POV-Ray : Newsgroups : povray.off-topic : More Haskell fanning Server Time
17 Jun 2026 01:06:52 EDT (-0400)
  More Haskell fanning (Message 44 to 53 of 53)
Subject: Re: More Haskell fanning
Date: 18 May 2011 18:40:11
Message: <4dd44acb@news.povray.org>
On Wed, 18 May 2011 22:30:32 +0100, Orchid XP v8 wrote:
> I gather that Linux only just got the ability to notify you if a file
> changes. (At least modern Linux desktops manage to *use* this
> information correctly, which is more than Windows Explorer manages...)
The notification API has been around for several years now.
As for ACLs, it depends on the tools.  I've seen proper ACLs overlaid on
*nix filesystems for several years now (as well) and it works properly.
Sometimes you have to map the bitmask rights to something in the new ACL
filesystem, but having MAC (ie, mandatory access controls) can certainly
help enforce permissions that would otherwise not be done.
Jim
Date: 18 May 2011 18:53:21
Message: <4dd44de1@news.povray.org>
Am Wed, 18 May 2011 15:28:44 -0700 schrieb Darren New:
> On 5/18/2011 14:50, Florian Pesth wrote:
>> Sure that there is no call for saying "Lock this file definitely" and
>> the other lock mechanisms are just kept for POSIX compability?
> Yes. The basic problem is that none of the lock mechanisms actually work
> reliably in all situations.
How about this:
http://www.hackinglinuxexposed.com/articles/20030623.html
Granted, the described problem, that if a program opens before and writes
after the lock (therefore overwriting the file) persists, but I don't
think this is really a locking problem or is it?
>> I think this is also older...
> One problem is that there's at least 3 ways of doing this in Linux, all
> three relatively recent.
> One would give you a signal when a file in the one single directory
> you're watching (maybe just the cwd) changed. Not very handy except for
> the refreshing of a window in a file manager.
> One would do some sort of something or other with messages sent to you
> somehow I forget when anything under a particular file tree changed,
> IIRC. It was poor because, IIRC, you had to block to wait for the
> messages or something.
> The latest one, done right, lets you open a file handle, writing to the
> handle says what you're waiting to see change, reading the (selectable)
> handle lets you know when something there changed and what it was.
Ok, thanks. I just was thinking of tailf which advertises with hard disk
spin down when the file does not change - so it definitely does not poll
and is around since at least 2003. I just searched for it and it seems
that there are two mechanisms: dnotify and the more recently inotify. Now
they might not do what you like to do with them (sorry I didn't
understand what you wanted to do exactly) but for being notified when a
file changes (which is what Andrew was talking about) even dnotify seems
to be fine (and is around since kernel 2.4.). Has your problem something
to do with blocking / non-blocking access of this information?
Date: 18 May 2011 19:33:24
Message: <4dd45744$1@news.povray.org>
That's not the only problem. The other problem is, as he said, taking down
an NFS server from user mode, for example.
Here's the article I was thinking of:
http://0pointer.de/blog/projects/locking
http://0pointer.de/blog/projects/locking2
Contrast with (for example) mainframe locking, where advisory locks usually
don't even use files, and mandatory locks are generally properly enforced
because large amounts of peoples' money depends on them working. (Which is
why all the stuff on Linux where peoples' money *does* depend on locking
working, like an RDBMS, you access all the relevant files via a socket to a
single process that does the locking without going through the file system
to do so.)
And in the 1.x kernels (and maybe later), locking could also lead to
starvation in Linux. It's all getting cleaned up over time, of course, but
us old farts remember this stuff and are leery about anything new. Linux has
it's own "wait for version 3 of anything MS releases".
Here's an exercise for you:
Write a backup program under Linux that correctly backs up files, even ones
you might be editing, without ever losing both the new and old versions of a
file.  I don't think that's possible.  I.e., I want to run a backup program
using normal file system access (rather than reading raw disk data) that
will reliably copy a local directory full of files, even if you're changing
them. There's several ways of doing this on Windows. I don't know any way of
doing it on Linux.
The hard disk spins down when the disk doesn't generate interrupts for some
length of time. That doesn't mean there's no file activity. It just means
all the file activity is using the buffers.
The three interfaces I remember are one that generates a SIGIO when your
registered directory changes (which apparently nobody even talks about any
more, but it was quite a ways back), dnotify (which required a separate file
handle for each directory and communicates using signals, which means you
can't really use threads to deal with it and you can't really be doing
something else at the same time in the same process because a signal handler
can't do I/O so you wind up polling to see if a signal happened), and
inotify which finally got it right.
That doesn't follow. The fact the disk spins down just means the kernel
doesn't have to look at the disk to know the file hasn't changed.
I don't really have a problem. We were just comparing areas in which Windows
seems to do a superior job to Linux (or at least Linux as of not too long ago).
The dnotify is just an exceptionally kludgey interface, requiring one handle
for each directory, "the problem of hard links to files has been ignored"
(my favorite gripe about all UNIX kernel functionality), and requiring you
to open each nested directory explicitly along with reading the entire
directory every time a file changes to see what changed. That's why they
replaced it. :-)
inotify is about as close as you're likely to get, letting you add the
sockets to a select() list so you can (for example) wait for data from the
keyboard while polling for directory changes.
None of them provide what Windows provides, which includes notifying you
about changes since last you asked, even if you weren't running when the
files changed.
   "Coding without comments is like
    driving without turn signals."
Date: 19 May 2011 04:35:20
Message: <4dd4d648$1@news.povray.org>
>> There might be a tiny few things which really are hard-coded to
>> Administrator (the user) and/or Administrators (the group), but I haven't
>> run into that.
> The only one I know of for sure is manipulating file system stuff.
> Partitioning a disk, reading the UNC, marking a file system dirty, etc.
> I don't know what privilege it is - maybe you actually can assign it.
Control Panel > Administrative Tools > Local Security Settings
Left pane: Local Policies > User Rights Assignment
Right pane says:
   Perform volume maintenance tasks: Administrators
Presumably this covers things like mounting/unmounting filesystems,
creating partitions, formatting them, and so forth. (The frustrating
thing about Windows is that you have to *guess*; this isn't written down
anywhere.) If you change the setting here, you can allow other users to
do this.
Also in there is "take ownership of files". In other words, bypass ACLs.
Note that everything in this pane refers to "Administrators" (the user
group, not "Administrator" the user).
If you flip the left page to Local Policies > Security Options, there's
more fun stuff to play with, for example:
   Devices: Allowed to format and eject removable media: Administrators
>>> That is the basic problem with complex permissions. :-)
>> I assume that comment is directed at AD.
> Well, all complex permissions systems.
As far as I can see, the existence of 3 different kinds of groups is an
artefact of the way AD is implemented internally, and how it maintains
backwards compatibility. Which is frustrating, because I don't care how
it works, and I don't need backwards compatibility. I just want
something comprehensible.
>> ...except that it's still implemented the old way.
> No it isn't. Well, maybe with XP, but I don't think that's the case any
> more.
And who's using anything newer than XP? I mean, really.
>> Which means that changing the parent's permissions has the intended
>> effect,
>> but if the parent has 80,000,000 children, it still takes forever to
>> set the
>> permissions, because you literally have to touch every child and
>> update its
>> ACL on disk.
> Maybe if you're doing it thru the explorer?
How else would you change a file's permissions?
>> Oh yeah. TRWTF is 8.3 names.
> What about them?
They still exist. And grown up programs sometimes end up using them.
>> Like I say, it's a shame you can't use this feature to launch stuff
>> programmatically. (At least, not without linking to C.)
> Well, what are you going to launch? You can't launch *anything* without
> linking to some sort of C code.
I mean, if you want to launch a program from the CLI, you just type its
name. But there isn't a command like "open Blue.ogg" which will fire up
the default application and load the named file. If you want to do this,
you have to write C code to query the registry and so forth.
>> how it's implemented. (I have a sinking feeling it's a type database for
>> each file manager, rather than something that arbitrary applications
>> can use.)
> I wouldn't be surprised.
Actually, you know what? There's probably one type database for KDE,
which only KDE applications can access using the KDE application
libraries, and then a second, completely independent type database for
GNOME, which only GNOME applications can access using the GNOME
libraries. And then half a dozen CLI applications which use their own
built-in mechanism.
And I've seen at least one Debian package which claims to contain a
program for analysing file contents to determine their actual type...
In short, it's an incoherent nightmare, just like almost everything else
in Unix.
>>> Even better, of course, would be having it in the actual metadata of the
>>> file, like the Mac's OS tried to do, except they did it before MIME was
>>> around, so it didn't work out as well as it might.
>> Is that the whole resource fork / data fork thing? I never heard how that
>> actually works. (Other than "it doesn't".)
> No, it was the Creator/Type thing, each a four-character code. So a text
> file made by MS Word might have a creator/type or MSWD/TEXT or something.
> Mac files had two forks. One was the data fork, which is just like a
> UNIX file. The other is the resource fork, which had structured blobs,
> each defined by a type and a size, maybe a name, etc. So what you see in
> a Windows executable as a "resource" file was actually the resource fork
> of a Mac application or data file.
I see... I think! o_O
Date: 19 May 2011 11:14:42
Message: <4dd533e2$1@news.povray.org>
OK, thanks!
Take ownership isn't exactly bypass ACLs.
Via the API that explorer uses.
>> What about them?
Oh, well, yes. Backwards compatibility and all.
> name. But there isn't a command like "open Blue.ogg" which will fire up the
start index.html
The command is "start".
Originally it was Apache that needed it, since Apache had to deliver mime
types based on file extensions or content.
> In short, it's an incoherent nightmare, just like almost everything else in
> Unix.
A strength and a weakness.
It was a nice idea. You could install fonts into the global space, or into
the executable for the word processor, or into an individual document that
used that font. You could localize a program after it was completely
finished just by adding resources to the executable. Stuff like that.
Oh, and chunks of code were also resources, so by calling code chunks, you'd
wind up loading dynamically the appropriate code resources, so you got
overlays for free, basically.
Date: 19 May 2011 11:26:20
Message: <4dd5369c@news.povray.org>
Or the CLI for that matter.
Date: 19 May 2011 11:41:26
Message: <4dd53a26$1@news.povray.org>
> OK, thanks!
No. But if you can take ownership of a file, you can give yourself
permission to access it, even if you didn't have that permission to
start with. In other words, it allows you to bypass ACLs.
(Which is just as well, because our project management application
occasionally deletes the ACL list for files, which makes them rather
difficult to work with...)
Well, yeah, if I were a C programmer that might be an option. :-P
>>> What about them?
Backwards compatibility = EVIL!
>> up the default application and load the named file.
> start index.html
And that works for any file type which Windows has a file association for?
> mime types based on file extensions or content.
Well, no, Apache doesn't need to know what to open it with at all. It
just needs to know what MIME type to claim it is. (Which might
potentially vary on a file-by-file basis in a way unrelated to the
extension on the name...)
>> else in Unix.
The Unix philosophy: Every tool should do one job, and do it well.
Unfortunately this leads to 25 different tools doing the same job
equally poorly in incompatible ways. Hence why your typical Linux distro
has (for example) a dozen different packages which implement MD5.
> into the executable for the word processor, or into an individual
> document that used that font. You could localize a program after it was
> completely finished just by adding resources to the executable. Stuff
> like that.
Still not really seeing why you need this implemented at the filesystem
level, but yeah...
> you'd wind up loading dynamically the appropriate code resources, so you
> got overlays for free, basically.
Do overlays matter any more? (Clearly they did once...)
Date: 19 May 2011 12:03:25
Message: <4dd53f4d$1@news.povray.org>
> permission to access it, even if you didn't have that permission to start
Sure, but then you own the file. I.e., you get caught. :-)  And you can't
put it back the way it was, either.
As far as I know, yes.
> Well, no, Apache doesn't need to know what to open it with at all. It just
Well, yes, that too. Which is why the desktops probably have different files.
> (Which might potentially vary
> on a file-by-file basis in a way unrelated to the extension on the name...)
Not in the original apache. :-)
> level, but yeah...
You don't *need* anything at all at the filesystem level. You don't need
directories, or locking, or ACLs. FORTH works fine without any of that.
That said, there's a benefit to having everyone use the same abstractions by
building them into the file system. When they're baked into the OS, everyone
does it the same way (so they're compatible) and nobody needs to have code
to deal with it in every application. The idea that "we don't need that in
the OS because we can implement it again and again in every application that
needs it" (especially when it's very close to every application that needs
it) is a broken philosophy.
As another example, the mainframe I worked on had keyed files. That meant
you could put a number on each line, and the editor could change individual
lines of the files without rewriting the entire file or even reading the
whole thing into memory. If you read the file "sequentially", you got it
back in line-number order. So you had a bunch of editors that physically
stored basically sorted hash tables (b-trees) of text lines, and a bunch of
compilers each of which could read what the editor wrote in the order the
editor expected them to read it. Now, if I want to edit a file bigger than
memory, I need to use sed instead of vi.
Not unless you're using a machine that can't handle demand paging.
Relatively few such machines nowadays don't have enough RAM to run
everything at once, but there are still some around. Stuff like credit card
terminals, for example.
Date: 19 May 2011 14:18:55
Message: <4dd55f0f$1@news.povray.org>
Well, yeah, if you're worried about catching people, turn on file access
auditing. (Something else which, AFAIK, Linux doesn't have.) I'm just
saying people with this priviledge can access stuff they shouldn't be
able to look at.
>> level, but yeah...
> abstractions by building them into the file system. When they're baked
> into the OS, everyone does it the same way (so they're compatible) and
> nobody needs to have code to deal with it in every application. The idea
> that "we don't need that in the OS because we can implement it again and
> again in every application that needs it" (especially when it's very
> close to every application that needs it) is a broken philosophy.
Fair enough. For example, under Linux there are apparently at least 3
different [incompatible] ways to access the sound hardware. Isn't that
wonderful?
> card terminals, for example.
Right. So for desktop computers it's a non-issue?
http://blog.orphi.me.uk/
Date: 19 May 2011 17:13:52
Message: <4dd58810$1@news.povray.org>
On 5/19/2011 11:18, Orchid XP v8 wrote:
> people with this priviledge can access stuff they shouldn't be able to look at.
Sure. But that's different from bypassing the ACLs. :-)
If you really want to prevent that, encrypt the file. (Something else Linux
doesn't have quite the same.)
> wonderful?
Actually, I think there's one way to access the sound hardware: /dev/audio.
There's a variety of servers acting as intermediaries, because for the most
part, while UNIX is a multi-user system, they never quite got the whole
"login" concept into the system.
Pretty much, yes. As I said, anything with demand paging is probably not
going to bother supporting overlays.
