POV-Ray : Newsgroups : povray.newusers : orthographic camera and conic_sweep object Server Time
18 Mar 2026 01:28:45 EDT (-0400)
  orthographic camera and conic_sweep object (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: orthographic camera and conic_sweep object
Date: 5 Nov 2017 20:10:00
Message: <59ffb668$1@news.povray.org>
Fixed in POV-Ray v3.8.0 (currently under development). If you dare, try
the binaries available at:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.9387404
(Make sure to name them differently than the original v3.7 binaries. It
should also be possible to extract them to a different directory and run
them from there.)
Date: 6 Nov 2017 14:05:00
Message: <web.5a00b1bec65a78b4ca73ee9d0@news.povray.org>
> them from there.)
Yes, I will try to install povray 3.8.0, why not...
I gathered informations with an old file I kept, named 'config.log' that
contains among others, differents variables/values a user can change before
compile time especially when inputing './configure' at the prompt/terminal.
Until someone will tell me I'm wrong , I think that the variables used to name
the final binary are 'PACKAGE' or/and 'PACKAGE_TARNAME' (they both contain
'povray' )but I'm not sure.
If you can give me some advice about that, I'll be glad. :-D
I discovered POVRay in 1997 in a magazine that came with a CD-Rom (that was the
2 second version under MS-DOS: v2.x) All I had as a CPU was an Intel 486 SX2
(yes, without a mathematic coprocessor :-( ). For a scene equivalent to the one
above with the conic_sweep, the render took about 6 hours, I quickly gave up
making scenes (I didn't use editor with the Scene description language, but a
software with iron wire interface with 4 windows named 'POVSB' (under windows
3.1) or something like this. I began learning the SDL later in 2007 until now.
Nostalgia... :-D
Date: 6 Nov 2017 16:41:49
Message: <5a00d71d$1@news.povray.org>
> (yes, without a mathematic coprocessor:-(  ). For a scene equivalent to the one
> Nostalgia...:-D
It took you long enough to drop in. ;-)
Welcome.
Regards
Date: 6 Nov 2017 18:26:21
Message: <5a00ef9d$1@news.povray.org>
Am 06.11.2017 um 20:02 schrieb Warren:
>> them from there.)
> Hi,
Oh wait... you're running Linux? Well, then it's a lot simpler: Just
download the tarball and proceed as usual (prebuild, configure, make,
install), this'll give you a POV-Ray installation living in an entirely
separate set of directories (with `3.8` in the name, as opposed to
`3.7`). Unless you're configuring to install in a custom directory anyway.
For Windows it's a bit more complicated since users don't usually build
their own binaries there. So for the users' convenience we provide
pre-built Windows binaries, but for our own convenience we don't provide
complete installer packages. So the binaries need to "piggyback" on an
existing installation.
> Nostalgia... :-D
I see your 1997 CD-ROM and raise you a ca. 1995 copy obtained via FidoNet.
(I'm cheating a bit though: I never did a lot with POV-Ray back then,
and only re-discovered it in 2008.)
Date: 7 Nov 2017 11:40:05
Message: <web.5a01e0d0c65a78b4ca73ee9d0@news.povray.org>
After a quick research for the 'ca' term, I see that it means 'approximately'
(circa) and that's true, the magazine and the CD-Rom in question was sold in
december 1995 it was named "Sciences et Vie Micro - Villagina 3". The 24 bits
Targa files rendered with POVRay definitely caught my fancy by comparison with
the 256 colors of the Windows 3.1 standard desktop.
I notice your message about 3.8.0 POVRay setup under Linux. Thank you ;-D
Date: 7 Nov 2017 12:30:00
Message: <web.5a01ec7cc65a78b4ca73ee9d0@news.povray.org>
> > [About Linux and povray setup ]
I did some research on my computer about the povray 3.7 binary and remembering
your message I get a result (in the Terminal) that doesn't match what you said
Here's the Terminal and the output of some command (I use Ubuntu 16.xx as Linux
only)
antoine@antoine-pcmapex:/usr/local/bin$ ls -lArth
total 9,6M
-rwxr-xr-x 1 root root 3,2M juin  25  2016 povray
-rwxr-xr-x 1 root root 2,7M avril 29  2017 geomorph
antoine@antoine-pcmapex:/usr/local/bin$ which povray
/usr/local/bin/povray
antoine@antoine-pcmapex:/usr/local/bin$ which ls
/bin/ls
antoine@antoine-pcmapex:/usr/local/bin$ cd ..
antoine@antoine-pcmapex:/usr/local$ ls
bin  Brother  etc  games  include  lib  man  sbin  share  src
antoine@antoine-pcmapex:/usr/local$ cd share
antoine@antoine-pcmapex:/usr/local/share$ ls
Aria  ca-certificates  doc  emacs  fonts  geomorph  locale  man  povray-3.7
SFML  sgml  timidity  xml
antoine@antoine-pcmapex:/usr/local/share$ cd povray-3.7/
antoine@antoine-pcmapex:/usr/local/share/povray-3.7$ ls
icons  include  ini  scenes  scripts
--------------------end
As you can see there's a povray (3.7) binary in '/usr/local/bin/' and that
doesn't look to be a link file (the weight is about 3.2 Mo). I do have a
'povray-3.7/' directory in '/usr/local/share/' but there's no any binary file in
it.
The following input command in a Terminal show:
antoine@antoine-pcmapex:/usr/local/bin$ ./povray --version
POV-Ray 3.7.0.unofficial
This is an unofficial version compiled by:
 Antoine FAURE
 The POV-Ray Team is not responsible for supporting this version.
Copyright 1991-2013 Persistence of Vision Raytracer Pty. Ltd.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Built-in features:
  I/O restrictions:          enabled
  X Window display:          enabled (using SDL)
  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  x86_64-unknown-linux-gnu
  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++-5 5.3.1
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
----------------------------------------------------end
This is the binary I have compiled some time ago (Antoine FAURE)
I don't seem to have the custom directory for the different versions of POVRay
you're talking about...
And doing some search with : 'sudo find / -name "povray" -type f' only displayed
 the '/usr/local/bin' file
Date: 7 Nov 2017 13:14:14
Message: <5a01f7f6$1@news.povray.org>
hi,
> only)
> total 9,6M
-----<snip>-----
that all looked alright at first glance.  the executable is always (I
think) simply povray, so on my machine I renamed the executable after
install to povray37 (alongside povray36).
IIUC, that's a misunderstanding.  everything except the program is in
versioned (sub)directories.  hth.
regards, jr.
Date: 7 Nov 2017 19:05:00
Message: <5a024a2c$1@news.povray.org>
Am 07.11.2017 um 18:25 schrieb Warren:
Goes to show how well I know the Linux version... not. (*sigh!*)
Guess you'll need to use the `--prefix=PREFIX` configure option then.
See `./unix/install.txt` (or `./INSTALL` after the prebuild step).
Date: 8 Nov 2017 10:50:52
Message: <5a0327dc$1@news.povray.org>
Perhaps the following newsgroup post from this summer also of help:
http://news.povray.org/povray.beta-test/message/%3C5950ff4b%40news.povray.org%3E/#%3C5950ff4b%40news.povray.org%3E
Keep in mind it was written when the current 3.8.0 was called 3.7.1.
If you are not dependent on changes in the shipped include/ini files
between versions, you can do compiles for whatever version you have
downloaded/grabbed/modified via github/git and on success, copy the
final binary in <sourceInstall>/unix/povray to your $HOME/bin directory
as povray38, povrayIdea57 or whatever(1) and use that command over
'povray' when you run. $HOME/bin needs to be in your $PATH environment
variable.
Day to day I mostly use this latter method over the more complete
--prefix method. The disadvantage is the $HOME/bin/<povrayVersion>
method will use for includes/ini and home directory defaults whatever
the previous, matching 3.7 or 3.8 machine/user install. Whether the
executable looks for 3.7 or 3.8 defaults depends upon the version of the
code branch being compiled.
Aside: The 'elsewhere' part of './unix/install.txt' "3.1.3 Building
in-place or elsewhere" was not working the last I tried such a compile
earlier this year & expect it's still not.
Bill P.
(1) - Yep, I'm lying in the first 3.8 use case. One needs to have
installed the 3.8 version on your machine - at some point - no matter
what is left as your 'povray' system default/last install. Otherwise the
$HOME/bin/<povrayVersion> program won't find the default 3.8 directories
and files.
Or
To avoid overwriting the 3.7 executable in /usr/local/bin/povray during
a 'make install' of a 3.8 distribution, the environment variable POVINI
can be set to point to a specific ini file with Library_Path=...
settings to directories such that 3.8 executable - say
'$HOME/bin/povray38' - will run with the old 3.7 install getting only a
warning about no system 3.8 conf file. It will, so long as you at some
point create local the $HOME/.povray/3.8 directory and files matching
what you have already for $HOME/.povray/3.7.
Date: 8 Nov 2017 14:45:24
Message: <5a035ed4$1@news.povray.org>
Am 08.11.2017 um 16:50 schrieb William F Pokorny:
Yes; and that might make it difficult to apply the approach: The v3.8
binary would try to read user-specific files from `~/.povray/3.8` which
would have been installed in `~/.povray/3.7`.
