POV-Ray : Newsgroups : povray.newusers : some special kind of glass (sorry, I don't know the english word for it...ground glass?); Server Time
6 May 2026 22:55:37 EDT (-0400)
  some special kind of glass (sorry, I don't know the english word for it...ground glass?); (Message 1 to 10 of 13)
Subject: some special kind of glass (sorry, I don't know the english word for it...ground glass?);
Date: 25 Apr 2000 15:28:51
Message: <3905f1f3$1@news.povray.org>
Hi, people.
I already posted this in povray.programming, but they told me to post it
here
I'd like to produce some kind of street lamp, but it has some special kind
of glass (somebody said 'ground glass', but I'm still not sure, if it's the
right name), I can't produce...
You should not be able to look through it, it should have a white color, and
it should let the light through. And if there's light on the other side of
the glass shining in the camera's direction, it should be visible on the
glass....
(This glass is used in these detective-films, for example; maybe you know
these office-doors with the white glass and the black text on it....)
Please help me
Thanks in advance
Wolfgang
Subject: Re: some special kind of glass (sorry, I don't know the english word for it...ground glass?);
Date: 25 Apr 2000 15:50:16
Message: <slrn8gbucl.4u6.ron.parker@linux.parkerr.fwi.com>
'round here, we call that frosted glass.  It's not that easy to get right
in POV, but you can fake it with either media (tricky, and prone to failure)
or a very small normal pattern with heavy nonadaptive antialiasing.  Your
render times will go through the roof, though.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
These are my opinions.  I do NOT speak for the POV-Team.
Date: 25 Apr 2000 19:28:53
Message: <39062a35@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] linuxparkerrfwicom...
Using a low enough filter value along with a little transmit can do okay along with
the normal (I almost always use granite for that) so long as the pigment color is
white
enough.  Can even go over rgb 1 as in rgbft <1.5,1.5,1.5,0.25,0.125> for example.
Then of course for the normal to do it's stuff you need a ior and specular highlight.
You'll certainly find that things will change dramatically when the camera and/or
light are moved. So it can often be a case of adjusting for one viewpoint.
Date: 25 Apr 2000 19:42:56
Message: <chrishuff_99-16FADB.18455525042000@news.povray.org>
In article <39062a35@news.povray.org>, "Bob Hughes"
> okay along with the normal (I almost always use granite for that) so
> long as the pigment color is white enough.  Can even go over rgb 1 as
> in rgbft <1.5,1.5,1.5,0.25,0.125> for example. Then of course for the
> normal to do it's stuff you need a ior and specular highlight. You'll
> and/or light are moved. So it can often be a case of adjusting for
> one viewpoint.
I did this a while ago, I posted some images to povray.binaries.images.
While I used a blurred transparency patch, the same thing could be done
with finely scaled normals.
I used a white pigment with about half transparency, ambient 0, some
reflection, and a diffuse value which added up with reflection to equal
1.(I usually try to design my textures so diffuse+ambient+reflection <=
1) I also added double_illuminate, so the glass is lit on both sides.(of
course, the last one requires MegaPOV)
Media should also work, I don't see why it would be "prone to failure".
It could be hard to adjust though...and probably slower than any other
option(unless you use MegaPOV and media method 2 or 3).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 25 Apr 2000 19:50:55
Message: <39062EF7.1EFF9133@pacbell.net>
Using media densities is really not that slow in the official version.
It's when you use scattering media that things slow way down.
Date: 25 Apr 2000 20:13:08
Message: <chrishuff_99-952867.19160725042000@news.povray.org>
In article <39062EF7.1EFF9133@pacbell.net>, lin### [at] povrayorg
You would have to use scattering media to get ground or frosted glass to
work right. Emitting media might fake it under some special conditions,
but it would be limited, and I think absorbing media would be useless
for this.
Date: 25 Apr 2000 21:59:10
Message: <39063FAD.E35A80DC@peak.edu.ee>
You can get the effect with scattering media in the lamp shade. It does require
a bit of tweaking, though. The render time will be somewhat high if you desire
smooth results. Alternatively you might want to try using MegaPOV, which has a
different method for rendering media. It will give smooth results at lower
settings and thus render faster.
I'll post an example scene to povray.binaries.scene-files; perhaps you can use
it as a basis.
Margus Ramst
Date: 26 Apr 2000 08:07:03
Message: <3906dbe7@news.povray.org>
erm... and what does this mean? Could you show me some scene-code?
Ron Parker <ron### [at] povrayorg> schrieb in im Newsbeitrag:
kind
the
failure)
Date: 26 Apr 2000 08:43:26
Message: <3906e46e@news.povray.org>
Chris Huff <chr### [at] yahoocom> schrieb in im Newsbeitrag:
chrishuff_99-16FADB.18455525042000@news.povray.org...
I'm sorry, I can't find this, because my newsreader-program crashes after
about 3000 messages ;)
Date: 26 Apr 2000 11:46:18
Message: <39070f4a@news.povray.org>
Something like this perhaps might do okay.
box {-1,1 scale <4,3,.1>
  pigment { rgbft <1.5,1.5,1.5,.25,.125>}
   normal {granite .15 scale .005}
    finish {ambient .05 diffuse .5 specular .8 roughness .01 reflection .15}
  scale 2 // scale texture to suit object/scene size
  interior {ior 1.5 caustics 1}
sphere {<0,0,1.5>,1 pigment {color red 1}}
light_source { <-.5,1.25,-1.5> color rgb <1,.95,.9>
  location  <1,.75,-2>
  angle 65
  look_at   <0, 0, 0>
"Wolfgang Illmeyer" <wol### [at] gmxnet> wrote in message
news:3906dbe7@news.povray.org...
| kind
| the
| failure)
