POV-Ray : Newsgroups : povray.off-topic : It had to happen again... Server Time
12 Oct 2026 20:23:49 EDT (-0400)
  It had to happen again... (Message 5 to 54 of 54)
<<< Previous 4 Messages Goto Initial 50 Messages
Subject: Re: It had to happen again...
Date: 25 Mar 2011 16:27:36
Message: <4d8cfab8@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> In any case, PC gaming is cramped by the success of consoles:  what does it
> matter to have all that power when it's used basically to run console game ports
> with resolutions going higher than your monitor supports and frame rates higher
> than your eyes support...
  With more RAM you can have higher-resolution textures, shadow maps and
so on. Also most game engines support all kinds of graphical effects which
require both RAM and computing prowess and can be turned on and off. With
the console, with its limited RAM and somewhat aging display hardware, they
tune the game settings so that it will work at a good framerate on the
console, while on the PC they leave it up to the player to tune the settings
to the max if he wants and his PC can handle it. And it's not only about
textures and visuals: Also the sheer amount of objects to render can be
limited on the console due to lack of RAM and the aging display hardware.
  The difference can sometimes be pretty striking when comparing side by
side: Textures, view distances, shadows, visual effects can all be
significantly better on a top-of-the-line PC compared to the Xbox 360.
Date: 25 Mar 2011 22:15:00
Message: <web.4d8d4b3c984fdae84f17b3b30@news.povray.org>
> so on.
at least as far as producers provide them. ;)
yep, but a top-of-the-line PC is also significantly expensive, plus games only
run on Windows.
More than that, my early comparison between Shadow of the Colossus for PS2 and
Assassin's Creed as a current gen tech should illustrate what I expect from
nextgen:  more, better everything, not simply better framerate, higher res
textures or more depth of field showing exactly same geometry.
SotC was topnotch on the PS2, but compared to AC it looks barren and empty, with
far less detailed world, far less detailed character and AC brings not just more
world visible at all at once, but much more detailed and populated with a
stunning number of characters themselves far more detailed than main character
in SotC.  Plus much better texturing, lighting, effects etc.
That's nextgen, not just better tech settings or slightly clear textures...
we're still to see that, even on PC.  I suspect only when Crytek and Epic reveal
their nextgen engines running on latest GPUs...
Date: 27 Mar 2011 06:58:40
Message: <4d8f1860$1@news.povray.org>
On 25/03/2011 07:32 PM, Warp wrote:
>    I warmly recommend Assassin's Creed 2. I don't know how it is on the PS3,
> but on the Xbox 360 it looks really gorgeous.
I found the graphics to be fairly tame on the PC versions of AS1 and
AS2. I also liked the style of AS1 more than AS2. (It's really hard to
take people seriously when they speak with an Italian accent. It just
sounds like a bad comedy sketch.) That said, AS2 is certainly not a
*bad* game. It's much bigger than AS1, and a lot more varied too. It's
just much harder to keep track of what's supposed to be happening...
http://blog.orphi.me.uk/
Date: 28 Mar 2011 13:37:21
Message: <4d90c751@news.povray.org>
> AS2.
  Depending on how powerful your PC is, you might be simply comparing it
to other PC games, rather than to other Xbox 360 games.
  The Xbox 360 has a pretty decent CPU and GPU even by today's standards
(although the GPU is probably getting a bit antiquated by the month), but
the absolutely major flaw of the system is the amount of RAM: 512 MB, which
by today's standards is absolutely puny. (Many PC games have had a minimum
requirement of 1GB for years.) What is worse, the RAM is shared by the CPU
and the GPU, in other words, the GPU doesn't have its own RAM (as is
customary in a PC). This means that graphics and other game data have to
share the 512 MB (unlike on a PC, where graphics can be done mostly on the
GPU's RAM and whatever the game needs on the main RAM).
  This is a real shame because the hardware is otherwise pretty capable.
The major problem is that games run out of RAM pretty fast, and have to
be content with lesser memory-hungry graphical settings such as lower
resolution textures, shadow maps, and so on. It also often limits visiblity
distances and forces somewhat drastic LOD changes.
  Having played several Xbox 360 games and, while they were graphically
nice, being slightly disappointed at some of the graphics (especially
low-resolution textures are sometimes a bit annoying), I was positively
surprised at the graphical quality of Assassin's Creed 2. Most textures
are really crisp, and the levels of detail are really high even at very
large distances. While you can sometimes see changes in LOD as you move,
it's surprisingly rare. And this on an open sandbox game.
  I'm sure they had to resort to pretty clever tricks to get this while
being constrained by 512 MB of RAM in total.
Date: 28 Mar 2011 15:21:41
Message: <4d90dfc5@news.povray.org>
Le 2011/03/28 13:37, Warp a écrit :
>> AS2.
It's one of the reason to refuse any PC with an integrated video. Most
laptops are in that case, and all netbooks. Those also have shared main
RAM/graphics RAM.
Another problem with that, is that the CPU always have to wait for the
GPU. Whenever the GPU, and other display hardware, is accessing your
RAM, NOTHING else can access it. If it was the other way around, you'd
get corrupted display with shearing, horizontal and vertical rolling,
and lot of flicker.
Depending on the resolution used, colour depth and refresh rate, it can
hit your CPU performance by over 50%.
On multicore systems, it's even worst.
Date: 28 Mar 2011 15:39:40
Message: <4d90e3fc@news.povray.org>
  When I bought my current PC a friend of mine had a bit earlier bought
an almost identical one (same motherboard, same CPU, same amount of RAM).
The difference was that he wasn't going to use his PC for gaming, so he
was content with the integrated GPU on the motherboard, while I bought
one of the top GPUs of the time. (Well, another difference was that he
had more hard drives, but that's inconsequential.)
  Because it's not every day that one can test almost identical hardware
setups side-by-side, with the only difference being the GPU, we tested
with a version of 3DMark. The difference in speed was outright astonishing.
His computer ran it at about 1-2 frames per second at worst, while mine
ran it at a comfortable 15-20 frames per second at the lowest (higher on
average).
Date: 28 Mar 2011 18:11:57
Message: <4d9107ad$1@news.povray.org>
On 3/28/2011 12:21, Alain wrote:
> Another problem with that, is that the CPU always have to wait for the GPU.
The Amiga (as well as some other machines of that era) and some old
mainframes would clock the memory at a multiple of the CPU speed and
time-slice the DMA that way. Now that memory is the slowest non-moving part
of the system, one can't really do that any more.
   "Coding without comments is like
    driving without turn signals."
Date: 29 Mar 2011 04:04:35
Message: <4d919293$1@news.povray.org>
>> CPU
>> the
It has advantages though, like not needing to transfer any data between
the CPU RAM and the GPU RAM (which is a major bottle-neck in a PC,
causing many complex algorithms to be developed).  On the xbox the CPU
can update textures and meshes directly without needing to either write
a complex vertex/pixel shader or transfer over large amounts of data
per-frame.
The lack of CPU RAM isn't as large a problem as you might expect.  A
well written PC game engine tries to minimise transfer between CPU RAM
and GPU RAM each frame, spreading out large data transfers (eg due to
the player entering a new part of the level) over many frames.  On a
console you load the new data from disc directly to the shared RAM
rather than from CPU RAM.
Of course some things need a lot of CPU RAM which are not possible on
the xbox (or need some clever programming), but I guess they decided the
unified RAM between CPU and GPU gave the best bang-for-buck for most games.
The difference between the xbox and normal PCs with shared memory is
that the xbox has a memory bandwidth of 22.4 GB/s.  Cheap PC
motherboards today with onboard GPU have something like 8 GB/s memory
bandwidth, laptops probably lower.  Even today the latest DDR3-2133 RAM
has "only" 17 GB/s.
> and lot of flicker.
Well you can still write to the RAM (obviously not at *exactly* the same
time as the GPU is reading it), you just make sure what you are writing
to is not needed by the GPU that frame (usually you write to a shadow
copy which then gets used the next frame).
Date: 29 Mar 2011 14:53:03
Message: <4d922a8f$1@news.povray.org>
>> AS2.
I haven't seen any Xbox games. I'm just comparing AS1 and AS2 on the PC
to, say, Team Fortress 2 on the PC. (I could compare it to Crysis, but
surely nothing else is *that* insane...)
Don't get me wrong, the graphics weren't *bad*. They just weren't
especially great, as PC games go.
Date: 29 Mar 2011 19:11:38
Message: <4d92672a$1@news.povray.org>
>>> CPU
>>> the
> per-frame.
Not at all in the case of the PCs. The GPU don't see the memory used by
the CPU, and the CPU don't see the memory used by the GPU. For the CPU,
the RAM allocated to the video just don't exist. The boundary is set on
the BIOS level and can't change at run time.
The data need to be moved between the main part of the RAM to the video
part. It passes through a simulated PCI/AGP/PCIe interface.
> The lack of CPU RAM isn't as large a problem as you might expect. A well
> written PC game engine tries to minimise transfer between CPU RAM and
> GPU RAM each frame, spreading out large data transfers (eg due to the
> player entering a new part of the level) over many frames. On a console
> you load the new data from disc directly to the shared RAM rather than
> from CPU RAM.
On a PC, there is NO shared RAM. On a game console, you may have it.
On a PC, the video RAM looks just like that of a dedicated video card.
> that the xbox has a memory bandwidth of 22.4 GB/s. Cheap PC motherboards
> today with onboard GPU have something like 8 GB/s memory bandwidth,
> laptops probably lower. Even today the latest DDR3-2133 RAM has "only"
> 17 GB/s.
I'd gues that is dual ported DDR, possibly dual channel.
>> and lot of flicker.
There is an hardware, BIOS controled, mutex with absolute priority to
the GPU. There is only ONE data bus.
To do what you mention, you'd need dual ported RAM (that's totaly
different from dual channel). Dual port enable you to have 2 concurent
data exchanges, 2 reads, 2 writes, or a read and a write, at the same
time from 2 sources or destinations. Some video RAM IS dual ported and
maybe some consoles do use that kind of memory. It's not new, the Matrox
video cards used that in the 90's for consumer level dards. I have one,
a Matrox Mystic.
As warp was able to test it, a distinct video card on a PC can mean a
tenfold performance boost.
I orinaly mentioned a 50% hit, looks like it's more like an 80 to 90% hit...
Date: 30 Mar 2011 04:12:52
Message: <4d92e604$1@news.povray.org>
>>>> CPU
>>>> have to
>>>> share the 512 MB
>> per-frame.
I don't know about PCs with shared memory (I can imagine they are not
designed for gaming speed!), I was talking about the xbox360, which is
specifically designed for gaming speed (with compromises that wouldn't
work for a normal PC).
Date: 30 Mar 2011 15:00:34
Message: <4d937dd2@news.povray.org>
>>>>> CPU
>>>>> have to
>>>>> share the 512 MB
>>> per-frame.
True.
Date: 31 Mar 2011 11:58:26
Message: <4d94a4a2@news.povray.org>
> per-frame.
  The major problem is not the speed, but the amount, as I mentioned.
The architecture would be fine, the problem is that the amount of RAM
is puny compared to modern game requirements. If the Xbox360 had, for
example, 2GB of RAM (or more), then it would really be a killer gaming
platform.
Date: 31 Mar 2011 12:19:28
Message: <4d94a990$1@news.povray.org>
> platform.
I have noticed that games on the xbox seem to have more prettiness than the
same games on the PS3.  Even looking at youtube videos of gameplay you can
tell whether it was recorded off an xbox or a ps3.
Is that just because the games I happened to look at were more polished on
the xbox, or does the xbox have actual noticably better support for
sophisticated shaders and such?
(I also noticed that the PS3 games seem to have huge wide-open spaces that I
don't see on any xbox games, but I suspect that's just my selection of
games. Altho it would make sense, having a bluray drive and probably more RAM.)
Date: 31 Mar 2011 13:15:41
Message: <4d94b6bd@news.povray.org>
  Looking at the hardware specifications of both consoles, they seem pretty
similar: Same amount of total RAM and similar GPUs (both based on the same
generation competing GPUs of ATI and NVidia respectively). The Xbox 360 GPU
might have a slight edge in that it seems to have some 10MB specialized
internal fast framebuffer that offers 4-sample antialiasing, alpha compositing
and Z/stencil buffering practically for free.
  On the PS3 the RAM is divided half-and-half between the GPU and the CPU,
with the GPU having 256 MB of dedicated RAM plus access to up to 224 MB of
the main RAM (whatever that means). I suppose that means that the CPU has
only up to 256 MB of RAM to play with (unlike the Xbox 360 where the CPU
can use all of the 512 MB). I don't know if this makes a difference, but
it might.
  The CPU architectures are completely different, with the one on the PS3
being extremely exotic. The PS3 suffered a lot in its initial years because
of that (no existing game engines could be easily ported to it so that they
would take full advantage of the CPU design). In fact, AFAIK it's still
suffering from it to some extent to this day. I don't know how much of an
impact this has on game visual quality and performance.
  There are many Xbox 360 games that have huge sceneries, such as the
Assassin's Creed series, Red Dead Redemption, Oblivion, etc.
Date: 31 Mar 2011 13:53:09
Message: <4d94bf85$1@news.povray.org>
I just noticed that things on the PS3 seem less ...  shiney. :-) Like,
there's much more detail in batman's cape on the xbox than the ps3, from
what I can notice without having them physically side-by-side.  Maybe the
dev tools for that sort of thing are easier on the xbox, so more work goes
into making it prettier.  Or it might just be my imagination. :-)
Yeah, that's the kind of thing I was thinking about. I've only personally
seen it in Uncharted and inFamous, which are PS3-specific.
Thanks for the info! :-)
Date: 31 Mar 2011 15:41:48
Message: <4d94d8fc$1@news.povray.org>
Darren New escreveu:
>> pretty
> the dev tools for that sort of thing are easier on the xbox, so more
> work goes into making it prettier.  Or it might just be my imagination. :-)
> personally seen it in Uncharted and inFamous, which are PS3-specific.
whatever the differences, they are pretty much negligible.  The bluray
would not allow for more anything than would be able to fit in the
memory at any one time.  Both consoles support huge open-worlds and the
360 GPU may have an edge on graphics (or artists just the bump up
spec/normal maps for the Microsoft console on multiplatform games).  The
bluray player just seems to allow for far more cinematics, scripted
events, history and voice acting, as seen in Uncharted, God of War 3 etc.
The recently released Crysis 2 is a huge open-world and has been awarded
king of graphics on consoles so far, with 360 with a slight edge at
this, that in the mouths of fanboys assume gigantic proportions.
a game sig: http://tinyurl.com/d3rxz9
Date: 31 Mar 2011 16:04:19
Message: <4d94de42@news.povray.org>
> The
  Nothing forces a game to be released on 1 DVD. Lost Odyssey comes in
4 DVDs, Blue Dragon, Star Ocean: The Last Hope and Final Fantasy XIII
com in 3 DVDs each, and Mass Effect 2 comes in 2 DVDs.
  Of course a Blu-Ray can hold the same amount of data as about 6 DVDs,
so it's easier to put put even more stuff in one.
Date: 31 Mar 2011 16:17:31
Message: <4d94e15b@news.povray.org>
Oh, agreed in all ways. It's not like we're comparing the Wii or something.
Date: 31 Mar 2011 16:29:54
Message: <4d94e442@news.povray.org>
  It's curious that technically the Wii is like 10 years old, yet if you
look at the sales, it surpasses the Xbox 360 and the PS3 combined. By a
large margin.
Date: 1 Apr 2011 03:49:35
Message: <4d95838f$1@news.povray.org>
> platform.
Don't forget games for the PC that quote 1GB or 2GB RAM requirements
need to accomodate the Windows OS and all other running services and
apps as well as the game itself.  I would be quite surprised if any game
for Windows actually used 1 or 2GB of RAM just for itself - apart from
caching files from disc on the way to the GPU, what else would a game
need that much CPU RAM for?
Date: 1 Apr 2011 03:56:34
Message: <4d958532$1@news.povray.org>
I haven't played on the xbox360 very often (I don't own one) but my
impression is games on the PS3 use motion-blur and depth-of-field
approximation effects more.  Maybe the devs are just trying to find ways
to use up the spare CPU cores, but often it makes the game look quite
bad in still shots, when you can see that they are just faking the effects.
Mind you, apart from the shadows (why use low resolution shadow map
textures in such a polished game??), Gran Turismo 5 is beautiful.
Date: 1 Apr 2011 04:13:17
Message: <4d95891d@news.povray.org>
While I would imagine that most of that is texture data, and possibly
models, a chunk of it is probably sound data too. Depending on the game,
it might also need to store non-trivial amounts of gameplay data.
Date: 1 Apr 2011 05:45:03
Message: <4d959e9f@news.povray.org>
> models,
I imagine a good written game-engine (like a good written OS) will use
up whatever unused resources it has available to the benefit of the user
- in this case filling up the CPU RAM with a cache of GPU data that
might be needed soon.  But it's not a minimum requirement for such RAM
to be available, it's just loaded directly from disc a few frames
earlier (big CPU<>GPU transfers are spread out over many frames anyway)
if the files aren't in the cache.
Didn't think of that, I guess uncompressed CD-quality sound takes up 10
MB or so per minute, maybe this is used a lot by PC games, IDK.  At
least when using XNA with the xbox, the sounds/music are stored in some
compressed format, it wouldn't surprise me if they are decompressed
on-the-fly to avoid using up too much RAM.
Yeh, this is the main point I was wondering about, apart from graphics,
what sort of data might a game need to store that runs in to several
hundred MBs?  I couldn't think of anything straight away.
Date: 1 Apr 2011 06:26:30
Message: <4d95a856$1@news.povray.org>
> MB or so per minute, maybe this is used a lot by PC games, IDK. At least
Yeah, MP3 or similar seems to be the norm here. (And these days,
decoding MP3 takes so little CPU power...)
I know when I looked at the HalfLife 2 engine, you needed to build
navigation maps to allow the NPC AI to navigate around the map. That's
not model data as such (it never goes near the GPU), but it's data that
you do need to run the game. On the other hand, for a typical HL2:DM or
CS:S map, it's only a dozen MB or so...
Date: 1 Apr 2011 06:49:35
Message: <4d95adbf@news.povray.org>
  Those effects are not dependent on the CPU.
Date: 1 Apr 2011 06:53:37
Message: <4d95aeb1@news.povray.org>
  The OS doesn't take half a gigabyte of RAM. That would be ridiculous
(even for Windows). You can actually see the amount of free RAM from the
task manager, and there's usually just some tens of megabytes less than
your total amount of physical RAM in the worst cases.
  And you shouldn't be running RAM-heavy apps at the same time you are
playing.
Date: 1 Apr 2011 06:56:06
Message: <4d95af45@news.povray.org>
  The scene geometry cannot be loaded all at once onto the GPU RAM if the
scenery is huge (which is the case at least with open sandbox games and even
non-sandbox ones if the scenery is very detailed). The scenery has to be
loaded dynamically as the player moves. The more RAM you have, the less
loading needed and the faster the game.
Date: 1 Apr 2011 07:08:11
Message: <4d95b21b$1@news.povray.org>
The CPU is routinely used for graphics effects in the PS3, here's the
first reference I could find via google:
"We're doing all the post-processing effects on the Synergistic
Processing Units." Screen Space Ambient Occlusion for example, was done
completely on the SPUs"
http://en.wikipedia.org/wiki/Uncharted_2:_Among_Thieves#Graphics_and_technology
Date: 1 Apr 2011 07:16:23
Message: <4d95b407@news.povray.org>
Why should loading the scenery from disc slow down the game?  It's done
in the background before you get to the part of the level where the
scenery is needed (the same way stuff is transferred from the CPU RAM to
the GPU RAM on PCs).  Otherwise it would be impossible to race around a
huge areas like the Nurburgring (or cities on GTA) on the PS3 without
"Loading..." screens half way around (which would be a little stupid for
a car driving game) :-)
Date: 1 Apr 2011 07:33:34
Message: <4d95b80d@news.povray.org>
  Well, I suppose that if the CPU has direct fast access to the different
GPU buffers, it could be used for that purpose.
Date: 1 Apr 2011 07:59:01
Message: <4d95be05@news.povray.org>
  Odd question. Because the disc is really, really slow?
  The more RAM you have, the more scenery you can preload, which allows
showing more detail at greater distances, reduce the amount of visible
changes in level-of-detail when you move, and overall works as a larger
"cache" for the scenery.
  If you have less RAM, this "cache" gets filled a lot quicker needing
a lot more loading from disc as you move around, and it reduces the amount
of detail you can show and introduces more visible changes in LOD levels.
Date: 1 Apr 2011 08:14:27
Message: <4d95c1a3$1@news.povray.org>
The CPU and GPU can carry on working whilst a file is loading, you don't
have to block everything whilst the file loads (thankfully!).
Date: 1 Apr 2011 08:47:05
Message: <4d95c949@news.povray.org>
  It's hard to work on something that has not been loaded.
Date: 1 Apr 2011 09:20:03
Message: <4d95d103$1@news.povray.org>
There's an obvious solution to that, which I think most large-world
games use, even on the PC (due to slow transfer between CPU and GPU
RAM).  IIRC on GTA3 if you hacked the cars to go really fast, you could
drive to places before the high-resolution textures and models had
loaded, then after a second or so everything would suddenly get more
detail :-)
Date: 1 Apr 2011 09:25:10
Message: <4d95d236$1@news.povray.org>
Right.
But you can usually split the scenery in areas. You only need the
current area and its neighbour in memory.
New area could be loaded when changing the list of neighbour (in fact,
you could just keep the current area, its neighbour and its neighbour's
neighbour. When the neighbour become current, there is still plenty of
works for CPU & GPU while loading the new neighbour's neighbours.)
That's the difference between games that put you in a tunnel/corridor,
and the ones which don't: the former only manage a 1D of areas, usually
as a basic list... the latter is more complex.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 1 Apr 2011 14:06:29
Message: <4d961425@news.povray.org>
Warp escreveu:
> large margin.
Unless you're considering sales only in one particular region.  Global
sales for 360 and PS3 combined are higher than for Wii.  Which is a good
thing as far as true gaming is concerned.
Wii didn't target gamers who are into this media for ages.  They tried
to bring a new audience into the media, by offering a new largely
buttonless control experience.  Unfortunately, the people playing Wii
are more acurately described as the people playing Wii Sports and a few
other casual games -- besides the die-hard loyal Nintendo fanboys.  Part
of this audience is now buying Kinect instead.
But Wii was just the begining into bringing down the industry to more
primitive and cheaper gameplaying experience.  Just look at Apple and
the 99 cents one-shot games proclaiming the death of Nintendo and even
consoles...
I for one had my fair share of primitive (but far more challenging)
gameplay in the 80's.  They are all the rage again now, except with no
challenge and much arrogance...
Date: 1 Apr 2011 14:22:41
Message: <4d9617f1$1@news.povray.org>
scott escreveu:
hmm, there's DOF in Assassin's Creed whenever you target someone.  Is
there none in 360?
Most new effects in this generation only make them justice in motion.
Normal and spec maps are wonderful, but in shots they just look like
more texture.  You don't see lighting dynamically changing them.  DOF
and motion blur much the same.
Shadow maps are another incredible effect, allowing for much shadowing
on characters and even self-shadowing.  They are lowrez after all, but
still impressive.
It's amazing how we've gone from blocky characters with almost no
texturing besides goraud shading and circular ground shadows in the
first generation of 3D hardware, to fine textured models with all
fingers and shadow projections in the environments in the second
generation to fully detailed models with fine details provided by
normal/spec maps and self-shadowing and environment shadows casted upon
them nowadays.  It's a marvel to behold.  Guess nextgen high quality AA,
motion blur, hirez shadow maps, HDR lighting, screen space AO, screen
space Subsurface scattering and real-time tesselation will pretty much
provide Pixar-level excellence in 60 frames per second...
Date: 1 Apr 2011 21:43:06
Message: <4d967f2a@news.povray.org>
> still impressive.
Have you ever played Splinter Cell for the 1st Xbox? Shadow maps really
gave that game justice.
Super Mario 64 was great...
Even the character in Driver 2 had shadows (plus a way to work your way
into any building)...
> in the second
It must be. I don't know whether to get a handhold emulator or the next
best Xbox... (or a Wii, because Mario games /rock/)
Ah, someday realistic 3D rendering will merge completely and
unequivocally with gaming technology. Hopefully those cards will be
optimized for raytracing. Can you imagine making a game with POV? (I
can, but the SDL needs some work :) )
____________
Now Playing:
  Clonk Rage
   Also Playing:
    Landslide, Smashing Pumpkins
     irony: 100%
Date: 2 Apr 2011 03:21:33
Message: <4d96ce7d@news.povray.org>
> Right.
  Which is exactly where more RAM helps a lot: You can have more detailed
models and higher-resolution textures (and other types of bitmaps) for
larger visiblity distances, and overall have a larger "buffer" for the
scenery, allowing for less visible changes in LOD levels.
  I don't even understand why we are having this conversation. What I'm
saying should be patently obvious. The counterargument makes it sound like
one doesn't need RAM at all to draw a 3D scene in real-time.
Date: 2 Apr 2011 03:25:08
Message: <4d96cf54@news.povray.org>
On 4/1/2011 11:22, nemesis wrote:
> hmm, there's DOF in Assassin's Creed whenever you target someone. Is there
> none in 360?
One of the neat effects in the XBox version of the Batman game is when
you're choking the crap out of someone, everything not close goes all
blurry.  So, yeah, they're managing it somehow.
Date: 3 Apr 2011 00:55:00
Message: <web.4d97fd80984fdae8f91e30d20@news.povray.org>
> > still impressive.
yeah, the original XBox was definitely ahead of both PS2 and GC.
it indeed was.  Magical at the time.
> > in the second
the Wii is a GC under different plastic box.  It's got none of the hardware
prowess of 360 and PS3 whatsoever.  You'll be playing games with same graphics
of past 10 years.  Mario Galaxy is awesome, but I can't have my gaming fix on
just Mario and Link alone.  Even Samus Aran should have ended her career in
Super Metroid or the first Metroid Prime...
Date: 4 Apr 2011 00:24:10
Message: <4d9947ea@news.povray.org>
On 4/2/2011 9:54 PM, nemesis wrote:
>>> in the second
> of past 10 years.
Gah! Nintendo might as well be selling exercise videos :(
I'd love to play that one. Just 48 hours of caffeine-fueled
uninterrupted game time...
What is up with those guys anyway? Always having to save the princess.
Peach breaks a nail, "help me Mario!" Zelda sees a pig, "the Moblins are
attacking the castle!" Get a grip, Zelda! Or better yet, pick up a power
glove once in a while, sheesh!
Aw, c'mon! Another (2D) Metroid game made well would be great! I thought
of a great prequel entitled, "The Last Chozo," where of course, you'd
play as a Chozo. There would be some storyline about how you were the
last one, Metroids along with space pirates invaded your home world,
blah, blah, blah... the Metroid games were more about action anyway ;)
Date: 4 Apr 2011 04:40:06
Message: <4d9983e6$1@news.povray.org>
If you need to send data to the GPU faster than a hard disc can supply
then you're going to have far more serious problems with your game
design.  And even if you do manage somehow to get good performance with
loading that much data, your CPU RAM is going to run out in a matter of
seconds (unless you have some carefully constructed repeated pattern of
textures/meshes that are swapped in and out every second or so).  I
can't think of a realistic situation where it is absolutely necessary to
have a large amount of CPU RAM to achieve some effect.
Just to clarify we're talking about CPU RAM here, not RAM in general.
It's completely possible to write a program on a PC that fills the GPU
RAM with complex meshes and textures, then releases nearly all CPU RAM
(apart from needed pointers and space for the CPU code itself).  It will
still work and be able to draw the scene in real-time, CPU RAM usage
will be minimal.
Date: 4 Apr 2011 12:27:42
Message: <4d99f17e$1@news.povray.org>
stbenge escreveu:
I'll probably still get Zelda: Skyward Sword by end of the year for Wii.
  Wii's swann's song, no doubt.  And perhaps even happens like TP:
launched for both GC and Wii.
Motion control games so far have only been used for simplistic sports
mini-games collections, fun for a while but ultimately too shallow and
repetitive.  Z:SS OTOH will deliver 1:1 sword playing, shield defensing,
arch&bow, canoeing and more all in one top adventure game.  The Wii was
built for games like this, but hardly delivered...
There's always the mobile versions, of course.  Fusion on GBA had better
controls than SM, but still not quite the feeling of SM.  There's also
Metroid Zero, which is basically Metroid 1 revamped with 16-bit
graphics.  Many great side-scrollers found much better home in the
Nintendo handhelds, including the awesome series of Metroidvanias from
Konami since Castlevania:SotN.
I was talking specifically of Metroid:Other M for Wii.  Not quite so good.
Date: 6 Apr 2011 05:03:32
Message: <4d9c2c63@news.povray.org>
> will be minimal.
  I am talking about the Xbox 360 with its shared RAM (the same RAM is used
by the CPU and the GPU), and how 512 MB is a puny amount.
  Consider it in the other direction: Imagine that the amount of RAM would
be 128 MB instead. Would games still look as good as they do? If not, why
not?
  Now consider 2 GB vs 512 MB. Exact same thing.
Date: 6 Apr 2011 06:01:40
Message: <4d9c3a04$1@news.povray.org>
> not?
I never disagreed that the amount of RAM directly available to the GPU
affects the graphical performance possible.  I disagree that the amount
of CPU RAM has any significant influence on the graphics possible.
Date: 6 Apr 2011 13:31:07
Message: <4d9ca35b@news.povray.org>
  And I explained you why it does: Even if the GPU has its own dedicated RAM,
you can't put the entire scene in it, especially with humongous open sandbox
games. You have to be selective about what you send the GPU to render. The
CPU makes the decision on what to render and with what LOD level. And it
obviously makes this decision based on what it as on its own RAM.
  The more RAM you have, the more and higher-definition scene data you can
have at a time to tell the GPU to render.
Date: 7 Apr 2011 03:58:33
Message: <4d9d6ea9$1@news.povray.org>
Your explanation is making incorrect assumptions (you seem to have
ignored my explanation), I'll try once more...
You would be correct if data could be transferred between CPU RAM and
GPU RAM much faster, but this isn't the case.  During a game it would
take several seconds to replace the GPU RAM completely, and in that time
you can probably load the data from the HD rather than having to keep it
in CPU RAM.  In typical games you don't need to replace the entire GPU
RAM anywhere near as often as that (in fact it would be a really bad
game engine design to do so), so it's even less of an issue.  That's why
it's possible for such games to run on a PS3 with a "puny" 256MB of CPU RAM.
Date: 9 Apr 2011 04:31:50
Message: <4da01976@news.povray.org>
  The majority of the data on the GPU's RAM is textures and other bitmaps
which do not change. You don't "replace the GPU RAM completely". You replace
the scene geometry. The geometry of the scene is being constantly transferred
from the CPU RAM to the GPU (if they don't share RAMs), especially on an open
sandbox game. There may be some geometry that is kept constantly on the GPU
RAM (such as stock objects and character models, if they can be animated
from inside the GPU itself), but the scenery itself has to be updated as
the player moves.
  The reason is rather obvious: The entire world cannot fit into either RAM
at once, but must be dynamically loaded and updated as the player moves.
The CPU makes the decision on what to load and what to display, and obviously
constantly updates the geometry from its own RAM to the GPU.
  You still make it sound like you don't need CPU RAM *at all* to play an
open sandbox game. That's obviously ridiculous.
  And you still haven't answered my question: Why is 512 MB better than
for example 128 MB of CPU RAM for large games? Or 32 MB. Or 1 MB.
  If you think about that question, then think why eg. 2 GB would be better
than 512 MB. Or is 512 MB some kind of magic limit after which any additional
RAM is obsolete? Can you explain why this would be so?
