POV-Ray : Newsgroups : povray.off-topic : A kind of revolution is happening in the United States Server Time
18 Jul 2026 09:25:11 EDT (-0400)
  A kind of revolution is happening in the United States (Message 271 to 280 of 452)
Subject: Re: A kind of revolution is happening in the United States
Date: 20 Apr 2011 19:19:13
Message: <4daf69f1$1@news.povray.org>
On 4/20/2011 4:01 PM, Patrick Elliott wrote:
> There is a reason why a lot of biologists use the term IDiocy to
> describe this. Sadly, a few too many comp-sci people fail to grasp why
> its similarly intractable in terms of computer code (where, the
> equivalent in that would be taking a running application, and inserting
> new code into it, without breaking links, jump points, functionality, or
> mangling the data being processed, mid-change).
To clarify, other requirements - The application be monolithic, not
include scripting/JIT compilation, and have massive crosslinking, such
that a minor change "might" be OK in the running code, but if you do
need to reboot (split off a clone, or produce other sorts of offspring),
some form of reboot "will" happen, and your change has just broken 500
other steps in the process, since its a critical part of some library,
which just happened to not cause problems in the "running"
implementation, but causes a whole shitload of errors, during start up
(like a zip library, which works fine for a set sized data sample, but
breaks when you try to unzip entire branches of the boot code, which are
larger, or smaller, than being handled in the "running" instance).
In any case, even if you could produce such a thing, and have it self
modify safely, it only helps the front load argument, not the "it didn't
evolve" one. You still have to show where the front load code is, which
means doing research, and... these people don't *do* research.
Date: 20 Apr 2011 22:37:13
Message: <4daf9859@news.povray.org>
On 4/20/2011 15:26, andrel wrote:
> That there are proteins (etc.) that didn't evolve by natural selection.
OK. Let's grant that that is the actual hypothesis.
> even weaker that their presence is easier explained by design than as a
> result of natural selection. (hijacking Occam's razor).
Designed by whom? An naturally-evolved creature? Who then selected that
protein unnaturally?  As soon as you say "naturally-evolved aliens might be
the intelligence" then you've broken your hypothesis.
Seedless grapes and bananas were evolved by natural selection. It happened
to be humans doing the selecting, but it was natural selection and evolution.
So again, even if you find a protein that you think could not have evolved
naturally, then you have to prove that nobody who is naturally evolved
created it.
   "Coding without comments is like
    driving without turn signals."
Date: 21 Apr 2011 01:06:40
Message: <4dafbb60$1@news.povray.org>
On Thu, 21 Apr 2011 00:26:31 +0200, andrel wrote:
>> And what is the hypothesis? That a particular protein didn't evolve? Or
>> that some intelligence actually created that protein?
> Or even weaker that their presence is easier explained by design than as
> a result of natural selection. (hijacking Occam's razor).
No, that's not correct.  Just because something can't be explained by
evolution (assuming it were found) doesn't mean ID is how it occurred.
What it means is we don't understand the process by which it occurred.
Leaping to the conclusion that it's ID because it isn't evolution is a
poor application of Occam's razor (at best) and lazy rationalization (at
worst).
Jim
Date: 21 Apr 2011 01:09:53
Message: <4dafbc21@news.povray.org>
On Wed, 20 Apr 2011 16:08:25 -0700, Patrick Elliott wrote:
> No it can't. Not in science.
I didn't say "in science".  In common usage, and that's part of the
problem with the Creationist argument (which I stated before):  They
misuse the word "Theory".
Now, if you couple the idea that ID is not science but evolution is, you
can use "theory" in describing both - because one has the context of not
being science, and one has the context of being science.
It is a legitimate *linguistic* usage of the word.  My point was to
illustrate that this is the device used by creationists to argue that
it's science, and it's born out of ignorance of the *scientific* usage of
the word as compared to the 'common usage' use of the word - or it's born
out of malicious use of the same word intended to cause confusion in
those who don't understand that words can actually mean more than one
thing, and that the *context* is important.
Jim
Date: 21 Apr 2011 10:19:18
Message: <4db03ce5@news.povray.org>
John VanSickle <evi### [at] hotmailcom> wrote:
> They were by no means "undeniably" Christian.  There is good ground to deny.
> When contacted by American chaplains, many German prisoners-of-war
> professed either atheism or nature-worship.  It is true that most were
> nominally Christians (specifically, either Lutheran or Catholic), but
> they had long abandoned whatever faith they had acquired from either of
> these churches.
  The problem with the claims that nazis were atheists is the implied
correlation-implies-causation. In other words, nazis did what they did
*because* they were atheists (and they would not have done it if they
had been christians). This is unjustified.
  Nevertheless, whether the nazis were religious or atheists, it doesn't
really matter. The *origin* of antisemitism is largerly religious. Religion
caused the spread of antisemitism and prejudice against the jews. Without
the Catholic church it's very possible that the nazis would have not been
antisemitic (for the simple reason that there would have not been a widespread
negative notion of the jews).
Date: 21 Apr 2011 10:55:15
Message: <4db04553@news.povray.org>
>> deny.
>> these churches.
Yep, that's the point I was getting at.
> Religion caused the spread of antisemitism and prejudice against the
> jews. Without the Catholic church it's very possible that the nazis
> would have not been antisemitic (for the simple reason that there would
> have not been a widespread negative notion of the jews).
Agreed.  At the very least, Naziism had an undercurrent of "Jews = Evil
because they killed Jesus", which to some extent was until *very*
recently something the Catholic Church supported (The Pope only in the
last year renounced that idea, certainly it was considered a 'valid'
position by some within the Catholic church in the 40's.)
But more to the point, who gets to define what is Christian (which was
the point of asking for an explanation of that statement), as throughout
history a lot of things are done in Christianity's name - so who gets to
decide "yes, that's a Christian thing to do" and "no, that's not a
Christian thing to do and one who does it isn't Christian".
Jim
Date: 21 Apr 2011 10:58:20
Message: <4db0460c@news.povray.org>
  Ah, the classic no true scotsman fallacy...
Date: 21 Apr 2011 11:09:06
Message: <4db04892@news.povray.org>
>> throughout history a lot of things are done in Christianity's name - so
>> who gets to decide "yes, that's a Christian thing to do" and "no,
>> that's not a Christian thing to do and one who does it isn't
>> Christian".
Precisely. :)
Jim
Date: 21 Apr 2011 12:29:49
Message: <4db05b7d$1@news.povray.org>
That was exactly my point. Everyone on the goddidit side believes there's
only evolution or god.
Date: 21 Apr 2011 12:35:00
Message: <web.4db05c514c35f31585627c70@news.povray.org>
> Following this from abroad, I don't know if this should be amusing or
> frightening...
> http://ncse.com/news/2011/03/antievolution-bill-tennessee-progresses-006545
> http://ncse.com/news/2011/03/intelligent-design-legislation-texas-006531
> http://ncse.com/news/2011/03/antievolution-legislation-florida-006524
> http://ncse.com/news/2011/02/antievolution-legislation-new-mexico-006469
> http://ncse.com/news/2011/01/second-antievolution-bill-oklahoma-006439
> http://ncse.com/news/2011/01/antievolution-legislation-missouri-006421
> http://ncse.com/news/2011/01/antievolution-legislation-kentucky-006389
(Replying late because I've been neck deep in idiotic accounting problems for a
couple of weeks.)
Following this from within, this is an easy question:
Frightening, hands down.
Yes, the vast majority of these folks, many of whom hold positions of
responsibility and authority in important institutions, are absolutely serious
and this completely out of touch with reality as indicated by reason,
observation and the scientific method.
Once a group of people have decided that agreement with an unquestioned
authority is the one and only check on reality that is required, and can
position, there is virtually no limit to the level of outright silliness that
then *YOU* are the bigot.
Best Regards,
Mike C.
