POV-Ray : Newsgroups : povray.off-topic : Another game question Server Time
22 Jun 2026 15:19:36 EDT (-0400)
  Another game question (Message 28 to 37 of 37)
Subject: Re: Another game question
Date: 20 Aug 2008 06:41:02
Message: <48abf4be$1@news.povray.org>
>> Uh-huh. And you understand that your monitor only physically draws 60
>> frames each second anyway, right?
> Not if you still have a CRT, my old CRT used to go up to 120 Hz and man
> that looked smoooooooth if you could get a game running at 120 Hz (and
> yes, you can tell the difference between 60 and 120 Hz refresh, IIRC
> above about 85 Hz you don't notice any difference).
Well let me put it this way: *I* can't tell the difference between 50
Hz, 60 Hz and 75 Hz. They all look the same to me.
http://blog.orphi.me.uk/
Date: 20 Aug 2008 06:43:42
Message: <48abf55e@news.povray.org>
>> The fact of the matter is, if you were on an island surrounded by
>> highly trained mercinaries and you were armed only with a pistol, you
>> wouldn't last five seconds.
> But you're a highly trained military type guy too, and you're taking
> them all by surprise.  Besides, it's not like they have an army
> anywhere, there's rarely more than a dozen of them in one area or more
> than a couple standing next to each other.  And once you've shot one of
> them, you have the same gun they do ;-)
I double you'd last long against sniper rifles and rocket launchers. ;-)
Actually, I'm waiting for the day when computer games will portray this
realistically. It's like HL2:DM. 12 guys run around inside a crumbling
dungeon hurling grenades and using rocket launchers. And after 20
minutes, the map itself just has a few bullet holes. Obviously, if you
did this in a *real* crumbling dungeon, there would be walls missing and
so forth! But no game seems to have managed to do this yet... Presumably
having a completely deformable map is just too much of a technical
challenge right now.
Date: 20 Aug 2008 06:53:03
Message: <48abf78f$1@news.povray.org>
>> man that looked smoooooooth if you could get a game running at 120 Hz
>> (and yes, you can tell the difference between 60 and 120 Hz refresh,
>> IIRC above about 85 Hz you don't notice any difference).
I always kept my CRTs running at above 60Hz. For some reason, staring at
60Hz or lower just makes me queezy.
Date: 20 Aug 2008 10:15:55
Message: <48ac271b$1@news.povray.org>
Invisible wrote:
>>> I get around 10 to 18 fps which is 'playable'.
>> o_O
> You've never played Quake II on a Pentium 233 MHz with 16 MB RAM and no
> 3D hardware, have you?
No, but only because I never *had* a Pentium 233 :)  I went straight
form a Pentium 166 to an AMD K6-2 300 (or 350, can't remember now).
>> Anything less than 30 consistently gives me rather bad headaches.  I
>> try to keep things running at 50+, though (obviously, 75+ is best, but
>> not feasible for me on modern games).
Actually, it draws 75 per second :)
Besides, this is something I've found I'm more sensitive to as I age.
Sure, I *used* to play all those old games that ran at, like, 20-30fps,
but I can't *anymore*.
...Chambers
Date: 20 Aug 2008 10:17:59
Message: <48ac2797$1@news.povray.org>
Wasn't there one a few years ago, Red Storm or something like that?  It
was, IIRC, made by a group of Russion grad students, and the story was
about miners on Mars revolting.
Completely deformable maps.  The demo let you blow a house to pieces,
and make a larger and larger crater as you threw rockets at it :)
...Chambers
Date: 20 Aug 2008 10:23:28
Message: <48ac28e0$1@news.povray.org>
>> this realistically. It's like HL2:DM. 12 guys run around inside a
>> crumbling dungeon hurling grenades and using rocket launchers. And
>> after 20 minutes, the map itself just has a few bullet holes.
>> Obviously, if you did this in a *real* crumbling dungeon, there would
>> be walls missing and so forth! But no game seems to have managed to do
>> this yet... Presumably having a completely deformable map is just too
>> much of a technical challenge right now.
Actually, thinking about it... LEMINGS!!
Date: 20 Aug 2008 11:34:53
Message: <48ac399d$1@news.povray.org>
http://hlcomic.com/index.php?date=2006-07-17
But nobody would play a realistic video game. Most people don't have the
training to play a realistic video game. And you'd need a whole bunch of
people together to do it properly.  (Think Quake II, where the first
thing that happens is you're cut off from all your teammates, and you go
the whole rest of the game without meeting anyone else.)
A realistic video game is "Boom! Headshot!  Game over, and you don't get
to play again."
Date: 20 Aug 2008 11:48:54
Message: <48ac3ce6$1@news.povray.org>
> to play again."
You just described Insurgency.
You get to play again, but other than that it's just like a real war -
i.e., not fun. It takes hours to walk anywhere. You can only run for a
few seconds before you get breathless. When you're breathless, your aim
is even more horrible than usual. There is no crosshair on the screen.
You *can* look down the barrel of the gun, but then you can't see
anything around you. And the gun dances all over the place as soon as
you pull the trigger.
Most importantly, you wander around for hours not seeing any other
players. You can *hear* gunshots coming from somewhere, but there are no
people. At some point, as you walk towards the sounds of gunfire, you
will suddenly drop dead for no apparent reason. The problem is that 4.8
miles away, there's a sniper hidden behind some bushes. (This is
probably beyond the max draw distance of the game engine.)
In short, it's a game that must have taken a vast amount of time and
effort to develop (it's a community mod, not a commercial game), but
it's completely boring and pointless. You just walk around until you
drop dead. You won't even *see* another player to actually shoot at.
You'll just drop dead suddenly.
It *does* have one redeeming feature though: If you play as US Marines,
when you reload this gaunt voice mumbles "changing mags". If you play as
the Iraqui Insurgents, an Arabic voice yells "rrrrrreloading!"
Funniest. Thing. Ever!
Date: 21 Aug 2008 05:15:01
Message: <48ad3215$1@news.povray.org>
> ...Chambers
I think the game you mean is Red Faction. It wasn't completely
deformable, though. There were sections of walls that could be blown up,
parts of a hallway wall could be knocked down with just grenades, others
would seem to be impervious to everything short of a rocket launcher.
It was a pretty good change to gameplay when it was released. I remember
a few LAN games when someone would find a new part of the wall that
could be removed, and gain a sudden advantage.
Date: 22 Aug 2008 00:38:49
Message: <48ae42d9$1@news.povray.org>
Sabrina Kilian wrote:
>> It was, IIRC, made by a group of Russion grad students, and the story
>> was about miners on Mars revolting.
>> ...Chambers
Ah yes, that's the one :)
I never played the retail game, though.  I might have to get around to that.
...Chambers
