POV-Ray : Newsgroups : povray.object-collection : Set of scalable colormaps recommended for scientific visualisation Server Time
15 Sep 2025 08:04:39 EDT (-0400)
  Set of scalable colormaps recommended for scientific visualisation (Message 1 to 9 of 9)
Subject: Set of scalable colormaps recommended for scientific visualisation
Date: 19 Feb 2023 18:29:46
Message: <63f2b0ea@news.povray.org>
This is a set of ready-to-use colormaps, each contains 256 colors. Most
of them exported from Matlab, other from this page:
https://www.kennethmoreland.com/color-advice/
Color information stored in 2D array, colormaps are generating by the
macro, allowing re-scaling and applying desired transparency.
Usage examples also present.
Download: https://github.com/syanenko/Colormaps
YB
Download 'list.png' (74 KB)
Preview of image 'list.png'
Subject: Re: Set of scalable colormaps recommended for scientific visualisation
Date: 19 Feb 2023 20:50:25
Message: <63f2d1e1$1@news.povray.org>
I see no mention of gamma in Mr. Moreland's article, nor in any of the
papers he linked.  Online colors are typically sRGB or gamma 2.2 (with
good reason), but your tool is set to gamma 1.0 (also with good reason),
and there are no srgb keywords or exponentiation in your code.  In the
absence of documentation to the contrary, color definitions tend to
default to sRGB, often simply because the author is completely unaware
that color non-linearity is a thing.  How can we be sure that you have
interpreted Mr. Moreland's colors correctly?
I am unfamiliar with MatLab.  Does it address color gamma?
Subject: Re: Set of scalable colormaps recommended for scientificvisualisation
Date: 20 Feb 2023 05:06:44
Message: <710228e9-9917-2c5b-9e0d-c7c21533e12e@gmail.com>
> papers he linked.
Hi Cousin,
Thanks for your comment and interesting question. I am not sure that
gamma correction is so important for scientific visualization. This is
not photography, where we trying to achieve highest realistic level,
colors only helps to interpret model more accurate, they are
'suppositive' here.
I any case, if someone need it, he can implement macro, processing data
array according his requirements (thanks to Bald for advice to store
data separately of their interpretation).
As to Matlab, yes, it has methods for gamma correction, but not at
colormap, but at image level:
https://www.mathworks.com/help/images/ref/lin2rgb.html
YB
Date: 1 Mar 2023 13:00:00
Message: <web.63ff91b82f3c3b63bebf0bf589db30a9@news.povray.org>
Hi YB
It's good that you have now included a license file in this repository and that
you mention where the color maps came from.
But are you sure that the "GNU Affero General Public License v3.0" compatible
with the licenses from the initial authors?
And are you aware that this license is more strict than the original licenses
that came with some of the color maps?
Also, I think that the original authors will appreciate it if you give them some
credit by mentioning their names somewhere in the code or on the repository
page.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 1 Mar 2023 13:25:13
Message: <79c34d03-6315-1a2e-1294-f3503ff3be50@gmail.com>
Hi, Tor.
Thank you for pointing me to this potential problem, I thought about it,
but unfortunately too far from licensing details. If you have more info
about that, maybe you can suggest to me the license that will 'best-fit'
to this publication ? If not, I will need to explore this area more
seriously.
> page.
This is a good idea, will do it for sure.
All the best,
YB
Date: 1 Mar 2023 19:35:00
Message: <web.63ffebac2f3c3b63383c879289db30a9@news.povray.org>
> Hi, Tor.
> seriously.
Note that I'm not claiming that there is a problem - and I do not know
much about copyright law.
I was just a bit surprised when I saw that license, since the license
for Inferno, Plasma and Viridis seems to be CC0 (i.e. no copyright).
https://github.com/BIDS/colormap
http://creativecommons.org/publicdomain/zero/1.0
Inferno and Plasma was made by Stefan van der Walt and Nathaniel Smith,
while Viridis was made by Eric Firing and then modified by Stefan van
der Walt and Nathaniel Smith.
I recommend that you try to find the original author of each of the
other color maps and then try to find out if they specified any
licenses for their code. - Yes; that is probably a lot of work with
that many color maps.
Here's a Wikipedia page that might be useful for you, especially the
section about compatibility, if you are going to use licenses that are
different that the ones the original authors specified:
https://en.wikipedia.org/wiki/Open-source_license
Tor Olav
http://subcube.com
Date: 1 Mar 2023 19:51:52
Message: <817f547d-528c-64bf-c632-a28b5d034045@gmail.com>
Thanks a lot for this info, I had to find it myself, not you :)
Agree with you, this work should be done, it's better to do everything
correctly.
Thanks again, I will read it, in any case it's better to know all
licensing rules for the future.
YB
Date: 2 Mar 2023 16:16:18
Message: <64011222@news.povray.org>
It may not make much practical difference, but this is better phrased as
"copyright waived."  In some jurisdictions it is not legally possible to
give up your copyright, thus the need for dedication licenses such as CC0.
Date: 3 Mar 2023 09:40:00
Message: <web.6402062f2f3c3b63d105cea189db30a9@news.povray.org>
I think that this is a rather strange license.
IIRC Norway is such a jurisdiction where it's not possible to
renounce one's copyright.
On the Wikipedia page I linked to there's a "Open-source software
licenses and how they interact" diagram. If I interpret this
diagram correctly, then it seems that it is actually ok to use
LGPL for works derived from something in the public domain.
Tor Olav
http://subcube.com
