POV-Ray : Newsgroups : povray.newusers : Reflect light inside box Server Time
22 Jan 2025 03:14:02 EST (-0500)
  Reflect light inside box (Message 1 to 10 of 18)
Subject: Reflect light inside box
Date: 10 Dec 2012 15:45:00
Message: <web.50c6497b5da86ae0e6e840160@news.povray.org>
I'm trying to draw a box, where the bottom half of the side of the box facing
the light source is cut away, allowing the light to enter the box. I've tried
using clipped_by and difference, and a few other things, but nothing is really
working. Probably because I have no idea what I'm doing. Can someone provide
some guidance?
Thanks in advance.
Rhonda
Here's the current, non-working version of my code:
background { color Blue }
    location <0, 10, -50>
    look_at  <0, 0,  20>
box {
    < -10,  0,  0>,   // left corner
    <10, 20,   20>  // right corner
   hollow
      Aluminum
 pigment { color Green }
 interior
 { ior 1.5
      finish {
       reflection {
   0.9, 1.0
   fresnel on
   metallic on
     clipped_by { box {
       <-9,1,0>,<9,10,1 >
rotate y*20
light_source { <5, 20, -30>
 color White
Subject: Re: Reflect light inside box
Date: 10 Dec 2012 16:45:43
Message: <50c65807@news.povray.org>
> some guidance?
> Thanks in advance.
> Rhonda
> camera {
>     look_at  <0, 0,  20>
> box {
>    hollow
>     texture {
>       Aluminum
>  interior
>  { ior 1.5
>       finish {
>        reflection {
>    0.9, 1.0
>    fresnel on
>    metallic on
>      clipped_by { box {
>        <-9,1,0>,<9,10,1 >
> rotate y*20
>  color White
your "clipped_by" needs to be bigger
What ever in Not in the 'clipped_by' get cuts off
When I use a box to clipped a box I just copy values front the box I
want to clip put in the 'clipped_by ' statement then and 1 to each
number the vectors. Except the on I want to cut off!
try:
      clipped_by { box {
        < -11,  -1,  0>,<11, 21,   21>
Have Fun!
Date: 10 Dec 2012 16:53:36
Message: <50c659e0$1@news.povray.org>
> some guidance?
> Thanks in advance.
Join the club Rhonda. :-)
Primitives in PovRay are solids (sometime they are only surfaces o_O)
So what you need to do is make a box with six thin boxes. forming the
walls, floors and ceiling. Use a union to join them then difference that
with another box.
You only need to use the keyword "hollow" if you are going to fill it
with media, such as scattering if you want to see the light.
I hope that helps and welcome.
Regards
Date: 10 Dec 2012 21:26:38
Message: <50c699de@news.povray.org>
> some guidance?
> Thanks in advance.
> Rhonda
><code clipped>
Your box is solid. If you do a difference or intersection, the resulting
shape is always closed.
You missuse the "hollow" keyword. It's a very common mistake. The
purpose of hollow is to enable the existance of some media in the
object. Otherwise, it have absolutely no effect. Also, the hollow, media
containing object normaly need to be transparent so that the media is
visible.
As have been said, clipped_by remove whatever is outside the clipping
object. You can reverse that by using the "inverse" keyword that reverse
the insideness of any object.
clipped_by{box{-1,1 inverse}} can be used to punch a hole in any object.
Here, {-1,1} is promoted to {<-1,-1,-1>,<1,1,1>}.
Your use of interior is OK.
When present, fresnel and metallic default to on. You don't need to
explicitely specify it. They default to off when NOT present. metallic
can use a float value from zero to whatever you want, but normaly no
larger that 1.
Using color in the colors definitions and application is mostly a legacy
thing and not needed.
pigment{ color Red } does exactly the same thing as pigment{ Red }.
Another thing you can do is to model a box with a thickness using a
difference:
difference{
  box{< -10,  0,  0>,<10, 20,   20>}//outside of the box
  box{<-9.6,0.4,0.4><9.6,19.6,19.6>}//inside of the box
// the walls now have a thickness of 0.4 unit
  box{<-9,1,0.4>,<9,10,1 >}// the opening
  texture{pigment{rgb<0.1,1,0.2>}finish{reflection{0.3, 1 fresnel
metallic}specular 1 roughness 0.1}
Now, the light comming into the opening will not actualy reflect in the
box. The highlight will reflect, but not the incoming light. For that,
you need to use the photons feature.
Add:
global_settings{photons{spacing 0.1}}
This turn on the photons feature.
You may also use count Value. Don't use both spacing and count.
With spacing, a small value increase the total number of photons shot.
Small values increase the quality.
With count, you specify a target number of photons to shoot. Large value
In the object definition, add, just before the closing bracket:
photons{target reflection on}
This allow photons to be shot at the object and reflect off it.
As your object is not transparent, you can leave refraction to it's
default of off.
You DON'T need to add any photons{} block to any light_source.
Now, another trick: Use the object pattern.
Change your texture as follow:
texture{
  object{box{<-9,1,0.0001>,<9,10,1 >}Your_texture, pigment{rgbt 1}}
All points outside the box will receive Your_texture and points inside
if it will be totaly transparent.
"Your_texture" been the texture you use now.
This will "paint" a transparent area in your box.
I replaced the zero by 0.0001 so that the opening will only show into
the side and not the floor of the box.
Date: 11 Dec 2012 14:35:01
Message: <web.50c789d7cf1ff5fee6e840160@news.povray.org>
This is all really helpful, thank you. I think I'm making progress. I still have
a few issues.
This is what I now have:
#declare my_texture =
  finish{
     reflection{
      0.3, 1
      fresnel
    metallic
   specular 1
   roughness 0.1
    look_at  <0, 0,  20>
difference{
  box{<-9.6, 0.4, 0.4>,<9.6, 19.6, 19.6>}//inside of the box
  box{<-9,1, 0>,<9, 10, 0.4>}// the opening
  texture{
   object{
    my_texture,
    pigment {rgbt 1}
 rotate y*20
 color White
I'm getting an error on the
texture{
   object{
    my_texture,
    pigment {rgbt 1}
code, saying that there is a missing }, but I don't see it.
Also, did I put the photons{target reflection on} in the right place, or do I
need to create an object that includes the box and the photons?
Rhonda
Date: 11 Dec 2012 16:18:30
Message: <50c7a326$1@news.povray.org>
> a few issues.
>   texture {
>    finish{
>       reflection{
>        0.3, 1
>        fresnel
>      metallic
>     specular 1
>     roughness 0.1
the metallic keyword belongs in the finish block ... not the reflection
block. The rest looked OK (quick glance)
Date: 11 Dec 2012 16:20:50
Message: <50c7a3b2@news.povray.org>
>> still have
>> a few issues.
>>   texture {
>>    finish{
>>       reflection{
>>        0.3, 1
>>        fresnel
>>      metallic
>>     specular 1
>>     roughness 0.1
LOL ... after reading further I see that that keyword /can/ indeed live
in the reflection block ... going back into my corner now.
Date: 11 Dec 2012 17:31:24
Message: <50c7b43c$1@news.povray.org>
Am 11.12.2012 22:20, schrieb James Holsenback:
Actually, if you use "metallic", you should put it in /both/ the finish
and reflection block: The one makes the highlights look metallic, the
other does the same for reflections.
Date: 11 Dec 2012 18:15:01
Message: <web.50c7be34cf1ff5fee6e840160@news.povray.org>
Thanks for the input. Any thoughts on why this isn't working:
texture{
   object{
    my_texture,
    pigment {rgbt 1}
where, this is declared above
#declare my_texture=
  finish{
     reflection{
      0.3, 1
      fresnel
    metallic
   specular 1
   roughness 0.1
Date: 11 Dec 2012 18:53:31
Message: <50c7c77b$1@news.povray.org>
> texture{
>     object{
>      my_texture,
>      pigment {rgbt 1}
>   texture {
>    finish{
>       reflection{
>        0.3, 1
>        fresnel
>      metallic
>     specular 1
>     roughness 0.1
check out:
http://wiki.povray.org/content/Reference:Object_Pattern
shown in the example
