![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ontrack Systemsweep 2000 has a very good crash prevention program. We use
Norton up at school, but for some reason, the CrashGuard seems to cause
crashes. Usually, upon starting Netscape with CrashGuard on, it crashes,
but when CG is off, it doesn't crash. Weird.
Go Ontrack!
This message brought to you by:
-=< Ian (the### [at] hotmail com >=-
Please visit my site at http://spectere2000.cjb.net! :)
Chris Huff <chr### [at] yahoo com> wrote in message
news:chrishuff_99-DF11BF.17072226121999@news.povray.org...
> In article <38667B19.7425D2FD@cybercable.fr>, Charles & Paula
> <pcd### [at] cybercable fr> wrote:
> > I have just started to use megapov from Nathan Kopp.
> > It works once well. After that povray stops totally the computer even
> > allowing Norton anti-crach program to intercept the problem.
> You mean Norton CrashGuard? I don't know about the Windows version, but
> the Mac version had a reputation for causing more trouble than it
> prevented. Of course, the two operating systems are so different that it
> is probably impossible to judge one by the other.
> Chris Huff
> e-mail: chr### [at] yahoo com
> Web page: http://chrishuff.dhs.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try ScanDisk as well.
omniVERSE <inv### [at] aol com> wrote in message
news:3868643c@news.povray.org...
> Not sure I would have edited the Windows registry like you did since
nothing
> should have changed there upon using MegaPOV anyway. It doesn't install,
> just uses the POV-Ray setup already there. Could be something else
> entirely, like Windows itself going bad somehow but maybe it's video
> related. Did you try reducing Hardware Acceleration in System Properties
> (Performance tab/Graphics button...)?
> Wish I knew the answer.
> Bob
> "Charles & Paula" <pcd### [at] cybercable fr> wrote in message
> news:3867BE25.D70F810C@cybercable.fr...
> > You all of you advise me to reinstall povray without Norton CrashGuard.
> > That's what I did (I restart the computer without NCG).
> > I didn't change what is happening:
> > 4 seconds after clicking on povray icon to start it the computer stops
> > without a blue screen, simply stops. I have to reset the computer.
> > Thanks to give me tips.
> > Charles
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As I have explained PovRAY is working well the first time after installation.
Then after some time it stops windows. It doesn't seem to be linked to video.
This happens just after the first time I use Megapov
Charles
omniVERSE wrote:
> Not sure I would have edited the Windows registry like you did since nothing
> Bob
> > Charles
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Charles & Paula <pcd### [at] cybercable fr> wrote ...
installation.
video.
If you don't ever run MegaPov, will POV-Ray crash?
-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes
POVRAY alone (without megapov) is crashing (It works well one time after
povray installation and then for each use, it is crashing).
I have done all what people said but unfortunaltly no change in the system
crash.
-disabled Norton CrashGuard
Charles
> installation.
> video.
> -Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sadly it sounds asthough your only option is to
reinstall windows.
I heard of someone having this problem a while ago
and his solution was a windows reinstall, after trying
many other things, (think it was Bill Dewit).
Good luck.
On Thu, 30 Dec 1999 21:04:04 +0100, Charles & Paula
>Yes
>crash.
>Charles
>> installation.
>> video.
>> -Nathan
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
10:38pm up 5 days, 10:57, 7 users, load average: 1.06, 1.09, 1.04
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello there,
I just started using povray and was playing with some simple scenes and the quality
settings. And I was wondering, is there a way to put the quality setting in the pov
file and not on the command line.
Thanks in advance
koos
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
koos wrote:
> Hello there,
> Thanks in advance
> koos
I have never tried this but you might want to check out the docs on the
use of .ini file options. I am pretty sure that you can specify quality
settings in a .ini file for your scene so you do not have to specify them
on the command line each time you run the program. This of course would
be a POV-Ray for Windows only solution. If you are using a different
platform I am not sure what the proceedures would be.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
koos <koo### [at] ibb1102 ibb uu nl> wrote:
: I just started using povray and was playing with some simple scenes and the quality
Not in the official povray, but it's possible with megapov.
http://nathan.kopp.com/patched.htm
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Ken" <tyl### [at] pacbell net> wrote in message
news:388429C6.6B931D11@pacbell.net...
quality settings. And I was wondering, is there a way to put the quality setting
in the pov file and not on the command line.
The Ini files can also be called upon at a command line, in DOS for instance,
basic idea is that a non-pov or non-inc file is read for input (I'm going by
memory here). However for doing so within the scene file (*.pov) you need to
use MegaPOV patch like Nieminen J. has suggested. Then you simply place a
ini_option "Quality=9" , for example, into 'global_settings'.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
