Am 20.08.2011 16:56, schrieb Darren New:
> Yep. How much of your networking isn't connection oriented? Here's a
> hint: all networking is connection oriented. IP layers
> non-connection-oriented networking on top of that, and then layers TCP
> to turn it back into connection-oriented, poorly. If IP wasn't
> connection oriented, you wouldn't need routing tables on each machine.
Nonsense. There's no connection-oriented networking in the classic
Ethernet, for instance - and IP ran fine on it. It's only the newer
Ethernet incarnations that installed connection-oriented principles
below IP, due to operating on point-to-point connections on the physical
layer. (Which again shows that, as you already mentioned, having
connection-oriented principles rooted pretty deep in the network stack
seems to have /some/ benefits.)
You /might/ consider the current route through the internet a kind of
IP-layer connection, but given that it can change even from packet to
packet, and the packets can reach the receiver in arbitrary order, I'd
call that pretty far-fetched.
Am 20.08.2011 12:49, schrieb Orchid XP v8:
> Can you imagine anything more MIND-NUMBINGLY BORING than staring at a
> sheet of 40 long division problems? YES, I GET IT! I KNOW HOW LONG
> DIVISION WORKS! STOP BUGGING ME ALREADY! >_<
> Seriously. If you know how it works, do you really need to do it 200
> times over just to *prove* that you know how it works? It's not even
It's called "training", and is intended to (1) identify and iron out any
occasional glitches, and (2) empower you to do it without needing to
think about.
For *proving* that you know the procedure you have the so-called "tests".
> like it's particularly important to be able to *do* long division; it
> isn't something you're going to need to do every day of your adult life.
> You just need to have a firm grasp of /how/ it works and /why/ it works.
> Once you've got that, practising it on endless question sheets is just
> an utter waste of time.
Yes, but instead of a firm grasp of /how/ and /why/ it works, some
people (and I guess they're the majority) need training to get a firm
grasp of /how to/ actually do it - either because they never will get a
firm enough grasp of the /how/ and /why/, or because they just don't
give a shit.
Am 20.08.2011 14:30, schrieb Orchid XP v8:
>> Wrong, it's not to prove that it works. It is to drum into your "thick
>> little head" how to do it with out thinking. Compare it to repeating a
>> dance step until your body does not think of the individual moves. Then
>> you can build on it.
> Doing arithmetic "without thinking" is how we ended up with Verizon Math
> Fail.
The trick is to do the thinking part on such smart questions as "is that
cents or dollars?", rather than on such boring arithmetical questions as
"how much is 1 divided by 100?".
Am 20.08.2011 20:05, schrieb Orchid XP v8:
> Admittedly it was a school for mentally retarded people such as myself...
I don't know the background of that diagnosis, but - fun fact: A lot of
highly intelligent people are diagnosed as stupid and poor learners, for
no other reason than them getting bored by the stuff they try to teach
the normal people.
>>> sheet
>>> of 40 long division problems? YES, I GET IT! I KNOW HOW LONG DIVISION
>>> WORKS!
>> You realize that most people aren't that smart, right?
> Pro tip: If I can answer 20 long-division questions correctly, I can
> probably answer 2,000 long-division question correctly. It'll just take
> me 100 times longer. :-P Thus, there's no real point to actually
> *making* me answer 2,000 questions...
Yes, but if you (ok, well, some other poor sod) can answer only 10 out
of 20 long-division questions correctly, then doing 2000 of them might
help to push that ratio to maybe 19 out of 20.
And because even maths teachers don't usually base their way of teaching
on stochastical methods, they'll just let every pupil do the 2000.
> I was just having a chuckle about my science teacher whining about how I
> "don't apply myself" in class. His final comment was "more effort
> required". I notice he was the only teacher who forgot to actually fill
> out the performance ratings in the school report. MORE EFFORT REQUIRED! :-P
> This amuses me, of course, because I got a B grade for my science, a
> grade which is apparently unprecedented in the history of the school.
> Yeah, I really need to "apply myself" more. :-P Self-important idiot of
> a teacher...
Heh, maybe he only tried to keep up the morale of the other pupils.
"Why do we have to do all the homework when Andrew doesn't?"
On 8/20/2011 17:38, clipka wrote:
> Nonsense. There's no connection-oriented networking in the classic Ethernet,
What machines does the broadcast address connect to? Guess what? That's what
they're connected to.
That's the sort of connection I'm talking about, which is important for
management and maintenance and routing. Indeed, the lack of management
features is exactly why people went to star topology ethernet, precisely
because ethernet, like IP, wasn't really connection oriented in that sense,
and when something broke (like beaconing or disconnecting), it was
impossible to isolate and diagnose.
Now, of course, IP treats each ethernet network as something separate from
the routers that link to other ethernet networks. IP isn't really needed if
you run over ethernet without routers.
I'll grant that IP also runs over non-CO networks like alohanet. Other than
that, there's a pretty clear idea of whether you're connected or not to
adjacent machines. IP also isn't needed if you run your network over alohanet.
I believe you misread me. I'm saying IP layers non-connection-oriented on
top of network connections. I don't need to explain how IP can be
interpreted as connection-oriented, because I'm saying IP makes
connection-oriented networks non-connection-oriented.
> packet, and the packets can reach the receiver in arbitrary order, I'd call
But in practice, it generally doesn't. That's why things like path MTU work.
However, you're reading me in the wrong direction. IP takes something
connection-oriented (dial-up, star topology ethernet, etc) and turns it into
non-connection-oriented. And then layers on top of IP are almost invariably
used to turn it back into a connection-oriented conversation. The most
commonly used reason to not have something connection-oriented is that IP
drops packets and you can't reliably know it happened. I.e., the reason to
use UPD instead of TCP is often that the underlying IP has made the
connection unreliable (non-reservation, etc) compared to something that's
actually connection-oriented.
How come I never get only one kudo?
Le 21/08/2011 06:03, Darren New nous fit lire :
I believe you have an issue of vocabulary.
Below IP is not a network (in IT terminology), but links.
Links can be connection-oriented or connectionless.
They can be point to point (like current rj45/c8p8 cables) or they can
be broadcasting media (like 10base5 and other ethernet coaxial cable).
They can even be multipoint (like ISDN and X.25).
The fact that most transmission occurs using TCP should not hide that
there is some other transport protocols above IP which do have their own
interest.
TCP is reliable and ordered. So it is often used.
But there is application who do not care about reliability and order
(such as video distribution: better skip a frame than freezing. same
goes for VoIP: delivery in time is more important; Such application then
use RTP, a protocol above UDP/IP (or when possible, directly above ATM)).
TCP covers 95% of applications, but there is more than TCP under the sun.
More like "it keeps the students quiet so we don't have to think up any
*real* tasks for them to do".
>> REQUIRED! :-P
>> a teacher...
No, he told everybody they were doing really badly, regardless of how
good or bad their work was.
And when I went over and told him I got a B, he was all like "see, I
always said you'd do well". NO YOU DIDN'T! You told me I would likely
fail! "I only said that to motivate you." WTF? Telling people they're
hopeless is NOT MOTIVATION!
Self-important dick... Man, everybody hated that guy.
http://blog.orphi.me.uk/
Recurring dream: Going back in time to school with the knowledge and
confidence I have now. But then I would probably see what sad examples
of humanity the male teachers were and give up in disgust.
At least you probably weren't belted (beaten with a leather belt).
Regards
>> What part of
>> | U x V | = |U| * |V| * cos a
>> do you *not* understand? :-P
> Would be a lot simpler if the damn stuff you have to use it in
> "understood" all that shit, natively. The problem I always run into is
> that you can find a perfectly comprehensible form of something some
> place, but it is only applicable is you a) do it by hand, or b) know how
> to derive some completely bloody different set of equations, that the
> damn computer will understand. Its like knowing, sort of, how to speak
> some obscure Chinese dialect, but then finding out that you need to
> *write* the information down in German, which for which the only work
> you know is the one applying to yourself, Dummkopf.
> Well, not exactly the same case, but if you don't have all the other
> stuff in between the two concepts, understanding what the math is doing
> in the "human" version won't get you any closer to understanding how the
> hell the computer needs to deal with it.
I'm having difficulty following what you're trying to say here.
> The original post in this, describing deriving the two equations needed
> for Mandelbrot, from the original non-computer usable one, is a perfect
> example. My reaction is, "Show the math, step by step, because WTF?" lol
Yeah. All the textbooks advanced enough to talk about complex dynamical
systems assume that you *already* know everything there is to know about
complex numbers (a much less advanced topic, comparatively speaking).
The first equation *is* useable in some software packages. But usually
you need to expand out the real and imaginary parts seperately - a step
which isn't mentioned anywhere and isn't described in any detail because
it's presumed to be "obvious".
I assume that was a rhetorical question, but I'll answer anyway...
Start with Z^2 + C. Assume that Z = X + Y i, and C = A + B i. For that
is what complex numbers are: a real part, and an imaginary part.
(Explaining *that* is a whole /other/ essay...)
Substituting into the original formula, we have
(X + Y i)^2 + (A + B i)
We can open the second pair of brackets without changing anything:
(X + Y i)^2 + A + B i
Now, the first pair of brackets. The binomial theorem tells us the
answer in canned form, but it's perfectly easy to do it all by hand.
Since K^2 means the same thing as K * K, we can say
(X + Y i) (X + Y i) + A + B i
Opening the first pair of brackets, we have
X (X + Y i) + Y i (X + Y i) + A + B i
Opening the first pair of brackets, we get
X X + X Y i + Y i (X + Y i) + A + B i
Obviously X X becomes X^2:
X^2 + X Y i + Y i (X + Y i) + A + B i
Do the same sort of thing with the last pair of brackets:
X^2 + X Y i + Y i X + Y i Y i + A + B i
The Y i X term is of course the same thing as X Y i:
X^2 + X Y i + X Y i + Y i Y i + A + B i
Since there are two X Y i terms, we can gather them together:
X^2 + 2 X Y i + Y i Y i + A + B i
The Y i Y i term is the same thing as Y Y i i. And that's obviously the
same as Y^2 i^2. Now, BY DEFINITION, i^2 = -1. And Y^2 * -1 = -Y^2. So
we have
X^2 + 2 X Y i - Y^2 + A + B i
If we now put all the terms containing "i" into one pair of brackets,
and everybody else in other pair of brackets, we get
(X^2 - Y^2 + A) + (2 X Y i + B i)
This is still the same formula, we've just added some redundant brackets
and rearranged the order a bit. Now, if we take everything in the left
set of brackets and divide through i, we get
(X^2 - Y^2 + A) + (2 X Y + B) i
This is still the same formula. (If we open the brackets, we get back
what we had a few lines ago.) But now we have two purely real
subexpressions, which a computer can calculate:
X := X^2 - Y^2 + A
Y := 2 X Y + B
QED.
I saw pictures in books of the "cubic Mandelbrot", and tried all sorts
of modifications of the formula to make it cubic instead of quadratic.
Of course, I didn't know about the binomial theorem yet. In order to get
a cubic, you need to do this:
(X + Yi)^3 + (A + Bi)
(X + Yi)(X + Yi)(X + Yi) + A + Bi
X(X + Yi)(X + Yi) + Yi(X + Yi)(X + Yi) + A + Bi
X^2(X + Yi) + XYi(X + Yi) + Yi(X + Yi)(X + Yi) + A + Bi
X^3 + X^2 Yi + XYi(X + Yi) + Yi(X + Yi)(X + Yi) + A + Bi
X^3 + X^2 Yi + X^2 Yi + X Y^2 i^2 + Yi(X + Yi)(X + Yi) + A + Bi
X^3 + X^2 Yi + X^2 Yi - X Y^2 + Yi(X + Yi)(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + Yi(X + Yi)(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + XYi(X + Yi) + Y^2 i^2(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + XYi(X + Yi) - Y^2(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + X^2 Yi + X Y^2 i^2 - Y^2(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + X^2 Yi - X Y^2 - Y^2(X + Yi) + A + Bi
X^3 + 2X^2 Yi - X Y^2 + X^2 Yi - X Y^2 - X Y^2 + Y^2 i + A + Bi
X^3 + 2X^2 Yi - X Y^2 + X^2 Yi - 2 X Y^2 + Y^2 i + A + Bi
X^3 + 2X^2 Yi - 3 X Y^2 + X^2 Yi + Y^2 i + A + Bi
X^3 + 3X^2 Yi - 3 X Y^2 + Y^2 i + A + Bi
(X^3 - 3 X Y^2 + A) + (3 X^2 Y i + + Y^2 i + Bi)
(X^3 - 3 X Y^2 + A) + (3 X^2 Y + Y^2 + B)i
X := X^3 - 3 X Y^2 + A
Y := 3 X^2 Y + Y^2 + B
As you can see, the result looks *nothing like* the quadratic case. If
you didn't know what the derivation procedure was, you would have no
idea why this is so.
> Uh, no. The reason you have to do sheet after sheet of utter bullshit
> like that was because your school, like mine, catered to the one idiot
> in the room that didn't grasp the idea after the first 3 times.
That still doesn't make sense. We each got given a textbook. We each
work through that textbook as quickly or slowly as we please. (Although
if you're too slow, you get yelled at.) If you get too much stuff wrong,
they make you redo it, or redo something from a similar textbook.
Which should *still* mean that you only have to do 2,000 questions if
you're actually that slow at getting it. But noooo...
When math is treated as some kind of punishment, why is anybody
surprised that nobody wants to do it?
> I refused to do any more of them, they sent me to a school psychologist,
> where they then jumped to several screwed up conclusions, based on, of
> all things, the fact that crayons got handed out alphabetically, so I
> always ended up with the black one (they later adjusted this so people
> got the chance to use other colors, but one wonders how many others
> where misdiagnosed with some sort of disorder over that silly thing),
> and my house **actually** had boxes around the trees and windows, so I
> was "disturbed", because I, "drew boxes around things and used black to
> do it". By the time the idiots figured out that the real problem was
> that I was bored to death of the crap they kept handing me to do, they
> had managed to put me a whole year behind in math. Luckily, I was like
> 6-7 years *ahead* in reading. lol
Did you just say "the education system is fundamentally broken"?
I remember seeing a psychologist. Part of the conversation went like this:
"What were you thinking about just now?"
"Crystals."
"OK. Tell me about crystals."
"Nah, you wouldn't really be interested. I can tell."
"How can you tell?"
"The frames of your glasses are grey."
Now, considering I was, like, 9 years old, most people would have just
laughed that off. This guy looked actually terrified that I was able to
READ HIS MIND just by the colour of his glasses. Literally, he was
desperately trying to figure out how I knew. Obviously, I didn't "know"
anything. I was just being daft.
It's like nerd-sniping. http://xkcd.com/356/ Apparently psychologists
are really, *really* easy to confuse.
>> I was always quite bad at arithmetic. I still am. The difference is that
>> today, I use a frigging *computer* to do the work for me. :-P My job is
>> to figure out what the actual calculation is; the computer does the
>> mundane work of actually *running* it.
> Yeah. Same here, more or less. I can't do math in my head worth shit,
> and I hate doing it by hand on paper.
I find doing /arithmetic/ on paper to be trivially easy. It's just not
particularly interesting. I quite often do /math/ on paper - mainly due
to the difficulty of typing most of the notation on a computer.
> Shortcuts would help, but you don't get those in school.
I haven't been to school in a long time. I hear they no longer teach
"mathematics". They teach "numeracy". And it doesn't involve knowing how
to add and subtract and multiply and divide. They only teach you how to
/estimate/ results.
I have no idea whether this is true, or just what the media tells us.
>> I spent almost all of my time at
>> college sat in the library, absorbing everything I could lay my hands on.
> Should probably do that myself. The problem is figuring out where the
> hell my gaps are to start with, then finding something that doesn't bore
> the hell out of me reading it
My problem is that I know a lot of quite advanced (i.e., interesting)
mathematics, but I don't know some of the stuff that comes before that.
Normally you would learn the simple stuff first, gradually moving on to
the more advanced stuff. Which means there are books full of simple
stuff, and books full of advanced stuff. And to fill the gaps in my
knowledge, I'd have to read one of the "introductory" books where I
already know 95% of what it says, just to learn the 5% that I haven't
stumbled across yet.
> like, I don't know, something directed at
> "application" of the math, not just how the hell you write the
> equations. I think this is a huge damn failing in "text books", and
> classes in general. Its one thing to hand someone a formula, or even a
> stupidly simply thing you want someone to do, like graphing a line, but
> give no possible context for why the hell anyone would bother to do so,
> save maybe some historical context. Its quite a bit different when you
> "need" to know, for your own purposes, how thick a rope will get, wound
> onto a spindle, and thus how big the spindle needs to be, versus just
> having someone hand you a problem, and ask you to give them a result,
> when your only thought is likely to be, "Why the hell do I need this?"
> Mind, that was physics class, while the normal math classes don't even
> give you problems that come even remotely close to that interesting. In
> any case, I don't remember the equations. lol
It depends.
Sometimes I just want to solve a specific problem. But I do also enjoy
reading about mathematical objects and their properties just for the
hell of doing so. It's interesting. (I suspect if you had to do this for
an actual *test*, it would become much less interesting...) For example,
reading about polynomials and all the patterns and symmetries they have.
And /then/, when you find yourself needing to solve some problem that
happens to involve polynomials, you already know quite a bit about them,
and therefore where to start looking for a solution.
> Nah.. Stupidity desirable? How could that ever be the case. I mean, its
> not like, at least in the US, there are politicians banking on it,
> products sold based on playing fast and loose with as little information
> as possible, or active attempts to undermine education. That is just
> absurd! Or, in reality, as I put it a bit ago when talking about the US
> version of libertarianism - "The concept is simple, lower taxes,
> resulting in poorer schools, resulting in closed schools, and since its
> everyone's 'right' to choose to be ignorant, the fact that 90% of the
> population is stupid has nothing to do with the failure of the system,
> its entirely the fault of people not moving to where the only two
> schools still open are located."
WOW. O_O
> Dear old Madison would be having a
> heart attack at this shit, if he hadn't had the sad misfortune of dying
> in 1836.
...irony...
> I seems only fitting that by 2036 the US might be so fucking stupid that
> they couldn't build a log cabin from his time, let alone work out why
> living in one would be preferable to huddling under a tree, or wearing
> animal skins in a cave... Or, so it sometimes seems the trajectory of
> some of this stupid shit is headed.
I think sometimes it's hard to tell whether the entire world is stupid,
or just a vocal minority.
There was a kid at school who used to bully me constantly. I used to
dream about doing terrible things to him.
And then one day I thought to myself "Wait a minute. Your dad is an
alcoholic, your whole family lives on welfare in a rundown council
flat... there is basically NOTHING I COULD DO that would make your life
anybody miserable than it already is. HAVE A NICE DAY!" :-D
I do remember two kids got the slipper. (You're probably not allowed to
do that, but they did.) The first kid stood there and took it like a
man. The second was a screaming wreck.
It depends on what IP travels over. If it's IP-over-ATM, there's most
certainly a network there. If it's IP over dial-up, less so.
Sure. And the point I was trying to make is that it's better to reserve
bandwidth than skipping a frame, but IP doesn't support that.
Yep. And I'm saying that the primary reason people don't use TCP is to
compensate for a lack of things like bandwidth allocation and routing
assurance. Nobody used TP4 over a network that will work fine with TP0.
I will say that I never had an art class before grad school that actually
wasn't of the busywork type. Very few of those sorts of classes actually
taught anything. I would have loved to go to music class where they actually
taught some music theory or something, or an art class where they talked
about the proportions for drawing people or the golden rectangle or
something like that.
On 8/21/2011 3:38, Orchid XP v8 wrote:
> NOTHING I COULD DO that would make your life anybody
Sounds like a Holly Lisle book.
Gabriel: "But God, the devils are breaking their contract. Thay're cheating!"
God: "Of course they are, Gabriel. They're devils."
Gabriel: "But ... but ... you should punish them!"
God: "They're already damned to hell, Gabriel. What would you have me do?"
A very amusing book, overall. I recommend at least the first 2 or 3 for
silly light reading.
> actually wasn't of the busywork type. Very few of those sorts of classes
> actually taught anything. I would have loved to go to music class where
> they actually taught some music theory or something, or an art class
> where they talked about the proportions for drawing people or the golden
> rectangle or something like that.
In our music class, they made us play musical instruments.
Oh, until the old teacher left and we got that *other* person, who
couldn't make kids do stuff for toffee...
We didn't even *have* art classes. Though we did have pottery classes,
where we actually made pots. I still have some of them.
Le 21/08/2011 17:04, Darren New nous fit lire :
Unless the "network" is only a part of the path.
(Interconnecting 2 Lan/Ethernet with pair of X.25 links: the system on
the lan are probably better using TP4 and the X.25 gateways just have to
push the clnp packets in the X.25 links. On these gateways, it's
probably simpler to have the application use also a TP4, even if they
could simplify the connections crossing only X.25 to use only a TP0).
Now, if I could have convinced the customer to use IS-IS on the
redundent four gateways per lan, that would have saved a few nightmares
about the routing table on the lan... and less money for my company on
the long run ;-)
Regarding IP-over-ATM, it depends from where you look (as you are
smashing the model inside another instance):
From IP (layer 3), ATM is simply a link (or set of links) (layer 2)
From ATM, it is providing nearly level 4 service. (and even more)
Vocal minority, plus a big non-vocal minority, who just want shit to
work, but not why or how. Just had one bozo on MSNBC last night all but
*admit* that Rick Perry, the Texas governor, who has driving his state
into a worse condition than the rest of the country, but now wants to
run to be president, is selling his constituents his own ideas, based on
fear, deception, and misinformation, because, "people are reacting to
what they feel is wrong, not the facts. The facts, such as Bush's last
days being a hemorrhaging of jobs, while Obama managed to at least
stabilize things, are basically irrelevant to the process of deciding
who the next Republican candidate is, or whether he will be elected."
The mans entire argument seemed to hinge in this being perfectly OK,
nothing wrong with it, for the most part, and entirely irrelevant to the
well being of the country. It was just how the right wing had to "sell"
the problem to their ignorant, stupid, angry, and wanting things to get
better, constituents. The fact that none of what was being sold to them
can or will solve the problems, most of it is stuff that caused them in
the first place, and that actually basing your policies of reality is
*necessary* to fix things, where all meaningless. My jaw would have
dropped, but it still hadn't receded from the floor from earlier, when
Bachman claimed that people where still afraid of the rising power of
the USSR (yeah, Soviet Russia), which she apparently failed to not the
fall of, while working cleverly inside the IRS to undermine the federal
tax system, before she decided to run for office some place else.
Fact is, most people don't want to know anything. Its inconvenient to do
so. So, the end game of that is that what sells, i.e., what speaks to
the gut at the time, matters, and silly things like facts, statistics,
truth.. well, those just don't sell as well, so fewer people will listen
to them. As long as people, "trust their gut", which has the brains of
Homer Simpson...
On 8/21/2011 3:16 AM, Orchid XP v8 wrote:
>>> What part of
Just that, in such a case, the problem isn't just translating between
languages, its knowing "which" of perhaps dozens of words might
correctly convey the original details. You could, without a lot of
problems, pick German words that muddle the meaning so badly its hard to
work out what the original even meant. This is actually even more the
case if you went from German to Chinese, since there is like a small
handful, and one major, written form of it, but like I don't know how
many dialects. Its the only language in the world where you write dog
nearly the same way in every single case, but there are 20 ways to "say"
it, some of them nothing at all alike.
If you don't know what the "intended" meaning is, i.e., the stuff in
between, the result is going to end up being complete nonsense.
Uh.. Will go over that some time and try to work out what you did. lol
Though, I could probably, based on the stuff he already gave, at least
make an attempt at it without you having helped. I did get far enough in
math to do some of that. I just am not sure I remember all the factoring
and other stuff clearly enough to get it right.
But, yeah, exactly. If you don't know all the stuff "between", you won't
get any place, other than confused.
That should have been "plus a big non-vocal majority".
On 20/08/2011 03:43 PM, Darren New wrote:
> On 8/20/2011 4:11, Warp wrote:
>> Drawing an accurate antialiased line (of certain width) is not a trivial
>> problem. Basically for each pixel you need to calculate how much of it is
>> covered by the line. Doing this accurately with integer math only can be
>> complicated.
> I am not sure you can do it accurately with integer math at all, given
> that there's a "portion of a pixel" involved in there somewhere. At best
> you'd be working in scaled fixed-point.
You realise that all of the quantities involved are rational, right? And
that a rational number is just two integers?
>> Nobody ever needs to compute the exact quotient of two 4-figure numbers
>> mentally. It's not necessary. You just need to be able to estimate the
>> answer with sufficient accuracy.
> True.
>> (Something which apparently a great
>> many people can't do for some reason...)
> Again true.
I hypothesize that this is due to their being far too much emphasis on
memorising the algorithms for (say) computing a quotient, and far too
little emphasis on getting a feel for what all the symbols *mean*, and
*why* you manipulate them in this way.
>> Practising something you're going to need to do every single day of your
>> life is worth while. Practising something which you will never, ever
>> need to actually do is pointless.
> Well it surprises me that you never need to calculate something when you
> are away from some form of calculator.
It's not that I never need to calculate something. It's that I never
need to calculate something to 6 figures. Usually I just need to
estimate the answer. If I really do need an *exact* answer, I can use a
calculator (given that there is *always* one in my pocket), or use
pencil and paper if it matters that much.
> give a shit.
It's a well-established fact that meaningful things are far easier to
remember than meaningless things. Hence, if you understand why a
procedure works, it's much easier to recall it.
This doesn't change the fact that some people don't give a damn about
maths. Then again, when "maths" just means memorising a bunch of stuff
for no other reason than "it's in the test", who can blame them?
Am 22.08.2011 10:14, schrieb Invisible:
>>> it is
>>> complicated.
But in the end you want to paint a pixel a particular color, which is a
/single/ integer. That's where the precision you might be able to keep
with rational representation ultimately breaks down.
That's where the precision with ANY POSSIBLE REPRESENTATION will break
down. :-P
Le 2011-08-19 09:25, Invisible a écrit :
>>> (Come to think of it, *all* of the networking stuff at college was done
>>> by Novel Netware. Now there's a name I haven't heard in a long time...)
>> They're still around.
> Novel is clearly still around. I meant Netware.
Netware, the OS, is pretty much gone. Novell still sells its NDS
(Novell Directory Services) and file servers, but they're now using
Linux for the OS (SuSE, if I recall)
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
That's what I suspected.
> Novell still sells its NDS (Novell Directory Services) and file servers
Interesting...
> but they're now using Linux for the OS (SuSE, if I recall)
Yeah, that's the one.
Darren New <dne### [at] san rr com> wrote:
> On 8/20/2011 11:55, Warp wrote:
> > So no, you don't get it "almost for free". Not if you want a high degree
> > of accuracy.
> Actually, I think you do, if you keep the slope of the line positive and
> below 45-degrees. Then you use basic rotations of the algorithm to handle
> other cases. The trick is the line will never go through more than 2 pixels
> in the same column, so whatever doesn't go into the first pixel does go into
> the second picture.
If the line is anything else than 0 or 90 degrees, it can cover a
triangular area of a pixel, not just a trapezoidal one.
Also, likewise, both edges of the line can go through the same pixel
(unless the width of the line is at least sqrt(2).)
Symmetries do not help here at all.
In practice the integers have a maximum value they can hold, so too much
precision in your rational value can easily overflow either (or both) of
the integers.
(If you were to use integers of unbounded size, you might just as well
use floating point values. They would be faster too.)
> the integers.
Yes. But if the quantities you're calculating with are pixel
coordinates, overflow is highly unlikely to be a problem.
> > the integers.
Except that we are talking about antialiasing here, which by definition
is calculating at subpixel accuracy.
On 19-8-2011 17:44, Jim Henderson wrote:
> On Fri, 19 Aug 2011 16:32:22 +0100, Invisible wrote:
>>>> ...but it was somewhat baffling to walk into a classroom and discover
>>>> that I know more about the subject than the lecturer does.
>>> Oh c'mon now! Anyone who can think his way out of a wet paper bag has
>>> had this experience repeatedly. We're just socially trained not to say
>>> so.
>> What, that the person being paid to teach you something knows less about
>> it than you already do?
> Yes, it's not that uncommon. In my case, it was an assembly language
> class I took in college - it started from how to use MASM, but I'd
> already used TASM quite extensively - but the course was a required
> course in my degree program.
Mine were e.g. in computer graphics related subjects. We had one teacher
that tried to keep ahead of the class by one week, but failed because of
over consumption of C2H5OH. To this day he is also the only person I
have ever met with a technical university degree that did not understand
the equation for a straight line.
The practical part was more fun, but we had a japanese arts student to
help us there...
The exam was a joke too, we could use our book and the questions were
like 'give the definition of...', 'what two problems are there when
using technique X'.
Aside: my main surprise in this was that the students from CS simply
accepted this level of teaching, many did not even notice.
That was something that surprised me as well - but then again, when I
took my Assembly class, I had programmed in something like 15 different
languages - more than anyone else in the class - and had been programming
(even was paid to write code) since I was about 10.
So many CS students need that level of teaching, because they have
(perhaps) math aptitude, but not (a lot of) hands-on experience writing
code.
Jim
> code.
A low level would be acceptable for that reason. But a guy that writes a
straight line and axes on the blackboard with a formula that does not
match what he has drawn? Adding that there is a problem with either
horizontal or vertical lines, because something might become infinitive
and choosing the wrong one (matching neither his formula, nor his
graph)? Or the assistant at the practical part that does not know the
difference between a variable and a parameter?
Nobody needs that level of teaching.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
>> programming (even was paid to write code) since I was about 10.
>> code.
> difference between a variable and a parameter? Nobody needs that level
> of teaching.
That's certainly true - what's being taught has to be taught effectively
*and* correctly.
Jim
After further consideration, I think you're right, yes. :-)
Uh, no? Sqrt(2) for a 45-degree line thru a pixel sort of thing?
That would be the "fixed point" part of my comment. Of course, if you want
high precision rationals, you might wind up with multi-word integers, at
which point you might as well just use floating point unless you're back on
8-bit hardware or something.
> /single/ integer.
Cold hearted orb that rules the night,
removes the colors from our sight,
red is gray and yellow white,
and we decide which is right,
and which is a quantitization error.
On 8/21/2011 8:28, Orchid XP v8 wrote:
> We didn't even *have* art classes. Though we did have pottery classes, where
Making a pot is rather different from the art of pottery making, tho. We
give kids fingerpaints in kindergarden and we don't call it "art class". Or,
at least, we don't think we're teaching them anything about art.
Symmetries help in that they reduce the number of cases you have to code
for. They don't make the math itself any simpler.
>> where
Sure. But it /was/ a school for stupid people... I have no idea what
they have in real schools.
Although, my sister's school did a production of Joseph and the
Technicolour Dreamcoat. And it was almost worth paying good money to
see. (!)
By coincidence, I lent one of our laptops to an employee yesterday. She
set it up with her ISP's install disk, and now the laptop appears to
have "Services for NetWare" installed. o_O
I'm still trying to figure out whether that's because they wanted to be
compatible with anyone still using NetWare, or whether the ISP is
actually powered by NetWare...
On Fri, 19 Aug 2011 13:00:24 +0100, Invisible wrote:
> I have nobody to impress anymore. :'{
> (Although... I wonder how much of the praise I received was actually
> justified. Especially at college, when I was in a class full of chavs
> who went out and got drunk *every day*. They'd be hung over for the
> morning classes, and mildly drunk for the afternoon ones. Is it any
> wonder the lecturers though I was brilliant?)
Believe it or not ...
Well, I was once a prolific poster on this group, but that was
about six years ago. Not sure what, if anything, you'd remember
about me, but I can assure you that "believe it or not" is
warranted.
... I heard a lot of the same crap as you from my teachers, even though I
never went to "Uni". And often from teachers, like yours, who did not
understand the subjects they were teaching.
No, I didn't spend my time scribbling formulae into notebooks[1], but I
was well known since grade school for my own set of tricks.
What I wonder is how destructive this praise from (molding by)
unqualified teachers ends up being to their students.
I imagine you were encouraged to "work with computers" and that this has
worked out decently for you, but it may be overall not an optimal fit.
I know enough programmers to know that "working with computers" means a
lot more than figuring out clever bits of code. It's an environment and a
lifestyle to which many clever people may not be well suited. Would Frank
have known this?
I know from my own experience that there are many affable people I would
not recommend become salesmen, many strong people I would not recommend
become carpenters, many hard-working people I would not recommend become
entrepreneurs, and many fit people I would not recommend become
roughnecks.
And I know that I wouldn't hire you as a programmer. I would prefer
someone, perhaps less encyclopedic, with a better work ethic; someone who
does what he's told by the person paying him to do it and who spends less
time on this forum; someone who's more interested in keeping the wheels
turning than it reinventing the wheel.
I might hire you as a tech writer.
At least "working with computers" is good practical advice. (My brother
just got his Doctorate in EE and will make a lot more money than most
people―though I'll bet he still ends up working for someone dumber than
himself.) How about those poor kids who are pushed into liberal arts?
-Shay
[1] I do that now. But I'm sure I'm not reinventing the wheel, because
what I'm trying to figure out are the subtleties of a personal "sacred
geometry" for my pictures: NOT draw_picture() algorithms, just subtleties
of form that I find satisfying. You really /should/ try POV-Ray.
ps. One example of some ludicrous praise I recently received: After
hearing that I had ridden my bicycle 150 miles on the previous day, my
wife's friend commented that I should "try" the MS-150 (A 150 miles in
TWO days bike ride). TRY?!! TRY to ride 150 miles in two days when I'd
just ridden it in one?!
The Real WTF is: What the *hell* is somebody who doesn't know about the
subject doing teaching it to people?! In what universe is that a
remotely good idea?
This is the operative question, yes.
> have known this?
Would Frank have cared? I highly doubt it.
Somebody *did* hire me as a tech writer. And liked my work. (And had no
problem with my "work ethic" - then again, it wasn't a big project...)
Could be bigger if you are interested.
> ...and now I'm feeling all nostalgic about the long-lost days when I
> could just sit in a corner reading about Gaussian elimination or
> something while the lecturer blathers on about the role of middle
> management or whatever. I could do crazy math stuff, and people would be
> *impressed* and stuff. My college notes are literally a fermenting sea
> of equations. Serious work mixed up with doodles and advanced math. I
http://www.xkcd.com/664/
I wonder how many great programmatical inventions have been lost
because they were made within the programming industry rather than
the academia.
> the academia.
After reading TFWTF, I'm tempted to say "not many". But then again, who
really knows?
> > the academia.
> really knows?
The industry does often make quite advanced discoveries and development,
even if it ends up being properietary and burdened by approximately half a
million patents. I'm just wondering how many of such discoveries never
become public knowledge for example because the company decides to discard
the feature from their software (but still keeps a tight hold to the rights,
of course) or the solution just goes unnoticed (and the programmer is not
allowed to divulge it).
Of course the academia and the industry often tend to solve different
types of problems. The industry tries to solve mostly practical problems,
while the academia often tries to solve mostly theoretical problems (most
of which may or may not have a practical application). For example, where
the academia tries to solve problems like "what is the fastest algorithm
to determine if two connected graphs are strongly bisimilar", the industry
tries to solve problems like "what's the fastest way of making millions of
database accesses" or "how do we make these graphics look realistic in
real time.
Both goals sometimes overlap (especially nowadays with all this fad with
multithreaded programming, which has strong theoretical foundations), and
at both venues there are sometimes excursions to the other side (with the
industry solving theoretical problems and the academia practical ones), but
it's probably not the norm.
> because they were made within the programming industry rather than the
> academia.
Indeed, and of course there are some concepts that nobody can use because
they're made in the industry and patented by companies with armies of
lawyers rather than in academia. I wonder how different the software
landscape would be today if some of the utterly stupid patents there are
outstanding lawsuits about weren't covered by a patent.
Jim
> the academia.
Given the impact of academic inventions on practical programming, I wonder
as well. (Consider, for example, relational databases, P/V semaphores and
deadlock prevention techniques, parsing/language theory, etc.) I'm thinking
that the really big academic discoveries do indeed tend to have a stunning
impact on practical business, in the form of stuff like RDBMS and parser
generators and public key encryption and etc.
