POV-Ray : Newsgroups : povray.off-topic : More Haskell fanning Server Time
25 Jul 2026 11:48:11 EDT (-0400)
  More Haskell fanning (Message 41 to 50 of 53)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: More Haskell fanning
Date: 18 May 2011 17:50:10
Message: <4dd43f12$1@news.povray.org>
Am Wed, 18 May 2011 22:30:32 +0100 schrieb Orchid XP v8:
> All Unix tools assume that file permissions are set using bitmasks. If
> this doesn't hold, most software designed for Unix-like operating
> systems simply stops working.
Well, binutils and the file managers of the most used desktop environments
KDE and Gnome seem to support it. Now what other programs do with it I
don't know...
> This is the trouble with having a wildly popular system - you can't
> change it. The fact that ACLs are turned off by default almost certainly
> has nothing to do with "people not needing it" - more likely it's turned
> off because it breaks so much stuff.
Well, it wouldn't hurt to turn extended attributes on, even if they would
get lost using the wrong programs. I think in Ubuntu really a lot of
stuff is turned off, because people don't need it or they think it is too
dangerous (like this stupid sudo su stuff and only certain users can
change to root, which was taken from BSD...).
> Similar problems with file locking. As I understand it, there's now an
> API to ask "is this file locked?", but if you don't use it, you bypass
> all the locking and can access a file even if it's locked. Yeah, that's
> really helpful.
Sure that there is no call for saying "Lock this file definitely" and the
other lock mechanisms are just kept for POSIX compability?
> I gather that Linux only just got the ability to notify you if a file
> changes. (At least modern Linux desktops manage to *use* this
> information correctly, which is more than Windows Explorer manages...)
I think this is also older... there is this tailf program, which does the
same as tail -f  but does not poll the file, so I guess there was some
mechanism already. But I agree, that a lot of the GUI's could implement
stuff much better.
Date: 18 May 2011 18:22:26
Message: <4dd446a2$1@news.povray.org>
On 5/18/2011 14:14, Orchid XP v8 wrote:
> There might be a tiny few things which really are hard-coded to
> Administrator (the user) and/or Administrators (the group), but I haven't
> run into that.
The only one I know of for sure is manipulating file system stuff.
Partitioning a disk, reading the UNC, marking a file system dirty, etc. I
don't know what privilege it is - maybe you actually can assign it.
>> That is the basic problem with complex permissions. :-)
> I assume that comment is directed at AD.
Well, all complex permissions systems.
> ...except that it's still implemented the old way.
No it isn't.   Well, maybe with XP, but I don't think that's the case any more.
> Which means that changing the parent's permissions has the intended effect,
> but if the parent has 80,000,000 children, it still takes forever to set the
> permissions, because you literally have to touch every child and update its
> ACL on disk.
Maybe if you're doing it thru the explorer?
> Oh yeah. TRWTF is 8.3 names.
What about them?
>> Like the "assoc" command?
> I usually go through the GUI. I don't know how to change it from the CLI.
> But basically, the part where every file that ends in ".txt" opens Notepad
> when you double-click it, while anything ending ".html" opens Internet
> Explorer.
That's the "assoc" command.
> Like I say, it's a shame you can't use this feature to launch stuff
> programmatically. (At least, not without linking to C.)
Well, what are you going to launch? You can't launch *anything* without
linking to some sort of C code.
> how it's implemented. (I have a sinking feeling it's a type database for
> each file manager, rather than something that arbitrary applications can use.)
I wouldn't be surprised.
>> Even better, of course, would be having it in the actual metadata of the
>> file, like the Mac's OS tried to do, except they did it before MIME was
>> around, so it didn't work out as well as it might.
> Is that the whole resource fork / data fork thing? I never heard how that
> actually works. (Other than "it doesn't".)
No, it was the Creator/Type thing, each a four-character code. So a text
file made by MS Word might have a creator/type or MSWD/TEXT or something.
Mac files had two forks. One was the data fork, which is just like a UNIX
file. The other is the resource fork, which had structured blobs, each
defined by a type and a size, maybe a name, etc. So what you see in a
Windows executable as a "resource" file was actually the resource fork of a
Mac application or data file.
   "Coding without comments is like
    driving without turn signals."
Date: 18 May 2011 18:28:46
Message: <4dd4481e@news.povray.org>
Yes. The basic problem is that none of the lock mechanisms actually work
reliably in all situations.
One problem is that there's at least 3 ways of doing this in Linux, all
three relatively recent.
One would give you a signal when a file in the one single directory you're
watching (maybe just the cwd) changed. Not very handy except for the
refreshing of a window in a file manager.
One would do some sort of something or other with messages sent to you
somehow I forget when anything under a particular file tree changed, IIRC.
It was poor because, IIRC, you had to block to wait for the messages or
something.
The latest one, done right, lets you open a file handle, writing to the
handle says what you're waiting to see change, reading the (selectable)
handle lets you know when something there changed and what it was.
Date: 18 May 2011 18:40:11
Message: <4dd44acb@news.povray.org>
The notification API has been around for several years now.
As for ACLs, it depends on the tools.  I've seen proper ACLs overlaid on
*nix filesystems for several years now (as well) and it works properly.
Sometimes you have to map the bitmask rights to something in the new ACL
filesystem, but having MAC (ie, mandatory access controls) can certainly
help enforce permissions that would otherwise not be done.
Jim
Date: 18 May 2011 18:53:21
Message: <4dd44de1@news.povray.org>
Am Wed, 18 May 2011 15:28:44 -0700 schrieb Darren New:
>> the other lock mechanisms are just kept for POSIX compability?
How about this:
http://www.hackinglinuxexposed.com/articles/20030623.html
Granted, the described problem, that if a program opens before and writes
after the lock (therefore overwriting the file) persists, but I don't
think this is really a locking problem or is it?
> you're watching (maybe just the cwd) changed. Not very handy except for
> the refreshing of a window in a file manager.
> IIRC. It was poor because, IIRC, you had to block to wait for the
> messages or something.
Ok, thanks. I just was thinking of tailf which advertises with hard disk
spin down when the file does not change - so it definitely does not poll
and is around since at least 2003. I just searched for it and it seems
that there are two mechanisms: dnotify and the more recently inotify. Now
they might not do what you like to do with them (sorry I didn't
understand what you wanted to do exactly) but for being notified when a
file changes (which is what Andrew was talking about) even dnotify seems
to be fine (and is around since kernel 2.4.). Has your problem something
to do with blocking / non-blocking access of this information?
Date: 18 May 2011 19:33:24
Message: <4dd45744$1@news.povray.org>
That's not the only problem. The other problem is, as he said, taking down
an NFS server from user mode, for example.
Here's the article I was thinking of:
http://0pointer.de/blog/projects/locking
http://0pointer.de/blog/projects/locking2
Contrast with (for example) mainframe locking, where advisory locks usually
don't even use files, and mandatory locks are generally properly enforced
because large amounts of peoples' money depends on them working. (Which is
why all the stuff on Linux where peoples' money *does* depend on locking
working, like an RDBMS, you access all the relevant files via a socket to a
single process that does the locking without going through the file system
to do so.)
And in the 1.x kernels (and maybe later), locking could also lead to
starvation in Linux. It's all getting cleaned up over time, of course, but
us old farts remember this stuff and are leery about anything new. Linux has
it's own "wait for version 3 of anything MS releases".
Here's an exercise for you:
Write a backup program under Linux that correctly backs up files, even ones
you might be editing, without ever losing both the new and old versions of a
file.  I don't think that's possible.  I.e., I want to run a backup program
using normal file system access (rather than reading raw disk data) that
will reliably copy a local directory full of files, even if you're changing
them. There's several ways of doing this on Windows. I don't know any way of
doing it on Linux.
The hard disk spins down when the disk doesn't generate interrupts for some
length of time. That doesn't mean there's no file activity. It just means
all the file activity is using the buffers.
The three interfaces I remember are one that generates a SIGIO when your
registered directory changes (which apparently nobody even talks about any
more, but it was quite a ways back), dnotify (which required a separate file
handle for each directory and communicates using signals, which means you
can't really use threads to deal with it and you can't really be doing
something else at the same time in the same process because a signal handler
can't do I/O so you wind up polling to see if a signal happened), and
inotify which finally got it right.
That doesn't follow. The fact the disk spins down just means the kernel
doesn't have to look at the disk to know the file hasn't changed.
I don't really have a problem. We were just comparing areas in which Windows
seems to do a superior job to Linux (or at least Linux as of not too long ago).
The dnotify is just an exceptionally kludgey interface, requiring one handle
for each directory, "the problem of hard links to files has been ignored"
(my favorite gripe about all UNIX kernel functionality), and requiring you
to open each nested directory explicitly along with reading the entire
directory every time a file changes to see what changed. That's why they
replaced it. :-)
inotify is about as close as you're likely to get, letting you add the
sockets to a select() list so you can (for example) wait for data from the
keyboard while polling for directory changes.
None of them provide what Windows provides, which includes notifying you
about changes since last you asked, even if you weren't running when the
files changed.
Date: 19 May 2011 04:35:20
Message: <4dd4d648$1@news.povray.org>
>> run into that.
> I don't know what privilege it is - maybe you actually can assign it.
Control Panel > Administrative Tools > Local Security Settings
Left pane: Local Policies > User Rights Assignment
Right pane says:
   Perform volume maintenance tasks: Administrators
Presumably this covers things like mounting/unmounting filesystems,
creating partitions, formatting them, and so forth. (The frustrating
thing about Windows is that you have to *guess*; this isn't written down
anywhere.) If you change the setting here, you can allow other users to
do this.
Also in there is "take ownership of files". In other words, bypass ACLs.
Note that everything in this pane refers to "Administrators" (the user
group, not "Administrator" the user).
If you flip the left page to Local Policies > Security Options, there's
more fun stuff to play with, for example:
   Devices: Allowed to format and eject removable media: Administrators
As far as I can see, the existence of 3 different kinds of groups is an
artefact of the way AD is implemented internally, and how it maintains
backwards compatibility. Which is frustrating, because I don't care how
it works, and I don't need backwards compatibility. I just want
something comprehensible.
> more.
And who's using anything newer than XP? I mean, really.
>> effect,
>> set the
>> update its
>> ACL on disk.
How else would you change a file's permissions?
> What about them?
They still exist. And grown up programs sometimes end up using them.
I mean, if you want to launch a program from the CLI, you just type its
name. But there isn't a command like "open Blue.ogg" which will fire up
the default application and load the named file. If you want to do this,
you have to write C code to query the registry and so forth.
>> can use.)
Actually, you know what? There's probably one type database for KDE,
which only KDE applications can access using the KDE application
libraries, and then a second, completely independent type database for
GNOME, which only GNOME applications can access using the GNOME
libraries. And then half a dozen CLI applications which use their own
built-in mechanism.
And I've seen at least one Debian package which claims to contain a
program for analysing file contents to determine their actual type...
In short, it's an incoherent nightmare, just like almost everything else
in Unix.
> UNIX file. The other is the resource fork, which had structured blobs,
> each defined by a type and a size, maybe a name, etc. So what you see in
> a Windows executable as a "resource" file was actually the resource fork
> of a Mac application or data file.
I see... I think! o_O
Date: 19 May 2011 11:14:42
Message: <4dd533e2$1@news.povray.org>
OK, thanks!
Take ownership isn't exactly bypass ACLs.
Via the API that explorer uses.
>> What about them?
Oh, well, yes. Backwards compatibility and all.
> name. But there isn't a command like "open Blue.ogg" which will fire up the
start index.html
The command is "start".
Originally it was Apache that needed it, since Apache had to deliver mime
types based on file extensions or content.
> In short, it's an incoherent nightmare, just like almost everything else in
> Unix.
A strength and a weakness.
It was a nice idea. You could install fonts into the global space, or into
the executable for the word processor, or into an individual document that
used that font. You could localize a program after it was completely
finished just by adding resources to the executable. Stuff like that.
Oh, and chunks of code were also resources, so by calling code chunks, you'd
wind up loading dynamically the appropriate code resources, so you got
overlays for free, basically.
Date: 19 May 2011 11:26:20
Message: <4dd5369c@news.povray.org>
Or the CLI for that matter.
Date: 19 May 2011 11:41:26
Message: <4dd53a26$1@news.povray.org>
> OK, thanks!
No. But if you can take ownership of a file, you can give yourself
permission to access it, even if you didn't have that permission to
start with. In other words, it allows you to bypass ACLs.
(Which is just as well, because our project management application
occasionally deletes the ACL list for files, which makes them rather
difficult to work with...)
Well, yeah, if I were a C programmer that might be an option. :-P
>>> What about them?
Backwards compatibility = EVIL!
>> up the default application and load the named file.
> start index.html
And that works for any file type which Windows has a file association for?
> mime types based on file extensions or content.
Well, no, Apache doesn't need to know what to open it with at all. It
just needs to know what MIME type to claim it is. (Which might
potentially vary on a file-by-file basis in a way unrelated to the
extension on the name...)
>> else in Unix.
The Unix philosophy: Every tool should do one job, and do it well.
Unfortunately this leads to 25 different tools doing the same job
equally poorly in incompatible ways. Hence why your typical Linux distro
has (for example) a dozen different packages which implement MD5.
> into the executable for the word processor, or into an individual
> document that used that font. You could localize a program after it was
> completely finished just by adding resources to the executable. Stuff
> like that.
Still not really seeing why you need this implemented at the filesystem
level, but yeah...
> you'd wind up loading dynamically the appropriate code resources, so you
> got overlays for free, basically.
Do overlays matter any more? (Clearly they did once...)
