POV-Ray : Newsgroups : povray.off-topic : Git tutorial Server Time
2 Jul 2026 09:28:11 EDT (-0400)
  Git tutorial (Message 37 to 46 of 76)
Subject: Re: Git tutorial
Date: 23 Apr 2011 06:25:18
Message: <4db2a90e$1@news.povray.org>
On 22/04/2011 12:39 AM, Darren New wrote:
> On 4/21/2011 13:07, Orchid XP v8 wrote:
>>> Well, git *does* store stuff in files, so technically you could copy the
>>> files. But by "copy files" I mean "use git to copy the new files." As
>>> in, "you don't have to run any diffs or patches or anything".
>> Oh, I see.
> Actually, you can store a repository on an http server and give everyone
> read access to the repository, and everyone can update from there. So,
> yeah, it basically *can* be done by copying the right files from one
> place to another.
I've done this with Darcs. Unfortunately, to update the repo, you
basically delete it off the server and copy the current version over
there - which is tedious. (By default, the server would also have a
working copy - which is pointless. Fortunately, if you delete that bit,
it still works.)
http://blog.orphi.me.uk/
Date: 23 Apr 2011 06:47:06
Message: <4db2ae2a$1@news.povray.org>
>> I much prefer the way Darcs does it (i.e., prompt you for which
>> changes you want to include in this particular commit).
> I prefer the GUI, actually. Much easier to pick out various commits to
> commit.
I will admit, a GUI is probably a superior interface for doing this.
(And I'm not aware of anyone having built a GUI for Darcs.)
>>>> not sure what you mean by "Darcs needs you to do that all in one step".
>>> I mean that gathering up the changes and committing them sounds like a
>>> single step in Darcs.
>> A single interactive step, yes.
> Which means you can't (for example) stop in the middle when you realize
> you forgot to make one of the 30 changes you want to commit to fix
> something in particular. You have to start over.
True enough. It would be nice if you could make Darcs remember which
changes you selected last time around. (Then again, some of those
changes might no longer exist next time you run Darcs...)
>> Except that usually 200 people will be editing 200 different parts of the
>> repository.
> And if that's the case in git, then you have no trouble merging things
> when and as you want them.
You still have to manually make Git combine all 200 changes into one
version, and then commit that. It just seems like an undless cycle of
merges trying to keep everything straight, generating an ever more
tangled history behind it.
>> to do lots of extra work and then record
>> it as a new item of data, which you don't actually need, but that's
>> just hot
>> Git works.
> What extra work? If you just want to commit everything you've changed,
> you say "git commit -all" or some such, and away you go. If you want to
> take my changes and update your repository, you say "git pull darren",
> and when you're ready to incorporate my changes into your development,
> you say "git merge darren". It's two steps because you don't want to tie
> "get Darren's changes" to "make sure Darren's changes are all compatible
> with mine."
It's more the conceptual annoyance of having to record every merge
operation as a new version of the entire repo, even if you only changed
one line. That seems really clumsy to me.
> Honestly, I'm not sure I see any advantage of Darcs over git.
Likewise, but inverted.
Still, until GHC moves from Darcs to Git, I won't have to actually care,
so I guess it doesn't really matter.
Date: 23 Apr 2011 07:06:30
Message: <4db2b2b6$1@news.povray.org>
On 22/04/2011 12:31 AM, Darren New wrote:
> OK, so say I have a Darcs repository and I'm working on my program. I
> have some changes in my working directory, when I come across a bug. I
> ask you about it, and you say "that's already fixed." Can I pull just
> that one change into my repository?
Obviously yes.
> What if I'm working on version 1 of the program, and you made a fix in
> version 2? How do I handle that?
Depends which way I set it up. If each version of the program is just a
tag, then see the above. If each version is a seperate repo, you just
need to pull from the v2 repo. (How much conflict you'll have to deal
with is another matter - but that's the fun of backporting, eh?)
> Indeed, how do I get out a version of the working directory excluding
> just one particular patch back in time, in order to see (for example) if
> that patch was the cause of a bug?
You say to Darcs "please revert patch #34823". If that doesn't fix your
problem, you say to Darcs "please revert all unrecorded changes" (since
the inverse change you just asked for hasn't been recorded yet). If that
*does* fix your problem... well, you can just hit record, or you can
investigate further to see if you can keep the good parts of the
original patch without causeing problems, or whatever.
Date: 23 Apr 2011 07:08:24
Message: <4db2b328$1@news.povray.org>
On 22/04/2011 12:46 AM, Darren New wrote:
> On 4/21/2011 13:28, Orchid XP v8 wrote:
>> 1. Having a copy of someone else's changes is useless unless I can
>> incorporate them into the latest version of the files.
> Also, does Darcs record when you applied various patches?
Not to my knowledge, no. It records who created a patch and when, but
not when it was applied to any particular repo.
> So if, for example, I'm working, and everything's good, and I take some
> patches from you, then work some more, then take some patches from Sam,
> then work some more, then run my test and it fails, can I figure out
> that it was Sam's patches, even if he created those patches before I
> even cloned the repository in the first place?
In that case you're presumably going to revert patches until the problem
goes away. Maybe one patch broke something, maybe its an interaction of
several patches. You turn patches on and off until you figure out what's up.
Date: 23 Apr 2011 07:13:57
Message: <4db2b475$1@news.povray.org>
>> Every time you try to combine two states of the repo, it creates a new
>> commit object representing the merge.
> Just to be clear, adding your changes to my repository is just adding a
> commit. A commit is like a Darcs patch. One update of the repository is
> one commit.
> There's a "merge commit" which is nothing but a commit saying "this is
> what it looks like after you merge two commits."
Seems more like because it's so difficult to merge two files, after
you've done it you have to save it to prevent you having to redo all
that complex hard work. And in the process, all change application is
forced to become strictly linear.
Apparently this doesn't stop people working on the Linux kernel. But it
> I'm not sure I'd want to check out something from Darcs that has a
> quarter million patches in it and wait for Darcs to apply them all one
> by one. How well does it handle that?
You're aware that Darcs keeps a cached copy of the latest state of all
the files, so it doesn't have to recompute them, right?
Last time I tried downloading the repos for GHC, it was dominated by
network latency. Processor usage was almost non-existent. It just takes
a long time to shift gigabytes of data over a slow ADSL link. Just as it
would if I had downloaded a Zip file of the source code with no history
data at all.
Date: 23 Apr 2011 07:15:09
Message: <4db2b4bd$1@news.povray.org>
> Which latest versions? Oh, right, Darcs only has one latest version, and
> if you don't want to apply changes from someone, you can't fetch them
> either.
Hint: Look up "darcs fetch". It fetches changes without applying them.
> That's the merge step. Three people send you three copies. When you're
> ready, you say "apply those changes to my copy." I'm not sure where your
> confusion is.
It's the fact that you have to commit the merged version of the file as
a new version. Every time you merge in a new change, you have to commit
a new version. It just seems clunky and unecessary.
> In Darcs, that's one step it seems - I can't get changes
> from you *without* applying them to the work I'm doing.
Not true. You can get changes without applying them. It's just that
usually, you want to fetch changes to, you know, *use* them.
> In git, it's two
> steps, because maybe you're in the middle of something and you don't
> want to merge in my changes until the stuff you're working on actually
> works and passes tests and stuff.
Then why fetch the changes at all? Why not wait until you're actually
ready to apply them?
> So if you have something like Linux, where there's a new release every
> few months, you need a complete repository for every release.
Um... why?
> And if I
> fix a bug in an old release and you want to incorporate that bug fix
> into newer releases, what do you do?
Oh, I see. You mean if you actually have multiple versions of something
being developed concurrently? Yeah, in that case you'd have to move the
changeset from one branch to another and hope it works.
>> You then have to
>> *create a new commit object* representing this new combined state.
> Yes.
So if two people have the same repo, and they merge in change X and then
later merge in change Y, and then the other guy merges in change Y first
and later change X, they now apparently have conflicting histories. (And
all because Git wants to pretend that everything happens in linear
order.) How do you get out of that?
>> I guess the thing that really flips my lid is that not only does Git
>> require
>> you to construct a useless merge commit every time you want to do
>> something
>> as trivial as put two changes together,
> Commits are trivially inexpensive in git. They represent the state of
> some particular repository at some particular time. It's how you store
> stuff.
As I say, it just annoys me that you have to assign an arbitrary
ordering to changes.
> Say you have 25 changes in your Darcs repository, and you want a version
> that applies every change except #23. What do you put in the repository
> to represent that?
You ask Darcs to revert change #23.
>> It also irritates me that Git insists that even unrelated changes must
>> have a linear time ordering.
> No they don't. Indeed, if unrelated changes had to have a linear time
> ordering, you wouldn't get merge conflicts at all, would you?
This doesn't make any sense to me at all...
Date: 23 Apr 2011 07:21:55
Message: <4db2b653$1@news.povray.org>
On 21/04/2011 06:54 PM, Darren New wrote:
> OK. All the confusions you think you're seeing in git are due to Darcs
> just not being able to do what git does.
> When Darcs gets a merge conflict, it just doesn't apply *either* patch.
> "Darcs escapes this problem by ignoring those parts of the patches that
> conflict."
Interesting. And here I was thinking it marks the conflicting parts of
the files for you so you can go fix it...
> "If the conflict is with one of your not-yet-published patches, you may
> choose to amend that patch rather than creating a resolve patch."
> And that's exactly what the "git merge" command does.
I thought "git merge" just combines changes, not resolves conflicts.
> "This is how a project with many contributors, but every contribution is
> reviewed and manually applied by the project leader, can be run." This
> is the bit about sending email you were talking about. git can work that
> way, and the terrible "merge" problems you're talking about are handled
> the same way: the guy getting the patches fixes the merge.
> What Darcs apparently can't do is support any way of doing distributed
> development with an authoritative repository *without* someone dedicated
> to fixing the merge conflicts. That's where the whole rant you're
> talking about came from.
I wasn't even talking about conflicts. I'm talking about the fact that
if the central repo changes, even in a way which does *not* conflict
with your changes, you still have to update your local repo, remerge all
the changes, and try again.
> I'll grant you that Darcs is definitely simpler, but I think it's less
> capable also, and that's the primary place the simplicity comes from.
I disagree, but I don't think this argument is going anywhere productive
right now.
> The Darcs replace command is interesting, but I'm not sure how well that
> would work in practice, especially in languages with complex scoping.
Yeah, it's only really useful for global names (e.g., functions or
types). If you've got a dozen functions with a variable named "x1" and
you want to make it "x_in" in one of them... yeah, good luck. Really,
you're going to have to sort it out by hand.
What should *really* happen is that Darcs looks at your edits and
*detects* that it's a find-and-replace affecting only certain lines, and
record that. But anyway...
Date: 23 Apr 2011 12:58:22
Message: <4db3052e$1@news.povray.org>
On 4/23/2011 3:47, Orchid XP v8 wrote:
> I will admit, a GUI is probably a superior interface for doing this. (And
There's a couple of standard git guis that come with git. One for really
sophisticated exploration of the history and one for manipulation of the
repository and working directory.
> True enough. It would be nice if you could make Darcs remember which changes
> you selected last time around. (Then again, some of those changes might no
Git also does some various funky things. Like if you're doing merges and you
get a conflict, it leaves extra information in the "index" part to keep
track of which merge conflicts you've fixed and which you haven't. The
"bisect" routine (which Darcs has as well) uses that area to track stuff. Etc.
Of course, in git they'll still exist, because it gets copied into the
repository when you say "remember this change", not when you say "commit".
But if they don't conflict, then that's one step.  (Well, one step for each
of the 200 changes, just like in Darcs.)
> It just seems like an undless cycle of merges
> trying to keep everything straight, generating an ever more tangled history
> behind it.
No, it doesn't really work like that. Like I said, of the Linux repo,
there's 240,000 commits, of which 15,000 are actually merges. Git has a lot
of ways of editing the history to make it look simpler, which is where all
the perceived complexity of git lies.
> It's more the conceptual annoyance of having to record every merge operation
> as a new version of the entire repo, even if you only changed one line. That
Just so you know: There's merges, and there's commits. A commit is the same
as what Darcs calls a changeset. A merge is when you have two different
branches that you're putting into one repository.
In git, a commit is a trivial thing. You say "git commit" just like in Darcs
you say "darcs record."  I do dozens of git commits a day just farting
around with my own programs.
In git, a merge is when you take two branches and apply the changes from one
branch to the other branch. In Darcs, this would involve two separate
repositories, one being updated from the other. It's about the same
complexity as that.
Well, here's the advantages of git, so far:
Git can keep multiple branches in one repository, which makes it easier to
move changes around, look at history, try out new combinations of changes, etc.
Git keeps track of where changes came from and when, so if I pull in a
2-month-old changeset and it breaks something, I can figure out when I
pulled it in vs when you wrote the change. (I didn't see that in Darcs, but
I didn't look very close.)
git keeps a history that can tell me what changes rely on other changes
semantically, not just syntactically. (I.e., the thing Darcs tries to do
with the retoken command, except that really only works for one specific
type of semantic change and still only works syntactically.)
git doesn't have to spend tens of hours applying 240,000 change sets to the
repository in order to give me the latest version of the files.
git has all kinds of sweet tools to manipulate the repository in ways Darcs
can't very easily. (Basically, you'd have to tell Darcs to make a bunch of
snapshots, then fiddle with the snapshots the same way git would fiddle with
the repository itself.)
> Still, until GHC moves from Darcs to Git, I won't have to actually care, so
Not unless you wind up working on a project that uses git.
I think 90% of your confusion with git is you're trying to think about it
like you think about Darcs, in terms of a series of changes, which is why I
posted the original link in the first place.
   "Coding without comments is like
    driving without turn signals."
Date: 23 Apr 2011 13:00:06
Message: <4db30596@news.povray.org>
>>> Oh, I see.
>> place to another.
> I've done this with Darcs. Unfortunately, to update the repo, you basically
> delete it off the server and copy the current version over there - which is
> tedious. (By default, the server would also have a working copy - which is
> pointless. Fortunately, if you delete that bit, it still works.)
Yeah. You can't update git via http, but you can update a repository stored
on the server and then there's a command called "update-http-hook" or
something that refreshes the index that clients use to quickly find files on
the http server. (I.e., the clients need to be able to get a directory
listing of all the heads of branches, which is something an http server
never really standardized.)
Date: 23 Apr 2011 13:38:49
Message: <4db30ea9$1@news.povray.org>
> each of the 200 changes, just like in Darcs.)
Except that you have to record the order you did it in, even though it
doesn't actually matter.
>> history behind it.
> lot of ways of editing the history to make it look simpler, which is
> where all the perceived complexity of git lies.
I might suggest that if you *need* the ability to edit history to make
it look simpler, you're doing it wrong.
> same as what Darcs calls a changeset. A merge is when you have two
> different branches that you're putting into one repository.
> Darcs you say "darcs record." I do dozens of git commits a day just
> farting around with my own programs.
> one branch to the other branch. In Darcs, this would involve two
> separate repositories, one being updated from the other. It's about the
> same complexity as that.
Except that with Darcs, you don't need to record the fact that a branch
ever even existed. You just record what was done with the actual file
contents.
I don't know how that works, but if you mean you can have multiple
working copies, then yes, I guess that could be quite useful.
I'm not sure I see why you would need that information, but OK, Darcs
can't tell you about that.
How?
> the repository in order to give me the latest version of the files.
Neither does Darcs.
> Darcs can't very easily.
Ways such as what?
>> care, so I guess it doesn't really matter.
That isn't going to happen.
1. I will never wind up "working" on anything that's version-controlled.
I am apparently doomed to spend the rest of my /working/ life rebooting
people's PCs because Word crashed, rather than doing interesting coding
tasks.
2. If we're talking about hobby projects, obviously I'm going to pick
one that uses my preferred tools.
> it like you think about Darcs, in terms of a series of changes, which is
> why I posted the original link in the first place.
It's not that I don't understand the difference between Git and Darcs.
It's that I can't begin to comprehend how what Git does can work. It
just seems such an obviously stupid way to approach the problem.
