POV-Ray : Newsgroups : povray.off-topic : Data transfer Server Time
8 Nov 2026 02:52:32 EST (-0500)
  Data transfer (Message 136 to 185 of 195)
<<< Previous 50 Messages Goto Latest 50 Messages Next 10 Messages >>>
Subject: Re: Data transfer
Date: 15 Sep 2011 20:37:43
Message: <4e729a57$1@news.povray.org>
Le 2011-09-15 15:36, Orchid XP v8 a écrit :
>>>> On Windows, you'd type:
>>>> route add 192.168.200.0 mask 255.255.255.0 192.168.1.1
>>> 1. I didn't know you could do that.
>>> 2. What does it do?
>> It tells your PC that there's a network called 192.168.200.0 somewhere
>> voer there, and that to get ot it, you must forward the packets to
>> 192.168.1.1 and he'll take care of them.
> Interesting. I didn't know Windows was actually capable of doing that.
> Usually when I need a router in a hurry, I load up Linux and read some
> manpages...
> Hmm, I wonder... If my VPN client doesn't route all the subnets I want,
> can I get it to dump the packets onto the wrong LAN segment, and then
> trust the router at that end to take it to the correct place?
Assuming your router knows the way and there are no filters or
restrictions in place, yes.
>>> Incidentally, I gather that there's two ways to control the ASA. One
>>> involves telnet. The other involves a serial cable...
>> Serial cable is required to give the machine its initial barebones
>> config, after that, it's telnet or preferably ssh. Since anyone could
>> sniff the telnet password.
> It's neat that you can configure it via IP. Then again, if you configure
> the IP stuff wrong, you need to connect somehow so you can reconfigure
> it. :-}
> I wonder what authentication options there are for SSH...
Userid / password.  Either local or via an external authentication
system (TACACS, Radius, Kerberos, RSA SecurID, etc...)
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 15 Sep 2011 20:46:17
Message: <4e729c59$1@news.povray.org>
Le 2011-09-14 04:40, Invisible a écrit :
>>> So how do you prevent somebody connecting to your server a thousand
>>> times per second and feeding it duff credentials, thereby preventing any
>>> legitimate users logging in, and wasting lots of CPU power?
>>> See, security isn't so simple...
>> by having a real firewall (such as the aforementioned Cisco ASA)
>> configured to throttle individual connections. ;)
> I'm sorry, I thought we were still talking about "why the average home
> user can't easily send a file to another average home user". :-) I doubt
> many home users will pay hundreds of pounds for a Cisco ASA and spend
> god-knows how long learning what "tee sea pee eye pee" is in order to
> set this up.
The average user will not get DDOSed unless he pissed off the person
DDoSing him.  Even the morons of 4Chan don't DDoS random people for the
lulz.
If you are afraid of a denial of service attack, it means you have
something worth attacking.  Therefore the few thousand dollars spent on
a decent security appliance will be worth it.  How long can your
business withstand being offline before your loses are more than the
price of the firewall?
>> Now the /b/tard in question would have to use zombie PCs to do his DOS
>> against your machine.
> Yeah, because none of the script kiddies have figured out how to do
> that. ;-)
Most of them still ask how to download LOIC and act all surprised when
they get a knock on their door.
> Then again, if somebody decides to DDoS you, it doesn't matter if you
> have *no* ports exposed to the Internet... You still get no service.
> Sometimes I think it would be nice if there was a widely-supported
> standard for configuring the firewall at the /other end/ of the last
> mile to drop certain packets. But anyway...
A DDoS needs to be extremely big for an ISP to notice one of its
customers is under attack.  And you need a special business relationship
to be able to call them up and ask that they block a certain type of
traffic at the head end.
Date: 15 Sep 2011 20:55:47
Message: <4e729e93$1@news.povray.org>
Le 2011-09-14 16:52, Orchid XP v8 a écrit :
>>>> Yep. You still need a computer for each user, tho.
>>> Sure. But I mean, you can set up an application server that more than
>>> one
>>> person can access, without doing anything particularly special.
>> You can do exactly the same thing on Windows that you do on Unix.
>> Log into the windows box remotely. Start an X client and point it at
>> your display. Disconnect without logging out. Someone else logs into the
>> windows box remotely. They start an X client and points it at their
>> display. They disconnect without logging out. Guess what? Windows
>> running X clients talking to two different X servers.
> Does anyone, anywhere on Earth, actually run X on Windows?
 > I mean, I gather that you *can*. But does anybody actually *do* this?
Yes.
For two reasons.
1) One of the network monitoring software suite I use is an ugly Windows
port of something that was developped for Solaris.  Most of the
configuration tools were written for Motif, and many of the command line
utilities are ksh scripts.  So the 5 servers that run this particular
tool all run not only X11, but a "unix environment for Windows" as well.
2) Other servers I manages ARE running AIX, Solaris or Linux.  so the
only way to run their GUI utilities is by tunnelling X through ssh back
to my PC.  Just like about 100,000 of my coworkers do.
Date: 15 Sep 2011 21:19:19
Message: <4e72a417$1@news.povray.org>
Le 2011-09-15 15:29, Orchid XP v8 a écrit :
>>> I'm fairly sure I tested it, and discovered that I needed to turn off
>>> multiple things to stop it accepting my password as a valid login. But
>>> since that was then and this is now, I guess I might be incorrect.
>> Did you at least refresh (aka reload) sshd when updating the
>> configuration ?
> Is rebooting the machine sufficient to do that?
> If so, yes...
Heathen!  Linux machines do not need to be rebooted.  Ever.
To quote Yoda:  Unlearn everything you must.
Date: 15 Sep 2011 21:23:16
Message: <4e72a504$1@news.povray.org>
Le 2011-09-15 13:15, Orchid XP v8 a écrit :
>>> 1995? Jesus, that's WITHIN MY OWN LIFETIME! Compared to Unix, which
>>> almost pre-dates binary computers, that's ultra-modernist!
>> Not only, but current ssh is version 2, which leave the status of draft
>> only in 2006; (1.99 is drafted version 2)
>> ssh of 1995 was version 1 and limited to remote shell (with very limited
>> inband file transfer).
> I'm told v1 isn't as secure either. I don't know if that's actually true...
ssh 1.0's insecurity was a major plot point of the Matrix II or III.
Date: 15 Sep 2011 22:08:27
Message: <4e72af9b$1@news.povray.org>
On 9/12/2011 1:41, Invisible wrote:
> After reading several dozen forum posts, it seems nobody has a really good
> solution for doing this.
Actually, when you think about it, the two people in this situation are not
unlikely using two computers both of which are using the same IP address,
like 192.168.0.2.  Hard to see how to make a TCP/IP transfer easy if both
target machines have the same IP address, regardless of software installed
or operating system in use.
   How come I never get only one kudo?
Date: 15 Sep 2011 22:10:10
Message: <4e72b002@news.povray.org>
I'm pretty sure you're wrong on that one.
Date: 15 Sep 2011 22:13:50
Message: <4e72b0de@news.povray.org>
On 9/15/2011 1:07, clipka wrote:
> An X /client/ on Windows (that is, software running on a Windows host and
> displaying on an X terminal)? Doesn't sound like a common use case to me.
Yep. On the other hand, I was merely trying to point out that it wasn't the
fact that Windows was present that was causing the problem. Even non-server
versions of Windows (Pro, not Home, generally) let you have multiple people
logged in using it as a server.
Date: 15 Sep 2011 22:15:51
Message: <4e72b157@news.povray.org>
On 9/15/2011 2:44, Le_Forgeron wrote:
> try playing xonix via VNC... it's far easier with just a X server on the
> windows system.
VNC wasn't really designed for efficiency.
> It's just a shame that windows applications are unable to be translated
> into X clients by MS.
X is a rather sucky protocol, in modern times, for doing this sort of stuff.
Lots of code breaks, for example, on a high-latency link, because so many
programs assume that things like change of focus will complete before
keypress events start arriving, but they don't. There's whole piles of
kludges to account for that kind of thing.
 > (well, they still have that "one user at a time"
> approach in a lot of their code too)
No they don't. That's enforced entirely by the login program checking licenses.
Date: 15 Sep 2011 22:17:24
Message: <4e72b1b4$1@news.povray.org>
On 9/15/2011 11:17, Orchid XP v8 wrote:
> If the two machines are on the same LAN, this probably isn't a problem.
Only if it's difficult to transfer data between the outside world and the
systems you're connecting, a la the original topic of the thread.
Date: 15 Sep 2011 22:31:52
Message: <4e72b518$1@news.povray.org>
On Thu, 15 Sep 2011 19:17:36 +0100, Orchid XP v8 wrote:
>>> As far as I know, getting X to actually work remotely is extremely
>>> difficult, whereas I know from experience that getting VNC to work
>>> remotely is trivial.
>> VNC is also trivially compromised unless you tunnel it over ssh or wrap
>> it in ssl.
> (And presumably the same applies to X as well anyway...)
Yes, that's true, if you trust the LAN.
Jim
Date: 15 Sep 2011 22:35:05
Message: <4e72b5d9$1@news.povray.org>
On Thu, 15 Sep 2011 19:46:42 +0100, Orchid XP v8 wrote:
>> Man pages are not intended to be tutorials.  They're manual pages.
> ...which is the point I'm trying to make, yes.
So then what's the problem?  You're complaining that they're not
tutorials, but they're not intended to be tutorials.
>>> Then again, sometimes the manpage just says "use info". And then you
>>> had /another/ problem...
>> Well, no, it's not *another* problem - you just need to use the info
>> command instead.
> Have /you/ tried navigating the thing?
> Since I'm guessing the answer is probably "yes", then I don't need to
> explain to you how hard it is...
Yes, and I usually end up googling instead.  I'm sure I could figure it
out, but I don't need it that often.
>>> So even with this line, people can *still* authenticate by password.
>> Not to the best of my knowledge.
It might be easier now, yes.  Honestly, I've never even looked for a CHAP-
based authentication mechanism for ssh.
>>>>> I thought the host key is how the server identifies itself to you,
>>>>> not how you identify yourself to the server?
>>>> Host keys aren't very commonly used AFAIK.
>>> All three of the SFTP systems we use commercially have them.
>> A sample size of 3 isn't exactly data supporting "commonly used".
> It's infinity times larger than a sample size of zero. ;-)
Sure, but not mathematically significant.
> Then again, one of these systems is set up to use PK authentication, and
> the server administrators emailled /us/ with the private key to use to
> get access. *facepalm*
> Imagine it: Going to all the trouble of setting up a secure system, and
> not even knowing how to secure it properly...
I don't have to - I see it fairly regularly.
Jim
Date: 15 Sep 2011 22:36:00
Message: <4e72b610@news.povray.org>
Yeah, kernel updates require a reboot.  Other than that, you usually
don't have to (unless you're killing zombie processes), but sometimes
"it's easier".
Jim
Date: 15 Sep 2011 22:46:31
Message: <4e72b887@news.povray.org>
> don't have to
Again, it depends on what you're doing and where the Linux is living. I'll
grant that *desktop* linux systems rarely *need* rebooting. And I'd argue
that if you have a server whose *only* job is being a web server, then
restarting the web server after an upgrade is essentially the same as a
reboot, except faster.
Date: 16 Sep 2011 04:21:53
Message: <4e730721$1@news.povray.org>
>>> configuration ?
>> If so, yes...
It's not so much that I purposely rebooted it; more that it's a laptop
that shuts down whenever the power is unplugged. So every time I moved
it to a different location in the building, it was effectively rebooted.
If you're going to quote Yoda, do it right:
"Then you must /unlearn/ all that you have /learned/."
Not every sentence he utters is in object-subject-verb order. (At least,
not in the original trilogy.)
If you really want to split hairs,
http://itre.cis.upenn.edu/~myl/languagelog/archives/002173.html
Date: 16 Sep 2011 04:24:51
Message: <4e7307d3@news.povray.org>
> I'll grant that *desktop* linux systems rarely *need* rebooting. And I'd
> argue that if you have a server whose *only* job is being a web server,
> then restarting the web server after an upgrade is essentially the same
> as a reboot, except faster.
Actually Windows is getting better at not needing to be rebooted either.
You can quite often install or uninstall software, and it doesn't bother
asking for a reboot. It just /works/. (Indeed, lots of older software
asks for a reboot, but actually works fine without one.)
And - fortunately - it's becoming less common to need to reboot due to
resource leaks too.
Date: 16 Sep 2011 04:25:21
Message: <4e7307f1$1@news.povray.org>
>> windows system.
The fail!
Date: 16 Sep 2011 04:28:27
Message: <4e7308ab$1@news.povray.org>
Quite. I did actually hear about a guy having to spend ages on the phone
to their ISP to ask for firewall configuration changes.
Now imagine if there were a standard, widely-implemented system for
letting the customer make those configuration changes themselves...
Let's face it, the ISP's routers are almost certainly remote-manageable
anyway. If the unwanted packets can be blocked at the entrance to the
ISP's network, they can save themselves the bother of having to route a
bunch of traffic. (Although the amount of data you can fire at one
customer is probably peanuts compared to the ISP network capacity.)
Ah well, dream on...
Date: 16 Sep 2011 04:30:41
Message: <4e730931$1@news.povray.org>
>> good
> not unlikely using two computers both of which are using the same IP
> address, like 192.168.0.2. Hard to see how to make a TCP/IP transfer
> easy if both target machines have the same IP address, regardless of
> software installed or operating system in use.
With NAT, it can work perfectly well. At long as each endpoint knows the
other only by its publicly routable IP address, anyway.
There are probably web servers that run on RFC-1918 IP addresses. And
plenty of home users who do. And yet, they can still talk to each other...
The /problem/ happens when you want to route between two entire
/networks/ with the same network number.
Date: 16 Sep 2011 04:34:42
Message: <4e730a22@news.povray.org>
No, I'm complaining that tutorials don't exist. Only reference manuals.
Let's just hope you're not trying to look up how to configure Internet
access...
No, I mean, I might be remembering this wrong.
Not /statistically/ significant, if you want to be picky.
This is the real WTF...
Date: 16 Sep 2011 06:03:43
Message: <4e731eff$1@news.povray.org>
Told me... this morning security update did insist on reboot.
As usual!
Date: 16 Sep 2011 06:06:18
Message: <4e731f9a$1@news.povray.org>
> As usual!
Sure. But that's because it's probably replacing bits of the OS kernel,
or at the very least it's replacing widely-used system libraries, and
the simplest way to handle that is to just reboot.
I can install an AV product and not need to reboot. (Very useful for
fileservers!) I can install .NET, or Office, or VisualStudio, and not
need to reboot. I can install all kinds of stuff, and mostly I don't
need to reboot. Sometimes you still do, but it used to be any installing
or uninstalling *anything* always required a reboot.
Date: 16 Sep 2011 12:12:37
Message: <4e737575$1@news.povray.org>
And, oddly enough, mine didn't. Possibly because I actually closed the
programs in the way before installing the updates.
Date: 16 Sep 2011 12:13:49
Message: <4e7375bd@news.povray.org>
>>> windows system.
> The fail!
Nope. It was just designed to be easy to implement instead of being
efficient. Show me X-Windows ported to a javascript client.
Date: 16 Sep 2011 12:15:27
Message: <4e73761f$1@news.povray.org>
Assuming you have configured at least one to *have* a publicly routable IP
address. That's kind of the point.
> There are probably web servers that run on RFC-1918 IP addresses. And plenty
The problem comes when the person running the server doesn't know how to
route traffic from the public IP address to the private one.
Date: 16 Sep 2011 12:54:06
Message: <4e737f2e$1@news.povray.org>
>> don't have to
I don't see a need to regularly reboot Linux servers either, unless
there's a kernel update.
Jim
Date: 16 Sep 2011 12:57:58
Message: <4e738016@news.povray.org>
Tutorials exist, they're not included with the OS.  Do I really need to
say (again) "GIYF"?
> access...
I've managed to do that enough times that it generally isn't something I
need to look up these days.  But if I did, a quick trip to my public
library to use one of their computers to do the search will in fact solve
that problem.
Or I could use my phone.
Or I could use another of my systems here.
>> CHAP- based authentication mechanism for ssh.
That's certainly possible.
Statistics is a branch of mathematics. :P
>>> and not even knowing how to secure it properly...
People who work in IT have not had to learn as much these days as they
did 20 years ago.  That means they set up systems and often don't have
the knowledge or skills to properly secure a system.
And the first thing to get cut from IT budgets is funding for training,
usually.  Training that could actually resolve some of those security
issues by having competent staff.
Jim
Date: 16 Sep 2011 13:01:52
Message: <4e738100@news.povray.org>
So when the memory leak in your Linux-based wireless access point crashes
your machine, what do you do?  When your cable box no longer synchronizes
with the cable provider, or you get a new configuration pushed to your cable
modem from the head end, what do you do? When you update the PRL on your
android phone, what happens after the new PRL is stored?
Date: 16 Sep 2011 13:06:07
Message: <4e7381ff$1@news.povray.org>
You're asking a lot there, Jim. ;-)
Regards
Date: 16 Sep 2011 13:14:01
Message: <4e7383d9$1@news.povray.org>
A previous version of that post had a smiley at the end.  I guess it got
lost during the vetting process.
Date: 16 Sep 2011 13:15:35
Message: <4e738437$1@news.povray.org>
> crashes your machine, what do you do?
I report the bug with supporting data, build the latest version of the
code, and try to fix it.  I don't just reboot it.
In fact, I went through something very similar to this not long ago - my
wireless router/access point runs openWRT, and a recent update borked the
atheros driver.  Rebuilt the older kernel, reported the bug, and applied
the downgrade.
> synchronizes with the cable provider, or you get a new configuration
> pushed to your cable modem from the head end, what do you do?
Well, I don't have cable any more (it was an expense we had to cut when I
was laid off).  But that's an appliance, not the same as "running a Linux
server" in my book.  If Comcast wants to reboot their box, they can
reboot their box.
> When you
> update the PRL on your android phone, what happens after the new PRL is
> stored?
Again, not a Linux *server* - it's an appliance.  If Verizon decides the
phone needs rebooted, then it gets rebooted.
There's probably a way to do this without rebooting the device
(especially if it's rooted), but often times it's just simpler to reboot.
That doesn't mean a reboot is *necessary*, which is what we were
discussing.
Jim
Date: 16 Sep 2011 13:16:49
Message: <4e738481$1@news.povray.org>
>> Training that could actually resolve some of those security issues by
Indeed, I am - but things could get interesting here job-wise, as I've
found a job where I might actually have to solve that one. :)
Jim
Date: 16 Sep 2011 13:17:07
Message: <4e738493$1@news.povray.org>
(Not as in "been given an offer for", rather I found a posting that I'm
applying for)
Jim
Date: 16 Sep 2011 13:18:05
Message: <4e7384cd$1@news.povray.org>
Correction: as long as both endpoints know each other by an address that
works for them.
I know of customers who do inbound natting of third party servers as
well, because they don't want to route the public IP range inside their
network.
I would wager that the vast majority of them do.
Date: 16 Sep 2011 13:24:21
Message: <4e738645$1@news.povray.org>
Then it would take 2.5 nanoseconds for a hacker to steal your
credentials and make those changes for you.  BLAM! total denial of service.
Some IDS/IPS vendors have programmed routines in their systems that can
automatically change firewall rules in the event that they detect an
attack, yet the majority of installations leave this feature turned off
because people are afraid of false alerts blocking valid traffic, and
having HAL in control of the pod bay doors.
I'm sure ISPs feel the same way about having their customers be able to
play with their firewall configs.
Date: 16 Sep 2011 14:10:37
Message: <4e73911d$1@news.povray.org>
> applying for)
Good luck with that one. I hope that you can deliver on time and in
budget ;-)
Regards
Date: 16 Sep 2011 15:00:29
Message: <4e739ccd$1@news.povray.org>
On 9/16/2011 10:15, Jim Henderson wrote:
>  not the same as "running a Linux server" in my book.
I agree. That's precisely my point.  Saying "you never have to reboot a
Linux machine except for kernel upgrades" is incorrect. It assumes the box
has all the tools it needs to manage it without rebooting, and it assumes
your software environment isn't hardened against you manipulating it in the
ways described.
> discussing.
OK, so how do you upgrade your PRL without rebooting your phone? My point is
that claiming "you don't have to" assumes a whole bunch of facts that
aren't true just because you're running Linux.
Date: 16 Sep 2011 15:57:59
Message: <4e73aa47$1@news.povray.org>
> box has all the tools it needs to manage it without rebooting, and it
> assumes your software environment isn't hardened against you
> manipulating it in the ways described.
You specified servers and desktops - not appliance devices.
I also never said "you never have to reboot a Linux machine except for
kernel updates".  I said "you usually never have to reboot a Linux
machine except for kernel updates".  There's a world of difference in
those two statements.
I also very specifically stated that if you're dealing with zombie
processes, a Linux system *requires* a reboot to the best of my knowledge.
>> discussing.
> point is that claiming "you don't have to" assumes a whole bunch of
> facts that aren't true just because you're running Linux.
I've never had a need to, so I don't know.  Presumably you could stop a
service or unload/reload a driver, or drop to single user mode and then
go back to the default runlevel.
Jim
Date: 16 Sep 2011 15:58:56
Message: <4e73aa80$1@news.povray.org>
>> applying for)
> budget ;-)
A little late on the "on time" bit (I had wanted to be back to work about
2 months ago - but only in a position that was right for me), but yeah, I
think this could work out well once I get the resume into the right
person's hands.  The trick is making sure it gets to the right person
rather than going through "the front door".
Jim
Date: 16 Sep 2011 16:22:56
Message: <4e73b020$1@news.povray.org>
No I didn't.  I was responding to someone else's comment of
That didn't say "Linux machines with a full development environment
installed and to which you have root access never have to be rebooted."
That's my point here. :-)
Cool. How do I drop to single-user mode on my cell phone?
Again, you're making assumptions that the linux in your phone (or your cable
box or your credit card terminal) is like the linux in your desktop or
server machine.
Date: 16 Sep 2011 16:45:32
Message: <4e73b56c$1@news.povray.org>
Am 16.09.2011 19:14, schrieb Francois Labreque:
Id didn't get lost - it just hid between the lines. I swear I can hear
it chuckling.
Date: 17 Sep 2011 00:36:38
Message: <4e7423d6$1@news.povray.org>
That's fair.  You wrote your reply to a message I wrote, so clearly I
thought you were responding to what I said.
Probably depends on the phone.  Like I said, I've never needed to find
out, so I don't know.
> cable box or your credit card terminal) is like the linux in your
> desktop or server machine.
Linux is a kernel.  I'm not making assumptions about the kernel.
Jim
Date: 17 Sep 2011 01:37:02
Message: <4e7431fe$1@news.povray.org>
I still never specified servers at all, and I only mentioned desktops in a
disclaimer. :-)
Date: 17 Sep 2011 10:13:30
Message: <4e74ab0a$1@news.povray.org>
Incidentally, in the real world, nobody cares about the kernel. If you have
10,000 airline agents hitting your database from all around the world, and
your database server takes 10 minutes to restart and recache its indexes
after you upgrade the code, nobody really cares if the kernel survived the
upgrade or not. :-)  That's what always amuses me about such discussions.
Indeed, people don't really even care if it was the database down or the
router provided by your ISP.  A backhoe outside your door is going to screw
up your uptime stats as much as a kernel upgrade will.
Date: 17 Sep 2011 13:31:09
Message: <4e74d95d$1@news.povray.org>
> have 10,000 airline agents hitting your database from all around the
> world, and your database server takes 10 minutes to restart and recache
> its indexes after you upgrade the code, nobody really cares if the
> kernel survived the upgrade or not. :-)  That's what always amuses me
Certainly - and the question of whether it has to be rebooted or not is
somewhat mooted by that point.  I can get a lot of things to restart
properly by just going to single user mode and back to runlevel 3 or 5,
but if services are offline, that's still downtime.
Server uptime isn't a great measure of availability.  Service uptime is
more meaningful.
Just like the neverending debate about which Linux desktop environment is
the "best".  I've used pretty much all of them, and have come to the
conclusion that the DE is pretty irrelevant - if I am using a computer,
I'm using it for the apps, not the DE.  If I'm focused on the DE so much
that I "hate" KDE or GNOME or LXDE or whatever - then I'm obviously not
using the computer as a tool to get actual work done.
> screw up your uptime stats as much as a kernel upgrade will.
Absolutely.
Jim
Date: 17 Sep 2011 13:32:38
Message: <4e74d9b6$1@news.povray.org>
> a disclaimer. :-)
"And I'd argue that if you have a server whose *only* job is being a web
server, then restarting the web server after an upgrade is essentially
the same as a reboot, except faster."
That seems to be the source of the misunderstanding, because you did talk
about servers there.
Jim
Date: 18 Sep 2011 12:14:28
Message: <4e7618e4$1@news.povray.org>
>> a disclaimer. :-)
Fair enough. Plus that statement applies to any OS, not just Linux. :-)
Date: 18 Sep 2011 12:15:22
Message: <4e76191a$1@news.povray.org>
Heh heh heh. I'm definitely going to steal that.
Date: 18 Sep 2011 15:09:32
Message: <4e7641ec$1@news.povray.org>
>>> in a disclaimer. :-)
>> web server, then restarting the web server after an upgrade is
>> essentially the same as a reboot, except faster."
>> talk about servers there.
That's certainly true.
Jim
Date: 18 Sep 2011 15:09:53
Message: <4e764201$1@news.povray.org>
Feel free. :)
Jim
