POV-Ray : Newsgroups : povray.off-topic : Be very afraid... Server Time
31 Jul 2026 11:58:18 EDT (-0400)
  Be very afraid... (Message 21 to 30 of 65)
Subject: Re: Be very afraid...
Date: 23 Sep 2009 23:36:55
Message: <4abae957@news.povray.org>
Orchid XP v8 wrote:
> I liked Crysis more than HL2, so I guess it's up to what you want out of
> a game.
Same here; I'm about halfway through Ep1, and I just haven't picked it
up in more than a week.
...Chambers
Date: 24 Sep 2009 03:29:13
Message: <4abb1fc9$1@news.povray.org>
> A GPU implementation of instant radiosity presented at this year's
> SIGRAPH.  Yeah, objects move around and affect GI.  be very afraid...
Yes I think dynamic GI is getting more and more realistic on the GPU, it
makes a huge visual difference that is often hard to pin down (ie it just
"looks better" but it's not massively obvious like adding reflections).
> Of course, that's only in the triangle mesh-world, not in the world of
> perfect sphere surfaces...
I don't understand the fascination with perfect mathematically described
surfaces, they are inflexible and slow to render.  If you use sub-divided
triangle meshes you can make the output perfectly smooth all the time and of
course do whatever transformations you like very easily by just transforming
every vertex.  AFAIK all film-quality 3D animation is done with triangle
mesh based renderers, and we can probably assume they have worked out the
best way to get photo-realistic quality.  And the huge benefit for games
(rather than offline rendering) is that it's very simple to reduce the
triangle count to keep real-time animation.
Date: 24 Sep 2009 03:33:30
Message: <4abb20ca$1@news.povray.org>
> this is an insanely amazing Crysis mod shot too:
http://www1.picturepush.com/photo/a/1578869/1024/Crysis/crysis64-2009-04-11-19-45-23-44.png
Imagine how long that would take to render in POV, media, DOF, refraction!
And I don't think the result would be *that* different (maybe the refraction
would look slightly different, but a normal person probably couldn't tell
which one was correct, especially during animation).
Date: 24 Sep 2009 04:24:09
Message: <4abb2ca9@news.povray.org>
>> of a game.
HL2 was technically astonishing. (Remember, at the time the only other
game I'd played was HL1. Oh, and Quake II.) But it wasn't all that much
fun to actually play.
HL2:EP1 added even better graphics, but wasn't greatly more fun to play.
(God I hate zombies!)
HL2:EP2 was graphically better still, but - far more importantly - it
was *fun*! I actually played it more than once. (Didn't do that with HL2
or HL2:EP1.) The final battle is absurdly difficult, but other than
that, it's really rather entertaining.
Date: 24 Sep 2009 04:25:52
Message: <4abb2d10$1@news.povray.org>
Really? I was under the impression that splines can describe any
possible surface. Triangles, on the other hand, can only give a crude
approximation to curves.
Date: 24 Sep 2009 04:26:57
Message: <4abb2d51$1@news.povray.org>
> refraction! And I don't think the result would be *that* different
> (maybe the refraction would look slightly different, but a normal person
> probably couldn't tell which one was correct, especially during animation).
It wouldn't have all those glitches that games have though. (Like grass
that rotates as you run past it, or "mist" that has sharp edges where it
intersects things.)
Date: 24 Sep 2009 04:28:16
Message: <4abb2da0@news.povray.org>
On Thu, 24 Sep 2009 09:25:52 +0100, Invisible wrote:
> I was under the impression that splines can describe any possible
> surface.
"When the only tool you have is a hammer, everything looks like a nail."
In my current sleep-deprived state, that seems a relevant quote.  It may
not after I go to bed, sleep, wake up, shower, and come back up here in
the morning.  But right now it seems relevant.
Jim ZZZZzzzzzzzzzzzzzzzzzzzzzzzz.................
Date: 24 Sep 2009 05:07:43
Message: <4abb36df@news.povray.org>
> Really? I was under the impression that splines can describe any possible
> surface.
How do you render a splined surface directly?  Even POV converts them to
triangles first!
> Triangles, on the other hand, can only give a crude approximation to
> curves.
In practice display devices are made of pixels, so using triangles you can
always get exactly the same output as using the true curve.  Have you ever
seen any "crude approximations" to curves in film CG?
Date: 24 Sep 2009 05:21:49
Message: <4abb3a2d$1@news.povray.org>
>> possible surface.
> triangles first!
It's news to me that POV supports splines in the first place.
>> curves.
> can always get exactly the same output as using the true curve.
Only if you have the original curve to hand.
> Have you ever seen any "crude approximations" to curves in film CG?
Have you ever seen any curved surfaces in computer games?
If you *insist* on using triangles, you're going to need a hell of a lot
of them to fake the appearence of a good curve. That means you either
need a triangle mesh of absurd dimensions, or you need to generate the
triangles on the fly.
What all known computer games do is use a static, very low resolution
triangle mesh and then smother it with lashes of low-level trickery to
give a vague semblance of curvature.
Date: 24 Sep 2009 05:28:10
Message: <4abb3baa$1@news.povray.org>
>> refraction! And I don't think the result would be *that* different (maybe
>> animation).
> intersects things.)
I don't think modern games have those glitches anymore, the grass is true 3D
geometry not just billboards, and the mist billboards usually compare depths
of existing pixels to avoid the hard edges with geometry.  Some games even
have true 3D volume textures and rendering for smoke and mist, I don't know
if Crysis uses this or just cheats with multiple billboards.  Maybe the
glitches you mention are on a game from 5 years ago or on a very badly
written modern one.
