Yes
POVRAY alone (without megapov) is crashing (It works well one time after
povray installation and then for each use, it is crashing).
I have done all what people said but unfortunaltly no change in the system
crash.
-disabled Norton CrashGuard
Charles
Nathan Kopp wrote:
> Charles & Paula <pcd### [at] cybercablefr> wrote ...
> > As I have explained PovRAY is working well the first time after
> installation.
> > Then after some time it stops windows. It doesn't seem to be linked to
> video.
> > This happens just after the first time I use Megapov
> If you don't ever run MegaPov, will POV-Ray crash?
> -Nathan
Sadly it sounds asthough your only option is to
reinstall windows.
I heard of someone having this problem a while ago
and his solution was a windows reinstall, after trying
many other things, (think it was Bill Dewit).
Good luck.
On Thu, 30 Dec 1999 21:04:04 +0100, Charles & Paula
<pcd### [at] cybercablefr> wrote:
>Yes
>crash.
>Charles
>> installation.
>> video.
>> -Nathan
Steve email mailto:sjl### [at] ndirectcouk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
10:38pm up 5 days, 10:57, 7 users, load average: 1.06, 1.09, 1.04
Hello there,
I just started using povray and was playing with some simple scenes and the quality
settings. And I was wondering, is there a way to put the quality setting in the pov
file and not on the command line.
Thanks in advance
koos
koos wrote:
> Hello there,
> Thanks in advance
> koos
I have never tried this but you might want to check out the docs on the
use of .ini file options. I am pretty sure that you can specify quality
settings in a .ini file for your scene so you do not have to specify them
on the command line each time you run the program. This of course would
be a POV-Ray for Windows only solution. If you are using a different
platform I am not sure what the proceedures would be.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
koos <koo### [at] ibb1102ibbuunl> wrote:
: I just started using povray and was playing with some simple scenes and the quality
Not in the official povray, but it's possible with megapov.
http://nathan.kopp.com/patched.htm
"Ken" <tyl### [at] pacbellnet> wrote in message
news:388429C6.6B931D11@pacbell.net...
quality settings. And I was wondering, is there a way to put the quality setting
in the pov file and not on the command line.
The Ini files can also be called upon at a command line, in DOS for instance,
basic idea is that a non-pov or non-inc file is read for input (I'm going by
memory here). However for doing so within the scene file (*.pov) you need to
use MegaPOV patch like Nieminen J. has suggested. Then you simply place a
ini_option "Quality=9" , for example, into 'global_settings'.
