POV-Ray : Newsgroups : povray.off-topic : Compiling stuff Server Time
3 Jul 2026 08:14:09 EDT (-0400)
  Compiling stuff (Message 101 to 110 of 283)
Subject: Re: Compiling stuff
Date: 12 Dec 2008 04:52:29
Message: <4942345d$1@news.povray.org>
scott wrote:
>>> ...it would drive me mad if I had to shut it down and boot it up
>>> from cold each time I used it.
>> No it wouldn't if it took only less than 5 seconds. And with SSD and
>> proper kernel config and INIT config it is very possible.
> Man, it takes longer than that to just get through the BIOS before it
> gets anywhere near an OS!
I have servers where the disks take longer than that to spin up. ;-)
...we try not to reboot it much. o_O
Date: 12 Dec 2008 04:54:25
Message: <494234d1$1@news.povray.org>
>> Doesn't that mean that after X hours the battery runs flat and you
>> need to cold boot it anyway?
> X is a very large number though, even after a weekend in standby the
> battery is still at 90-something %.
I think the last time I used my laptop was about 4 months ago?
(Mind you, that's kind of moot; *my* battery is non-functional now.
Disconnecting from the mains instantly shuts down the machine.)
>> (I guess it depends on exactly which "sleep mode" you mean...)
> Start -> Shutdown -> Standby
> AIUI it just supplies enough power to the RAM to keep its contents
> refreshed, everything else is turned off.
Right. Unlike "Hibernate", which writes the RAM image to disk, so next
time you cold boot it can just reload that.
Either way, don't you find that huge amounts of hardware stops working
properly when you start it back up again?
Date: 12 Dec 2008 05:07:18
Message: <494237d6@news.povray.org>
True in many cases, I agree. But BIOS settings can have big influence on
this too. For example: I don't have a floppy disk drive connected at
all. But if I disable it from BIOS, loading the kernel takes 2 secs more
than if I had it enabled. So grub is someway confused. Maybe a BIOS or
Grub bug.
But there are options in BIOS which might make it faster to reach Grub.
Hopefully we'll see faster BIOS loading in the future, too.
Date: 12 Dec 2008 05:08:20
Message: <49423814$1@news.povray.org>
Right, well mine is on continually during the day at work (I use it for
email and my desktop for other work), and sometimes in the evening or at
weekends I use it for a while eg in front of the TV or in the kitchen.  It
also gets used on the road (eg on the train, in the hotel, at customer
meetings) every few weeks if I need to travel anywhere.
No, the only thing I notice is that if I put it into standby while it is
docked at work, then undock it and boot it up at home, the screen resolution
is wrong for the internal LCD (1600x1200 instead of 1920x1200).  But I can
cope with that, I usually make sure to undock it before putting it to
standby (undocking it changes the resolution back from the external monitor
to the internal one).
Date: 12 Dec 2008 05:12:06
Message: <494238f6@news.povray.org>
> Grub bug.
Yeh, this is why I stand-by rather than shut-down, it means when I come back
I don't have to go through the BIOS.
As a side note, on my BIOS I have to insert my USB security key and enter a
password, but even without that it still takes longer than it does to resume
from standby.
Date: 12 Dec 2008 05:31:39
Message: <49423d8b$1@news.povray.org>
> resolution is wrong for the internal LCD (1600x1200 instead of
> 1920x1200).  But I can cope with that, I usually make sure to undock it
> before putting it to standby (undocking it changes the resolution back
> from the external monitor to the internal one).
Ah yes, the wonders of docking stations. ;-)
The Dell system we have here is great. If the laptop is powered on while
docked, it sends it video signal to the external monitor at the correct
resolution. If you open the laptop, it switches to the internal LCD
monitor, at the correct resolution. And if you close the laptop again...
it goes into hibernate mode. o_O
Do you have ANY IDEA how ANNOYING that is?!
You'd expect doing the reverse of what you just did to undo the changes,
but NOOO... that would be too easy. :-P
Date: 12 Dec 2008 05:39:05
Message: <49423f49$1@news.povray.org>
You probably have the "When I close the lid" option set to "hibernate", I
set mine to "do nothing".
Date: 12 Dec 2008 05:45:33
Message: <494240cd$1@news.povray.org>
> I set mine to "do nothing".
Probably. But it's not like I'm going to go to all 6 laptops and change
the setting *now*... :-/
Date: 12 Dec 2008 06:00:56
Message: <49424468$1@news.povray.org>
> Grub bug.
I have one mobo (Asus SK8N) that complaints about floppy drive not found
if FDD is disabled from the BIOS. OTOH enabling it removes the error,
even while there is no floppy drive.
-Aero
Date: 12 Dec 2008 13:00:10
Message: <4942a6a9@news.povray.org>
Invisible wrote:
> scott wrote:
>> I always put my XP laptop to sleep rather than turning it off, from
>> hitting the power button to windows unlock prompt is always under 5
>> seconds - it would drive me mad if I had to shut it down and boot it up
> Doesn't that mean that after X hours the battery runs flat and you need
I think Vista has a feature where it saves the RAM contents to disk and gets
into sleep (not hibernate) mode. If battery lasts enough to keep the RAM
alive, it will be fast to get out of sleep mode, unlike hibernation. If it
doesn't, you have the data saved to disk anyway, unlike sleep.
Or, maybe, the feature was that when it's running low on battery, it wakes
up, saves RAM to disk, and hibernates.
I don't remember the details.
