POV-Ray : Newsgroups : povray.off-topic : A question of physics Server Time
10 Aug 2025 03:14:29 EDT (-0400)
  A question of physics (Message 1 to 4 of 4)
Subject: A question of physics
Date: 17 Oct 2008 05:55:13
Message: <48f86101$1@news.povray.org>
OK, so I need to buy a set of PC speakers. It doesn't really matter how
good they sound, but they need to be loud enough for a crowded room full
of people to hear them.
The trouble is, I'm looking at the product catelogue, and although every
single product clearly states how many Watts it gives you, not one
single one seems to say HOW LOUD THEY ARE! >_<
Is there any way to infer the approximate loudness of a cheap PC speaker
from the Wattage rating? I realise that it's quite possible to make an
8W speaker that is deafening, but most manufacturers "typically" don't
od this, so... is there any way I can figure out the data I need?
Subject: Re: A question of physics
Date: 17 Oct 2008 06:01:46
Message: <48f8628a$1@news.povray.org>
> from the Wattage rating? I realise that it's quite possible to make an 8W
> speaker that is deafening, but most manufacturers "typically" don't od
Speaker sensitivity is the parameter you are after, tells you the "loudness"
in dB 1 metre away from the speaker when you apply 1 Watt of electrical
power to it.  Typical values are from 80 - 100, so I guess you could use 90
to work out the dB.  I doubt cheap PC speakers will tell you the actual
value.
Date: 17 Oct 2008 06:11:55
Message: <48f864eb$1@news.povray.org>
Indeed. But it isn't quoted.
> Typical values are from 80 - 100, so I guess you could use 90 to work out the dB.
Heh. Yeah. Now I just have to figure out how many dB I actually need to
fill a room...
> I doubt cheap PC speakers will tell you the actual value.
That's the problem. :-/
OTOH, at least the Wattage ratings are all RMS. (Although it doesn't
tell you at what frequency...) Some even state the impedance - which
seems a little redundant in an active speaker system...
Date: 17 Oct 2008 09:06:00
Message: <48f88db8@news.povray.org>
48f864eb$1@news.povray.org...
> fill a room...
Consider a 6dB fade every time you double distance in free field* from a
point source (fade_power 2)
*Obviously a room full of people is NOT a free field : walls reflect a part
of the sound and people absorb another part.
For a better intelligibility try to put your speakers  above head level so
people get sound coming in straight line from speakers.
Marc
