray doesn't comply with Debian's definition of
"free" either, so it's in non-free or something...)
In fairness, looking back at the ticket, the actual issue was that
such-and-such a package doesn't work properly on AMD64. The issue
presumably was upstream (i.e., it isn't Gentoo's fault that SmartEiffel
doesn't run correctly on AMD64). That probably doesn't help. Plus I
doubt SmartEiffel is insanely popular.
> upstream.
Not if you don't speak C you can't. :-P
Heh. Made me chuckle when I first heard it.
I still think dselect is horrid! >_<
I didn't mean any specific Linux community. I just offhandedly meant
"every one that I've tried".
Did you know I used to be a member of the local Linux User Group? Went
to all the physical meetings and everything. I even brought my Amiga
1200 with me, running Debian "potato". I was rather surprised that this
turned out to be *drastically* slower than AmigaOS. Like, it took 20
minutes for GNOME to start. (!!)
The guys in the LUG were very friendly and everything. It's just that
they never had the slightest clue how to fix my problems, or even where
to start looking. Every suggestion I got from them always started with
"man" followed by a command name...
Again, if a video driver for a very common video card doesn't work, I
would assume this has already been reported multiple times over.
Virtual memory being the big one...
I'm thinking more about the fact that if you do a default install of
[any distro you care to mention], it installs power management
utilities, firmware updates, scanner and webcame capture software, and
all sorts of other hardware-related stuff which is simply useless on a
VM. So first you have to wait for all this lot to download, and then you
have to spend time uninstalling it again.
I'm just wondering if anybody has packaged up a set of stuff more
appropriate to running a VM. But yeah, I guess it's going to vary
depending on what you want the VM for...
>> good luck!
Some of the stuff written my MVPs is quite enlightening. For example, I
once found [and will probably never find again] a website dedicated to
MS Word glitches. It actually explains several interesting points which
aren't mentioned in the documentation anywhere. Very useful stuff.
Replies to specific issues that I desperately want to fix tend to be
less helpful. It seems the experts have no more idea what to try than I
do. (Of course, with most of these things there's always the potential
for the problem being some 3rd party software that a Microsoft expert
isn't going to know anything about...)
Sure. But "this one specific printer doesn't print through Terminal
Services" got me little to no replies either.
> Nope, I haven't.
That's pretty impressive.
>>> for help.
>> well isn't. :-P
I didn't say it's impossible to use Linux. Heck *I* do that! I said in
certain situations it's impossible to make the package manager do what
you want.
As it happens, I've just upgraded my work PC, and I was just about to
set up a couple of Linux VMs. One of them will probably be OpenSUSE. I
may or may not be able to get VMware Tools to work on it... so I may
have to take you up on that one.
(OTOH, I'm not looking forward to setting up yet *another* account on
yet *another* forum... Like I don't have enough of those yet!)
> win.
Except that if you don't play, the probability of winning is zero, and
if you do play, the probability of winning is so close to zero as to be
effectively zero for all practical purposes.
Can you tell why I don't play the lottery?
Date: 20 Oct 2011 05:18:08
Message: <4e9fe750@news.povray.org>
> Try it.
Not easily feasible. I don't have access to a SUSE box right this minute.
Well, you know, that's what manpages do. They give you a terse reference
to the bare essentials of what a tool does. That doesn't seem like much
of an "assumption" to me.
The Earth *is* flat. Oh, it isn't flat in *Euclidian* geometry, true
enough. But in elliptic geometry? It's flat. Or flattish, anyway...
OK, well like I say, I'm about to try to set up a new OpenSUSE
installation. If it doesn't work out, I'll give it a try.
Clearly I'm searching in the wrong places. You know, given that I never
find anything worth even applying for... I still need to look at that,
actually.
Date: 20 Oct 2011 12:36:02
Message: <4ea04df2@news.povray.org>
On 10/20/2011 2:18, Invisible wrote:
>> Try it.
http://lmgtfy.com/?q=man+yast2&l=1
Sorry, but you really needed the lmgtfy this time. :-)
> Well, you know, that's what manpages do. They give you a terse reference to
> the bare essentials of what a tool does. That doesn't seem like much of an
> "assumption" to me.
While true in this case, actually running Yast gives you a very nice and
comprehensible interface.
> Clearly I'm searching in the wrong places. You know, given that I never find
> anything worth even applying for... I still need to look at that, actually.
Did you apply to google?  Send me your contact info, and I'll push it into
the process here to get you a call.
Date: 20 Oct 2011 16:00:45
Message: <4ea07ded$1@news.povray.org>
Darren used to say "Google is your friend".
Now we say "Google is your employer". :-P
>> never find
>> actually.
> into the process here to get you a call.
If I apply, am I going to have to commute to London?
If yes, then there's really no point applying. If they'd let me work
remotely, than I'd totally be interested...
(Not that it's impossible for me to travel to London. I just don't want
to do it on a daily basis.)
Date: 20 Oct 2011 17:15:34
Message: <4ea08f76@news.povray.org>
OK, now *that* is going in my .signature at some point.
You would have to work that out with them. They'd probably pay to relocate you.
I don't know about England, but in the USA, that tends not to be common.
That said, why the hell are you so resistant to even talking about applying?
Why are you asking me for all the reasons you shouldn't even bother to apply
to one of the most desirable tech companies around when someone on the
inside is offering to get your resume to the top of the pile? Do you think
if you interview they're going to *make* you work there?
You know, this is probably one of the few places where your employer might
pay you to work in Haskell. :-)
> (Not that it's impossible for me to travel to London. I just don't want to
Sure. I live 75 miles from where I work, and until I got that straightened
out, it was pretty annoying commuting every day. There's still enough people
here that commute to the next city over that we run 3 vans every day.
   People tell me I am the counter-example.
Date: 21 Oct 2011 04:09:31
Message: <4ea128bb$1@news.povray.org>
Do you have any idea how long I've been waiting to say that? ;-)
Mmm, that's what I figured. Oh well...
> applying? Why are you asking me for all the reasons you shouldn't even
> bother to apply to one of the most desirable tech companies around when
> someone on the inside is offering to get your resume to the top of the
> pile? Do you think if you interview they're going to *make* you work there?
I'd just feel kinda bad about making them go to all the trouble of
interviewing me, going through a long elaborate selection process,
finally getting a job offer, and then after all that saying "oh, you
want me to work in London? OK, forget it, I'm not interested", and them
being all like "WTF? Why did you even apply?!" I'd feel like I wasted
everybody's time.
> might pay you to work in Haskell. :-)
Yeah, maybe. Or perhaps look after some other piece of their
infrastructure. I'm easy. (You may have noticed.)
>> want to do it on a daily basis.)
> straightened out, it was pretty annoying commuting every day. There's
> still enough people here that commute to the next city over that we run
> 3 vans every day.
I currently commute 40 miles a day. But in the opposite direction to all
the rush hour traffic, which is nice.
It's impossible to commute to London by car. (Well, no, it's
theoretically possible, but you'd be insane to try.) More to the point,
I absolutely hate London, so unless they're going to pay me 10x what I
get now, it wouldn't be worth it.
Date: 21 Oct 2011 13:40:50
Message: <4ea1aea2@news.povray.org>
> interviewing me, going through a long elaborate selection process, finally
> getting a job offer, and then after all that saying "oh, you want me to work
> in London? OK, forget it, I'm not interested", and them being all like "WTF?
> Why did you even apply?!" I'd feel like I wasted everybody's time.
What if they said "We'll give you $150,000 more each year to move to London"?
> It's impossible to commute to London by car. (Well, no, it's theoretically
> possible, but you'd be insane to try.) More to the point, I absolutely hate
> London, so unless they're going to pay me 10x what I get now, it wouldn't be
> worth it.
Can it hurt to try? Trust me, you'd not be wasting anyone's time. If nothing
else, if you're 100% dead set against setting foot in london, tell the
interviewer that. I have no idea where all the offices are.
Date: 21 Oct 2011 18:25:03
Message: <4ea1f13f$1@news.povray.org>
>>> to configure Apache using YaST.
>> Try it.
> minute.
Well, I did mean the next time the opportunity presents itself.
I learned to script in bash using the manpage.  That's not exactly a
terse one - again, hard to generalise about this kind of thing.
That's all I'm saying. :)
> actually.
Well, I happen to be in a similar boat.  The trick is not to care about
the offers you don't get (and yes, that is hard - I've had a couple
places I really wanted to find work at that didn't work out for various
reasons), but to get to the one that *does* offer it to you.
5 months and counting for me.  At least I've found some short-term
contract work to do.
Jim
Date: 21 Oct 2011 18:27:27
Message: <4ea1f1cf$1@news.povray.org>
I know perfectly sane people who have done (and IIRC currently do)
exactly that.
Jim
Date: 21 Oct 2011 18:28:41
Message: <4ea1f219$1@news.povray.org>
>> it. With Apache, the same holds true - if you want to put it someplace
>> where Apache won't care, don't put it in /etc/apache2. :)
> there were like include directives or something.
Honestly I don't know - the newer versions use a conf.d directory that
load everything with a .conf extension in that directory, regardless of
name.  That seems to be becoming more common (indeed, I'm contracting to
do some documentation for a company that's got daemons that are being
converted to work in this manner).
Jim
Date: 21 Oct 2011 18:29:20
Message: <4ea1f240$1@news.povray.org>
> debates. Certainly I'm not going to mind that you thought I was doing
> that. :-)
LOL
>> MS extensions being installed without the user being asked. :)
> support in firefox, but there you have it.
Probably to avoid accusations of acting in a non-competitive manner or
something like that.
Jim
Date: 21 Oct 2011 18:42:05
Message: <4ea1f53c@news.povray.org>
  Ever checked zsh's manpage(s)? It's actually divided into 16 man pages,
each dealing with a subset of the features, and most of them aren't exactly
short (for example the manpage for 'zshexpn' is over 1900 lines long).
Date: 21 Oct 2011 18:46:51
Message: <4ea1f65b@news.povray.org>
>> because one could ask people with more experience.  They could get in
>> touch with teammates who know the systems better, or with people they
>> know from other companies.  They could ask at a user group meeting (if
>> it's not a critical system-down issue, obviously - waiting until your
>> next LUG meeting isn't really good if the users can't work).
> Google..."
Which also is perfectly fine.  As I mentioned elsewhere, people tend now
to learn how to find things rather than how to do things.
>> be that way.
Well, if you don't believe me, then you're telling me my experience
didn't happen.  So I'd suggest belief is the appropriate course of
action. ;)
>> the fix is in progress, though, before you answer that question.
> out...)
Right.
If it was openSUSE, then it's
/etc/init.d/SuSEfirewall2_setup stop; /etc/init.d/SuSEfirewall2_init stop
And yes, if you had a package that wasn't in the standard repositories,
malcolmlewis would likely build it for you using the build service,
because it *doesn't* actually take hours/days to do so for someone versed
in how OBS works.
I can see that you might be reluctant to believe this, yes - but your
stubbornness about it is approaching legendary levels.
>>> are code and which parts are data? How do you know where in the
>>> program the processor was executing?
> data is the stack?
Various and sundry registers contain that information.  The debugger can
ask the kernel for information about that - after all, the kernel *must*
know these things in order to actually execute the program.
So finding these things out is a matter of asking the kernel what it
knows about the running processes.
>> software known to the debugger.
A program follows a certain structure.  When compiled, a program stores
variable data in a certain space, code in a certain space, and the
references to those addresses are all known to the kernel, and a debugger
can learn them by asking the kernel.
>> doing in a particular stack frame.
Yes.  A debugger can even execute instructions one by one (on the
processor) to do single-step debugging.
You've used virtual machines and emulators, haven't you?  Similar
principles are at play in a debugger.
>> be that way.  There may actually be an underlying problem that needs to
>> be fixed that would make it less of a pain for you.  But you'd rather
> with it.
Sometimes managing packages on Windows also falls down. <shrug>
I've not said "there's nothing wrong with it" - there's *always* room for
improvement.  What I have said is "it's not as bad as you make it out to
be", which is true.
>>> to recall that if you installed POV-Ray under Debian, it used to
>>> insist on installing PVM, because the Debian POV-Ray package was a
>>> heavily modified PVM-patch of the official POV-Ray sources or
>>> something weird like that. (I presume this has been fixed now...)
>> dependency issues.
Yeah, because nobody on the planet can build POV-Ray or any other
software package.  Ever.  It's just impossible. *sigh*
Right.  It's not GPL or under a OSI-approved license, which makes it "non-
free" according to the FSF.  I gather that's supposed to change in POV-
Ray 4.0, or it's planned to.
Now you're understanding it.
>>> it, you can fix it". Erm, no. No you can't. Unless you're very
>>> fortunate.
>> upstream.
You're missing the point, but I gather you know what I'm saying.
>>>> issues.
You've not tried the ones I'm in, and my experience in those communities
has been quite good.
So you were a member in what, 1957?  ;)
So if you were a member of a LUG in 1957, it's possible, just possible,
that things have changed since then.
Note that "1957" is actually facetious - I do know Linux is only 20 years
old. ;)
>> else has the issue and reports it, it's guaranteed not to get looked
>> at.
But worth asking just in case it's a problem unique to your setup.
That's why I asked.  If it wasn't reported, I would have reported it and
provided information to help debug it.
As it happens, the bug has now been closed as fixed - so I get to try
again this weekend if time permits. :)
Just like a real machine.  Check out Studio, lots of customisation
options there.
Yep.
I find it does depend on how one asks the question, too.
Then it might be worth generalising the question.  Try with a different
kind of printer, if that doesn't work, then it's not that specific
printer, but a more general issue.  If it does work, then it may be
necessary to - instead of talking to Microsoft or MVPs about it - ask the
printer manufacturer.
>>> utterly break your install to the point where you have to replace the
>>> entire OS?
>> Nope, I haven't.
I've only been doing Linux for 10-15 years or so. ;)
>>>> asked for help.
>>> well isn't. :-P
> you want.
And those millions of people using Linux don't use package management?
No, actually, they do.  So we've come full circle.
>> using openSUSE.  You'll *probably* be pleasantly surprised.
Feel free to.  There are some existing discussions over on
forums.opensuse.org about using VMware and openSUSE together.
One thing I've wanted to push for is using openID for authentication on
OSF.  Not sure if vBulletin can support that, though - but if you post
using NNTP, you'll find it's just a matter of pointing at
forums.opensuse.org:119 and pulling a list of newsgroups.
>> win.
Of course, that's why I added the bit that you didn't quote. ;)
Same reason I don't.  Well, that, and there's no lottery in Utah. ;)
Jim
Subject: Re: Is this the end of the world as we know it?
Date: 21 Oct 2011 21:22:00
Message: <4ea21ab8@news.povray.org>
>> > reference to the bare essentials of what a tool does. That doesn't
>> > seem like much of an "assumption" to me.
>   pages,
> exactly short (for example the manpage for 'zshexpn' is over 1900 lines
> long).
I haven't looked at it myself, but it doesn't surprise me that there are
manpages that have a lot of documentation in them.
Jim
Date: 22 Oct 2011 02:08:20
Message: <4ea25dd4$1@news.povray.org>
>> that. :-)
> LOL
> Jim
Snort.. Yeah, which is I suppose why those things are usually "disabled"
automatically by Firefox, as a) security threats, and b) prone to cause
instability. lol
Date: 22 Oct 2011 05:32:40
Message: <4ea28db8$1@news.povray.org>
 From what I recall, the manpage for Bash practically lists the entire
BNF grammar for the scripting language. Great if you're trying to
reimplement Bash for some reason, almost useless if you want to actually
LEARN HOW TO USE IT.
A reference manual is no substitute for an introduction.
Date: 22 Oct 2011 05:59:08
Message: <4ea293ec$1@news.povray.org>
>> Google..."
The point being, *I* could do that myself. I was asking somebody else
hoping that they might know something I don't. Actually it seems most of
the guys in our IT department don't understand long words like
"registry" or "SCSI controller"...
OK, I would literally never have guessed that. o_O
> in how OBS works.
 From what I've observed, compiling anything nontrivial that's written
in C takes hours and hours. And that's assuming it doesn't fail half way
through, demanding many hours of fruitless tweaking...
>> data is the stack?
OK. So I see how that can work for a running process. I'm not sure how
it's possible from a memory dump.
I thought the compiled binary is just a flat file containing a list of
machine opcodes?
Yeah, but a VM doesn't just save the contents of memory, it saves a
whole bunch of metadata too.
>> with it.
> Sometimes managing packages on Windows also falls down.<shrug>
Windows doesn't really "manage" packages. It just runs installers and
uninstallers, and keeps track of what's installed.
Well presumably the POV-Ray developers have all the necessary tools,
libraries and build environment set up to do this. But trying to guess
what that is by following the build errors is a very time consuming and
difficult process.
Does POV-Ray actually have more than 1 person working on it any more?
Yep, that's right. ;-) I may only have been a twinkle in my
grandfather's eye, but I was sure as heck a LUG member. :-P
My point is that you make it sound like I tried Linux for 10 minutes,
couldn't figure it out, and just gave up. That isn't true. And my more
recent interactions with the so-called "Linux community" haven't lead me
to change my opinion.
> options there.
Where do I find that?
>> do.
Well, true. You do see a lot of posts in broken English saying something
hysterical about "we have major issue with we demand fix immediate, how
to be making printer to print again??!!!!! ugency!" It always surprises
me that anybody bothers replying to those.
As I recall, the exact problem was that a certain printer *was* working,
and then on a particular day, that specific printer [and no other]
simple stopped working, for no defined reason. I was hoping to get some
troubleshooting tips... but I got nothing.
Still, it least it's *possible* to ask questions about MS products. How
many printer manufacturers offer any kind of product support of any
description? Exactly.
Well, the first problem is that if I enable USB in VMware, the mouse
pointer doesn't work properly. If you move the mouse an inch, the
pointer moves an inch, but if you click, it clicks on something two
inches away. WTF? o_O
No, wait - the *first* problem is that 50% of the time when I boot the
live GNOME CD, the GNOME toolbar doesn't appear. And the other 50% of
the time it does. Damned strange...
Date: 22 Oct 2011 06:11:17
Message: <4ea296c5@news.povray.org>
  You don't have to recall anything. All manpages can be found online with
a simple google search.
  Nobody every claimed that manpages are anything else than reference manuals.
Yet many unix users have learned to use most unix tools via their manpages.
Date: 22 Oct 2011 13:18:35
Message: <4ea2faeb$1@news.povray.org>
>> now to learn how to find things rather than how to do things.
Sure, given your environment, they might do the same things you might
do.  They also might search with search terms that return different
results, though, so it's still not a bad thing.
>> stop
That's a question that would have received a fast answer on OSF.
>> versed in how OBS works.
Your observations are not accurate for those who have much more
experience.  Malcolm is very good at what he does, and I don't think I've
seen an instance where he's not been able to get a package to compile in
OBS.
But what's more, he's willing to take the time to do stuff like this for
those who take the time to ask.
"hours and hours"?  Really?  I compiled rockbox last night (alternative
firmware for the iPod and other MP3 players).  Took about 15 minutes to
build.
>>> data is the stack?
>> can ask the kernel for information about that - after all, the kernel
>> *must* know these things in order to actually execute the program.
You have a piece of software that in effect emulates the processor state.
A core dump is a machine state, containing everything the machine has at
the time the core is taken.  (on *nix, it's a single process, but the
same principles apply).
Now, if you are working on a system live, you have this set of data about
the process (call it 'set a').
If you're working from a coredump, you still have 'set a' about the
process, and just need something that can do what a life debugger can do.
>> debugger can learn them by asking the kernel.
> machine opcodes?
No.  It contains information about variables as well.  In fact, just this
last week, I was working on documenting configuration file parameters for
Linux binaries.   First step:  strip the symbolic information out of the
file (function names and whatnot, since that's only used by the
debugger).  Second step:  "strings exename > exename.strings"
Presto, all the strings - error messages and whatnot as well - in a text
file.
Now, given that the parameters follow a particular format, just extract
those from the output.  Then review with the developer and see which ones
I need to document.  (In this instance, I'm not permitted to see the
source code - obviously, if I did, that would be much easier, but this
was actually pretty trivial to do).
Like I said, a compiled binary has a structure, it's not just
instructions - it contains data as well.
*Exactly*.  Programs contain metadata, and a debugger uses that metadata
(as pulled from a coredump) to help you discover things about the program.
>>> can't figure out is why you seem to be denying that there's anything
>>> wrong with it.
That does actually count as package management. ;)  Those installers
know, for example, that .NET Framework 3.5 is required, and if it's not
installed, they do something (some will install it, some will just fail
and say "you need to install X").
> difficult process.
a) they've documented the required tools in order to build it.
b) if there's an error, you're not on your own - there happen to be some
experts here in these very forums who know how to build it and can help
troubleshoot those issues.
>> "non- free" according to the FSF.  I gather that's supposed to change
>> in POV- Ray 4.0, or it's planned to.
Ask Warp.  Or Clipka.  Or Chris Cason.  Hmmm, there's 3. ;)
But to the original point, to convert it to a GPL license, they have to
talk to those who contributed earlier code and get their permission (at
least as I understand it).
>>> this turned out to be *drastically* slower than AmigaOS. Like, it took
>>> 20 minutes for GNOME to start. (!!)
You do know what "sarcasm" is, don't you? ;)
I don't make it sound like that.  You do.  And I've told you how/where to
go to get help the next time you try.
>> options there.
http://www.susestudio.com .  It's free to use.
>>> I do.
Well, actually, I don't see questions like that in the openSUSE forums.
Occasionally we have posters who assume we know everything about their
system, but in general, they get asked for more information, sometimes
with a joking comment about "my crystal ball seems to be broken, can you
tell us more about your setup?"
It probably helps that in OSF, we have forums for non-English users so
they can ask in their native language rather than having to try to write
in a language they don't know that well.
But some of us also have years of experience in decyphering what someone
posting in English - when it's not their native language - is asking.
There are some constructs that are quite predictable.
Your sample, for example, parses as being asked by someone in India,
especially "how to be making printer to print again?".
So what I'd do is tell them that if they want professional support, they
might look into SUSE Linux Enterprise, where they can pick up the phone
and call someone for assistance.  But if they don't want to do that,
we'll do the best we can to help.  To do so, we need answers to the
following questions:
1.  What version of openSUSE are you using?
2.  What is the make/model of the printer?
3.  If this was working in the past, what happened between the time the
printer worked and the time it didn't?
(Question 3 is crucial - if something worked and then it didn't,
*something* changed. Troubleshooting is about figuring out what it was
that changed)
Yeah, I've done this a few times over the past 20 years. ;)
>>>> and doesn't work right" isn't likely to get you an answer, either.
>> the printer manufacturer.
Well, as I said above, troubleshooting is about figuring out what
changed.  (Note that there's a difference between "what changed" and
"what you changed" - you may not have changed anything, but something
certainly changed, and we need to figure out what it was, ideally, in
order to fix it).
If I determined the problem was caused by an HP driver update, you can
bet I'd be on the phone to HP printer support.
Never seen that before, and I use VMware on openSUSE quite regularly
(though not to run openSUSE, and not with the host as Windows).  Tools
installed?  Using the VMware-supplied tools, or the OSS version of the
tools?  What version of openSUSE?  What version of Windows?  What version
of VMware?  The mouse is presumably a USB mouse, yes?  Etc, etc, etc -
there are lots of questions to ask about this problem that help dig
deeper into what the root cause is.
My point isn't to answer the question here (this isn't the right venue),
but to show you that it's not just a question of:
"X is broken, how do I fix it?"
"Oh, you just need to splunge the flange, and then it'll work fine."
It sometimes is that simple, but IME it rarely is these days.
Well, and there again, I'd be asking things like which version, what
hardware, and similar things.
Jim
Date: 22 Oct 2011 13:23:01
Message: <4ea2fbf5$1@news.povray.org>
It is a comprehensive reference for the language, yes.  Learning how to
use it is like learning how to use any programming language.
True, but I didn't need an introduction.  I suspect you wouldn't need an
introduction to programming either, if you approached it the way I did.
In this particular instance, it was during a hands-on certification
exam.  I worked out pseudocode for what I wanted the script to do, and
then used the manpage to figure out the syntax.
Note that I wouldn't recommend that anyone try to learn a scripting
language while taking a certification exam - I just happened to be in
that situation, and while I was making a serious attempt at the exam (and
I did pass, though not with full points for the script I wrote), I wasn't
concerned about cost or having to take it again.  Most people would be.
Jim
Date: 22 Oct 2011 15:30:07
Message: <4ea319bf@news.povray.org>
My point here is that I generally don't bother asking other team members
about problems, because they apparently know less about computers than I
do. (As absurd as that is...)
Or maybe it's just that they're American, and they take the approach of
"hey, I could spend hours trying to understand this small problem, or I
could just hit it with a wrench until it works". I'm not sure.
> build.
 From what I recall, compiling X11 took about 3 hours on my PC.
Interestingly, compiling Firefox took way, way longer than that...
I was under the impression that a core dump is exactly that - a simple
copy of what was in the machine's memory at the instant of the crash.
This is insufficient data to generate any useful information. (For
example, you wouldn't be able to fire up an emulation in a VM with just
this data.)
Your answers seem to indicate that a core dump actually contains
additional metadata which allows you to DO STUFF with the data. If
that's true, it makes quite a difference. (Although without knowing
exactly how the compiler transformed the original source code into
machine code - or even what the original source code was - I still don't
see how you'd get very far...)
>> difficult process.
I'm sure most developers have far better things to do than answer stupid
questions from somebody who can't figure out the setup required to build
their code.
Yes. Perhaps you missed mine? :-P
OK. I'll go take a look.
I posit there are a couple of reasons for that.
1. There aren't as many people using OpenSUSE as there are using [insert
any MS product name here].
2. Most people didn't pay actual money to use OpenSUSE.
3. There aren't as many people trying to use OpenSUSE to actually run a
business with.
[Question: Can you actually do that? I mean, I presume the OpenSUSE
license doesn't preclude commercial usage...?]
> order to fix it).
Sure. That's the major difference between "it never worked" and "it used
to work fine, but then it stopped". In the latter case, figuring out
what changed is the top priority.
HP have support??
Literally, create a new VM, set it to boot from the ISO image of either
the GNOME or KDE live CD downloaded from the website. If the VM has a
USB controller, the mouse pointer and actual mouse focus are out of
sync. Remove USB, and it works perfectly. That's pretty random. (It also
fails the same way for Ubuntu, but works perfectly for every flavour of
Windows...)
Sure. I was just muttering really. Wasn't expecting you to actually come
up with an answer right now. (This thread is long enough already...!)
Date: 22 Oct 2011 17:56:44
Message: <4ea33c1c@news.povray.org>
Well, I don't think it's absurd, because you do quite well when you apply
yourself.  Being isolated also makes it difficult to become part of a
coherent team.
Ahem.  You do realise that even though I spell things as those in England
do, I am in fact American, yes?  Broad brush strokes aren't going to do
you any favours. ;)
>>>    written
>>> way through, demanding many hours of fruitless tweaking...
>> build.
Of course, times have in fact changed, as has hardware.  I remember
building GCC back in the early 90's on a Sparc 2 system.  It took (IIRC)
3 compilation cycles, and could take about that long.
So it sounds to me like you're either stuck back in 1990, or you're still
using an 8088 to compile with.
>> state.
>> at the time the core is taken.  (on *nix, it's a single process, but
>> the same principles apply).
> this data.)
It depends on if the core is from a complete system or not.  *nix core
files tend to be for a single program (or process).
But what's in memory includes vital information about the machine state.
There is certainly sufficient information if you know how to parse it.
Again, trust me - I've actually *done* this to resolve problems.  If
there was not sufficient information, it would be impossible.  The fact
that I and thousands of other people with the knowledge to do this should
in fact cast sufficient doubt on it being "impossible".
Now we're getting somewhere.
Let's take an example.
Several years ago (almost 20 years ago, in fact), I "broke" a utility
used for editing a database used to store identity data.  The utility was
(and is) designed for use by experienced support engineers with specific
training on the utility, and that utility is not given to the public.
How'd I do it?
With a kernel debugger.
I single-stepped through the machine code, using symbolic information
available to the kernel debugger, and determined exactly how it worked -
and in so doing, determined how to extract the password used to protect
the tool (it was a very poor scheme that has since been changed) and how
to bypass the time-bombing logic.
The only tool I used was a kernel debugger.
And a bit of persistence. ;)
>>> and difficult process.
>> some experts here in these very forums who know how to build it and can
>> help troubleshoot those issues.
> their code.
You'd be surprised.  Again, been doing this for 20 years.  Would you
believe, for example, that *the* Linux kernel driver guy (Greg Kroah-
Hartmann) answers questions in one of the openSUSE forums?
These forums, BTW, are not for developers - generally the developers
don't visit them.  But Greg takes the time to come out and talk to people
and answer questions about the openSUSE "rolling upgrade" release (called
'Tumbleweed').
Or perhaps you missed mine. :P
I was sure I'd mentioned it before. :)
>>> something hysterical about "we have major issue with we demand fix
>>> immediate, how to be making printer to print again??!!!!! ugency!" It
>>> always surprises me that anybody bothers replying to those.
Perhaps, but then again, I explained the primary reason is because we
have avenues for those for whom English is not their primary language.
That doesn't actually matter at all.  People using it, whether they paid
money for it or not, are going to want help.  And they get it.
> business with.
Actually, quite a few do.  I often am surprised to hear how many actually
do use the free version to run a business on.
The GPL certainly doesn't forbid it.  Linux - and openSUSE is just a
Linux distribution - certainly can be used for profit.
That's kinda the point of "Free Software" - you're free to do with it
what you want.  That's the context of "Free" here - not necessarily "at
no cost" (gratis), but "libre".
>>> working, and then on a particular day, that specific printer [and no
>>> other] simple stopped working, for no defined reason. I was hoping to
>>> get some troubleshooting tips... but I got nothing.
>> order to fix it).
Exactly.  So online forums such as OSF are there to help people with less
experience leverage the experience of those with more experience to
narrow down the problem.
>>> How many printer manufacturers offer any kind of product support of
>>> any description? Exactly.
> HP have support??
Of course they do.  They produce products that are used by professionals
and consumers alike.  Kinda hard to sell stuff if you don't provide
people with a way to get help when things don't work.
What's more, HP does (or used to) provide support centres for a number of
other companies - I remember Novell used to use HP for front-line support
for their products at one time.
>> version of VMware?  The mouse is presumably a USB mouse, yes?  Etc,
>> etc, etc - there are lots of questions to ask about this problem that
>> help dig deeper into what the root cause is.
> Windows...)
So you've basically just described the problem in exactly the same way
that you did initially.  When clarifying questions are asked, that's so
the problem can be drilled down into.
Computers don't tend to do things for "random" reasons.  They do them for
a specific reason.  The trick is in figuring out why it's doing what you
told it to instead of what you want it to do.
>> venue),
It certainly is.
But as I said, there are those who can answer questions like that, and a
hell of a lot of people donate their time to help others with problems.
Jim
Date: 22 Oct 2011 20:18:11
Message: <4ea35d43$1@news.povray.org>
I meant, I don't know what the support for firefox was, given that click
once works in browsers without that plug-in.
Date: 22 Oct 2011 20:19:52
Message: <4ea35da8$1@news.povray.org>
I think it depends on how well organized things are in the documentation and
in what you're trying to learn. Most of the programming langauges I learned,
I learned by reading the reference manuals.
Date: 23 Oct 2011 04:57:55
Message: <4ea3d713$1@news.povray.org>
So it's not an introduction, and yet it's how most users introduce
themselves?
Now don't get me wrong. For something trivial like ln or cp, the
reference manual is probably all you need. There's not much to learn,
after all. But for something as complex as Bash, some examples and
exposition would really help tremendously... I wasted literally *hours*
trying to work out how the **** to execute the same command for every
file in the current directory. In the end I was forced to do it by hand.
http://blog.orphi.me.uk/
Date: 23 Oct 2011 05:20:34
Message: <4ea3dc62@news.povray.org>
> coherent team.
It just urks me that I'm part of a team of so-called computer experts,
and everybody's answer to everything is "did you try rebooting it?" Not
"hey, let me engage my brain for 15 seconds and see if I can come up
with a real answer", just "did you try rebooting it?"
And yes, being the only person in the team who works geographically
isolated really puts the "me" in "team".
> you any favours. ;)
Perhaps an analogy: Takings slightly to extremes, if a car engine broke
down, I'd take the entire thing apart down to the component level to try
to figure out what's wrong with it, while the Americans would just buy
an entire new car and be done with it. Argue amongst yourselves which
approach is better.
Of course, that's an exaggeration. But those guys do seem reluctant to
throw any real thought power at the problem when you can just replace
stuff and see if that fixes it. Maybe they're just busier than me...
seems to be a cultural thing though.
No, this was on the same PC I'm using right now - AMD Athlon64 X2 4200+
2.2 GHz with 3 GB RAM.
In my experience (which, again, is quite limited), it's extremely hard
to figure out what disassembled code does without source code to compare
to - and that's on the Motorola 68000 platform, which has sane machine code!
Ko fight!
Sure. But people who've paid money for something sometimes have this
attitude of "this piece of crap you sold me isn't working - FIX IT!"
Whereas most people who get something for free are a little less
self-righteous about it. (Although not always, sadly...)
>> business with.
As I understand it, the only difference between that and the commercial
version is the level of support involved.
Sure. That's the general idea of a free license. But some licenses are
freer than others. And different distros have different ideas about
that. (See, again, Debian classifying POV-Ray as non-free.)
>> HP have support??
Sure, but presumably they only *support* your products if you pay for an
expensive support package?
The fact that I'm running from the standard ISO image of the live CD
tells you it doesn't have any VM tools installed. (Unless there are any
present on the disk itself.) I'll admit I forgot to include the version
numbers.
This is why it disturbs me so when a computer does something for no
apparent reason. Like booting the same VM multiple times, when it can
have no record of what happened before, and yet seeing a different
result each time...
Date: 23 Oct 2011 05:48:23
Message: <4ea3e2e7@news.povray.org>
> themselves?
  I didn't say unix users have learned *all* tools via their manpages.
I just said it's the case with many (or even most) tools.
  (As for that particular problem, it's "for F in *; do echo $F; done",
or if you are using zsh, you can also write "for F (*) echo $F".)
Date: 23 Oct 2011 06:44:58
Message: <4ea3f02a$1@news.povray.org>
YOU didn't, no. But Jim seemed to be strongly hinting at it.
Just a few lines of example code could have helped me figure this out in
a few minutes instead of several hours. (And this must surely be a VFAQ
for shell scripting; it's just about the simplest task you could
possibly want to script!)
Date: 23 Oct 2011 12:01:56
Message: <4ea43a74$1@news.povray.org>
No. You still have to understand how the file system works and how the
command line works in order to use them. That's just something you've
already learned tho.  Come from a DOS or mainframe background and ask "what
are all these slashes? What's a mount point? Why doesn't it tell me the type
of the file? How do I set a password or encryption key on this file?"
However, that's all in the man pages too.
http://linux.die.net/man/1/intro
http://linux.die.net/man/2/intro
Altho I will say, compared to actual AT&T UNIX, the linux intro man pages
suck hard.  Not really surprising, given you're *supposed* to have read the
source code for the kernel. ;-)
Date: 23 Oct 2011 12:03:46
Message: <4ea43ae2$1@news.povray.org>
> **** to execute the same command for every file in the current directory. In
http://stackoverflow.com/questions/2640374/bash-map-equivalent-run-command-on-each-file
Geez, dude. Third hit on google even uses the same words a Haskell
programmer would use. :-)  It *is* a FAQ. FAQs aren't in man pages. Deal
with it. :-)
Date: 23 Oct 2011 12:16:02
Message: <4ea43dc2$1@news.povray.org>
>> directory. In
Yes, because the Internet is always accessible. Oh, wait...
<<< Previous 50 Messages Goto Latest 50 Messages Next 50 Messages >>>
