POV-Ray : Newsgroups : povray.newusers : How can I fix surface perfections on my render? Server Time
30 Mar 2026 02:04:26 EDT (-0400)
  How can I fix surface perfections on my render? (Message 1 to 10 of 14)
Subject: How can I fix surface perfections on my render?
Date: 9 May 2020 19:45:01
Message: <web.5eb73fc759256ef14eff8dd80@news.povray.org>
Hey all. Just started using POV-Ray with FreeCAD. I'm trying to render a solid
assembly, and so far have had reasonable success. The issue I'm facing is that
the output surface has a lot of imperfections around edges. You can see what I
mean here:
https://i.imgur.com/jmSYFlA.png
I've played around with a bunch of settings, but nothing seems to work. Here's
my current .ini settings:
        Input_File_Name="tester.pov"
        Width=1600
        Height=1200
        Output_Alpha=true
        Antialias=On
        Antialias_Threshold=0.05
        Output_File_Type=N
        Initial_Frame=1
        Final_Frame=20
        Subset_Start_Frame=1
        Subset_End_Frame=20
Here's the .pov template:
            // Persistence of Vision Ray Tracer Scene Description File
            // for FreeCAD (http://www.freecadweb.org)
            #version 3.6;
            #include "metals.inc"
            #include "rad_def.inc"
            global_settings {
                radiosity {
                    Rad_Settings(Radiosity_Normal,off,off)
            #default {finish{ambient 0}}
            sky_sphere {
                    gradient y
                    color_map {
                        [0.0  color LightGray]
                        [0.3  color White]
                        [0.7  color LightGray]
            // Standard finish
            #declare StdFinish = finish { crand 0.01 diffuse 0.8 };
            //RaytracingContent
            //default light
            light_source {
                cam_location
                color White
                area_light <100, 0, 0>, <0, 0, 100>, 10, 10
                adaptive 1
                jitter
Finally here's the camera view in FreeCAD:
        // Generated by FreeCAD (http://www.freecadweb.org/)
        #declare cam_location =  <427.57,263.719,-212.527>;
        #declare cam_look_at  = <59.4051,145.125,-29.1809>;
        #declare cam_sky      = <-0.271638,0.959461,0.0751569>;
        #declare cam_angle    = 45;
          location  cam_location
          look_at   cam_look_at
          sky       cam_sky
          angle     cam_angle
          right x*800/600
Any tips would be appreciated!
Subject: Re: How can I fix surface perfections on my render?
Date: 9 May 2020 20:00:00
Message: <web.5eb743e649257b65fb0b41570@news.povray.org>
"circuit" <nomail@nomail> wrote:
Update to #version 3.8 if at all possible.
I truly don't know squat about aa settings, but maybe try 0.3 - which seems
standard.
>             // Standard finish
Get rid of crand.  _Especially_ if you're doing an animation.
Diffuse seems a bit high, I might be tempted to add a touch of specular
(0.1-0.2), but that's inconsequential to your problem.
>             //default light
>             light_source {
>                 cam_location
>                 color White
>                 adaptive 1
>                 jitter
That seems - excessive?  Especially for a simple render.
And it might have something to do with the weird look.
Just use a standard point light source, and you'll get adequate lighting and
good shadows.
Hard to really say what other potential problems may be without seeing the scene
as a whole.   You can post .pov files in the scene files section if the above
doesn't fix anything.
Date: 9 May 2020 20:47:22
Message: <5eb74f1a$1@news.povray.org>
> mean here:
Without seeing the whole scene description file, it's hard to say, but
the "imperfections" in the image look like radiosity artifacts.  The
setting Radiosity_Normal uses:
   count 200
   error_bound 0.3
   pretrace_end 0.01
Increasing count will always improve radiosity, but tweaking the other
settings can often get the job done more efficiently.  A pretrace_end of
0.01 seemed fine for POV-Ray 3.6, which is what the scene file was
designed for; but if your POV-Ray installation is 3.7 or later, 0.01 is
inadequate.  The rad_def.inc settings were not updated in the 3.7 update.
These settings are usually good enough in my experience:
   error_bound 0.5
   pretrace_end 2 / max (image_width, image_height)
   recursion_limit 2
If there are still artifacts, try changing pretrace_end to:
   pretrace_end 1 / max (image_width, image_height)
P.S. As long as your scene file starts with #version 3.6; and uses
radiosity, all ambients on non-glowing objects should be set to zero.
If your objects and textures have ambients individually applied, and
none of your objects glow in the dark, this is easily done with
global_settings { ambient_light 0 }.  If you do have glowing objects,
you cannot change the global ambient_light; you must instead use
#default { finish { ambient 0 } }, and delete or override any ambients
on non-glowing objects and textures.
Date: 9 May 2020 23:00:00
Message: <web.5eb76d4d49257b654eff8dd80@news.povray.org>
Thanks for the tips. I made adjustments based on your feedback. I also messed
around with the radiosity settings according to
http://wiki.povray.org/content/HowTo:Use_radiosity and the combination seems to
have done the trick! Here's what I have so far:
https://i.imgur.com/PUAURpc.gifv
I seem to have some issues with the rear spindle flashing when the wheel is
given transparency. How can I prevent this? I'm not sure how to attach files, so
I uploaded one animation frame's .pov content here (I can uploaded all 20 if
needed):
https://pastebin.com/4euSmKWH
Here's the contents of .ini:
Width=1600
Height=1200
Output_Alpha=true
Antialias=On
Antialias_Threshold=0.3
Output_File_Type=N
Initial_Frame=1
Final_Frame=20
Subset_End_Frame=20
Thanks again!
Date: 10 May 2020 08:10:00
Message: <web.5eb7ee7149257b65fb0b41570@news.povray.org>
I also messed
Ah yes - Ricky, that was a good catch with the radiosity.   I've seen it before,
but I don't use it often enough, nor as often as I should  ;)
It's hard to tell with so few frames, but:
You may be casting a shadow onto that with your 3-armed object.
add no_shadow to whichever part it is
mesh2 {Part39 no_shadow} and see if that fixes it.
or you could add the "shadowless" keyword to your light_source definition and
that won't cast any shadows for anything.
Later, if you want shadows, but don't want THAT shadow, you may have to split
the scene into different "light groups" or something else.
That _looks_ to me like it could be partly the dreaded "coincident surface"
problem.
You need a tiny amount of space (> 0.000001 POV units) between scene elements
otherwise how does the renderer "know" which texture to make the pixel where 2
objects are that occupy the same pixel?  There's some digital/coding/floating
point error that plays into that that needs to be accounted for, thus the 1e-6
value as insurance against it.
I think if you're just adding a transmit value, that should be ok.  If you use
filter instead, then you will get oscillations when the thick and thin parts
move across that back piece.  Twice the thickness = twice the filtering.
Also, for preliminary developmental purposes, you may want to decrease the size
of your renders, say to 640x480 or even 320x240, and then crank up the number of
frames you render to give a much smoother animation.   I'd shoot for at least 15
FPS or above for the final render.
The way this whole thing is set up, you need to use one of the sections that
allows attachments.    povray.binaries.images (p.b.i) is the usual spot.
http://news.povray.org/povray.binaries.images/
Typically, the best way to link threads and perhaps shift the discussion over
there is to post the image first, wait for a bit for the server to process the
image, and then go to your post and copy the link and paste it here in your next
post.
It's looking good so far  :)
Are you running windows?
I know that some folks on here are looking for a functioning modeler, as well as
a way to export to .stl for 3D printing, and they may be interested in how to
set up FreeCAD and what its capabilities are.
Date: 10 May 2020 11:11:11
Message: <5eb8198f$1@news.povray.org>
> needed):
You appear to be using the Web interface, and the Web interface does not
allow attachments in povray.newusers.  You can post attachments in
newsgroups with "binaries" in their name, such as
povray.binaries.scene-files and povray.binaries.images.  A newsreader
app can post attachments to any newsgroup, but that is considered bad
netiquette.
Date: 10 May 2020 12:18:48
Message: <5eb82968$1@news.povray.org>
> standard.
That antialias setting is ok for final renders. A good compromise would
be something like 0.1.
>>              // Standard finish
I agree.
>>              //default light
>>              light_source {
>>                  cam_location
>>                  color White
>>                  adaptive 1
>>                  jitter
> good shadows.
Yes, should use adaptive 0
Date: 10 May 2020 12:29:08
Message: <5eb82bd4$1@news.povray.org>
>> a solid
>> is that
>> see what I
>> mean here:
>    count 200
>    error_bound 0.3
>    pretrace_end 0.01
They where not even updated for version 3.5, only the version directive
got updated. They are based on early 3.3, or maybe even older.
That include is in desperate need of a complete overhaul.
Before version 3.5, low_error_factor defaulted to 0.8. Starting with
version 3.5, the default low_error_factor is 0.5. red_def.inc use that
old 0.8 value as a base.
>    error_bound 0.5
>    recursion_limit 2
> radiosity, all ambients on non-glowing objects should be set to zero. If
> your objects and textures have ambients individually applied, and none
With version 3.7 and later, there is no need to set ambient to zero as
all ambient become zero when radiosity is used.
You need to use emission for glowing objects.
Date: 10 May 2020 13:09:58
Message: <5eb83566@news.povray.org>
>>>              //default light
>>>              light_source {
>>>                  cam_location
>>>                  color White
>>>                  adaptive 1
>>>                  jitter
>> lighting and
>> good shadows.
That depends on the scene.  I've had some scenes for which adaptive 0
was fine, and others for which the result was hideous.
Date: 11 May 2020 03:20:01
Message: <web.5eb8fc1849257b654eff8dd80@news.povray.org>
Wow, this community is awesome. I appreciate all the responses.
> problem.
100% sure it's a coincident surface issue. In fact, similar artifacting also
exists in FreeCAD's rendered output. Here's an animation using FreeCAD
"activeView":
https://i.imgur.com/zljJarj.gifv
This is actually not my model... it's just the first demo file I found online
that had assembly constraints, so I ran with it. I have no idea if it was
designed properly. I plan on testing this out more thoroughly with a model I
build myself.
For sure. Here's a smoother animation! This time at 20 fps:
https://i.imgur.com/6c3mLUn.gifv
It's definitely a lot quicker to render this way. I took me around 2 minutes for
the 50 frames on my i5 laptop.
I am on Windows, yup, although I've played around with a few Linux distros in
the past :) I'm by no means a modeller though. I come from an electrical
background, but I have a strong interest in robotics. My plan is to use FreeCAD
to design and simulate (animate) robotic gait. Then of course, once I'm happy,
I'll 3D print the end result. POV-Ray just makes the animation quite a bit
nicer.
From my limited exposure, I'm really liking FreeCAD. I've used Fusion 3D and
Solidworks in the past, and sure, FreeCAD is not quite as polished, but it one
really great thing going for it: Python scripting. The possibilities are
limitless. Other than that, FreeCAD seems to be just as capable as the others
(but once again, I'm not a power user).
I'm happy to help provide guidance if other wants to delve into the tool.
I like output a lot better with this change. Edges are better defined.
Cheers everyone.
