POV-Ray : Newsgroups : povray.newusers : Help with CGS Server Time
14 Mar 2026 01:51:20 EDT (-0400)
  Help with CGS (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Help with CGS
Date: 16 Apr 1999 04:14:18
Message: <3716E1F0.706FC63A@pacbell.net>
Kevork Abadjian wrote:
> I was looking at the two replies posted to my message and as far as I can see
> Ken explained the situation even better than I could; but he stopped just short
> of a suggestion to fix the problem.
> there is nothing special about the source, I am using the std seen file and
> just and std texture for glass and a switch to toggle on an off the photones.
  Your misunderstanding about how the merge function is supposed to behave
is not to do with the results you are witnessing from the example you are
using but instead of the way you are using a CSG operation inside of a
while loop. The correct way to implement a merge using a csg is like the
example below. It is your while loop rearranged to operate correctly.
When using a CSG within a while loop you must move the merge statement
outside the while statement or it is not acted upon correctly. Don't
ask me why this is so but I found after many hair pulling sessions and
then finaly by asking in these groups how to solve my problem. So without
further ado...
// This should now act correctly for a merge csg operation:
 #declare cnt=0
        merge {
 #while (cnt < 5)
        object {ball
                translate <cnt/2.5,0,0>
        #declare cnt=cnt+1
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Apr 1999 04:29:36
Message: <3716E849.3493316D@tiac.net>
Well, now I'm a bit confused too...
what am I doing wrong?
MERGE from the docs:
"The union operation just glues objects together, it does not remove the
objects' surfaces inside the union. Under most circumstances this
doesn't matter. However if a transparent union is used, those interior
surfaces will be visible. The merge operations can be used to avoid this
problem. It works just like union but it eliminates the inner
surfaces..."<snip>
I changed the code a little. I dropped the texture to use a pigment that
changes
color from sphere to sphere with a .7 transmit in order to show that
merge did
NOT as the docs say "eliminates the inner surfaces".
Heres my change:
#declare cnt=0;
#while (cnt < 5)
     merge {
          sphere{<-.7,-0.3,0>, 0.4
          pigment{rgbt<cnt*0.05,cnt/4.5,0.5,0.7>}//texture {T_Glass3}
          //interior{ior 1.5}
          #if (phon)
               photons{
                   density 0.01*phd
                   reflection on
                   refraction on
          //rotate y*50        //I was checking to see if it was just an
effect of a bad angle
#declare cnt=cnt+1
I'll post my render of this in povray.images under "Help with CGS"
Date: 16 Apr 1999 04:32:59
Message: <3716E652.446B9B61@pacbell.net>
> surfaces..."<snip>
> changes
> merge did
Your code suffers the same as his in that the merge needs to be specified
outside the while loop before it will be acted upon.
Ken Tyler
Date: 16 Apr 1999 04:36:24
Message: <3716E9E1.2979744@tiac.net>
Aha! that fixed it!
Date: 16 Apr 1999 04:40:24
Message: <3716EA1D.7F0D75F1@zess.uni-siegen.de>
What do you expect? If you have the "merge" _inside_ the #while
loop, POV creates a "merge"-object fo each pass through the
loop. That's the way things work. No need to ask "why?"
Markus
Date: 16 Apr 1999 05:07:48
Message: <3716EE77.2B49791E@pacbell.net>
> Markus
Not altogether a programmer type and struggling to use what I can of these
functions I expect no more or no less than what I can figure out myself
of from what I can learn from the generous guidance of others. What is
intuitively obvious to you is sometimes heap big juju magic to me.
Ken Tyler
Date: 16 Apr 1999 06:09:21
Message: <3716FCE7.6C3C00D4@pacbell.net>
Stripped down and rearranged for clarity and examples sake I offer the
following two examples of correct and incorrect behavior. Which is which
I leave to the person who renders it to decide but it should be as obvious
as obvious can be.
  camera{
  location  <0.0, 0, -5.0>
  look_at   <0.0, 0.0,  0.0>}
  light_source{<0,440,-300>rgb 1 }
 plane { y,-3 pigment{ rgb 1}}
 plane { z, 3 pigment{ rgb 1}}
 #declare Ball1 =
 sphere{0,0.4
  pigment{rgbf<1,1,1,0.97>}
   translate<-0.4,-0.2,0>
    interior {ior 1.99}
 #declare Ball2 =
 sphere{0,0.4
  pigment{rgbf<0,0,1,0.97>}
   translate<-0.4, 0.2,0>
    interior {ior 1.19}
#declare cnt=0
       merge {
#while (cnt < 4)
       object {Ball1 rotate z*90*cnt}
       object {Ball2 rotate z*90*cnt}
       #declare cnt=cnt+1
 translate x*1.25
#declare cnt=0
#while (cnt < 4)
     merge {
 translate x*-1.35 }
       #declare cnt=cnt+1
Ken Tyler
Date: 16 Apr 1999 08:21:54
Message: <37171E09.16D8FD7C@zess.uni-siegen.de>
That might be, myself being the programmer-type this has always been
obvious to me. Let me try to give you (or the original poster) a more
detailed explanation:
Case 1, "merge" _inside_ #while:
    #declare n = 0;
+-->  #while (n<10)
|       merge			// a new object is created
|          object {....}
|       }				// merge object is finished
|     #declare n = n+1;
+-- #end			// loop again and create a new object
Note that each time POV loops through the #while, it parses a
complete merge-object.
Case 2, "merge" _outside_ #while:
    #declare n = 0;
+-->  #while (n<10)
|        object {....}
|     #declare n = n+1;
Note here how the loop only adds new objects to the merge object.
Hope this makes it a little bit more clearer. Even if you're not at
all the programming type [tm], you should get one concept into
your head (no offense meant, it's just the lack of better english):
POV parses the file line by line and the #while only tells it
to parse some lines more often. It is just redirected to a new
position in the file.
The first case would "unroll" (common practice for the programmer
type ;-) to the following:
merge {object {...}}
merge{ object {...}}
anbd the second case unrolls to:
merge
  object {...}
  object {...}
  object {...}
  object {...}
This should make it clearer.
Markus
 Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
Date: 16 Apr 1999 10:34:06
Message: <37173c4e.0@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: Don't
: ask me why this is so but I found after many hair pulling sessions and
: then finaly by asking in these groups how to solve my problem.
  Markus explained it well. You can also think about it this way:
#declare i=0;
#while(i<4)  // Make 4 copies of this:
                 merge { sphere { ... } }
 #declare i=i+1;
  After parsing the result is:
  On the other hand:
merge {
#declare i=0;
                 sphere { ... }
 #declare i=i+1;
merge {
                 sphere { ... }
                 sphere { ... }
                 sphere { ... }
                 sphere { ... }
  Sometimes the first behaviour is the wanted behaviour. For example:
union {
#declare i=0;
                 merge { sphere { ... } sphere { ... } }
 #declare i=i+1;
  The result:
union {
Date: 17 Apr 1999 03:05:55
Message: <3718265D.1DADA59B@conted.lan.mcgill.ca>
Thanks to everyone for hempling me;  specially to Ken for the smaple code.  It solved
the problem.
>  #declare cnt=0
>         merge {
>  #while (cnt < 5)
>         object {ball
>         #declare cnt=cnt+1
>  #end
