>> So... unless I don't connect any SATA devices, it is *actually
>> impossible* to fit this particular graphics card. Weeeeee!! :-D
> Could you not fit a 90 degree SATA socket, like this one:
> http://estore.asus.com/images/14-000107075.jpg
Hmm... It's possible. Would be a pretty tight fit though.
OTOH, I just remembered that my motherboard (being a high-end "delux"
version) has a second SATA controller. So I think I can use the sockets
for that. I forget where those are, but I think they're on a different
part of the board...
nemesis wrote:
> Orchid XP v8 <voi### [at] dev null> wrote:
>> I'm not making this stuff up!!
> How many horsepower in there? They must be stallions! :D
715 gigaFLOPS, bitches!! :-D
[Er, but that's *peak* performance. And at *single* precision.]
Also... 182 W TDP? o_O
I think that's more then the *radiator* in my bedroom!
Darren New wrote:
> We sell more than everyone else put together! How do we do it? Volume!
> Our ads are louder than anyone else's!
I don't know about adverts, but I'm wondering how loud that fan is going
to be... ;-)
That was going to be my next suggestion :-) I have not seen a motherboard
with all the SATA sockets exactly in the same place. I think mine has a
header near the back for an "external SATA" socket - but unused currently.
>> sockets for that. I forget where those are, but I think they're on a
>> different part of the board...
> motherboard with all the SATA sockets exactly in the same place. I
> think mine has a header near the back for an "external SATA" socket -
My motherboard is a £90 Gigabyte K8N Ultra-SLI powered by the nForce 4
SLI chipset, which gives you 4 SATA II ports that can be configured for
RAID. Gigabyte then added an onboard Silicon Image SATA controller,
giving you an additional 4 SATA II ports. (This is on top of not one but
*two* Firewire ports - one of them a faster Firewire-B port - two
gigabit Ethernet ports [remember when those used to be expensive? This
was back then!!], and of course SLI support [SLI was still very new.])
More impressive still, not only does the board have 8 SATA sockets, but
THEY GIVE YOU EIGHT SATA CABLES!
COLOUR CODED!!
As one reviewer wrote, "penny-pinching is not evident".
http://www.tomshardware.co.uk/finally-available,review-1164-12.html
From the image here (which is for the GA K8NXP-9), it appears that the
extra SATA sockets are on the bottom edge of the board, clear of the GPU
bay. So that ought to be usable.
Damn, I spent £90 on a motherboard, and today it's almost a museum
piece. How technology moves on, eh? (Remember, back then socket-939 was
supposed to be "the next Big Thing"...)
> to be... ;-)
The larger the fan, the slower it needs to spin to move the same volume
of air.
Most of the time, it should be quiet enough. Unless you're playing a
game, doing some heavy Photoshop stuff, running Vista with Aero, looking
at it wrong, et cetera. You get the idea :)
...Chambers
www.pacificwebguy.com
Or, better yet, here:
http://www.giga-byte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1867
Click to enlarge the image. You'll see 4 *yellow* SATA connectors. Those
are from the nForce 4 chipset. You'll also see 4 *red* SATA connectors.
These are from the Silicon Image SATA controller. (And so these don't
have the RAID feature - which is "host-based RAID" anyway, as it happens.)
The box for the motherboard actually contains 4 red and 4 yellow SATA
cables. And colour-coded IDE and FDD cables. And several types of PSU
adaptors. And... Seriously, the box contains everything you could
possibly need to set this board up. It was way more than just a
cardboard box with a PCB in it! :-D
You can also see where the two PCI Express slots of the twin graphics
cards are. (Remember, this is a 2-way SLI board.) I think my new card
actually extends off the edge of the motherboard! o_O
Also, on checking, the card takes 2 bay slots - so looking at the
placement of those PCI slots, it looks like you *could* fit two of
these. At least, there's enough physical space. I can't believe that the
airflow would be in any way "optimal" though...
>> to be... ;-)
> of air.
Yes, but OTOH... if they fitted a fan this huge in the first place, this
suggests it's going to need it. ;-)
I mean, Jesus, the card is 2 bays wide just so it can accomodate enough
heatsinks and fans. It has a TDP of 182W!! o_O
Really? Interesting. The fan on my existing card (nVidia GeForce 7900GT)
spins at constant speed.
(As does the CPU fan. But that probably just means you need a special
driver to throttle it...)
That's funny... you would think that a card that advanced would know how
to throttle the fan. My 4850 certainly does (in fact, I almost never
hear it, even when playing games!)
...Chambers
Can't you use the other PCIe slot for the new GPU? Or does the first one
have to go in the right slot?
Does the GPU really cover all 4 of the SATA sockets? Wow.
> one have to go in the right slot?
I *believe* the first GPU has to go in the upper slot. I'll check the
manual. (The manual is currently downloading from Gigabyte's website at
roughly 1KB/sec, as is typical for motherboard downloads...)
Well, I haven't actually tried it, but it's 2 bays wide, and holding it
up against the motherboard (which isn't easy) it appears to be longer
then the full width of the board, so...
Hehe, would be quicker just to try it out and see if it boots or not.
Yeh, why is it that all MB manufacturers have websites with a total
bandwidth of 4kb/sec? And just when you need some simple onboard sound
driver quickly, you see it's a 63MB download and it's going to take 3 weeks
to complete.
> Well, I haven't actually tried it, but it's 2 bays wide, and holding it up
> against the motherboard (which isn't easy) it appears to be longer then
To cover all 4 SATA sockets it must be pretty thick.
>> at roughly 1KB/sec, as is typical for motherboard downloads...)
Well, maybe. :-P Currently at... ooo, 48%? o_O
> weeks to complete.
Yeah, why the **** is that??? Like, even if the download is 78KB, it's
the slowest 78KB of your entire life! o_O
Have you *seen* the photograph??
No. You can't.
"Invisible" <voi### [at] dev null> wrote in message
news:49819695$1@news.povray.org...
Wow, that's weird, I've just tried it myself, and what a weird way to
download it, all I get is a blank page with download info in the bottom left
corner. :oO
~Steve~
Orchid XP v8 wrote:
> Ooo, check this out... I didn't see this part... I also get a free copy
> of FarCry 2! :-D
Don't bother. That game is the most repetitive POS I've played.
Crysis, OTOH...
>> copy of FarCry 2! :-D
> Don't bother. That game is the most repetitive POS I've played. Crysis,
> OTOH...
...will cost me money, whereas FarCry 2 I already have. ;-) I might as
well at least see what it's like...
Hmm, although... if it's any harder than FarCry 1, I guess there really
*is* no point. o_O
"Kyle" <no### [at] spam ok> wrote in message news:4981a9e5$1@news.povray.org...
>> of FarCry 2! :-D
Yeah, I've heard that too, and I was really looking forward to it after
the original, (which I thought was brilliant for gameplay).
> Crysis, OTOH...
No doubt about it... :)
~Steve~
>> Crysis, OTOH...
Well, Nemesis seems to pretty strongly doubt it. :-P
news:4981ace6$1@news.povray.org...
>>> Crysis, OTOH...
Well, in a way, he's right about the 'tech demo' side of it, but I woudn't
go as far as saying that it's bland. The story is quite good, the cutscenes
are very good, scenery is amazing, (you'll get to see that with your 260
easy), and gameplay is just great if you love freedom to do what you want
and how you want. I completed it in about 12 hours and honestly, it's one of
those games where you'll want to take a break because you'll want to just
carry on to see what happens next.
~Steve~
Invisible wrote:
>> Crysis, OTOH...
Sure, check it out since it's *ahem* free. How much did you pay for
that video card?
Also, I thought you were going to buy Crysis anyway.
> *is* no point. o_O
I don't think it's harder. Don't expect the same game as FarCry 1,
though. It's quite different. Crysis is much more similar to FarCry 1
than FarCry 2 is.
> that video card?
£200. Because I wanted a big, chunky GPU to run all my insane
compute-bounded mentalness on? ;-)
Er, yeah. But probably not "soon"...
> than FarCry 2 is.
OK then.
http://blog.orphi.me.uk/
On 28-Jan-09 22:46, Orchid XP v8 wrote:
> Darren New wrote:
>> When did it get common to tack a "U" on the end of "Power Supply"?
>> Nobody calls it a Power Supply Unit. :-)
> Er... I do?
> I've always seen it referred to as PSU.
Would you pronounce that as P.S.U. and if not would you pronounce the
the P as in pseudo?
Yes.
OK, so last night I embarked on an epic HD moving process.
Suffice it to say, I removed the 80GB HD that I don't really use much. I
took the two remaining HDs and moved them to the bottom of the drive
rack. There is now space for the giant graphics card to slot into the PC
without purchasing a larger case.
It sounds like a trivial operation, but it wasn't. I only just have
enough power connectors, and various cables weren't really long enough, etc.
There is one small problem: the drive I removed was the one with the
working boot sector on it. I did try plugging the drives into the other
SATA sockets, but the Windows XP install CD apparently lacks the drivers
necessary to access the secondary SATA controller, so it couldn't "find"
the drives in that configuration. (KNOPPIX found them just fine, but not
Windows XP.)
Actually, it turns out the new graphics card will only block *two* of
the primary SATA sockets, so I can in fact still plug my drives in in
the usual way. I have now done this, and Windows XP can "see" them again.
Now *all* I have to do is figure out how to put NTLDR and friends back
onto the drive using the recovery console and my PC will be usable
again... o_O
Cool.
> again... o_O
Then you should be able to try the latest ones from here:
http://www.nzone.com/object/nzone_downloads_nvidia.html
>> again... o_O
One time, I actually sat down and tried every demo on nVidia's website.
(Up until the point where the higher ones wouldn't run, anyway.)
Some of the demos are just rubbish, but a few of them are really awesom.
Most especially this one:
http://www.nzone.com/object/nzone_luna_home.html
OK, technologically it's probably not that special. But seriously...
WOW! o_O This is some SERIOUSLY WEIRD CRAP! How the **** did they come
up with this stuff?! ._.
Unfortunately, I rapidly discovered that many of the demos will not
cleanly uninstall afterwards. (!!)
> again... o_O
Under Windows NT, there was a feature where you could boot from the
install CD, select "repair", and it would scan your HDs, try to find an
installed copy of Windows NT, and if it found one, attempt to make it
bootable. (E.g., check the boot sector, add the various executables and
configuration files required for a successful boot, and even replace
missing or corrupted DLLs and so on.)
Apparently this feature does not exist in Windows XP. (One presumes it
was found to be too useful, and its removal allows M$ consultants to
charge you money to fix your PC for you...)
Anyway, after consulting not less than 7 different KB articles, it
appears that I can use the Recovery Console to manually copy the two
boot files from the CD to the HD and semi-automatically rebuild the boot
configuration menu.
In case anybody wants to know, the procedure appears to be this:
- Start the Recovery Console. (I.e., boot the install CD and press "R"
when prompted.)
- Type "map" and observe the drive letter for the CD drive.
- Copy NTLDR to the harddrive: copy O:\i386\ntldr C:\
- Copy NTDETECT.COM too: copy O:\i386\ntdetect.com C:\
- Build a new BOOT.INI file: bootcfg /all
- This last command spends a few hours scanning all your HDs looking for
anything that looks like a Windows installation. It then gives you an
interactive prompt asking which ones to add to the boot menu.
Hopefully at this point the system should become bootable again. (And if
not, I'll just reinstall Windows. That should get rid of those old
nVidia demos that wouldn't uninstall...)
I just realised... I can't even run them in a VM! They need the GPU. ;-)
>> again... o_O
How did you manage to mess that up by simply replacing a graphics card?!?!
>>> back onto the drive using the recovery console and my PC will be
>>> usable again... o_O
Read again, carefully: I haven't even changed the graphics card yet. All
I've actually done is move some hardware around so that there's a big
enough space to insert the card.
The reason Windoze is upset is because I removed HD 0. (For reasons
beyond my comprehension, M$ insists that the boot files must always be
on HD 0, even if the OS itself isn't.) So I need to put the boot files
onto the drive that has now become HD 0. Unfortunately the documentation
for this isn't that easy to find, but I believe I know how to fix this now.
Orchid XP v8 wrote:
> "Powering your XFX graphics card"
> "XFX does not support the use of two 4-pin to one 6-pin power cable
> converter for these graphics cards."
> So, uh, why did you supply just such a converter IN THE BOX WITH THE
> CARD???
> Is it just me?! o_O
Seriously - I'm still bemused by this one... :-?
>> Luckily those are not very expensive.
> Well, that's the main thing, yes. ;-)
> (Otherwise, right now you'd see my sitting in the corner crying.)
...or rather, "300W PSUs are not very expensive". Typically you can buy
one of those for about £6, or anything upwards.
Unfortunately, I need a minimum of 500W (and the "recommended" is 630W,
and if you ever go to SLI that becomes 680W). PSUs in that sort of range
typically go for about £60. (Occasionally you will see *one* model at
£20 or so, but when you read the spec you discover that it only has 3
plugs or something daft.)
I'm thinking... if I'm going to actually spend real money on getting a
bigger PSU, I might as well spent a little bit more on one that can do
the job *properly*. (I.e., one with enough connectors, and a decent
Wattage.)
I'm thinking just buy 2x 300W ones for 12 pounds :-)
>> buy one of those for about £6, or anything upwards.
>> 630W, and if you ever go to SLI that becomes 680W). PSUs in that sort
>> of range typically go for about £60.
Mmm, yes... One PSU to power my PC, and the second one to power my GPU!! :-D
I'm not really sure how the case arrangements for that work out though.
(Notice that the recommended power is 630W, so 2x300W would still be
insufficient. However, I think my current PSU might be 400W, so...)
Anyway, it seems that if you want 700W *and* two 6-pin PCIe connectors,
you're talking about quite a lot of money. But if you settle for 650W,
you can find it quite a bit cheaper. I'm thinking I might go for this:
http://www.ebuyer.com/product/151295
It exceeds the recommended Wattage, it has two seperate PCIe connectors,
and it has enough other connectors to run the rest of my stuff. (It's
also 80plus certified, which is nice...) Only £40, which isn't as bad as
the £80+ for something like a modular Thermaltake 800W unit.
Like everything, the exceptionally cheap ones are crap and will die, ofte
n
taking out other parts, in a year or so. Spend the extra and get the good
one.
> (Occasionally you will see *one* model at £20 or so,
And it'll either be a piece of crap or specialized for a particular produ
ct
line.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
You might need to use mbrfix (or is it fixmbr?)
Or use diskpart to make the partition active, I think. It's been a while
since I tried to fix an XP partition.
"Ouch ouch ouch!"
> often taking out other parts, in a year or so. Spend the extra and get
> the good one.
Yeah, if I buy I PSU, I tend to not buy *the* cheapest one. I like to
buy one that's a little more. Not too much, but just so that it's not
the £6 model. Maybe £15 or something?
I'm like that with a lot of things though. I tend to avoid *the*
cheapest one, and go for one a few notches higher up.
OTOH, when looking at something like CPUs, I tend to not go for *the*
most powerful one, because typically it's 8x the price for 8% more
performance. ;-)
Yes. Actually I already did this from KNOPPIX. Just marking the
partition as "bootable" seemed to be enough to get me to the "CAN'T FIND
NTLDR" message. But I found the corresponding commands (it *is* fixmbr
and fixboot BTW) in the Recovery Console also.
Actually, that's "bootcfg /add" or /rebuild.
And, for whatever reason, it doesn't work. After a while it crashes out
with an error message about an unreadable filesystem or something.
Interestingly, it seems that placing NTLDR and NTDETECT.COM onto the
drive is sufficient to make it boot. When you boot the system, it says
"INVALID BOOT.INI; BOOTING FROM C:\WINDOWS". I'm guessing this only
works for certain cases. Since by Windows installation is your standard
"the OS is in the standard place on the first HD", it Just Works(tm).
Weirdly, once Windows has loaded there is apparently no way to recreate
a correct BOOT.INI file. However, cut-and-pasting the example one from
M$'s website seems to have fixed things nicely.
Wee, my PC works again! :-D
OK. If you got that far, all you need to do is copy boot.ini, ntldr, and the
ohter one whose name I forget offhand, and you should be good. (I'm not 100%
sure you need boot.ini if you put windows in the obvious place, either.)
"Ouch ouch ouch!"
>> FIND NTLDR" message. But I found the corresponding commands (it *is*
>> fixmbr and fixboot BTW) in the Recovery Console also.
> the ohter one whose name I forget offhand, and you should be good. (I'm
> not 100% sure you need boot.ini if you put windows in the obvious place,
> either.)
NTLDR and NTDETECT.COM - and no, you apparently don't need BOOT.INI (see
my other post). And there's nowhere to "copy" BOOT.INI from. ;-)
Well, you could copy it onto a floppy and then from there onto the hard
drive, assuming it was the same. And you can "copy con boot.ini" I believe.
"Ouch ouch ouch!"
Muhuhuhu! The new bigger, badder PSU is here! 8-D
The PSU is now installed. Now I'm going to download the drivers for the
new card, uninstall the drivers for the old card, and fit The Daddy... :-D
Jesus Christ, the video driver is 110 MB?? o_O
> of FarCry 2! :-D
> And "3DMark Vantage Advanced Edition" for free.
And 3DMark Vantage *only* works with Windows Vista. Oh well...
Don't worry about it. It isn't impressive.
"Ouch ouch ouch!"
Heh. Oh well. It's just that I've never been able to run 3DMark
properly. (I always have the free version that's crippled so you can't
run half the tests or adjust any settings.) And now I've got a real
geniune license code to run the full product, except... but for this
version of Windows.
I guess they assume that if you just paid £200 for a card with DirectX
10 support, you'd also want to run it under an OS that supports DirectX 10.
The new GPU is up and running. :-D
And... oh my *god*... it's so quiet!!
My PC just got about 5x quieter than it was before. o_O
(Although I notice it gradually gets louder than I ask it to do
something 3D.)
