POV-Ray : Newsgroups : povray.off-topic : Use case Server Time
27 May 2026 17:22:49 EDT (-0400)
  Use case (Message 1 to 10 of 14)
Subject: Use case
Date: 24 Aug 2011 13:31:53
Message: <4e553589$1@news.povray.org>
Now that the debate has died down slightly, here's an idea...
Suppose I have a bunch of files. I edit one of them, and then I want to
edit all of the others in the same way. Is there an easy way to make
Emacs do that? Because, if there is, that would be Actually Useful for
something.
http://blog.orphi.me.uk/
Subject: Re: Use case
Date: 25 Aug 2011 11:36:46
Message: <4e566c0e@news.povray.org>
> something.
  Your question can be reduced to "can elisp be used to do that?"
Since elisp is a programming language with basically all the same
expressiveness as lisp, the answer should be obvious.
  The more relevant question would be, however, whether that's the
*easiest* way of doing that. Probably not, unless you are an elisp guru.
Date: 25 Aug 2011 11:49:49
Message: <4e566f1d@news.povray.org>
>> something.
The question was more "is there already a button that does that?" I
could implement such a feature in any language. The question was whether
one is already present.
Date: 25 Aug 2011 12:14:15
Message: <4e5674d7@news.povray.org>
  "I want to edit all of the others in the same way" is quite a vague
description. I don't even know what exactly you mean by that.
  There's probably no "button" to do that (although it wouldn't surprise
me if there was). It doesn't sound like an extremely common task.
Date: 25 Aug 2011 14:22:47
Message: <4e5692f7$1@news.povray.org>
As best as I can tell, it's a line-based file format, where each line
contains a key/value pair. Basically if I use the tool and it changes
the line that says "mode=7" to read "mode=9", then I want to make that
change to all the files in the set. Similarly if it adds a new line or
removes an existing one.
I imagine you can probably do it somehow using diff and patch. But those
aren't usually present on Windows. (I gather Emacs has a special mode
for viewing the output from diff or something like that... Presumably
that only works on Unix though.)
Date: 25 Aug 2011 15:27:27
Message: <4e56a21f@news.povray.org>
  Usually you'd do a search&replace on multiple files to do that. I don't
know offhand if emacs has readymade support for search&replace on multiple
files, but it sounds like something that could be done with just a bit of
elisp. (Normally you would do this on the command line using 'sed' or other
similar tools, unless the changes are very complex, in which case it becomes
more difficult.)
Date: 25 Aug 2011 18:28:00
Message: <4e56cc70$1@news.povray.org>
Orchid XP v8 escreveu:
Install perl.  I don't remember perl at all, but it's probably a simple
one-liner.  A few switches on the command line and a simple regex
substitution should do the trick.  The right tool for the job, plain and
simple.  And yes, it's available for windows in a standard windows
install package.
a game sig: http://tinyurl.com/d3rxz9
Date: 26 Aug 2011 03:55:10
Message: <4e57515e$1@news.povray.org>
>> those aren't usually present on Windows. (I gather Emacs has a special
>> mode for viewing the output from diff or something like that...
>> Presumably that only works on Unix though.)
> install package.
The right tool for the job would obviously be some sort of file
comparison tool - which Perl isn't.
Date: 26 Aug 2011 09:48:41
Message: <4e57a439$1@news.povray.org>
>> install package.
Do you need to make the same change in each file?  If so, Perl or sed,
or awk are perfect tools for the job.
I don't see where diff comes into play...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 26 Aug 2011 10:53:54
Message: <4e57b382@news.povray.org>
  The problem sounds indeed like a simple search&replace task, which
tools like sed or perl are designed for.
