POV-Ray : Newsgroups : povray.off-topic : Question about garbage collection (not a flame) Server Time
27 Jul 2026 10:40:09 EDT (-0400)
  Question about garbage collection (not a flame) (Message 21 to 24 of 24)
Subject: Re: Question about garbage collection (not a flame)
Date: 1 Apr 2008 12:05:45
Message: <op.t8xy3ubv7bxctx@e6600.bredbandsbolaget.se>
On Tue, 01 Apr 2008 11:08:34 +0200, Warp <war### [at] tagpovrayorg> wrote:
> Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
>> That stack allocation is fast should come as no surprise since it
>> typically requires a grand total of zero additional CPU instructions. In
>> the worst case it requires a single one-cycle instruction.
>   But so does using a pre-allocated array. The array is *already*
> allocated.
> The function doesn't need to allocate it each time. Yet, in some cases,
> the function becomes faster by using the stack-allocated array than the
> pre-allocated array in the heap.
Two points to consider:
- Data locality
Allocating the array from the stack keeps it close to the local variables,
thus confining memory accesses to a smaller area. This plays better with
memory caches.
- Register contention
Accessing a heap-allocated array requires loading its address into a CPU
register. Accessing a stack-allocated array can be done with the stack
register, freeing other registers for use in calculations.
FE
Date: 1 Apr 2008 14:52:22
Message: <47f29276$1@news.povray.org>
Warp wrote:
>   How is that nondeterministic? It's perfectly predictable when those
> objects will be destroyed. Just because destroying one object causes
> the destruction of another doesn't make it "nondeterministic".
You can't tell by looking at
   a = null;
how long it will take to execute that statement.
It depends entirely on how long the system has been running, how much
data is hanging off pointers in "a", and so on. I.e., you get the same
sort of stop-and-wait-for-GC that you get with mark-and-sweep.
This is usually people talking about things close to real time but not
critical enough to actually figure out how long it would take, like
games and such.
If "a" points to a parsed XML file read from a file specified by the
user, you don't know how long it'll take to collect it, as an example.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 1 Apr 2008 18:37:28
Message: <47f2c737@news.povray.org>
>    a = null;
  By the same logic something like 'printf("Hello\n");' is nondeterministic
because I can't know how long it will take. It could take hours for all
I know.
  The subject was about deterministic object destruction, not deterministic
runtime.
Date: 1 Apr 2008 19:27:16
Message: <47f2d2e4$1@news.povray.org>
> runtime.
No, actually, my comment was
    That's where the "nondeterministic time" comes in with reference
    counting, just so you recognise.
*I* was talking about the fact that people discussing real-time GC don't
like reference counting because you have to run an arbitrarily large
number of links to reclaim memory.
When it happens is deterministic. How long it takes is (while
deterministic) too complicated to calculate reliably.
