POV-Ray : Newsgroups : povray.off-topic : Git tutorial Server Time
22 Nov 2026 21:45:05 EST (-0500)
  Git tutorial (Message 51 to 76 of 76)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: Git tutorial
Date: 23 Apr 2011 13:54:29
Message: <4db31255$1@news.povray.org>
On 4/23/2011 4:21, Orchid XP v8 wrote:
>> "If the conflict is with one of your not-yet-published patches, you may
>> choose to amend that patch rather than creating a resolve patch."
>> And that's exactly what the "git merge" command does.
> I thought "git merge" just combines changes, not resolves conflicts.
It doesn't. Altho there's the "git rerere" command, which resolves merge
conflicts the same way you did last time, if you want. :-)
What do you mean by "resolves conflicts"? That's a manual process in git and
in darcs.
> I wasn't even talking about conflicts. I'm talking about the fact that if
> the central repo changes, even in a way which does *not* conflict with your
> changes, you still have to update your local repo, remerge all the changes,
> and try again.
*If* you're *pushing* to a repository that is unattended, yes. How do you do
it in Darcs?  What happens if people push conflicts into the central
repository? Is that where the "we ignore conflicts without telling you" part
comes in?
>> I'll grant you that Darcs is definitely simpler, but I think it's less
>> capable also, and that's the primary place the simplicity comes from.
> I disagree, but I don't think this argument is going anywhere productive
> right now.
It's less capable in that you only have one branch in a Darcs repository,
and you have no staging area where you can commit in sections. To the extent
that you avoid doing that in git, they seem pretty much identical to me.
> Yeah, it's only really useful for global names (e.g., functions or types).
Yeah, I try to avoid working in languages with global names. I honestly
don't really even know any languages like that any more. Even global names
in C aren't actually global.
> What should *really* happen is that Darcs looks at your edits and *detects*
> that it's a find-and-replace affecting only certain lines, and record that.
Yeah, when your repository system starts understanding that stuff, it has
some advantages. :-)
   "Coding without comments is like
    driving without turn signals."
Date: 23 Apr 2011 14:19:05
Message: <4db31819@news.povray.org>
On 4/23/2011 10:38, Orchid XP v8 wrote:
>> But if they don't conflict, then that's one step. (Well, one step for
>> each of the 200 changes, just like in Darcs.)
> Except that you have to record the order you did it in, even though it
> doesn't actually matter.
You *can* do all 200 at once, if you want. It's just a mess to specify.
>> No, it doesn't really work like that. Like I said, of the Linux repo,
>> there's 240,000 commits, of which 15,000 are actually merges. Git has a
>> lot of ways of editing the history to make it look simpler, which is
>> where all the perceived complexity of git lies.
> I might suggest that if you *need* the ability to edit history to make it
> look simpler, you're doing it wrong.
One is editing history only to back out changes or rearrange commits. Once
it's in a repository anyone else can see, you can't edit it safely any more.
Just like Darcs.
> Except that with Darcs, you don't need to record the fact that a branch ever
> even existed. You just record what was done with the actual file contents.
I would classify that as a problem, not a benefit. I'd like to know which
patches were developed independently, when they were incorporated into the
current code, etc.
>> Well, here's the advantages of git, so far:
>> Git can keep multiple branches in one repository
> I don't know how that works, but if you mean you can have multiple working
> copies, then yes, I guess that could be quite useful.
No. It's exactly like having multiple repositories in one directory.
Branching in git is cloning the repository in Darcs. Merging in git is a
pull in Darcs.
>> Git keeps track of where changes came from and when, so if I pull in a
>> 2-month-old changeset and it breaks something, I can figure out when I
>> pulled it in vs when you wrote the change.
> I'm not sure I see why you would need that information, but OK, Darcs can't
> tell you about that.
Because if you created a patch six months ago and I only applied it last
week, it would be good to know that when things start breaking, it *might*
be because of a change that I only saw a week ago, and I might have to go
back as far as six months worth of changes to understand the problem.
You really don't see the benefit of knowing the difference between "when I
wrote the code" and "when I gave you the code"?  It's the same reason you
put version numbers on executable files you distribute - so you know what
you're running when.
>> git keeps a history that can tell me what changes rely on other changes
>> semantically, not just syntactically.
> How?
Exactly that "linear" order you're complaining about. The DAG of commits
tells you which changes were written with one version in mind but without
other changes in mind.
If I change on April 1 the semantics of function XYZ, then I write code  on
April 3 depending on the new semantics, and you on April 5 write code
depending on the old semantics, you now have a dependency from your code to
the April 1 code that isn't recorded anywhere in Darcs.  It's recorded in
git, tho.
If I have a repository and I merge in a bunch of your changes and apply
them, then I merge in a bunch of changes from Jim, I could very well get
tons of conflicts if Jim didn't apply your changes when he started working.
It seems fragile to me to have a working directory and a repository where I
can incorporate changes into the repository that I cannot get into the
working directory to work on.
>> git doesn't have to spend tens of hours applying 240,000 change sets to
>> the repository in order to give me the latest version of the files.
> Neither does Darcs.
Sure it does. Delete your working directory.
When you clone git, it pulls down the repository, then creates the working
directory from that. When you clone darcs, it sounds like it pulls down both
the repository and the working copy (which would seem problematic if the
working copy had changes to it that weren't recorded, yes?).
>> git has all kinds of sweet tools to manipulate the repository in ways
>> Darcs can't very easily.
> Ways such as what?
Like the bisecting command, just as an example. Or the stash command. Or
commiting things in phases. Or efficiently giving me a copy of the files as
they existed at a specific point in time. (Indeed, since Darcs doesn't
actually record what order you pulled changes in, it seems Darcs can't
really even do that inefficiently.)
>>> Still, until GHC moves from Darcs to Git, I won't have to actually
>>> care, so I guess it doesn't really matter.
>> Not unless you wind up working on a project that uses git.
> That isn't going to happen.
BTW, if you ever want to play, there's a script for git that will import the
changes from and export to a Darcs repository.
http://vmiklos.hu/project/darcs-fast-export/git-darcs
Just from reading the comments, it looks like it stores the Darcs repository
as one branch of the git repository, treating it like a remote repository.
> 1. I will never wind up "working" on anything that's version-controlled. I
> am apparently doomed to spend the rest of my /working/ life rebooting
> people's PCs because Word crashed, rather than doing interesting coding tasks.
<Yoda> And that is why you fail. </Yoda>
> 2. If we're talking about hobby projects, obviously I'm going to pick one
> that uses my preferred tools.
Sure.
> It's not that I don't understand the difference between Git and Darcs. It's
> that I can't begin to comprehend how what Git does can work. It just seems
> such an obviously stupid way to approach the problem.
It seems like a tremendously elegant system to me, like the relational model
for version control. You have a big pile of snapshots, one for each
committed set of changes. All differences are calculated from the snapshots
as needed.
Darcs too is fairly elegant. If they had a more sophisticated way of
handling groupings of changes besides "clone the entire repository and then
make irreversable changes to it" it would be even better.
Date: 23 Apr 2011 14:22:17
Message: <4db318d9$1@news.povray.org>
On 4/23/2011 10:48, Orchid XP v8 wrote:
> My general reaction being "don't do that",
Sounds like a problem for any dvcs. Some development cycles take a while,
you know? :-)
It seems like a problem exactly because darcs doesn't record what version of
the code you were using when you made a particular change. If I change
something "at the same time" as you change something that uses the old
version, there's nothing recording that you wrote that after I made my
change but before you actually knew about my change. *That* is the "linear"
bit you're complaining about in git.
Date: 23 Apr 2011 14:55:44
Message: <4db320b0$1@news.povray.org>
On 23/04/2011 06:46 PM, Darren New wrote:
> If you make the WD match
> the repository, then fetch changes without applying them, then ask for
> diffs, isn't Darcs going to tell you the WD doesn't match the
> repository?
Yes.
> If your change added the line ABC, isn't darcs diff going to
> tell you you removed ABC from the WD?
I'm not precisely sure what you're asking.
> So what do you mean "apply"? What happens if your WD matches the
> repository, then you do a fetch, then you say "record", what does Darcs do?
Records a new patch reverting all the changes that you didn't apply,
presumably. (Of course, what it's *actually* going to do is prompt you
for which ones you want to record, but anyway...)
>> It's the fact that you have to commit the merged version of the file as a
>> new version. Every time you merge in a new change, you have to commit
>> a new version. It just seems clunky and unecessary.
> It's mildly clunky, but it tells you which changes are applied to which
> snapshots. git does this because it records files, not changes, yes.
> It's probably the part of git that people like least.
It's the part I least like, at any rate.
> What happens if I have a number of tags in the repository (v1 and v2 and
> the current v3 under development), and I want to apply a bugfix to the
> v1 version that doesn't apply to the later versions? How do I do that?
You can't really use tags for that; you'd have to have seperate repos
for v1, v2 and v3. Oh, you *can* put all the patches in one repo, but
it's going to get messy very quickly.
> I might want the development branch to apply the changes but not the
> branch that's half way thru QA testing.
The Darcs way to do this is to store copies that are meant to be
different in different places - which seems fairly logical to me.
(Admittedly a little inefficient on disk space...)
>> Oh, I see. You mean if you actually have multiple versions of something
>> being developed concurrently? Yeah, in that case you'd have to move the
>> changeset from one branch to another and hope it works.
> And *that* is exactly what a git merge is. You don't do a merge every
> time you record a change. You only do a merge when you're actually, you
> know, merging two sets of changes into one branch of the repository.
You don't do a merge every time you record a change. You do a merge
every time somebody *else* records a change.
> A git branch is like a darcs repository.
> A git commit is like a darcs record.
> A git merge is like a darcs fetch-and-apply.
Except that you don't explicitly keep a record of a darcs fetch-and-apply.
>> So if two people have the same repo, and they merge in change X and then
>> later merge in change Y, and then the other guy merges in change Y
>> first and
>> later change X, they now apparently have conflicting histories.
> Well, you don't really "merge in" a change. You merge a change from one
> branch to another. You're not merging changes, you're merging branches.
> You're not going to have conflicting histories. Indeed, you *can't* have
> conflicting histories because history is immutable. You might have
> different histories in each repository, but that's like having two Darcs
> repositories cloned from the same source but with a different set of
> changes in each.
So what you're saying is, the histories in two Git repos don't actually
have to match, only the file contents?
>> (And all
>> because Git wants to pretend that everything happens in linear order.)
> No, git very specifically does *not* pretend things happen in a linear
> order. There's all kinds of tools to examine the DAG of dependencies
> between versions.
OK, "linear order within a single branch".
>> As I say, it just annoys me that you have to assign an arbitrary
>> ordering to changes.
> It's not really arbitrary. Darcs just ignores the fact that they aren't.
> If I add function AAA to file BBB and record that change, then add a
> call to function AAA into file CCC, then record that change, would that
> really be independent unordered changes in Darcs? That seems awfully
> fragile.
Darcs doesn't guarantee that a particular combination of patches will
produce a working combination of files. Neither does Git, or RCS, or
CVS. Git /assumes/ that if you apply the changes in the same order that
the author did, this is more likely to produce a working configuration,
but there's no /guarantee/ at all.
Changes have descriptions for a reason.
>>> Say you have 25 changes in your Darcs repository, and you want a version
>>> that applies every change except #23. What do you put in the repository
>>> to represent that?
>> You ask Darcs to revert change #23.
> And how do you do that? "darcs revert" doesn't do that. "darcs unrecord"
> throws the change away entirely. Obliterate deletes the patch entirely
> as well.
"darcs rollback" does it though.
> Patches within any one branch have a linear time ordering. But git
> handles multiple branches in the same repository. So changes between
> branches aren't linearly ordered.
OK, fair enough. But changes within a branch are linearly ordered.
> For example, attached is a picture of the last few dozen commits to the
> Linux kernel.
What we see here is a long tangled history of sequential changes, rather
than a set of mostly independent changes which could safely be combined
in any combination.
http://blog.orphi.me.uk/
Date: 23 Apr 2011 14:56:37
Message: <4db320e5$1@news.povray.org>
> Ways such as what?
Here's another example of something I don't understand how to do in Darcs.
Say you and I are both working on the same program. I find a bug in function
ABC that needs a counter incremented in a loop. At the start of the loop, I
add the counter increment.  You, at the "same time", find the same bug and
fix it by adding the counter increment to the end of the loop.
Now, when we merge repositories, we'll be incrementing the counter twice.
OK, not a problem that a VCS can solve, and you'd get the same ugly in git.
But ... OK, so I see you fixed the bug by adding the counter at the bottom,
and since I already fixed it, I throw away that change from my repository.
You see you already fixed it, so you throw away my change in *your* repository.
How do we reconcile that later? How often do I have to exclude your change
from my repository (while still obtaining your other changes), or how do I
tell you to throw away your change and use mine instead?
In git, I'd manipulate the branch structure, or possibly rebase my changes,
or I'd revert out that one change from my code during the merge and continue
on. But since Darcs apparently doesn't record "they both started from the
same place and made changes in parallel",
I don't see how Darcs can rationally handle the *history* of this change,
other than having one or the other of us record a change that deletes the
line that we added, then distributing that change around. I.e., I don't see
how you can say "add this line, but delete that line it only if you apply
the patch that fixes the problem elsewhere" in any sort of managable way.
Date: 23 Apr 2011 14:58:48
Message: <4db32168$1@news.povray.org>
>> Apparently this doesn't stop people working on the Linux kernel. But it
>> seems really clumsy to me.
> It seems clumsy because you keep thinking git is recording changes. You
> keep thinking of "changes" instead of "versions".
That's because "changes" are the logical thing to think about. Take a
look at a bunch of commit messages, and they all tell you about what
just *changed*.
>> Last time I tried downloading the repos for GHC, it was dominated by
>> network latency. Processor usage was almost non-existent.
> Yep. But you only got the latest version. If you wanted to get every
> tag, you wind up copying all those files again anyway.
Um... why? The tags are downloaded along with all the rest of the history.
Or perhaps you meant if I wanted GHC-6.6 and GHC-HEAD? In which case, I
gather that Darcs caches patches which have recently been downloaded, so
I would only have to download the handful of patches which are actually
different between the two.
Date: 23 Apr 2011 15:14:46
Message: <4db32526$1@news.povray.org>
If I bring my WD up to date, then I fetch changes, then say "record", isn't
that going to record a diff that backs out all your changes?
> presumably.
That sounds really dangerous to me.
The tool that shows history has options to leave out commits that are
nothing but merges without any other changes. :-)
> You can't really use tags for that; you'd have to have seperate repos for
> v1, v2 and v3. Oh, you *can* put all the patches in one repo, but it's going
See, git has no trouble with that. One repo has all of every version of
Linux since 2.6.16 or so.
> The Darcs way to do this is to store copies that are meant to be different
> in different places - which seems fairly logical to me. (Admittedly a little
And a bit fragile. The idea of git is that you have a repo with all the
history in it. You don't have to chop it into multiple repos in order to
actually exclude some of the history from here and there.
> You don't do a merge every time you record a change. You do a merge every
No, you do a merge every time you want to *apply* someone else's changes to
Exactly. Which seems like a downside to me more than an upside. It means you
have to have separate repos for different versions of the same program,
duplicating all that history and making it "fragile" in the operational
sense (as in, too easy to accidentally update a repo with changes that
shouldn't be there, with no easy way to remove those changes since the fact
that you fetched them isn't recorded).
> So what you're saying is, the histories in two Git repos don't actually have
The histories merge if two histories bring you to the same set of contents.
Indeed, since each file is stored with a name based on the hash of its
contents, it's literally impossible to have the same content in two
different files.
Yes. And that's a *good* thing, I'd posit, for the reasons I mentioned in
other threads.
>> fragile.
> produce a working combination of files. Neither does Git, or RCS, or CVS.
Yes. But more than that, Darcs doesn't record what your WD looked like at
the time you created the changes. *That* is the problem.
In Darcs, I'd have much more trouble tracking this bug down. In git, I'd be
able to see that you created your patch before you knew about my change to
function AAA, and maybe that's the source of the problem. In Darcs, I don't
think I have any way of looking at your patch to CCC and saying "what
version of file BBB was he reading while he was writing file CCC?"
A manually-entered description isn't going to say what versions of the files
you *didn't* change you were relying on. That's where the commit history in
git helps out.
>>>> to represent that?
>> as well.
Oh, OK. But again it makes a permanent change in the repository. I guess
you'd have to clone the entire repository, then roll back that one patch.
Yes, and that's a good thing. You can trivially reorder them if they're
independent, but there's no way of knowing whether they're really
independent.  Git assumes they aren't, and if they are, you can reorder them
if you care. Darcs assumes they are unless you tell it so.
>> Linux kernel.
I'm not sure how you get a tangle of sequential changes. What does that even
mean?
> than a set of mostly independent changes which could safely be combined in
> any combination.
Each of those strings of sequential history is a set of independent changes.
I don't think Darcs is any less tangled, or to the extent it is, I'm not
sure it would be accurate to rearrange them.
Might I ask, why do you care? You're talking about a VCS being a record of
the history of changes, and your biggest complaint against git seems to be
that it's actually recording the history of changes. Darcs seems to throw
away useful information about the history of the changes in the hope that it
can automatically deduce enough of the history not to break in the future.
Date: 23 Apr 2011 15:16:50
Message: <4db325a2@news.povray.org>
It also sounds like it would be sketchy if #24 depended on #23 (or even
changed something else #23 changed) and now your rollback patch has a merge
conflict? Or your rollback patch has a merge conflict with someone else's
changes?
Date: 23 Apr 2011 15:21:09
Message: <4db326a5$1@news.povray.org>
> That's because "changes" are the logical thing to think about. Take a look
> at a bunch of commit messages, and they all tell you about what just *changed*.
No. The history is the logical thing to think about. Commits are a logical
thing to think about. Changes are *one* logical thing to think about, but I
think it's easier to generate changes from history than to generate history
from changes, especially when changes aren't in any particular order.
In other words, changes don't represent all the history. You're throwing
away the history of "clone" and "pull" and "push" and "apply". All you're
recording is the changes to the files in the WD, not changes in the
repository itself.
No, I meant if I wanted to compile each tagged version in the repository. I
want to compile GHC-1.0, GHC-1.1, GHC-1.2, GHC-2.0, ....
I have to basically apply every patch in sequence in the entire repository,
in some unknown order.
In git, all those files are already there.  If it's packed, you might wind
up applying a lot of patches, but the patches are optimal in that case,
rather than an accident of history.
Date: 23 Apr 2011 15:23:59
Message: <4db3274f$1@news.povray.org>
>> How?
> without other changes in mind.
In other words, Git is *guessing* which changes depend on each other
semantically from which changes were written at the same point in time
in the same repo.
I could change thing X, and then change thing Y which has nothing to do
with thing X, and still Git will assume a relationship exists there.
Darcs, on the other hand, only concerns itself with *real* dependencies.
It's true Darcs can't guarantee that a particular combination of patches
will produce runnable code. It's also true that Git can't guarantee that
the code in any particular commit object is runnable either.
> on April 3 depending on the new semantics, and you on April 5 write code
> to the April 1 code that isn't recorded anywhere in Darcs. It's recorded
> in git, tho.
For every true dependency, there will be a bazillion spurious ones. So
it's a case of "Which is worse? Missing some real dependencies, or
recording millions of fake ones?" Given that the former is much simpler
conceptually, I'll go with that thanks.
Is this not the case for every known distributed version control system?
> where I can incorporate changes into the repository that I cannot get
> into the working directory to work on.
Why can't you get them into the working directory?
>> Neither does Darcs.
> working directory from that. When you clone darcs, it sounds like it
> pulls down both the repository and the working copy (which would seem
> problematic if the working copy had changes to it that weren't recorded,
> yes?).
Wrong.
It doesn't pull down the working directory at all. Indeed, in the copy I
put on my webserver, I *deleted* the working directory.
It pulls down the *pristine* copy, which contains only recorded changes.
[And is compressed.] If you're silly enough to delete that, then you
just broke your repo. (I'm not sure whether the repair command can fix
this... I believe so, but I've never tried it. It probably won't be fast
though.)
>> Ways such as what?
Without looking those up, I don't know what they do.
> Or commiting things in phases.
You mean like if you go to record something and realise you want to
tweak it first?
> as they existed at a specific point in time. (Indeed, since Darcs
> doesn't actually record what order you pulled changes in, it seems Darcs
> can't really even do that inefficiently.)
You could add a tag before you pull anything in. Then if you have
problems, you can go back to the tag. (Or just query exactly what
happened after the tag.) But yes, I suppose the fact that you need to
remember to do this could be considered a weakness. There's no really
fundamental reason why Darcs couldn't keep a history of what's happened
to your repo though. (And keep it local to that repo, not part of the
shared change history.)
> the changes from and export to a Darcs repository.
Given the radically different ways in which the two systems work, I
imagine the history gets pretty mangled in the conversion - no matter
which system you believe is the "correct" one.
>> coding tasks.
Is this the same Yoda who lived in a universe where you can literally
make inanimate objects physically move just by *believing* that you can?
Date: 23 Apr 2011 15:38:19
Message: <4db32aab$1@news.povray.org>
>>> Darcs do?
>> presumably.
Even though it explicitly prompts you whether you want to record each of
those changes?
But is that better?
If Darcs does have a weakness, it's that it mostly assumes that the main
thing you want to do is perform modifications to the one single "latest
version" of stuff. It could be made more flexible in this direction, yes.
> to your working directory.
Well, yes, that's what I meant.
>> actually have to match, only the file contents?
> contents.
I see. I was assuming that if two repos disagree about history, your
computer would explode or something. So Git is actually smart enough to
handle that?
>>> as well.
I admit, I'm surprised it actually records a patch for it. I would have
expected it to just alter the WD. But whatever. If you rollback the
change and then get bored with it, you can then erase the rollback
patch. [Provided you didn't give it to anyone else.]
I'm guessing this curious glitch is related to the designer's "one true
latest version" mentallity. The whole *point* of storing history as a
set of changes should be to make this kind of task easy.
> of the history of changes, and your biggest complaint against git seems
> to be that it's actually recording the history of changes. Darcs seems
> to throw away useful information about the history of the changes in the
> hope that it can automatically deduce enough of the history not to break
> in the future.
This, fundamentally, seems to be what it all comes down to. You seem to
think that this information is *useful*, whereas to me it's annoying
clutter that I'd rather not have to waste time explicitly micro-managing.
Date: 23 Apr 2011 16:54:00
Message: <4db33c68$1@news.povray.org>
> semantically from which changes were written at the same point in time in
> the same repo.
No. git is merely recording what changes from your repository you had
already applied to your working directory at the time you made the change.
It's not guessing that it's semantically meaningful. It's recording it in
case it is.
> I could change thing X, and then change thing Y which has nothing to do with
> thing X, and still Git will assume a relationship exists there. Darcs, on
But if you change Y that depends on me *not* having changed X, that's a real
dependency that darcs does *not* track.
> It's also true that Git can't guarantee that the code in any
But *I* can guarantee that code in any particular commit object is runnable.
I can test it. I can't do that with darcs, because fetching new stuff might
retroactively change whether something works in a way that isn't recorded in
the repository.
> For every true dependency, there will be a bazillion spurious ones. So it's
> a case of "Which is worse? Missing some real dependencies, or recording
> millions of fake ones?" Given that the former is much simpler conceptually,
I think your "fake dependency" aversion is kind of silly, since nobody
really records fake dependencies.
Yes. But git lets me resolve the issue, while darcs makes it a very manual
process for me to figure out *why* Jim's changes conflict.  If I go to merge
Jim's changes, darcs gives me no help. Git tells me what version Jim's
changes are *supposed* to merge cleanly into.
Because that messes up my working directory in a way I can't recover from.
> [And is compressed.] If you're silly enough to delete that, then you just
> broke your repo. (I'm not sure whether the repair command can fix this... I
> believe so, but I've never tried it. It probably won't be fast though.)
OK, so darcs doesn't record only the changes, but the changes and then the
result of applying all those changes, *and* you have a working directory.
That makes a bit more sense I guess.
Ways of saving your changes temporarily in a different part of the repository.
> You mean like if you go to record something and realise you want to tweak it
> first?
Yes. Resolving merges a bit at a time, compiling and testing in between,
rather than having the "record" and "commit" be the same action.
>There's no really fundamental reason why Darcs
> couldn't keep a history of what's happened to your repo though.
I agree. It just doesn't.
 > (And keep it
> local to that repo, not part of the shared change history.)
No, that doesn't work, because you still want that history when you clone
the repository or it's useless in the bigger picture.  Especially when
cloning the repository is how you make a temporary branch.
> Given the radically different ways in which the two systems work, I imagine
> the history gets pretty mangled in the conversion - no matter which system
The git import function works by running a script to "get the next version"
and then checking it in, over and over, until it's all checked in. If you
can write a script that says "make a file that holds the commit message, and
a command line to fetch the next version", then you have enough for git.
Of course, darcs doesn't really have a "next version" concept, so that could
be problematic.
> Is this the same Yoda who lived in a universe where you can literally make
You have a point.
Date: 23 Apr 2011 17:00:34
Message: <4db33df2$1@news.povray.org>
>>>> Darcs do?
>>> presumably.
> those changes?
Yes.
> But is that better?
I'd say so. YMMV.
Yeah, that's it. And that everyone is pretty much working on the same
version of stuff. Works for small scale, not so much for large scale, I think.
Well, that's a different thing. I can record a dozen changes which you apply
only once.  In the linux kernel it seems to be about 15:1 ratio.
>> contents.
> handle that?
There's only one history. Nothing you put into a repo ever changes or
disappears. So both histories are in the repo, and at the point where I drew
yours in, it got linked into my history as a loop earlier in the development.
> latest version" mentallity. The whole *point* of storing history as a set of
Yeah, I think that's the basic problem I have with Darcs. All the things
that make git complicated compared to darcs have to do with having one
repository having lots of different versions being developed at different
speeds.
> think that this information is *useful*, whereas to me it's annoying clutter
You really don't have to micromanage it. The git commands are all pretty
much isomorphic to the darcs commands. It's extremely useful when you merge
in a change and something breaks, so you can easily go "Oh, I see why,
because his change says "outputs index counter" and I changed the output
function *since* he started work on that."
Without that clue, you have to actually look at the "outputs index counter"
change and read it to see what version of the output routines he's
expecting, which can be especially confusing if he *wrote* the patch after
you changed the output function but before he merged and applied your patch.
I'm not all that sure how you can't see how that's helpful. :-)
Date: 24 Apr 2011 04:35:36
Message: <4db3e0d8$1@news.povray.org>
>> clutter
> merge in a change and something breaks, so you can easily go "Oh, I see
> why, because his change says "outputs index counter" and I changed the
> output function *since* he started work on that."
> counter" change and read it to see what version of the output routines
> he's expecting, which can be especially confusing if he *wrote* the
> patch after you changed the output function but before he merged and
> applied your patch.
There really has to be a better way of solving this problem than
serialising the entire change history forever...
Date: 24 Apr 2011 13:48:37
Message: <4db46275$1@news.povray.org>
On 4/24/2011 1:35, Orchid XP v8 wrote:
> There really has to be a better way of solving this problem than serialising
Well, as I see it, both git and darcs stores a DAG. Git stores a DAG of
collections-of-files, and Darcs stores a DAG of collections-of-changes. Git
stores enough information that you can reproduce the changes from the files
well after the fact. Darcs does not store enough information that you can
reproduce files from changes reliably (in that I can't tell what files you
were looking at when you made a particular change, for example).
So, basically, there are changes that have known dependencies, and changes
that have unknown dependencies. Git records all history explicitly,
including dependencies that may or may not actually exist. Darcs assumes if
you don't tell it about the dependencies that they specifically don't exist.
Darcs also fails to record anti-dependencies. Git lets you put multiple
histories in the same repository, while Darcs can't really represent
multiple histories so you wind up with lots of individual repositories to
manage with apparently no good tools to compare them (since the DAG between
different repositories is intentionally discarded when you clone the
repository, as I understand it).
I think if you're working on a small project, either by yourself or with a
small team you're in communication with on a frequent basis, either might
work. Either seems pretty easy to understand.
The only way of improving on serializing the change history is to specify in
Darcs exactly what you rely upon and what you don't, which would seem to
require actually doing a full analysis of the program every time you check
in a change. If function XXX relies on the behavior of function YYY, and you
change function XXX and I change YYY, there may or may not be a dependency
between those two changes, depending on whether I "break" your XXX with my
change to YYY. But then you have to define "break".  I can see, however, how
a language like Haskell or Eiffel or something with 100% test coverage
available to every repository holding the project could make that mostly
feasible.
Date: 28 Apr 2011 04:32:08
Message: <4db92608$1@news.povray.org>
On 20/04/2011 10:44 AM, Invisible wrote:
> I had assumed that all DVCSs were the same, but I now see that at least
> Git and Darcs use fundamentally different models.
This is somewhat related:
http://koweycode.blogspot.com/2011/04/why-darcs-users-care-about-consistency.html
Date: 28 Apr 2011 12:27:53
Message: <4db99589$1@news.povray.org>
Thanks. That's interesting.
The most well-known remaining cause of blowups in theory 2 is the problem of
"conflict fights" where one side of the conflict resolves the conflict and
gets on with their life without propagating the resolution back to the other
side.
This is basically the source of the mess in git, also. In the whole blah
going on here: http://bramcohen.livejournal.com/74462.html I'm not sure I
can understand how presenting that work as a set of patches makes sense.
You'd wind up with a repository that changes A into B twice and B into A
once without any particular ordering between them, so I'm lost as to how
Darcs would handle that.
Date: 29 Apr 2011 05:55:10
Message: <4dba8afe$1@news.povray.org>
Interesting, disturbing, whatever you want to call it. ;-)
All describing problems I've never come across. Then again, when your
development team consists of one person...
> problem of "conflict fights" where one side of the conflict resolves the
> conflict and gets on with their life without propagating the resolution
> back to the other side.
Given the entire purpose of *distributed* revision control... yeah, that
would be a problem. (Exponential-time merge worries me more though.)
> I can understand how presenting that work as a set of patches makes
> sense. You'd wind up with a repository that changes A into B twice and B
> into A once without any particular ordering between them, so I'm lost as
> to how Darcs would handle that.
You understand that Darcs *does* have an ordering between *related*
patches, right? It's only *unrelated* patches that have no order
relationship. I can flip the same line of code back and forth 20 times,
and record that as 20 patches, and they will have a strictly linear
ordering.
Date: 29 Apr 2011 12:16:34
Message: <4dbae462$1@news.povray.org>
On 4/29/2011 2:55, Orchid XP v8 wrote:
> You understand that Darcs *does* have an ordering between *related* patches,
Yes, I figured that.
Indeed, that's my main complaint with the whole concept: the idea that
simply because two patches are in different files doesn't mean they're
unrelated. If I implement foo() in file abc.c and call foo() in file def.c,
those are not two unrelated patches.
> right? It's only *unrelated* patches that have no order relationship. I can
> flip the same line of code back and forth 20 times, and record that as 20
> patches, and they will have a strictly linear ordering.
So, you clone a repository and I clone a repository.
You create a file called XX with the line Hello in it.
I create a file called XX with the line Goodbye in it.
We both record our changes.
I then change my XX file to say "Hello\nGoodbye".
You change your XX to say "Goodbye\nHello".
I then change my XX file to say "Hello". You change yours to say "Goodbye".
We attempt to merge our repositories.
Can you try this on a blank repository on your machine and tell me what happens?
Resolving this in git is very straightforward. You can just pick one that's
right and say "Henceforth, that's the answer". Or you can just grab all the
changes and basically never merge them back together again (say, if you have
two distros in the same repository).
Also, what happens if I rename a file from XXX to YYY and you rename it from
XXX to ZZZ?  Do I wind up with both YYY and ZZZ in my repository?
Date: 29 Apr 2011 12:18:55
Message: <4dbae4ef$1@news.povray.org>
BTW, the problem here is that those patches are *not* related. Each branch
down the side is a separate Darcs repository. So the first guy takes A,
makes it a B, then patches it back to A. In parallel, in *your* repository,
you independently take A and make it into B. Now everyone copy all the
patches from everyone else. Do I wind up with A or B? I'm not sure there's
an answer there that makes sense from a technical perspective.
Date: 29 Apr 2011 12:55:10
Message: <4dbaed6e$1@news.povray.org>
> def.c, those are not two unrelated patches.
And my complaint about Git is that just because change X happened after
change Y does not necessarily mean that change X depends on change Y in
any way, yet Git assumes that it does.
Fundamentally, I expect working out which changes truly depend on each
other is probably undecidable. [And that's before we even get into the
fact that the only way for this to work properly is to implement a
seperate detection engine for every programming language you ever want
to version control.]
Apparently both models do work in practise, since there are people using
them. Personally, I much prefer the way Darcs does it.
> happens?
I imagine Darcs will say "error, these changes conflict, please fix it".
And other words, "I can't figure out what to do; you decide".
> that's right and say "Henceforth, that's the answer". Or you can just
> grab all the changes and basically never merge them back together again
> (say, if you have two distros in the same repository).
That sounds in principle like the same thing that Darcs does.
> from XXX to ZZZ? Do I wind up with both YYY and ZZZ in my repository?
Same again, I would imagine.
Date: 29 Apr 2011 12:56:17
Message: <4dbaedb1$1@news.povray.org>
> branch down the side is a separate Darcs repository. So the first guy
> takes A, makes it a B, then patches it back to A. In parallel, in *your*
> repository, you independently take A and make it into B. Now everyone
> copy all the patches from everyone else. Do I wind up with A or B? I'm
> not sure there's an answer there that makes sense from a technical
> perspective.
I haven't tried it personally, but as I understand it, Darcs says "there
is a conflict here; please decide what you want me to do".
Date: 29 Apr 2011 13:18:06
Message: <4dbaf2ce$1@news.povray.org>
Yep. It's a question of whether you're being conservative or not, is all.
> Fundamentally, I expect working out which changes truly depend on each other
I don't think it's undecidable. I think it merely depends on what your specs
are.
Indeed, if I take a file that prints nothing and make it print "Hello", and
you take a file that prints nothing and make it print "Goodbye", then it's
obviously impossible to figure out in the merge which should come first and
which should come second, or if either at all is right.
I can see the appeal of both. I wasn't really pushing for git as being
better. My original post was "hey, I found a good way to understand it."
> I imagine Darcs will say "error, these changes conflict, please fix it". And
But then how do you resolve it, such that I get the same resolution?
I don't think Darcs lets me merge your patches back in and easily work on
one set or the other, right? Each repository really only holds one
authoritative version of the patches, right?  I.e., there's exactly one
"pristine" that you compare against?
Yeah, OK.
Date: 29 Apr 2011 15:25:27
Message: <4dbb10a7@news.povray.org>
Or, to be fair, more appropriately, git doesn't imply that just because
change A followed change B that change B depends on change A. Reading
dependencies into the order of commits is reading in something that isn't there.
Git is storing a series of snapshots. Each commit contains a complete record
of everything that was in your working directory when you committed it
(sorta, using Darcs terms). Each commit points to the version that was in
your working directory that you changed in order to get the new version. As
I said, git doesn't store changes. It says "he started with X, then he had
with Y," with no real implication that Y somehow depends on X.
Date: 27 May 2011 04:31:58
Message: <4ddf617e$1@news.povray.org>
On Wed, 20 Apr 2011 16:49:57 +0100 in povray.off-topic, Invisible wrote:
> The problem Git seems to have is that it uses heads to keep track of
> things. Delete the head and the corresponding commit drops off the face
> of the Earth.
Actually, there are usually many ways to retrieve a lost head.
.git/logs/ directory is the most prominent tool or that.
The terminal's history buffer is another. Usually the very
commands that drop the current head will print its name.
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 6 Jun 2011 10:58:25
Message: <4deceb11$1@news.povray.org>
>> of the Earth.
Actually, there are "relog" or "rehead" files or something like that, which
are basically text files listing each head and the corresponding SHA1 as a
log file each time you move a head.
Also, doing the equivalent of a chkdsk will give you back any SHA1's that
don't have anything else pointing to them.
Both intentionally stick around for quite some time (several weeks by default).
